7E.64.8.230.0001
7E.64.8.230.0001
    FINDER
    FINDER - 7E.64.8.230.0001 - ENERGY METER, 1-PH, 230VAC, DIN RAIL
7E.64.8.230.0001 数据手册
Energy meters 7E SЕRIES Panels for electrical distribution Control panels Electrical energy control Industrial robots Road / tunnel lighting Elevators and lifts FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 7E SERIES Energy meters 7E SERIES 7E.12.8.230.0002 kWh Energy meter 1-phase with electromechanical display and SO pulse output 7E.13.8.230.0010 7E.16.8.230.0010 Type 7E.12.8.230.0002 10 (25) A , kWh, No MID, horizontal display Type 7E.13.8.230.0010 5 (32) A , kWh, MID, 1 module wide Type 7E.16.8.230.0010 10 (65) A, kWh, MID, horizontal display • Complies with EN 62053-21 and EN 50470 • Certified by PTB (7E.13 and 7E.16) (Physikalisch - Technischen Bundesanstalt) • Nominal current 10 A • Accuracy class 1/B (25 A Maximum) • Protection class II • 1-phase 230 V AC • SO pulse output for remote energy monitoring • SO pulse output according to EN 62053-31 • 35 mm wide • Tamper-proof cover with lead seal facility available as an accessory • Nominal current 5 A • Nominal current 10 A (32 A Maximum) • MID certified (50 Hz) • 1-phase 230 V AC • SO pulse output • 17.5 mm wide • MID certified (50 Hz) • 1-phase 230 V AC • SO pulse output • 35 mm wide (65 A Maximum) • Space saving small size • 35 mm rail (EN 60715) mount E For outline drawing see page 15 Specification Nominal/Maximum current  A Minimum measured current  A 0.04 0.02 0.04 Current range (within accuracy class)  A 0.5…25 0.25…32 0.5…65 Maximum peak current  A 750 (10 ms) 960 (10 ms) 1950 (10 ms) Supply (& monitored) voltage (UN)  V AC Operating range 10/25 5/32 10/65 230 230 230 (0.8…1.15)UN (0.8…1.15)UN (0.8…1.15)UN Frequency  Hz 50 50 50 Power consumption  W
7E.64.8.230.0001 价格&库存
很抱歉,暂时无法提供与“7E.64.8.230.0001”相匹配的价格&库存,您可以联系我们找货
