93.02.7.024
93.02.7.024
    FINDER
93.02.7.024 数据手册
41 SERIES 41 Series - Low profile PCB relays 8 - 12 - 16 A Features 41.31 41.52 41.61 1 & 2 Pole - Low profile (15.7 mm height) 41.31 - 1 Pole 12 A (3.5 mm pin pitch) 41.52 - 2 Pole 8 A (5 mm pin pitch) 41.61 - 1 Pole 16 A (5 mm pin pitch) A PCB mount - direct or via PCB socket 35 mm rail mount - via screw and screwless sockets AC and DC coils 8 mm, 6 kV (1.2/50 μs) isolation, coil-contacts • Cadmium Free contact materials • Flux proof: RT II standard, (RT III option) • • FOR UL RATINGS SEE: “General technical information” page V 3.5 mm contact pin pitch 1 Pole 12 A • PCB direct or via socket 5 mm contact pin pitch 2 Pole 8 A • PCB direct or via socket 5 mm contact pin pitch 1 Pole 16 A • PCB direct or via socket • • • • • • Copper side view Copper side view Copper side view 1 CO (SPDT) 2 CO (DPDT) 1 CO (SPDT) Contact specification Contact configuration Rated current/Maximum peak current A 12/25 Rated voltage/Maximum switching voltage V AC 250/400 250/400 250/400 8/15 16/30 Rated load AC1 VA 3,000 2,000 4,000 Rated load AC15 (230 V AC) VA 600 400 750 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) 0.5 0.3 0.5 12/0.3/0.12 8/0.3/0.12 16/0.3/0.12 300 (5/5) 300 (5/5) 300 (5/5) AgNi Standard contact material AgNi AgNi Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC Operating range 24 - 115 - 230 24 - 115 - 230 24 - 115 - 230 5 - 6 - 12 - 24 - 48 - 60 - 110 5 - 6 - 12 - 24 - 48 - 60 - 110 5 - 6 - 12 - 24 - 48 - 60 - 110 0.75/0.4 0.75/0.4 0.75/0.4 AC (0.8...1.1)UN (0.8...1.1)UN (0.8...1.1)UN DC VA (50 Hz)/W (0.7...1.5)UN (0.7...1.5)UN (0.7...1.5)UN Holding voltage AC/DC 0.8/0.4UN 0.8/0.4 UN 0.8/0.4 UN Must drop-out voltage AC/DC 0.15/0.1UN 0.15/0.1 UN 0.15/0.1 UN Mechanical life AC/DC cycles 10·106/10·106 10·106/10·106 10·106/10·106 Electrical life at rated load AC1 cycles 60 · 103 60 · 103 50 · 103 Technical data X-2014, www.findernet.com Operate/release time ms Insulation between coil and contacts (1.2/50 μs) kV Dielectric strength between open contacts V AC Ambient temperature range Environmental protection °C 8/6 8/6 8/6 6 (8 mm) 6 (8 mm) 6 (8 mm) 1,000 1,000 1,000 –40…+70 (AC); +85 (DC) –40…+70 (AC); +85 (DC) –40…+70 (AC); +85 (DC) RT II RT II RT II Approvals (according to type) 1 41 SERIES 41 Series - Bistable low profile PCB relays 8 - 16 A Features 41.61.6.xxx 1 & 2 Pole - Polarized bistable, Low profile (15.7 mm height) 41.52 - 2 Pole 8 A (5 mm pin pitch) 41.61 - 1 Pole 16 A (5 mm pin pitch) Printed Circuit mount Polarized bistable relay with 2 coils 10 mm, 6 kV (1.2/50μs) isolation, coil-contacts • Cadmium Free contact materials • Flux proof: RT II standard • • • • 2 Pole, 8 A PCB direct mount • • 1 Pole, 16 A PCB direct mount 2 coil version: A3(+) A2 (−) = Set A3(+) A1 (−) = Reset 2 coil version: A3(+) A2 (−) = Set A3(+) A1 (−) = Reset Copper side view Copper side view 2 CO (DPDT) 1 CO (SPDT) Contact specification Contact configuration Rated current/Maximum peak current (IN/Imax) A 8 / 15 16 / 30 Rated voltage/Maximum switching voltage (UN/Umax) V AC 250 / 400 250 / 400 Rated load AC1 VA 2,000 4,000 Rated load AC15 (230 V AC) VA 350 750 Single phase motor rating (230 V AC) kW 0.37 0.55 Breaking capacity DC1: 30/110/220 V Minimum switching load A 8/0.3/0.12 16/0.3/0.12 mW (V/mA) 500 (5/100) 500 (5/100) AgSnO2 AgSnO2 Standard contact material Coil specification Nominal voltage (UN) 5 - 12 - 24 5 - 12 - 24 Rated power (PN) V DC W 0.65 0.65 Operating range DC (0.7 ... 1.1)UN (0.7 ... 1.1)UN Min. impulse duration ms 20 20 Max. impulse duration s 30 30 Technical data Mechanical life DC cycles 5·106 5·106 Electrical life at rated load AC1 cycles 30 · 103 30 · 103 10 / 5 10 / 10 Insulation between coil and contacts (1.2/50 μs) kV 6 (10 mm) 6 (10 mm) Dielectric strength between open contacts V AC 1,000 1,000 –40…+85 –40…+85 RT II RT II Operate/release time Ambient temperature range Environmental protection Approvals (according to type) 2 ms °C — X-2014, www.findernet.com A 41.52.6.xxx 41 Series - Low profile PCB relays (SSR) 3 - 5 A Features 41.81 - 9024 41 SERIES 41.81 - 8240 Solid State Relays A Printed circuit mount: - direct or via PCB socket 35 mm rail mount: - via screw or screwless sockets Single circuit output switching options - 5 A 24 V DC - 3 A 240 V AC • Silent, high speed switching with long electrical life • LED indicator • Low profile (15.7 mm) • Wash tight: RT III • 2,500 V AC insulation, input-output • • • 5 A, 24 V DC output switching PCB or 93 Series sockets 3 A, 240 V AC output switching Zero crossing switching • PCB or 93 Series sockets • • Copper side view Copper side view 1 NO (SPST-NO) 1 NO (SPST-NO) Output circuit Contact configuration Rated current/Maximum peak current (10 ms) A Rated voltage/Maximum blocking voltage Switching voltage range Repetitive peak off-state voltage 5/40 3/40 V (24/35)DC (240/—)AC V (1.5...24)DC (12...275)AC — 600 Vpk Minimum switching current mA 1 50 Max. “OFF-state” leakage current mA 0.01 1 0.3 1.1 Max. “ON-state” voltage drop V Input circuit Nominal voltage V DC 12 24 12 24 Operating range V DC 8...17 14...32 8...17 14...32 5.5 9 8.8 9 Control current Release voltage Impedance mA V DC Ω 4 9 4 9 1,550 2,600 1,030 2,600 Technical data Operate/release time ms Dielectric strength between input/output V AC Ambient temperature range Environmental protection °C 0.05/0.25 10/10 2,500 2,500 –20...+60 –20...+60 RT III RT III X-2014, www.findernet.com Approvals (according to type) 3 41 SERIES 41 Series - Low profile PCB relays Ordering information Electromechanical relay (EMR) Example: 41 series low-profile PCB relay, 2 CO (DPDT), 24 V DC coil. 4 1 . 5 A B C D 2 . 9 . 0 2 4 . 0 0 1 0 Series Type 3 = PCB - 3.5 mm pinning 5 = PCB - 5 mm pinning 6 = PCB - 5 mm pinning No. of poles 1 = 1 pole for 41.31, 12 A 41.61, 16 A 2 = 2 pole for 41.52, 8 A Coil version 6 = DC bistable, 2 coils 8 = AC 9 = DC A: Contact material 0 = Standard AgNi 4 = AgSnO2 5 = AgNi + Au D: Special versions 0 = Flux proof (RT II) 1 = Wash tight (RT III) 6 = Bistable version (RT II) B: Contact circuit 0 = CO (nPDT) 3 = NO (nPST) C: Options 0 = Production line 0 1 = Production line 1 Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Coil voltage See coil specifications Type 41.31 41.52 41.61 41.31/52/61 41.52 41.61 Coil version DC DC DC AC DC bistable DC bistable A 0-4-5 0-5 0-4 0 4 4 B 0 0 0 0 0 0 -3 -3 -3 -3 C 1 1 1 0 1 1 D 0-1 0-1 0-1 0 6 6 Solid state relay (SSR) Example: 41 series SSR relay, 5 A output, 24 V DC supply. 4 1 . 8 Series Type 8 = SSR type 1 . 7 . 0 2 4 . 9 0 2 4 Output circuit 9024 = 5 A - 24 V DC 8240 = 3 A - 240 V AC Output 1 = 1 NO (SPST-NO) Input circuit See input specifications X-2014, www.findernet.com A 4 41 SERIES 41 Series - Low profile PCB relays Electromechanical relay Technical data A Insulation according to EN 61810-1 1 pole 1 pole bistable 2 pole 2 pole bistable Nominal voltage of supply system V AC 230/400 230/400 230/400 230/400 Rated insulation voltage V AC 250 400 250 250 400 250 2 2 3 2 2 Pollution degree 3 Insulation between coil and contact set Type of insulation Reinforced (8 mm) Reinforced (10 mm) Reinforced (8 mm) Reinforced (10 mm) Overvoltage category III III III III Rated impulse voltage kV (1.2/50 μs) 6 6 6 6 4,000 4,000 4,000 — Basic Basic III Dielectric strength V AC 4,000 Insulation between adjacent contacts Type of insulation — Overvoltage category — — III Rated impulse voltage kV (1.2/50 μs) — — 4 4 V AC — — 2,000 2,000 Dielectric strength Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength Micro-disconnection V AC/kV (1.2/50 μs) 1,000/1.5 1,000/1.5 Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 μs) on A1 - A2 (differential mode) EN 61000-4-5 level 3 (2 kV) Other data Bounce time: NO/NC ms 4/6 (monostable) - 2/10 (bistable) Vibration resistance (5…55)Hz: NO/NC Shock resistance Power lost to the environment g 15/2 (monostable) - 5/3 (bistable) g 16 (monostable) - 10 (bistable) without contact current with rated current W 1.7 (41.31) 1.2 (41.52) 1.8 (41.61) mm ≥ 5 X-2014, www.findernet.com Recommended distance between relays mounted on PCB W 0.4 (monostable) 5 41 SERIES 41 Series - Low profile PCB relays Contact specification F 41 - Electrical life (AC) v contact current (monostable) Type 41.52 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 Cycles Cycles Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 limit for 41.31 H 41- Maximum DC1 breaking capacity DC breaking current (A) F 41 - Electrical life (AC) v contact current (bistable) Cycles 1 pole 2 pole 41.61 limit current 41.31 limit current 41.52 limit current 41.52 - 2 contacts in series single contact DC voltage (V) Coil specifications • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. AC coil data R 41 - AC coil operating range v ambient temperature Nominal voltage UN V 24 115 230 Coil code Operating range Umin V 19.2 92 184 8.024 8.115 8.230 Umax V 26.4 126.5 253 Resistance Rated coil consumption R I at UN Ω mA 350 31.6 8,100 6 32,500 3.2 DC coil data Nominal voltage UN V 5 6 12 24 48 60 110 Coil code Operating range Umin V 3.5 4.2 8.4 16.8 33.6 42 77 9.005 9.006 9.012 9.024 9.048 9.060 9.110 Umax V 7.5 9 18 36 72 90 165 Resistance Rated coil consumption R I at UN Ω mA 62 80 90 66.7 360 33.3 1,440 16.7 5,760 8.3 9,000 6.6 24,200 4.5 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. R 41 - DC coil operating range v ambient temperature DC coil data (bistable) Nominal voltage UN V 5 12 24 6 Coil code 6.005 6.012 6.024 Operating range Set Umin V 3.5 8.4 16.8 Reset Umin V 3.5 8.4 16.8 Set/Reset Umax V 5.5 13.2 26.4 Resistance Rated coil power R Ω 38 220 885 mW 650 650 650 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. X-2014, www.findernet.com A F 41 - Electrical life (AC) v contact current (monostable) Types 41.31/61 41 SERIES 41 Series - Low profile PCB relays Solid state relay Technical data Other data Power lost to the environment 41.81 - 9024 41.81 - 8240 without current W 0.25 0.25 with maximum current W 1.75 3.5 A Input specification Input data - DC types Nominal voltage UN V 12 24 Input code 7.012 7.024 Operating range Umin V 8 14 Umax V 17 32 Release voltage Impedance V 4 9 Ω 1,550 2,600 Control current I at UN mA 5.5 9 Output specification Output current L 41 - Output current v ambient temperature SSR - 3 A AC output types X-2014, www.findernet.com Output current L 41 - Output current v ambient temperature SSR - 5 A DC output types 7 41 SERIES 93 Series - Sockets and accessories for 41 series relays Screw terminal socket 35 mm (EN 60715) mounting A 93.02 Approvals (according to type): Supply voltage Relay type Socket type 6 V AC/DC 12 V AC/DC 24 V AC/DC 60 V AC/DC (110...125)V AC/DC (220...240)V AC/DC (230...240)V AC 6 V DC 12 V DC 24 V DC 48 V DC 60 V DC Accessories 41.52.9.005.0010 or 41.61.9.005.0010 41.52.9.012.0010 or 41.61.9.012.0010 41.52/61.9.024.0010 or 41.81.7.024.xxxx 41.52.9.060.0010 or 41.61.9.060.0010 41.52.9.110.0010 or 41.61.9.110.0010 41.52.9.110.0010 or 41.61.9.110.0010 41.52.9.110.0010 or 41.61.9.110.0010 41.52.9.005.0010 or 41.61.9.005.0010 41.52/61.9.012.0010 or 41.81.7.012.xxxx 41.52/61.9.024.0010 or 41.81.7.024.xxxx 41.52.9.048.0010 or 41.61.9.048.0010 41.52.9.060.0010 or 41.61.9.060.0010 93.02.0.024 93.02.0.024 93.02.0.024 93.02.0.060 93.02.0.125 93.02.0.240 93.02.8.230 93.02.7.024 93.02.7.024 93.02.7.024 93.02.7.060 93.02.7.060 8-way jumper link Plastic separator Sheet of marker tags, 72 tags Technical data Rated values Dielectric strength 093.08 (see specification next page) 093.01 (see specification next page) 060.72 (see specification next page) 10 A - 250 V 6 kV (1.2/50 μs) between coil and contacts Protection category IP 20 Ambient temperature (UN≤ 60 V/> 60 V) °C –40...+70/–40...+55 Screw torque Nm 0.5 Wire strip length mm 8 Max. wire size for 93.02 socket solid wire mm2 1x6 / 2x2.5 AWG 1x10 / 2x14 stranded wire 1x4 / 2x2.5 1x12 / 2x14 X-2014, www.findernet.com Note: Not for bistable relays 8 93 Series - Sockets and accessories for 41 series relays Screwless terminal socket 35 mm (EN 60715) mounting Supply voltage Relay type 41 SERIES Socket type A 6 V AC/DC 41.52.9.005.0010 or 41.61.9.005.0010 93.52.0.024 12 V AC/DC 41.52.9.012.0010 or 41.61.9.012.0010 93.52.0.024 24 V AC/DC 41.52/61.9.024.0010 or 41.81.7.024.xxxx 93.52.0.024 60 V AC/DC 41.52.9.060.0010 or 41.61.9.060.0010 93.52.0.060 (110...125)V AC/DC 41.52.9.110.0010 or 41.61.9.110.0010 93.52.0.125 (220...240)V AC/DC 41.52.9.110.0010 or 41.61.9.110.0010 93.52.0.240 (230...240)V AC 41.52.9.110.0010 or 41.61.9.110.0010 93.52.8.230 6 V DC 41.52.9.005.0010 or 41.61.9.005.0010 93.52.7.024 12 V DC 41.52/61.9.012.0010 or 41.81.7.012.xxxx 93.52.7.024 24 V DC 41.52/61.9.024.0010 or 41.81.7.024.xxxx 93.52.7.024 48 V DC 41.52.9.048.0010 or 41.61.9.048.0010 93.52.7.060 60 V DC 41.52.9.060.0010 or 41.61.9.060.0010 93.52.7.060 Accessories 8-way jumper link 093.08 (see table below) Plastic separator 093.01 (see table below) Sheet of marker tags, 72 tags 060.72 (see table below) Technical data Rated values 10 A - 250 V Dielectric strength 6 kV (1.2/50 μs) between coil and contacts Protection category IP 20 Ambient temperature (UN≤ 60 V/> 60 V) °C –40...+70 /–40...+55 Wire strip length mm 8 Max. wire size for 93.52 socket solid wire stranded wire 93.52 Approvals (according to type): mm2 AWG 1x2.5 1x14 1x2.5 1x14 Note: Not for bistable relays P A PEAN N T E O O T EUR EUR Accessories 8-way jumper link for 93.02 and 93.52 sockets 093.08 (blue) Rated values 10 A - 250 V Plastic separator for 93.02 and 93.52 sockets 093.01 093.08.0 (black) 093.08.1 (red) PEAN 093.08 Approvals (according to type): X-2014, www.findernet.com 093.01 Thickness 2 mm, required at the start and the end of a group of interfaces. Can be used for visual separation group, must be used for: - protective separation of different voltages of neighbouring PLC interfaces according to VDE 0106-101 - protection of cut jumper links Sheet of marker tags for 38.x2, plastic, 72 tags, 6x12 mm 060.72 060.72 9 41 SERIES PCB socket For relay type Accessories Plastic retaining clip Technical data Rated values Dielectric strength Protection category Ambient temperature 95.13.2 95.15.2 95.13.2 (blue) 95.13.20 (black) 95.15.2 (blue) 95.15.20 (black) 41.31 41.52, 41.61, 41.81(1) 095.42 10 A - 250 V * 6 kV (1.2/50 μs) between coil and contacts IP 20 °C –40…+70 * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). (1) With the relay 41.81 the NO change-over contact will be 11-14. Approvals (according to type): 13 7.5 41.52 41.81 - 9024 41.61 41.81 - 8240 1.5 3.5 3.5 41.31 30 20 95.13.2 95.15.2 Copper side view Copper side view Note: Not for bistable relays Packaging codes How to code and identify retaining clip and packaging options for sockets. Example: 9 5 . 1 3 . 2 S L A A Standard packaging SL Plastic retaining clip 9 5 . 1 3 . 2 Without retaining clip X-2014, www.findernet.com A 93 Series - Sockets and accessories for 41 series relays 10
93.02.7.024 价格&库存
很抱歉,暂时无法提供与“93.02.7.024”相匹配的价格&库存,您可以联系我们找货
    • 1+123.04990
    库存:74
