34.51.7.012.0010
34.51.7.012.0010
    FINDER
    插件
    特性:单电路输出切换选项:6 A、24 V DC;2 A、240 V AC。 静音、高速切换,电气寿命长。 超薄(5 mm)封装。 灵敏的直流输入电路(使用93系列插座可实现双交流/直流输入驱动)。 ...
34.51.7.012.0010 数据手册
34 SЕRIES Ultra-slim PCB Relays (EMR or SSR) 0.1 - 0.2 - 2 - 6 A Bottling plant Packaging machines Labelling machines Road / tunnel lighting Burners, boilers and furnaces Timers and lighting controls Electronic circuit boards Programmable controllers FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 34 SERIES Ultra-Slim electromechanical PCB relays 6 A 34 SERIES 34.51 Ultra-slim 1 Pole - 6 A relay 34.51-5010 Printed circuit mount - direct or via PCB socket 35 mm rail mount - via screw, screwless or push-in terminal sockets A • 1 Pole changeover contacts or 1 Pole normally open contact • Ultra slim (5 mm), package • Sensitive DC coil - 170 mW (Dual AC/DC coil • 5 mm wide • Low coil power • PCB or 93 series sockets • 5 mm wide • Low coil power • PCB or 93 series sockets • Contact AgNi + Au Copper side view Copper side view 1 CO (SPDT) 1 CO (SPDT) 6/10 6/10 drive possible using 93 series sockets) • UL Listing (certain relay/socket combinations) • Cadmium Free contact materials • 8/8 mm clearance/creepage distance • 6 kV (1.2/50 μs) insulation, coil-contacts For UL ratings see: “General technical information” page V For outline drawing see page 9 Contact specification Contact configuration Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage A 250/400 250/400 Rated load AC1 VA 1500 1500 Rated load AC15 (230 V AC) VA 300 300 Single phase motor rating (230 V AC) kW 0.185 0.185 Breaking capacity DC1: 30/110/220 V A 6/0.2/0.12 6/0.2/0.12 mW (V/mA) 500 (12/10) 50 (5/2) AgNi AgNi + Au — — 5 - 12 - 24 - 48 - 60 5 - 12 - 24 - 48 - 60 —/0.17 —/0.17 Minimum switching load V AC Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) Rated power AC/DC VA (50 Hz)/W V DC Operating range AC — — DC (0.7…1.5)UN (0.7…1.5)UN Holding voltage AC/DC —/0.4 UN —/0.4 UN Must drop-out voltage AC/DC —/0.05 UN —/0.05 UN Mechanical life AC/DC cycles —/10 · 106 —/10 · 106 Electrical life at rated load AC1 cycles 60 · 10 60 · 103 5/3 5/3 6 (8 mm) 6 (8 mm) Technical data XI-2018, www.findernet.com Operate/release time  ms Insulation between coil and contacts (1.2/50 µs)kV Dielectric strength between open contacts V AC Ambient temperature range Environmental protection °C 3 1000 1000 –40…+85 –40…+85 RT II RT II Approvals (according to type) 3 34 SERIES 34 SERIES Ultra-Slim solid state PCB relays (SSR) 0.1 - 6 A 34.81.7.xxx.9024 Ultra-slim Solid State Relays • Single circuit output switching options - 6 A, 24 V DC - 2 A, 240 V AC • Silent, high speed switching with long electrical life • Ultra slim (5 mm), package • Sensitive DC Input circuits (Dual AC/DC input drive possible using 93 series sockets) • UL Listing (certain relay/socket combinations) • Wash tight: RT III • 3000 V AC insulation, input-output • 6 A, 24 V DC output switching • 2 A, 240 V AC output • PCB or 93 series sockets switching • Zero crossing switching • PCB or 93 series sockets input output For outline drawing see page 9 input output Copper side view Copper side view 1 NO (SPST-NO) 1 NO (SPST-NO) Output circuit Contact configuration Rated current/ Maximum peak current (10 ms) A 6/50 2/80 Rated switching voltage V 24 DC 240 AC (50/60 Hz) Switching voltage range V (1.5…33)DC (12…275)AC Maximum blocking voltage V 33 — Vpk — 800 W 36 — 300 Repetitive peak off-state voltage Rated load DC13 Rated load AC15 VA — Minimum switching current mA 1 35 Max. “OFF-state” leakage current mA 0.001 1.5 0.4 1.6 Max. “ON-state” voltage drop V Supply specification Nominal voltage (UN)V DC Rated power Operating range W 5 12 24 60 5 12 24 60 0.035 0.085 0.17 0.21 0.06 0.085 0.17 0.21 V DC 3.5…12 8…17 16…30 35…72 3.5…10 8…17 16…30 35…72 Control current mA 7 7 7 3.5 12 7 7 3.5 Release voltage V DC 4 4 10 20 1 4 10 20 Technical data Electrical life at rated load Operate/release time cycles ms Insulation between input and output (1.2/50µs)kV Ambient temperature range Environmental protection °C > 106 > 106 0.02/0.2 11/11 4 4 –20…+70* –20…+50* RT III RT III Approvals (according to type) * Note: all technical data relates to using the relay directly on PCB or PCB socket type 93.11. If the relay is used with 35 mm rail socket type 93.51, refer to the technical data of 38 Series; if used with types 93.60, 93.61, 93.62, 93.63, 93.64, 93.65, 93.66, 93.67,93.68 and 93.69, refer to the technical data of the MasterINTERFACE 39 Series. See L34 diagrams page 8 4 XI-2018, www.findernet.com A 34.81.7.xxx.8240 Printed circuit mount - direct or via PCB socket 35 mm rail mount - via screw, screwless or push-in terminal sockets 34 SERIES Ultra-Slim solid state PCB relays (SSR) 0.1 - 6 A 34 SERIES 34.81.7.xxx.7048 Ultra-slim Solid State Relays 34.81.7.xxx.7220 Printed circuit mount - direct or via PCB socket 35 mm rail mount - via screw, screwless or push-in terminal sockets A • Single circuit output switching options - 0.1 A, 48 V DC - 0.2 A, 220 V DC • Silent, high speed switching with long electrical life • Ultra slim (5 mm), package • Sensitive DC Input circuits (Dual AC/DC input drive possible using 93 series sockets) • UL Listing (certain relay/socket combinations) • Wash tight: RT III • 3000 V AC insulation, input-output For outline drawing see page 9 • 100 mA, 48 V DC output • 200 mA, 110/220 V DC output switching • PCB or 93 series sockets • PCB or 93 series sockets input output input output switching Copper side view Copper side view 1 NO (SPST-NO) 1 NO (SPST-NO) Output circuit Contact configuration Rated current/ Maximum peak current (10 ms) A 0.1/0.5 0.2/10 Rated switching voltage V 48 DC 220 DC Switching voltage range V (1.5…53)DC (90…256)DC Maximum blocking voltage V 53 256 Rated load DC13 W 2.4 44 Minimum switching current mA 0.05 0.05 Max. “OFF-state” leakage current mA 0.001 0.001 1 0.4 Max. “ON-state” voltage drop V Supply specification Nominal voltage (UN)V DC Rated power W 24 60 24 60 0.17 0.21 0.17 0.21 Operating range V DC 16…30 35…72 16…30 35…72 Control current mA 7 3.5 7 3.5 Release voltage V DC 10 20 10 20 Technical data Electrical life at rated load Operate/release time cycles ms Insulation between input and output (1.2/50µs)kV Ambient temperature range Environmental protection °C > 106 > 106 0.03/0.6 0.4/2.2 4 4 –20…+70* –20…+70* RT III RT III XI-2018, www.findernet.com Approvals (according to type) * Note: all technical data relates to using the relay directly on PCB or PCB socket type 93.11. If the relay is used with 35 mm rail socket type 93.51, refer to the technical data of 38 Series; if used with types 93.60, 93.61, 93.62, 93.63, 93.64, 93.65, 93.66, 93.67,93.68 and 93.69, refer to the technical data of the MasterINTERFACE 39 Series. 5 34 SERIES 34 SERIES Ultra-Slim PCB relays Ordering information Electromechanical relay (EMR) Example: 34 series Ultra-Slim electromechanical relay, 1 CO (SPDT) 6 A contacts, 24 V sensitive DC coil. 3 4 . 5 A B C D 1 . 7 . 0 2 4 . 0 0 1 0 Series A: Contact material 0 = Standard AgNi 4 = AgSnO2 5=A  gNi + Au Type 5 = Electromechanical type No. of poles 1 = 1 pole, 6 A D: Special versions 0 = Flux proof (RT II) 9 = Flat version C: Options 1 = None B: Contact circuit 0=C  O (SPDT) 3=N  O (SPST) Coil version 7 = Sensitive DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version A B C D 34.51 sens. DC 0-4-5 0-3 1 0 34.51 sens. DC 0-4-5 0 1 9 Solid state relay (SSR) Example: 34 series solid state relay, 6 A 24 V DC output, 24 V DC supply. 3 4 . 8 Series Type 8 = SSR type 1 . 7 . 0 2 4 . 9 0 2 4 Output circuit 9024 = 6 A - 24 V DC 7048 = 0.1 A - 48 V DC 7220 = 0.2 A - 220 V DC 8240 = 2 A - 240 V AC Output 1 = 1 NO (SPST-NO) Input circuit See input specifications Flat pack version Copper side view Option = 34.51.7xxx.x019 Environmental protection RT I 6 XI-2018, www.findernet.com A 34 SERIES Ultra-Slim PCB relays 34 SERIES Electromechanical relay Technical data A Insulation according to EN 61810-1 Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 250 Pollution degree 400 3 2 Insulation between coil and contact set Type of insulation Reinforced Overvoltage category III Rated impulse voltage kV (1.2/50 μs) 6 Dielectric strength V AC 4000 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50 μs) 1000/1.5 Insulation between coil terminals Rated impulse voltage (surge) differential mode (according to EN 61000-4-5) kV(1.2/50 µs) 2 Other data Bounce time: NO/NC ms 1/6 Vibration resistance (5…55)Hz: NO/NC g 10/5 Shock resistance g 20/14 Power lost to the environment without contact current W 0.2 with rated current W 0.5 Recommended distance between relays mounted on PCB mm ≥ 5 Contact specification H 34 - Maximum DC1 breaking capacity DC breaking current (A) F 34 - Electrical life (AC) v contact current Cycles Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 60 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. Coil specifications DC coil data Nominal voltage R 34 - DC coil operating range v ambient temperature Coil code UN Umin V XI-2018, www.findernet.com 5 Operating range 7.005 Umax Resistance Rated coil consumption R I at UN V V Ω mA 3.5 7.5 130 38.4 12 7.012 8.4 18 840 14.2 24 7.024 16.8 36 3350 7.1 48 7.048 33.6 72 12300 3.9 60 7.060 42 90 19700 3 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 7 34 SERIES Ultra-Slim PCB relays 34 SERIES Solid state relay Technical data Insulation Between input and output EMC specifications Electrostatic discharge Dielectric strength 3000 V AC contact discharge air discharge Radiated electromagnetic field (80…1000 MHz) Fast transients on supply terminals (burst 5/50 ns, 5 and 100 kHz) common mode Voltage pulses on supply terminals (surge 1.2/50 μs) differential mode Radio-frequency common mode voltage (0.15…230 MHz) Other data Power lost to the environment without output current with rated current Reference standard EN 61000-4-2 EN 61000-4-2 EN 61000-4-3 4 kV 8 kV 10 V/m EN 61000-4-4 EN 61000-4-5 EN 61000-4-5 EN 61000-4-6 2 kV 0.7 kV 0.7 kV* 10 V Impulse (1.2/50 μs) 4 kV W 0.15 W 0.4 * For 34.81.7.005…= 0.3 kV ; for 34.81.7.012…= 0.5 kV Input specification Input data - DC types Nominal voltage Input code Operating range Release voltage Impedance Control current Ω mA I at UN UN Umin Umax V V V V 5 7.005 3.5 12* 1 715 7* 12 7.012 8 17 4 1715 7 24 7.024 16 30 10 3430 7 60 7.060 35 72 20 17000 3.5 * For 34.81.7.005.8240: UMAX = 10 V, I @ 5 V = 12 mA Output specification L 34-1 - Output DC current v ambient temperature 34.81.7…9024 L 34 - Output AC current v ambient temperature 34.81.7…8240 I: SSR installed on 93 series sockets as a group (without gap between sockets) II: SSR installed individually in free air , or with a gap ≥ 9 mm, which implies a not significant influence from nearby components Max recommended switching frequency (Cycles/Hour, with 50% Duty-cycle) at ambient temperature 50°C, single mounting Load 34.81.7xxx.9024 34.81.7xxx.8240 34.81.7xxx.7048 24 V 6 A DC1 180 000 — — 24 V 3 A DC L/R = 10 ms 5000 — — 24 V 2 A DC L/R = 40 ms 3600 — — 24 V 1 A DC L/R = 40 ms 6500 — — 24 V 0.8 A DC L/R = 40 ms 9000 — — 24 V 1.5 A DC L/R = 80 ms 3250 — — 230 V 2 A AC1 — 60 000 — 230 V 1.25 A AC15 — 3600 — 48 V 0.1 A DC1 — — 60 000 220 V 0.2 A DC1 — — — 8 34.81.7xxx.7220 — — — — — — — — — 60 000 XI-2018, www.findernet.com A 34 SERIES Ultra-Slim PCB relays 34 SERIES Outline drawings Type 34.51 Type 34.81 XI-2018, www.findernet.com A 9 34 SERIES 93 SERIES Sockets and accessories for 34 series relays A 93.61 Screw terminal socket 35 mm rail mounting (EN 60715) Common features - Space saving 6.2 mm wide - Connections for 16-way jumper link - Integral coil indication and protection circuit - Secure retention and easy ejection by plastic clip - Dual screw head (blade+cross) terminals For technical data and supply versions, refer to the MasterINTERFACE 39 Series – “Relay interface module” Electromechanical Relay - EMR Supply voltage 93.62 93.63 Relay type 6 V AC/DC 34.51.7.005.xx10 12 V AC/DC 34.51.7.012.xx10 24 V AC/DC 34.51.7.024.xx10 60 V AC/DC 34.51.7.060.xx10 (110…125)V AC/DC* 34.51.7.060.xx10 (220…240)V AC* 34.51.7.060.xx10 (110…125)V AC/DC 34.51.7.060.xx10 (24…240)V AC/DC 34.51.7.024.xx10 (220…240)V AC 34.51.7.060.xx10 (110…125)V DC 34.51.7.060.xx10 220 V DC 34.51.7.060.xx10 * Leakage current suppression MasterBASIC (39.11.....) 93.61.7.024 93.61.7.024 93.61.7.024 — — — 93.61.0.125 — 93.61.8.230 — — Socket type (reference with the 39 Series) MasterPLUS MasterINPUT MasterOUTPUT (39.21.....) (39.31.....) (39.41.....) 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.060 — — 93.63.3.125 — — 93.63.3.230 — — 93.63.0.125 93.64.0.125 93.62.0.125 93.63.0.240 — — 93.63.8.230 93.64.8.230 93.62.8.230 93.63.7.125 — — 93.63.7.220 — — MasterTIMER (39.81.....) — 93.68.0.024 93.68.0.024 — — — — — — — — MasterBASIC (39.10.....) — — — — 93.61.0.125 — 93.61.8.230 93.61.7.024 93.61.7.024 93.61.7.024 — — — Socket type (reference with the 39 Series) MasterPLUS MasterINPUT MasterOUTPUT (39.20.....) (39.30.....) (39.40.....) — — — 93.63.0.024 93.64.0.024 — 93.63.3.125 — — 93.63.3.230 — — 93.63.0.125 93.64.0.125 93.62.0.125 93.63.0.240 — — 93.63.8.230 93.64.8.230 93.62.8.230 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.060 — — 93.63.7.125 — — 93.63.7.220 — — MasterTIMER (39.80.....) 93.68.0.024 93.68.0.024 — — — — — — — — — — — Solid State Relay - SSR Supply voltage 93.68 Approvals (according to type): Relay type 12 V AC/DC 34.81.7.012.xxxx 24 V AC/DC 34.81.7.024.xxxx (110…125)V AC/DC* 34.81.7.060.xxxx (220…240)V AC* 34.81.7.060.xxxx (110…125)V AC/DC 34.81.7.060.xxxx (24…240)V AC/DC 34.81.7.024.xxxx (220…240)V AC 34.81.7.060.xxxx 6 V DC 34.81.7.005.xxxx 12 V DC 34.81.7.012.xxxx 24 V DC 34.81.7.024.xxxx 60 V DC 34.81.7.060.xxxx (110…125)V DC 34.81.7.060.xxxx 220 V DC 34.81.7.060.xxxx * Leakage current suppression Accessories 16-way jumper link Dual-purpose plastic separator Sheet of marker tags Technical data Rated values Dielectric strength Protection category Ambient temperature°C Screw torqueNm Wire strip lengthmm Max wire size mm2 AWG 10 093.16 (blue), 093.16.0 (black), 093.16.1 (red) 093.60 060.48 and 093.48 6 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 −40…+70 0.5 10 Solid wire and stranded wire 1 x (0.5…2.5) / 2 x 1.5 1 x (21…14) / 2 x 16 XI-2018, www.findernet.com 93.64 93 SERIES Sockets and accessories for 34 series relays 93.60 34 SERIES Push-In terminal socket 35 mm rail mounting (EN 60715) Common features - Space saving 6.2 mm wide - Connections for 16-way jumper link - Terminal doubler 093.62 - Integral coil indication and protection circuit - Secure retention and easy ejection by plastic clip A For technical data and supply versions, refer to the MasterINTERFACE 39 Series – “Relay interface module” Electromechanical Relay - EMR Supply voltage 93.65 93.66 Relay type 6 V AC/DC 34.51.7.005.xx10 12 V AC/DC 34.51.7.012.xx10 24 V AC/DC 34.51.7.024.xx10 60 V AC/DC 34.51.7.060.xx10 (110…125)V AC/DC* 34.51.7.060.xx10 (220…240)V AC* 34.51.7.060.xx10 (110…125)V AC/DC 34.51.7.060.xx10 (24…240)V AC/DC 34.51.7.024.xx10 (220…240)V AC 34.51.7.060.xx10 (110…125)V DC 34.51.7.060.xx10 220 V DC 34.51.7.060.xx10 * Leakage current suppression MasterBASIC (39.01.....) 93.60.7.024 93.60.7.024 93.60.7.024 — — — 93.60.0.125 — 93.60.8.230 — — Socket type (reference with the 39 Series) MasterPLUS MasterINPUT MasterOUTPUT (39.51.....) (39.61.....) (39.71.....) 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.060 — — 93.66.3.125 — — 93.66.3.230 — — 93.66.0.125 93.67.0.125 93.65.0.125 93.66.0.240 — — 93.66.8.230 93.67.8.230 93.65.8.230 93.66.7.125 — — 93.66.7.220 — — MasterTIMER (39.91.....) — 93.69.0.024 93.69.0.024 — — — — — — — — MasterBASIC (39.00.....) — — — — 93.60.0.125 — 93.60.8.230 93.60.7.024 93.60.7.024 93.60.7.024 — — — Socket type (reference with the 39 Series) MasterPLUS MasterINPUT MasterOUTPUT (39.50.....) (39.60.....) (39.70.....) — — — 93.66.0.024 93.67.0.024 — 93.66.3.125 — — 93.66.3.230 — — 93.66.0.125 93.67.0.125 93.65.0.125 93.66.0.240 — — 93.66.8.230 93.67.8.230 93.65.8.230 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.060 — — 93.66.7.125 — — 93.66.7.220 — — MasterTIMER (39.90.....) 93.69.0.024 93.69.0.024 — — — — — — — — — — — Solid State Relay - SSR 93.67 93.69 XI-2018, www.findernet.com Approvals (according to type): Supply voltage Relay type 12 V AC/DC 34.81.7.012.xxxx 24 V AC/DC 34.81.7.024.xxxx (110…125)V AC/DC* 34.81.7.060.xxxx (220…240)V AC* 34.81.7.060.xxxx (110…125)V AC/DC 34.81.7.060.xxxx (24…240)V AC/DC 34.81.7.024.xxxx (220…240)V AC 34.81.7.060.xxxx 6 V DC 34.81.7.005.xxxx 12 V DC 34.81.7.012.xxxx 24 V DC 34.81.7.024.xxxx 60 V DC 34.81.7.060.xxxx (110…125)V DC 34.81.7.060.xxxx 220 V DC 34.81.7.060.xxxx * Leakage current suppression Accessories 16-way jumper link Dual-purpose plastic separator Terminal doubler Sheet of marker tags Technical data Rated values Dielectric strength Protection category Ambient temperature°C Wire strip lengthmm Max wire size mm2 AWG 093.16 (blue), 093.16.0 (black), 093.16.1 (red) 093.60 093.62 060.48 and 093.48 6 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 −40…+70 8 Solid wire and stranded wire 1 x (0.5…2.5) 1 x (21…14) 11 34 SERIES 93 SERIES Sockets and accessories for 34 series relays Screw less terminal socket 35 mm rail mounting (EN 60715) Common features - Space saving 6.2 mm wide - Connections for 20-way jumper link - Integral coil indication and protection circuit - Secure retention and easy ejection by plastic clip A 93.51 Approvals (according to type):  ertain relay/socket C combinations For technical data and supply versions, refer to the 38 Series – “Relay interface module” Electromechanical Relay - EMR and Solid State Relay - SSR Relay type (reference with the 38 Series) Electromechnanical relay - EMR Solid State Relay - SSR Supply voltage (38.61.....) (38.81.....) 12 V AC/DC 34.51.7.012.xx10 — 24 V AC/DC 34.51.7.024.xx10 — (110…125)V AC/DC 34.51.7.060.xx10 34.81.7.060.xxxx (220…240)V AC/DC 34.51.7.060.xx10 34.81.7.060.xxxx (110…125)V AC/DC* 34.51.7.060.xx10 34.81.7.060.xxxx (220…240)V AC* 34.51.7.060.xx10 34.81.7.060.xxxx (220…240)V AC 34.51.7.060.xx10 34.81.7.060.xxxx 12 V DC 34.51.7.012.xx10 34.81.7.012.xxxx 24 V DC 34.51.7.024.xx10 34.81.7.024.xxxx 60 V DC 34.51.7.060.xx10 34.81.7.060.xxxx * Leakage current suppression 93.51.0.024 93.51.0.024 93.51.0.125 93.51.0.240 93.51.3.125 93.51.3.240 93.51.8.240 93.51.7.024 93.51.7.024 93.51.7.060 093.20 093.01 093.48 6 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 −40…+70/−40…+55 10 Solid wire and stranded wire 1 x 2.5 / 2 x 1.5 1 x 14 / 2 x 16 XI-2018, www.findernet.com Accessories 20-way jumper link Plastic separator Sheet of marker tags Technical data Rated values Dielectric strength Protection category Ambient temperature (UN ≤ 60 V/> 60 V)°C Wire strip lengthmm Max wire size mm2 AWG Socket type 12 93 SERIES Sockets and accessories for 34 series relays 93.11 Approvals (according to type): PCB socket with retaining and release clip For relay type Technical data Rated values Dielectric strength Protection category Ambient temperature°C 34 SERIES 93.11 (blue) 34.51, 34.81 A 6 A - 250 V ≥ 6 kV (1.2/50 μs) between coil and contacts IP 20 –40…+70 XI-2018, www.findernet.com Retaining and release clip use: Please see general technical information 13
34.51.7.012.0010 价格&库存
很抱歉,暂时无法提供与“34.51.7.012.0010”相匹配的价格&库存,您可以联系我们找货
  • 9+92.345519+11.93401
  • 10+84.1973810+10.88101
  • 20+81.1795520+10.49101
  • 50+58.3531550+7.54110
  • 100+56.30567100+7.27650
库存:5215
34.51.7.012.0010
  • 12+74.8970812+9.67911
  • 25+71.6798625+9.26334
库存:27
34.51.7.012.0010
  • 1+79.809541+10.31396
  • 20+68.6650020+8.87373
  • 40+66.3117640+8.56961
  • 60+64.9736060+8.39668
  • 100+63.32186100+8.18322
  • 260+60.34395260+7.79838
  • 500+58.38542500+7.54527
  • 1000+56.377601000+7.28580
库存:2178
34.51.7.012.0010
  • 1+60.25912
  • 10+54.95893
  • 20+53.08347
  • 50+50.55569
  • 100+48.76178
库存:5215
