224400244610
224400244610
    FINDER
    FINDER - 224400244610 - Contactor, 22 A, DIN Rail, Panel, 440 VAC, DPST-NO, DPST-NC, 4 Pole
224400244610 数据手册
Modular contactors 25 - 40 - 63 A Hotel room energy-enabling units Garden and night lighting Streetlights and car park lighting Bathrooms lighting control Office lighting control Pump control 22 SЕRIES FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 22 SERIES Modular contactors 25 - 40 - 63 A 22 SERIES 22.32.0.xxx.1xx0 25 A modular contactor - 2 pole • 17.5 mm wide • NO contact gap ≥ 3 mm, double break • Continuous duty for the coil and contacts • AC/DC silent coil (with varistor protection) • Protective separation (reinforced insulation) 22.32.0.xxx.4xx0 between coil and contacts • Mechanical and LED indicators as standard • Auto-On-Off selector version available • AgNi and AgSnO2 contact versions available • Compliant with EN 61095: 2009 • Auxiliary contact module available, quick-assembly with the main contactor (1 NO + 1 NC and 2 NO versions) • For railway applications; materials compliant with fire and smoke characteristics (EN 45545-2 + A1: 2016) • 35 mm rail (EN 60715) mount • AgNi contacts, specifically • AgSnO2 contacts, specifically intended for resistive and slightly inductive loads as well as for motor loads intended for lamp loads and for high inrush current loads 2 NO (x3x0) 2 NC (x4x0) 22.32…1xx0/22.32…4xx0 Screw terminal 1 NO + 1 NC (x5x0) For outline drawings see page 10 Contact specification Contact configuration 2 NO, 3 mm* (or 1 NO + 1 NC or 2 NC) Rated current/Maximum peak current Rated voltage A V AC 25/80 25/120 250/440 250/440 VA 6250 6250 A 10 10 Rated load AC15 (per pole @ 230 V) VA 1800 1800 Single-phase motor rating (230 V AC) Rated load AC1 / AC-7a (per pole @ 250 V)  Rated current AC3 / AC-7b kW 1 1 Rated load AC5a (per pole @ 250 V) A 15 15 Rated current AC-7c A — 10 230 V incandescent/halogen W fluorescent tubes with electronic ballast W fluorescent tubes with electromechanical ballast W CFL W 800 2000 300 800 200 100 500 200 100 200 100 200 300 25/5/1 800 25/5/1 1000 (10/10) 1000 (10/10) AgNi AgSnO2 12 - 24 - 48 - 60 - 120 - 230 12 - 24 - 48 - 60 - 120 - 230 • Contact gap ≥ 3 mm for NO contacts only; NC contacts ≥ 1.5 mm Nominal lamp rating: 230 V LED W LV halogen or LED with electronic ballast W LV halogen or LED with electromechanical ballast W Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Contact material Coil specification Nominal voltage (UN) V DC/AC (50/60 Hz) Rated power AC/DC VA (50 Hz)/W 2/2.2 2/2.2 Operating range DC/AC (50/60 Hz) (0.8…1.1)UN (0.8…1.1)UN Holding voltage DC/AC (50/60 Hz) 0.4 UN 0.4 UN Must drop-out voltage DC/AC (50/60 Hz) 0.1 UN 0.1 UN L I-2019, www.findernet.com Technical data Mechanical life AC/DC cycles 2 · 106 2 · 106 Electrical life at rated load AC-7a cycles 70 · 103 30 · 103 ms 30/20 30/20 kV °C 6 –20…+50 6 –20…+50 IP 20 IP 20 Operate/release time  Insulation between coil and contacts (1.2/50 µs) Ambient temperature range Protection category Approvals (according to type) 3 22 SERIES 22 SERIES Modular contactors 25 - 40 - 63 A 22.34.0.xxx.1xx0 25 A modular contactor - 4 pole • 35 mm wide • NO contact gap ≥ 3 mm, double break • Continuous duty for the coil and contacts • AC/DC silent coil (with varistor protection) • Protective separation (reinforced insulation) 22.34.0.xxx.4xx0 between coil and contacts • Mechanical and LED indicators as standard • Auto-On-Off selector version available • AgNi and AgSnO2 contact versions available • Compliant with EN 61095: 2009 • Auxiliary contact module available, quick-assembly with the main contactor (1 NO + 1 NC and 2 NO versions) • For railway applications; materials compliant with fire and smoke characteristics (EN 45545-2 + A1: 2016) • 35 mm rail (EN 60715) mount • AgNi contacts, specifically intended for resistive and slightly inductive loads as well as for motor loads • AgSnO2 contacts, specifically intended for lamp loads and for high inrush current loads 22.34…1xx0/22.34…4xx0 Screw terminal 4 NO (x3x0) For outline drawings see page 10 Contact specification Contact configuration 3 NO + 1 NC (x7x0) 2 NO + 2 NC (x6x0) 4 NO, 3 mm* (or 3NO + 1NC or 2NO + 2NC) Rated current/Maximum peak current Rated voltage A V AC 25/80 25/120 250/440 250/440 VA 6250 6250 A 10 10 Rated load AC15 (per pole @ 230 V) VA 1800 1800 Three-phase motor rating (400 - 440 V AC) kW 4 4 Rated load AC5a (per pole @ 250 V) A 15 15 Rated current AC-7c A — 10 230 V incandescent/halogen W fluorescent tubes with electronic ballast W fluorescent tubes with electromechanical ballast W CFL W 800 2000 300 800 200 100 500 200 100 200 100 200 300 25/5/1 800 25/5/1 1000 (10/10) 1000 (10/10) AgNi AgSnO2 12 - 24 - 48 - 60 - 120 - 230 12 - 24 - 48 - 60 - 120 - 230 Rated load AC1/AC-7a (per pole @ 250 V)  Rated current AC3/AC-7b * Contact gap ≥ 3 mm for NO contacts only; NC contacts ≥ 1.5 mm Nominal lamp rating: 230 V LED W LV halogen or LED with electronic ballast W LV halogen or LED with electromechanical ballast W Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Contact material Coil specification Nominal voltage (UN) V DC/AC (50/60 Hz) Rated power AC/DC 2/2.2 DC/AC (50/60 Hz) VA (50 Hz)/W (0.8…1.1)UN (0.8…1.1)UN Holding voltage DC/AC (50/60 Hz) 0.4  UN 0.4 UN Must drop-out voltage DC/AC (50/60 Hz) 0.1 UN 0.1 UN Mechanical life AC/DC cycles 2 · 106 Electrical life at rated load AC-7a cycles 150 · 10 30 · 103 ms 18/40 18/40 kV °C 6 –20…+50 6 –20…+50 IP 20 IP 20 Technical data Operate/release time  Insulation between coil and contacts (1.2/50 µs) Ambient temperature range Protection category Approvals (according to type) 4 2 · 106 3 I-2019, www.findernet.com L 2/2.2 Operating range 22 SERIES Modular contactors 25 - 40 - 63 A 22 SERIES 22.44.0.xxx.4xx0 40 - 63 A modular contactor - 4 pole 22.64.0.xxx.4xx0 • NO and NC contact gap ≥ 3 mm, double break • Continuous duty for the coil and contacts • AC/DC silent coil (with varistor protection) • Protective separation (reinforced insulation) between coil and contacts • Mechanical indicator as standard • AgSnO2 contacts • Compliant with EN 61095: 2009 and with EN 60947-4-1: 2009 • 35 mm rail (EN 60715) mount 22.44…/22.64… Screw terminal • For high inrush current loads • Specifically intended: 176 A • Contact material AgSnO2 for high inrush current loads 240 A • Contact material AgSnO2 4 NO (4310) For outline drawings see page 10 3 NO + 1 NC (4710) 2 NO + 2 NC (4610) Contact specification Contact configuration 4 NO, (or 3NO + 1NC or 2NO + 2NC) ≥ 3 mm Rated current/Maximum peak current Rated voltage Rated load AC1 / AC-7a (per pole @ 400 V)  Rated current AC3 / AC-7b (400 V) A 40/176 63/240 V AC 400/440 400/440 VA 16000 24000 A 22 30 Rated load AC15 (per pole @ 230 V) VA — — Three-phase motor rating (400 - 440 V AC) kW 11 15 Rated load AC5a (per pole @ 250 V) A 20 32 Rated current AC-7c A — — 4000 5000 1500 2000 Nominal lamp rating: 230 V incandescent/halogen W fluorescent tubes with electronic ballast W fluorescent tubes with electromechanical ballast W 1500 2000 CFL W 1000 1500 230 V LED W 1000 1500 1000 1500 LV halogen or LED with electronic ballast W LV halogen or LED with electromechanical ballast W Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Contact material 1500 2000 40/4/1.2 63/4/1.2 1000 (17/50) 1000 (17/50) AgSnO2 AgSnO2 Coil specification Nominal voltage (UN) V DC/AC (50/60 Hz) Rated power AC/DC VA (50 Hz)/W 12 - 24 - 110…120 (110 V DC) - 230…240 (220 V DC) 5 5 Operating range DC/AC (50/60 Hz) (0.85…1.1)UN (0.85…1.1)UN Holding voltage DC/AC (50/60 Hz) 0.85 UN 0.85 UN Must drop-out voltage DC/AC (50/60 Hz) 0.2 UN 0.2 UN L I-2019, www.findernet.com Technical data Mechanical life AC/DC cycles 3 · 106 3 · 106 Electrical life at rated load AC-7a cycles 100 · 103 100 · 103 20/45 20/45 Operate/release time  ms Insulation between coil and contacts (1.2/50 µs) kV 6 6 Ambient temperature range °C –15…+55 (–25...+55)* –15…+55 (–25...+55)*C IP 20 IP 20 Protection category * 4 NO version only Approvals (according to type) 5 22 SERIES 22 SERIES Modular contactors 25 - 40 - 63 A Ordering information Exemple: 22 series, modular contactor 25 A, 4 NO contacts, coil 230 V AC/DC, AgSnO2 contacts, Auto-On-Off selector + mechanical indicator + LED. 2 2 . 3 A B C D 4 . 0 . 2 3 0 . 4 3 4 0 D: Special versions 0 = Standard C: Options 1 = Mechanical indicator 2 = Mechanical indicator + LED 4 = Auto-On-Off selector + mechanical indicator + LED B: Contact circuit 3 = All NO contacts 4 = All NC contacts (22.32 only) 5 = 1 NO + 1 NC 6 = 2 NO + 2 NC 7 = 3 NO + 1 NC A: Contact material 1 = AgNi 4 = AgSnO2 Series Type 3 = 25 A modular contactor range 4 = 40 A modular contactor range 6 = 63 A modular contactor range Number of contacts 2 = 2 pole 4 = 4 pole Coil version 0 = AC (50/60 Hz)/DC Coil rated voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type 22.32 22.34 22.44 22.64 Coil version AC/DC AC/DC AC/DC AC/DC A 1-4 1-4 4 4 B 3-4-5 3-6-7 3-6-7 3-6-7 C 2-4 2-4 1 1 D 0 0 0 0 Options Auto-On-Off selector + mechanical indicator + LED (xx40 option) Type 22.32 / 22.34 Options 1 1 Selector The three-position manual selector has the following functions: • ON position - the contacts are latched in the operated state (NO contacts - closed and NC contacts - open), the mechanical indicator is visible in its window, the LED is not illuminated. • AUTO position - the state of contacts, mechanical 3 indicator and LED follow the coil supply voltage. 2 • OFF position - even if terminals A1 - A2 are supplied with rated voltage, the coil is not energized, and so the contacts remain in the non-operated state, the mechanical indicator is not visible and the LED is not illuminated. Type 22.44 / 22.64 2 LED 3 Mechanical indicator Options Mechanical indicator L I-2019, www.findernet.com 1 6 22 SERIES Modular contactors 25 - 40 - 63 A 22 SERIES Technical data Insulation 22.32/22.34 Rated insulation voltage  V AC 250 Pollution degree 3* 22.44/22.64 440 440 2 3 Insulation between coil and contact set Type of insulation Reinforced Reinforced III III kV (1.2/50 µs) 6 4 Overvoltage category Rated impulse voltage Dielectric strength V AC 4000 2000 Type of insulation Basic Basic Overvoltage category III III kV (1.2/50 µs) 4 4 Insulation between adjacent contacts Rated impulse voltage Dielectric strength V AC 2500 Insulation between open contacts 2000 NO contact Contact gap mm 3 Overvoltage category III Rated impulse voltage kV (1.2/50 µs) 4 Dielectric strength V AC/kV (1.2/50 µs) 2500/4 NC contact NO/NC contacts 1.5 3 II III 2.5 4 2000/3 2000/3 * Only for versions without Auto-On-Off selector. For versions with Auto-On-Off selector pollution degree 2 applies. Insulation between coil terminals Rated impulse voltage (surge) differential mode (according to EN 61000-4-5) kV(1.2/50 µs) 4  Short circuit protection 2 22.32 / 22.34 Rated conditional short circuit current kA 3 Back-up fuse A 32 (gL/gG type) Terminals 22.44 22.64 3 3 63 80 Solid and stranded cable 22.32 / 22.34 Max. wire size – contact terminals Max. wire size – coil terminals Min. wire size – contact and coil terminals 22.44 / 22.64 mm2 1 x 6 / 2 x 4 1 x 25 (solid) - 1 x 16 (stranded) AWG 1 x 10 / 2 x 12 1 x 4 (solid) - 1 x 6 (stranded) mm2 1 x 4 / 2 x 2.5 1 x 2.5 AWG 1 x 12 / 2 x 14 1 x 14 mm2 1 x 0.2 1 x 1 (coil) - 1 x 1.5 (contacts) AWG 1 x 24 Screw torque Wire strip length  Other data 1 x 18 (coil) - 1 x 16 (contacts) Nm 0.8 1.2 (coil terminals) 3.5 (contact terminals) mm 9 10 22.34 22.44 22.64 Vibration resistance (10…150)Hz g 4 4 3 3 Shock resistance g 10 10 15 15 Power lost to the environment 22.32 without contact current W 2 2 5 5 with rated current 6.3 17 37 W 4.8 NOTE 22.32/22.34: It is suggested an air gap of 9 mm between adjacent relays for installations and working conditions close to the limit (that is, ambient temperature > 40 °C, coil operated for a prolonged period of time, all contacts loaded with current > 20 A). L I-2019, www.findernet.com 22.44/22.64: The maximum ambient temperature with 3 adjacent contactors is + 40 °C; when more than 3 contactors are installed, it is necessary an air gap of 9 mm. With 2 adjacent contactors the maximum ambient temperature is + 55 °C; when more than 2 contactors are installed, it is necessary an air gap of 9 mm. 7 22 SERIES Modular contactors 25 - 40 - 63 A 22 SERIES Contact specification Ratings and utilization categories according to EN 61095: 2009 Type AC-7a Rated current Rated electrical (A) life (Cycles) 70 · 103 (NO) 25 30 · 103 (NC) 25 30 · 103 150 · 103 (NO) 25 100 · 103 (NC) 25 30 · 103 40 100 · 103 63 100 · 103 22.32….1xx0 (AgNi contacts) 22.32….4xx0 (AgSnO2 contacts) 22.34….1xx0 (AgNi contacts) 22.34….4xx0 (AgSnO2 contacts) 22.44….4xx0 22.64….4xx0 Utilization category AC-7b Rated current Rated electrical (A) life (Cycles) AC-7c Rated current Rated electrical (A) life (Cycles) 10 30 · 103 — — 10 30 · 103 10 30 · 103 10 30 · 103 — — 10 22 30 30 · 103 150 · 103 150 · 103 10 — — 30 · 103 — — Utilization category: AC-7a = Slightly inductive loads (cos ϕ = 0.8) AC-7b = Motor loads; (cos ϕ = 0.45, Imaking = 6x Ibreaking) AC-7c = Compensated electric discharge lamps (cos ϕ = 0.9, C = 10 mF/A) H 22 - Maximum DC1 breaking capacity - Type 22.44/22.64 DC breaking current (A) DC breaking current (A) H 22 - Maximum DC1 breaking capacity - Type 22.32/22.34 type 22.64 type 22.44 DC voltage (V) DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. Coil specifications AC/DC version data (type 22.34) AC/DC version data (type 22.32) (230…240 AC) (220 DC) Coil code 0.012 0.024 0.048 0.060 0.120 0.230 Operating range Umin V 9.6 19.2 38.4 48 88 184 (AC) 176 (DC) Umax V 13.2 26.4 52.8 66 138 264 (AC) 242 (DC) Rated coil consumption IN at UN (AC) mA 165 83 42 33 16.5 8.7 AC/DC version data (type 22.44 / 22.64) Nominal voltage UN V 12 24 120 L (110…125) 230 (230…240 AC) (220 DC) Coil code 0.012 0.024 0.120 102 0.230 196 (230…240 AC) (220 DC) Coil code 0.012 0.024 0.048 0.060 0.120 0.230 Operating range Umin V 9.6 19.2 38.4 48 88 Umax V 13.2 26.4 52.8 66 138 184 (AC) 176 (DC) 264 (AC) 242 (DC) Rated coil consumption IN at UN (AC) mA 165 83 42 33 16.5 Umax V 13.2 26.4 138 264 (AC) 242 (DC) Rated coil consumption IN at UN (AC) mA 417 208 41 21 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 8 8.7 R 22 - Coil operating range v ambient temperature Operating range Umin V 10.2 20.4 Nominal voltage UN V 12 24 48 60 120 (110…125) 230 I-2019, www.findernet.com Nominal voltage UN V 12 24 48 60 120 (110…125) 230 22 SERIES Modular contactors 25 - 40 - 63 A 22 SERIES Wiring diagrams Type 22.32 Line and neutral switched Line only switched Type 22.34 Type 22.34 Line and neutral switched Line only switched Type 22.44/22.64 Type 22.44/22.64 I-2019, www.findernet.com L 9 22 SERIES 22 SERIES Modular contactors 25 - 40 - 63 A Outline drawings Type 22.32 Screw terminal Types 22.32 + 022.33/022.35 Type 22.34 Screw terminal Types 22.34 + 022.33/022.35 Types 22.44/22.64 Types 22.44/22.64 + 022.63/022.65 Screw terminal Screw terminal Types 022.33/022.35 Screw terminal Types 022.63/022.65 Screw terminal Screw terminal Screw terminal I-2019, www.findernet.com L 10 22 SERIES Modular contactors 25 - 40 - 63 A 22 SERIES 022.33 Auxiliary modules 022.35 022.63 022.65 Mechanically linked contacts according to Annex L of EN 60947-5-1 33 34 Type of contactor Type 22.44022.63 Type 22.32 Type 22.34 Type 22.64 Contact specification Contact configuration 2 NO 1 NO + 1 NC 2 NO Conventional free air thermal current IthA 6 6 Rated power AC15 (230 V) VA 700 700 Electrical life at rated load cycles 30 · 103 Minimum switching load  mW (V/mA) 1000 (10/10) Contact material 1 NO + 1 NC 30 · 103 1000 (10/10) AgNi AgNi Short circuit protection Rated conditional short circuit current Back-up fuse Terminals Max. wire size Min. wire size Screw torque Wire strip length kA 1 1 A 6 (gL/gG type) 6 (gL/gG type) Solid and stranded cable Solid and stranded cable mm2 1 x 4 / 2 x 2.5 1 x 2.5 AWG 1 x 12 / 2 x 14 1 x 14 mm2 1 x 0.2 1 x 1 AWG 1 x 24 1 x 18 Nm 0.6 0.6 mm 9 9 Power lost to the environment without contact current W — — with rated current W 0.5 0.5 Approvals (according to type) I-2019, www.findernet.com NOTE: It is not possible to assembly the auxiliary module on 22.32.0.xxx.x4x0 (2 NC versions). 22.32 + 022.33/022.35 22.44 + 022.63/022.65 22.34 + 022.33/022.35 22.64 + 022.63/022.65 L 11 22 SERIES 22 SERIES Modular contactors 25 - 40 - 63 A Accessories Adaptor for panel mounting (for 22.32 type), plastic, 17.5 mm wide 020.01 Adaptor for panel mounting (for 22.34 type), plastic, 35 mm wide 011.01 Sheet of marker tags (CEMBRE Thermal transfer printers) for all relays (48 tags), 6 x 12 mm 060.48 Identification tag, plastic, 1 tag, 17x25.5 mm 019.01 Separator for rail mounting, plastic, 9 mm wide 022.09 8-way jumper link for type 22.32, 17.5 mm wide 022.18 (blue) Rated values 10 A - 250 V 6-way jumper link for type 22.34, 35 mm wide 022.26 (blue) Rated values 10 A - 250 V 020.01 011.01 060.48 019.01 PEAN P A N T E O O T EUR EUR 022.09 PEAN P A L PEAN N T E O O T EUR EUR 022.18 PEAN I-2019, www.findernet.com 022.26 12 Please see general technical information
224400244610 价格&库存
很抱歉,暂时无法提供与“224400244610”相匹配的价格&库存,您可以联系我们找货
