94.54SPA
94.54SPA
    FINDER
94.54SPA 数据手册
55 SERIES 55 Series - General purpose relays 7 - 10 A Features 55.12 55.13 55.14 Printed circuit mount, general purpose 2, 3 & 4 Pole relays A 55.12 - 2 Pole 10 A 55.13 - 3 Pole 10 A 55.14 - 4 Pole 7 A AC coils & DC coils Cadmium Free contacts • Contact material options • RT III (wash tight) option available • • • • 55.12 55.13 2 pole, 10 A PCB mount • • 3 pole, 10 A PCB mount • • 4 pole, 7 A PCB mount 55.14 FOR UL RATINGS SEE: “General technical information” page V Copper side view Copper side view Copper side view 2 CO (DPDT) 3 CO (3PDT) 4 CO (4PDT) Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 10/20 10/20 7/15 250/400 250/400 250/250 Rated load AC1 VA 2,500 2,500 1,750 Rated load AC15 (230 V AC) VA 500 500 350 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material 0.37 0.37 0.125 10/0.25/0.12 10/0.25/0.12 7/0.25/0.12 300 (5/5) 300 (5/5) 300 (5/5) AgNi AgNi AgNi Coil specification Nominal voltage (UN) V AC (50/60 Hz) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 V DC Rated power AC/DC VA (50 Hz)/W Operating range AC DC 6 - 12 - 24 - 48 - 60 - 110 -125 - 220 1.5/1 1.5/1 1.5/1 (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN Holding voltage AC/DC 0.8 UN/0.5 UN 0.8 UN/0.5 UN 0.8 UN/0.5 UN Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/0.1 UN 0.2 UN/0.1 UN 20 · 106/50 · 106 20 · 106/50 · 106 20 · 106/50 · 106 Technical data Mechanical life AC/DC Electrical life at rated load AC1 II-2014, www.findernet.com Operate/release time cycles cycles ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range Environmental protection °C 3 200 · 10 3 200 · 10 150 · 103 10/5 10/5 11/3 4 4 4 1,000 1,000 1,000 –40…+85 –40…+85 –40…+85 RT I RT I RT I Approvals (according to type) 1 55 SERIES 55 Series - General purpose relays 7 - 10 A Features 55.33 55.34 Plug-in mount, general purpose 2, 3 & 4 Pole relays 55.32 - 2 Pole 10 A 55.33 - 3 Pole 10 A 55.34 - 4 Pole 7 A Lockable test button and mechanical flag indicator as standard on 2 & 4 pole types • AC coils & DC coils • UL Listing (certain relay/socket combinations) • Cadmium Free contacts • Contact material options • 94 series sockets • Coil EMC suppression • Timer accessories 86 series • European Patent • 55.32 55.33 • • 2 pole, 10 A Plug-in 94 series sockets • • 3 pole, 10 A Plug-in 94 series sockets • • 4 pole, 7 A Plug-in 94 series sockets 55.34 FOR UL RATINGS SEE: “General technical information” page V Contact specification 2 CO (DPDT) Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 3 CO (3PDT) 4 CO (4PDT) 10/20 10/20 7/15 250/400 250/400 250/250 Rated load AC1 VA 2,500 2,500 1,750 Rated load AC15 (230 V AC) VA 500 500 350 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material 0.37 0.37 0.125 10/0.25/0.12 10/0.25/0.12 7/0.25/0.12 300 (5/5) 300 (5/5) 300 (5/5) AgNi AgNi AgNi Coil specification Nominal voltage (UN) V AC (50/60 Hz) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 V DC Rated power AC/DC VA (50 Hz)/W Operating range AC DC 6 - 12 - 24 - 48 - 60 - 110 - 125 - 220 1.5/1 1.5/1 1.5/1 (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN Holding voltage AC/DC 0.8 UN/0.5 UN 0.8 UN/0.5 UN 0.8 UN/0.5 UN Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/0.1 UN 0.2 UN/0.1 UN 20 · 106/50 · 106 20 · 106/50 · 106 20 · 106/50 · 106 Technical data Mechanical life AC/DC Electrical life at rated load AC1 Operate/release time cycles cycles ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range Environmental protection Approvals (according to type) 2 °C 3 3 200 · 10 200 · 10 150 · 103 10/5 10/5 11/3 4 4 4 1,000 1,000 1,000 –40…+85 –40…+85 –40…+85 RT I RT I RT I II-2014, www.findernet.com A 55.32 55 Series - General purpose relays 7 - 10 A 55 SERIES Ordering information Example: 55 series plug-in relay, 4 CO (4PDT), 12 V DC coil, lockable test button and mechanical indicator. 5 5 . 3 A B C D 4 . 9 . 0 1 2 . 0 0 4 0 Series A: Contact material 0 = Standard AgNi 5 = AgNi + Au Type 1 = PCB 3 = Plug-in B: Contact circuit 0 = CO (nPDT) No. of poles 2 = 2 pole, 10 A 3 = 3 pole, 10 A 4 = 4 pole, 7 A Coil version 8 = AC (50/60 Hz) 9 = DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version 55.32/34 AC-DC AC AC DC DC 55.33 AC-DC AC DC 55.12/13/14 AC-DC A 0-5 0-5 0-5 0-5 0-5 0-5 0-5 0-5 0-5 B 0 0 0 0 0 0 0 0 0 C 0 2-3-4-5 54 2-4 -6 -7-8-9 74 - 94 0 1-3-5 1-6-7-8-9 0 D 0 0 / 0 / 0 0 0 0-1 A D: Special versions 0 = Standard 1 = Wash tight (RT III) for 55.12, 55.13 and 55.14 only C: Options 0 = None 1 = Lockable test button 2 = Mechanical indicator 3 = LED (AC) 4 = Lockable test button+mechanical indicator 5 = Lockable test button + LED (AC) 54 = Lockable test button + LED (AC) + mechanical indicator 6* = Double LED (DC non-polarized) 7* = Lockable test button + double LED (DC non-polarized) 74* = Lockable test button + double LED (DC non-polarized) + mechanical indicator 8* = LED + diode (DC, polarity positive to pin A1/13) 9* = Lockable test button + LED + diode (DC, polarity positive to pin A1/13) 94* = Lockable test button + LED + diode (DC, polarity positive to pin A1/13) + mechanical indicator * Option not available for the 220 V DC version. Descriptions: options and special versions 3 II-2014, www.findernet.com 1 2 Lockable test button and mechanical flag indicator (0010, 0040, 0050, 0054, 0070, 0074, 0090, 0094) O P A PEAN N T E T EUR EUR C: Option 8, 9, 94 LED + diode (DC, polarity positive to pin A1/13) PEAN C: Option 6, 7, 74 Double LED (DC non-polarized) O C: Option 3, 5, 54 LED (AC) The dual-purpose Finder test button can be used in two ways: Case 1) The plastic pip (located directly above the test button) remains intact. In this case, when the test button is pushed, the contacts operate. When the test button is released the contacts return to their former state. Case 2) The plastic pip is broken-off (using an appropriate cutting tool). In this case, (in addition to the above function), when the test button is pushed and rotated, the contacts are latched in the operating state, and remain so until the test button is rotated back to its former position. In both cases ensure that the test button actuation is swift and decisive. 3 55 SERIES 55 Series - General purpose relays 7 - 10 A Technical data Insulation according to EN 61810-1 V AC 230/400 Rated insulation voltage V AC 400 Pollution degree 4 pole 230 250 2 2 Insulation between coil and contact set Type of Insulation Basic Basic Overvoltage category III III Rated impulse voltage kV (1.2/50 µs) 4 4 Dielectric strength V AC 2,000 2,000 Insulation between adjacent contacts Type of insulation Basic Basic Overvoltage category III II Rated impulse voltage kV (1.2/50 µs) 4 Dielectric strength 2.5 V AC 2,000 2,000 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength Micro-disconnection V AC/kV (1.2/50 µs) 1,000/1.5 1,000/1.5 Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 µs) on A1 - A2 (differential mode) EN 61000-4-5 level 4 (4 kV) Other data Bounce time: NO/NC ms 1/3 Vibration resistance (5…55)Hz: NO/NC g 15/15 Shock resistance g 16 Power lost to the environment without contact current with rated current Recommended distance between relays mounted on PCB W 1 W 3 (2 pole) 4 (3 pole) 3 (4 pole) mm ≥ 5 Contact specification F 55 - Electrical life (AC) v contact current 4 pole relay Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 Cycles Cycles F 55 - Electrical life (AC) v contact current 2 and 3 pole relays Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 H 55 - Maximum DC1 breaking capacity 2 & 3 pole current limit 4 pole current limit contacts in series DC voltage (V) 4 • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. II-2014, www.findernet.com DC breaking current (A) A 2 pole - 3 pole Nominal voltage of supply system 55 SERIES 55 Series - General purpose relays 7 - 10 A Coil specifications DC coil data Nominal voltage UN V 6 12 24 48 60 110 125 220 AC coil data Coil code Operating range 9.006 9.012 9.024 9.048 9.060 9.110 9.125 9.220 Umin V 4.8 9.6 19.2 38.4 48 88 100 176 Umax V 6.6 13.2 26.4 52.8 66 121 138 242 Resistance Rated coil consumption R I at UN Ω mA 40 150 140 86 600 40 2,400 20 4,000 15 12,500 8.8 17,300 7.2 54,000 4 Nominal voltage UN V 6 12 24 48 60 110 120 230 240 Coil code 8.006 8.012 8.024 8.048 8.060 8.110 8.120 8.230 8.240 Operating range Umin V 4.8 9.6 19.2 38.4 48 88 96 184 192 Umax V 6.6 13.2 26.4 52.8 66 121 132 253 264 Resistance Rated coil consumption R I at UN (50Hz) Ω mA 12 200 50 97 190 53 770 25 1,200 21 4,000 12.5 4,700 12 17,000 6 19,100 5.3 R 55 - DC coil operating range v ambient temperature R 55 - AC coil operating range v ambient temperature 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. Accessories Top flange mount adaptor for 55.32, 55.33, 55.34 056.25 056.25 with relay 056.25 056.27 Rear flange mount adaptor for 55.32, 55.33, 55.34 056.26 056.25 056.25 with relay 056.27 with 056.26 relay 056.26 with relay 056.26 II-2014, www.findernet.com Top 35 mm rail (EN 60715) adaptor for 55.32, 55.33, 55.34 056.27 056.26 with relay 056.27 056.27 with relay 056.27 056.27 with relay 5 A 55 SERIES 94 Series - Socket overview for 55 series relays A Module Socket 99.02 94.02 94.03 94.04 Relay 55.32 55.33 55.32 55.34 Module Socket 99.02 94.54 Relay Description 55.32 Screwless terminal socket 55.34 - For fast cable connections - Top terminals - Contacts - Bottom terminals - Coil Module Socket 99.01 94.72 94.73 94.74 Relay Description Mounting 55.32 Screw terminal (Plate clamp) socket Panel or 35 mm rail 55.33 (EN 60715) mount 55.32 55.34 Accessories - Coil indication and EMC suppression modules - Metal retaining clip Module Socket 99.01 94.82 Relay Description Mounting 55.32 Screw terminal (Plate clamp) socket Panel or 35 mm rail - 23 mm wide for space saving (EN 60715) mount Accessories - Coil indication and EMC suppression modules - Metal retaining clip 94.04 Description Screw terminal (Box clamp) socket - Top terminals - Contacts - Bottom terminals - Coil Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Timer modules - Plastic retaining and release clip Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Timer modules - Plastic retaining and release clip See page 7 94.54 See page 8 94.74 See page 9 94.82 See page 9 94.84.3 Module Socket Relay Description 99.80 94.84.2 55.32 Screw terminal (Box clamp) socket 55.34 94.82.3 55.32 94.84.3 55.32 55.34 Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Plastic retainig and release clip Module Socket Relay 99.80 94.92.3 55.32 94.94.3 55.32 55.34 Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Plastic retaining and release clip See page 10 Description Screw terminal (Box clamp) socket - Top terminals - Contacts - Bottom terminals - Coil 94.94.3 94.14 See page 12 94.22 See page 12 94.34 See page 13 6 Module — — — Socket 94.12 94.13 94.14 Relay Description 55.32 PCB sockets 55.33 55.32 55.34 Mounting PCB mounting Accessories - Metal retaining clip Module — — — Socket 94.22 94.23 94.24 Relay Description 55.32 Panel mount 55.33 with solder connections 55.32 55.34 Mounting Panel mount on 1 mm thick panel Accessories - Metal retaining clip Module — — — Socket 94.32 94.33 94.34 Relay Description 55.32 Panel mount 55.33 with solder connections 55.32 55.34 Mounting M3 screw fixing Accessories - Metal retaining clip II-2014, www.findernet.com See page 11 94 Series - Sockets and accessories for 55 series relays Screw terminal (Box clamp) socket panel or 35 mm (EN 60715) rail mount For relay type Accessories Metal retaining clip 94.04 Plastic retaining and release clip Approvals (supplied with socket - packaging code SPA) (according to type): 6-way jumper link Identification tag Modules (see table below) Timer modules (see table below) Certain relay/socket Sheet of marker tags for retaining and release clip 094.91.3 combinations plastic, 72 tags, 6x12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature °C 094.91.3 Screw torque Nm Wire strip length mm Max. wire size for 94.02/03/04 sockets mm2 AWG 94.02 Blue 55.32 94.02.0 94.03 Black Blue 55.33 55 SERIES 94.03.0 94.04 94.04.0 Black Blue Black 55.32, 55.34 A 094.71 094.91.3 094.91.30 094.91.3 094.91.30 094.91.3 094.91.30 094.06 094.06.0 094.06 094.06.0 094.06 094.00.4 99.02 86.30 060.72 10 A - 250 V 2 kV AC IP 20 –40…+70 0.5 8 solid wire 1x6 / 2x2.5 1x10 / 2x14 094.06.0 stranded wire 1x4 / 2x2.5 1x12 / 2x14 Top terminals 060.72 P A PEAN N T E O O T EUR EUR 94.04 Bottom terminals 6-way jumper link for 94.02, 94.03 and 94.04 sockets 094.06 (blue) Rated values 10 A - 250 V 094.06.0 (black) PEAN 094.06 86 series timer modules (12…24)V AC/DC; Bi-function: AI, DI; (0.05s…100h) 86.30 99.02 II-2014, www.findernet.com Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 86.30.0.024.0000 (110...125)V AC; Bi-function: AI, DI; (0.05s…100h) (230...240)V AC; Bi-function: AI, DI; (0.05s…100h) Approvals (according to type): 86.30.8.120.0000 86.30.8.240.0000 99.02 coil indication and EMC suppression modules for 94.02, 94.03 and Diode (+A1, standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (110...240)V AC 94.04 sockets 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 7 55 SERIES 94 Series - Sockets and accessories for 55 series relays Screwless terminal socket 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip Plastic retaining and release clip 6-way jumper link Modules (see table below) Sheet of marker tags, 72 tags, 6x12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature °C Wire strip length mm Max. wire size for 94.54 socket mm2 AWG A 94.54 Approvals (according to type): 094.91.3 94.54 (blue) 55.32, 55.34 094.71 094.91.3 094.56 99.02, 86.30 060.72 10 A - 250 V 2 kV AC IP 20 –25…+70 10 solid wire 2x(0.2…1.5) 2x(24…14) stranded wire 2x(0.2…1.5) 2x(24…14) Top terminals 060.72 Sockets + jumper link P A PEAN N T E O O T EUR EUR Bottom terminals 6-way jumper link 094.56 (blue) Rated values 10 A - 250 V PEAN 094.56 86 series timer modules 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 8 86.30.0.024.0000 (110...125)V AC; Bi-function: AI, DI; (0.05s…100h) 86.30.8.120.0000 (230...240)V AC; Bi-function: AI, DI; (0.05s…100h) 86.30.8.240.0000 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 94.54 sockets Diode (+A1, standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (110...240)V AC 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 II-2014, www.findernet.com 86.30 (12…24)V AC/DC; Bi-function: AI, DI; (0.05s…100h) 55 SERIES 94 Series - Sockets and accessories for 55 series relays 94.74 Approvals (according to type): 94.82 Approvals (according to type): Screw terminal (Plate clamp) socket panel or 35 mm (EN 60715) rail mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Modules (see table below) Screw terminal (Plate clamp) socket: panel or 35 mm rail mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Modules (see table below) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 94.72/73/74 and 94.82 sockets mm2 AWG 94.72 94.72 Blue 55.32 94.72.0 94.73 Black Blue 55.33 94.82 (blue) 55.32 94.73.0 94.74 94.74.0 Black Blue Black 55.32, 55.34 A 094.71 99.01 94.82.0 (black) 55.32 094.71 99.01 10 A - 250 V 2 kV AC IP 20 –40…+70 0.5 8 (94.72/73/74) solid wire 1x2.5 / 2x1.5 1x14 / 2x16 9 (94.82) stranded wire 1x2.5 / 2x1.5 1x14 / 2x16 94.73 94.74 Top terminals Bottom terminals 94.82 99.01 II-2014, www.findernet.com Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. 99.01 coil indication and EMC suppression modules for 94.72, 94.73, 94.74 and 94.82 sockets Blue* Diode (+A1, standard polarity) (6...220)V DC 99.01.3.000.00 Diode (+A2, non standard polarity) (6...220)V DC 99.01.2.000.00 LED (6...24)V DC/AC 99.01.0.024.59 LED (28...60)V DC/AC 99.01.0.060.59 LED (110...240)V DC/AC 99.01.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.01.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.01.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.01.9.220.99 LED + Diode (+A2, non standard polarity) (6...24)V DC 99.01.9.024.79 LED + Diode (+A2, non standard polarity) (28...60)V DC 99.01.9.060.79 LED + Diode (+A2, non standard polarity) (110...220)V DC 99.01.9.220.79 LED + Varistor (6...24)V DC/AC 99.01.0.024.98 LED + Varistor (28...60)V DC/AC 99.01.0.060.98 LED + Varistor (110...240)V DC/AC 99.01.0.230.98 RC circuit (6...24)V DC/AC 99.01.0.024.09 RC circuit (28...60)V DC/AC 99.01.0.060.09 RC circuit (110...240)V DC/AC 99.01.0.230.09 Residual current by-pass (110...240)V AC 99.01.8.230.07 9 55 SERIES 94 Series - Sockets and accessories for 55 series relays A 94.84.3 Approvals (according to type): 94.84.2 Approvals (according to type): 094.91.3 Screw terminal (Box clamp) socket panel or 35 mm (EN 60715) rail mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Plastic retaining and release clip 6-way jumper link Identification tag Modules (see table next page) Sheet of marker tags for retaining and release clip 094.91.3 plastic, 72 tags, 6x12 mm Screw terminal (Box clamp) socket panel or 35 mm (EN 60715) rail mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Plastic retaining and release clip 6-way jumper link Identification tag Modules (see table next page) Sheet of marker tags for retaining and release clip 094.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 94.82.3, 94.84.3 and 94.84.2 sockets mm2 AWG 94.82.3 Blue 55.32 094.91.3 094.06 94.84.2 Blue 55.32, 55.34 094.91.3 094.06 10 A - 250 V 2 kV AC IP 20 –40…+70 0.5 7 solid wire 1x6 / 2x2.5 1x10 / 2x14 94.82.30 Black 94.84.3 94.84.30 Blue Black 55.32, 55.34 094.71 094.91.30 094.91.3 094.06.0 094.06 094.80.3 99.80 060.72 094.91.30 094.06.0 94.84.20 Black 094.71 094.91.30 094.06.0 094.80.3 99.80 060.72 stranded wire 1x4 / 2x2.5 1x12 / 2x14 060.72 Top terminals Bottom terminals 94.84.3 94.84.2 Bottom terminals 94.84.2 10 II-2014, www.findernet.com Top terminals 94 Series - Sockets and accessories for 55 series relays Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip 6-way jumper link Identification tag Modules (see table below page) Sheet of marker tags for retaining and release clip 094.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 94.92.3 and 94.94.3 sockets mm2 AWG 94.94.3 Approvals (according to type): 094.91.3 55 SERIES 94.92.3 (blue) 94.92.30 (black) 94.94.3 (blue) 94.94.30 (black) 55.32 55.32, 55.34 094.91.3 094.06 094.71 094.91.30 094.91.3 094.06.0 094.06 094.80.3 99.80 060.72 10 A - 250 V 2 kV AC IP 20 –25…+70 0.5 8 solid wire 1x6 / 2x2.5 1x10 / 2x14 094.91.30 094.06.0 stranded wire 1x4 / 2x2.5 1x12 / 2x14 060.72 Top terminals P A PEAN N T E O O T EUR EUR Bottom terminals 94.94.3 6-way jumper link for 94.84.2, 94.82.3, 94.84.3, 94.92.3 and 94.94.3 sockets 094.06 (blue) Rated values 094.06.0 (black) 10 A - 250 V PEAN 094.06 99.80 II-2014, www.findernet.com Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. 99.80 coil indication and EMC suppression modules for 94.84.2, 94.82.3, 94.84.3, 94.92.3 and 94.94.3 sockets Blue* Diode (+A1, standard polarity) (6...220)V DC 99.80.3.000.00 LED (6...24)V DC/AC 99.80.0.024.59 LED (28...60)V DC/AC 99.80.0.060.59 LED (110...240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.80.9.220.99 LED + Varistor (6...24)V DC/AC 99.80.0.024.98 LED + Varistor (28...60)V DC/AC 99.80.0.060.98 LED + Varistor (110...240)V DC/AC 99.80.0.230.98 RC circuit (6...24)V DC/AC 99.80.0.024.09 RC circuit (28...60)V DC/AC 99.80.0.060.09 RC circuit (110...240)V DC/AC 99.80.0.230.09 Residual current by-pass (110...240)V AC 99.80.8.230.07 11 A 55 SERIES 94 Series - Sockets and accessories for 55 series relays PCB socket 94.14 Approvals (according to type): 94.12.0 94.13 Black Blue 55.33 For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values 10 A - 250 V Dielectric strength 2 kV AC Ambient temperature °C –40…+70 94.13.0 94.14 94.14.0 Black Blue Black 55.32, 55.34 094.51 Copper side view 94.12 Panel mount solder socket 1 mm thick panel 94.22 Approvals (according to type): 94.13 94.22 Blue 55.32 94.14 94.22.0 94.23 Black Blue 55.33 For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values 10 A - 250 V Dielectric strength 2 kV AC Ambient temperature °C –40…+70 94.23.0 94.24 94.24.0 Black Blue Black 55.32, 55.34 094.51 II-2014, www.findernet.com A 94.12 Blue 55.32 12 94 Series - Sockets and accessories for 55 series relays Panel mount socket M3 screw fixing - solder connections 94.34 Approvals (according to type): For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values Dielectric strength Ambient temperature °C 94.32 Blue 55.32 94.32.0 94.33 Black Blue 55.33 55 SERIES 94.33.0 94.34 94.34.0 Black Blue Black 55.32, 55.34 094.51 10 A - 250 V 2 kV AC –40…+70 Packaging codes How to code and identify retaining clip and packaging options for sockets. Example: 9 4 . 0 4 S P A A Standard packaging SM Metal retaining clip SP Plastic retaining clip 4 Without retaining clip II-2014, www.findernet.com 9 4 . 0 13 A
94.54SPA 价格&库存
很抱歉,暂时无法提供与“94.54SPA”相匹配的价格&库存,您可以联系我们找货
94.54SPA
