12.81.8.230.0000
12.81.8.230.0000
    FINDER
    RLY WEEKLY TIMER DPDT 16A 230VAC
12.81.8.230.0000 数据手册
Time switches 16 A Heating and cooling NEON Shop displays 12 SЕRIES Lighting for parks Streetlights and car park lighting School bells FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 12 SERIES Time switches 16 A 12 SERIES 12.01 Mechanical time switches - Daily time setting* - Weekly time setting** 12.11 12.31 Type 12.01 --Daily --1 CO 16 A --35.8 mm wide --35 mm rail mount Type 12.11 --Daily --1 NO 16 A --17.5 mm wide --35 mm rail mount • Mechanical daily time switch • Mechanical daily time switch • 1 CO 16 A • 1 NO 16 A • 35 mm rail (EN 60715) mount • 35 mm rail (EN 60715) mount Type 12.31-0000 --Daily --1 CO 16 A --72 x 72 mm --Front panel mount • Mechanical daily or weekly • 1 CO 16 A • Front panel mounting Type 12.31-0007 --Weekly --1 CO 16 A --72 x 72 mm --Front panel mount • Minimum time interval setting: 1 h (12.31-0007) 30 min (12.01) 15 min (12.11 - 12.31-0000) * Same program every day ** Different program possible for each of the 7 days of the week For outline drawing see page 13 Contact specification Contact configuration Rated current/Maximum peak current  Rated voltage/ Maximum switching voltage  1 CO (SPDT) 1 NO (SPST-NO) 1 CO (SPDT) A 16/— 16/30 16/— V AC 250/— 250/— 250/— Rated load AC1  VA 4000 4000 4000 Rated load AC15 (230 V AC)  VA 750 420 420 I Nominal lamp rating: incandescent (230 V) W 2000 (NO contact) 2000 2000 compensated fluorescent (230 V) W 750 (NO contact) 750 750 uncompensated fluorescent (230 V) W 1000 (NO contact) 1000 1000 halogen (230 V) W 2000 (NO contact) 2000 2000 1000 (10/10) 1000 (10/10) 1000 (10/10) AgSnO2 AgSnO2 AgCdO V AC (50/60 Hz) 230 230 120 - 230 V DC — — — Minimum switching load  mW (V/mA) Standard contact material Supply specification Nominal voltage (UN)  Rated power AC/DC  VA (50 Hz)/W Operating range  AC (50 Hz) DC 2/— 2/— 2/— (0.85…1.1)UN (0.85…1.1)UN (0.85…1.1)UN — — — 50 · 103 50 · 103 daily daily daily weekly 24 (168/week) Technical data Electrical life at rated load in AC1  cycles XI-2017, www.findernet.com Type of time switch Switching intervals /day Minimum switching interval  Accuracy  Ambient temperature range  Protection category 50 · 103 48 96 96 min 30 15 15 s/day 1.5 1.5 1.5 –5…+50 –5…+50 –10…+50 IP 20 IP 20 IP 20 °C 60 Approvals (according to type) 3 12.81 OP EAN N T T E P A EU 12.51 EAN • Digital time switch • 1 CO 16 A EUR Type 12.51 Digital (analogue-style) time switch, daily/weekly programming --Can be programmed in “Classic” mode via the joystick, or “Smart” mode via smartphones with NFC communication --Minimum time interval setting - 30 minutes --Easily configurable for daily or weekly programming Type 12.81 Digital Astro-switch --Can be programmed in “Classic” mode via the joystick, or “Smart” mode via smartphones with NFC communication -- Astro program: calculation of sunrise and sunset times through date, time and location coordinates -- Option for Astro ON period override, by timeswitch --Location coordinates easily settable for most European countries through post codes --Offset function: allows programming of switching times offset from the astronomic time (by up to 90 min, in 10 min steps) • Summer/Winter European, Australian, Brazilian time • 1 CO 16 A output contact • LCD status indication, set-up and programming • Lock with a 4-digit PIN • Back-light display • Internal battery for set-up and programming without supply, easily replaceable from the front • Protective separation between supply and contacts • 35 mm wide • 35 mm rail (EN 60715) mount • Cadmium free contact material R 12 SERIES Time/Astro-Switch 16 A OP 12 SERIES • Digital Astro-switch • 1 CO 16 A I Contact specification Contact configuration Rated current/Maximum peak current  A Rated voltage/ Maximum switching voltage  V AC Rated load AC1  VA Rated load AC15 (230 V AC)  VA Nominal lamp rating: 230 V incandescent/halogen W fluorescent tubes with electronic ballast W fluorescent tubes with electromechanical ballast W  CFL W  230 V LED W LV halogen or LED with electronic ballast W LV halogen or LED with electromechanical ballast W Minimum switching load  mW (V/mA) Standard contact material Supply specification Nominal voltage (UN)  V AC (50/60 Hz) V DC Rated power AC/DC  VA (50 Hz)/W Operating range  V AC (50 Hz) V DC Technical data Electrical life at rated load in AC1  cycles Switching intervals Minimum switching interval  min Accuracy  s/day Ambient temperature range  Protection category Approvals (according to type) 4 °C 1 CO (SPDT) 16/30 (120 A - 5 ms) 1 CO (SPDT) 16/30 (120 A - 5 ms) 250/400 4000 750 250/400 4000 750 2000 2000 1000 1000 750 400 400 750 400 400 400 400 800 1000 (10/10) AgSnO2 800 1000 (10/10) AgSnO2 110…230 110…230 2.8/0.9 88…264 88…264 110…230 110…230 2.8/0.9 88…264 88…264 100 · 103 48 30 1 –20…+50 (see page 9, diagram L12) IP 20 100 · 103 — — 1 –20…+50 (see page 9, diagram L12) IP 20 XI-2017, www.findernet.com For outline drawing see page 13 12 SERIES Time switches 16 A 12 SERIES 12.61 12.62 • Weekly programming • 1 CO 16 A • Switch ON, Switch OFF, Pulse • Weekly programming • 2 CO 16 A • Switch ON, Switch OFF, Pulse Digital time switch, weekly programming --Can be programmed in “Classic” mode via the joystick, or “Smart” mode via smartphones with NFC communication Type 12.61 --1 CO 16 A Type 12.62 --2 CO 16 A • Functions: Switch ON, Switch OFF Pulse: 1s…59 min • Minimum time interval setting - 1 minute • Summer/Winter European, Australian, Brazilian time • LCD status indication, set-up and programming • Lock with a 4-digit PIN • Back-light display • Internal battery for set-up and programming without supply, easily replaceable from the front • Protective separation between supply and contacts • 35 mm wide • 35 mm rail (EN 60715) mount • Cadmium free contact material For outline drawing see page 14 Contact specification Contact configuration Rated current/Maximum peak current  Rated voltage/ Maximum switching voltage  A 1 CO (SPDT) 2 CO (DPDT) 16/30 (120 A - 5 ms) 16/30 (120 A - 5 ms) 250/400 250/400 Rated load AC1  V AC VA 4000 4000 Rated load AC15 (230 V AC)  VA 750 750 230 V incandescent/halogen W 2000 2000 1000 1000 750 750 Nominal lamp rating: fluorescent tubes with electronic ballast W fluorescent tubes with electromechanical ballast W  CFL W 400 400  230 V LED W 400 400 400 400 LV halogen or LED with electronic ballast W LV halogen or LED with electromechanical ballast W Minimum switching load  mW (V/mA) 800 800 1000 (10/10) 1000 (10/10) AgSnO2 AgSnO2 Standard contact material I Supply specification Nominal voltage (UN)  V AC (50/60 Hz) 12…24 110…230 110…230 V DC 12…24 110…230 110…230 Rated power AC/DC  VA (50 Hz)/W Operating range  V AC (50 Hz) 10…30 2.8/0.9 88…253 88…253 2.8/0.9 V DC 10…30 88…253 88…253 Technical data Electrical life at rated load in AC1  100 · 103 100 · 103 Weekly Weekly 50 50 min 1 1 s/day 1 1 –20…+50 (see page 9, diagram L12) –20…+50 (see page 9, diagram L12) IP 20 IP 20 cycles Type of time switch XI-2017, www.findernet.com Memory locations for switching times  Minimum internal setting  Accuracy  Ambient temperature range  Protection category °C Approvals (according to type) 5 12 SERIES 12 SERIES Time/Astro-Switch 16 A Weekly Astro time switch --Can be programmed in “Classic” mode via the joystick, or “Smart” mode via smartphones with NFC communication --"Astro" program: calculation of sunrise and sunset times through date, time and location coordinates Type 12.A1 --1 CO 16 A Type 12.A2 --2 CO 16 A • Functions: "Astro" ON, "Astro" OFF Switch ON, Switch OFF Pulse: 1s…59 min • Location coordinates easily settable for most European countries through Post codes • Offest function: allows programming of switching times offset from the astronomic time (by up to 90 min, in 1 min step) • Minimum time interval setting - 1 minute • Summer/Winter European, Australian, Brazilian time • LCD status indication, set-up and programming • Lock with a 4-digit PIN • Back-light display • Internal battery for set-up and programming without supply, easily replaceable from the front • Protective separation between supply and contacts • 35 mm wide • 35 mm rail (EN 60715) mount • Cadmium free contact material 12.A1 12.A2 • Weekly programming • 1 CO 16 A • Switch ON, Switch OFF, Pulse • Weekly programming • 2 CO 16 A • Switch ON, Switch OFF, Pulse For outline drawing see page 14 Contact specification Contact configuration 1 CO (SPDT) 2 CO (DPDT) 16/30 (120 A - 5 ms) 16/30 (120 A - 5 ms) 250/400 4000 250/400 4000 VA 750 750 230 V incandescent/halogen W fluorescent tubes with electronic ballast W fluorescent tubes with electromechanical ballast W CFL W 2000 2000 1000 1000 750 400 750 400 230 V LED W LV halogen or LED with electronic ballast W LV halogen or LED with electromechanical ballast W Minimum switching load  mW (V/mA) 400 400 400 400 800 1000 (10/10) 800 1000 (10/10) AgSnO2 AgSnO2 Rated current/Maximum peak current  Rated voltage/ Maximum switching voltage  Rated load AC1  Rated load AC15 (230 V AC)  A V AC VA Nominal lamp rating: I   Standard contact material Supply specification Nominal voltage (UN)  V AC (50/60 Hz) 110…230 12…24 110…230 V DC 110…230 12…24 110…230 Rated power AC/DC  VA (50 Hz)/W 2.8/0.9 Operating range  V AC (50 Hz) 88…253 10…30 2.8/0.9 88…253 V DC 88…253 10…30 88…253 cycles 100 · 103 100 · 103 Weekly Weekly 50 50 1 1 1 –20…+50 (see page 9, diagram L12) IP 20 1 –20…+50 (see page 9, diagram L12) IP 20 Electrical life at rated load in AC1  Type of time switch Memory locations for switching times  Minimum internal setting  Accuracy  Ambient temperature range  Protection category Approvals (according to type) 6 min s/day °C XI-2017, www.findernet.com Technical data 12 SERIES Time switches 16 A 12 SERIES 12.71 Electronic digital time switches --1 Weekly time setting Type 12.71 --1 CO 16 A --17.8 mm wide • Minimum time interval setting - 1 minute • Internal battery for set-up without supply • Pulse output function: 1 s… 59:59(mm:ss) • Automatic adjustment for daylight saving • 35 mm rail (EN 60715) mount • Digital weekly time switch • 1 CO 16 A • 17.8 mm wide For outline drawing see page 13 Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current  Rated voltage/ Maximum switching voltage  A 16/30 V AC 250/— Rated load AC1  VA 4000 Rated load AC15 (230 V AC)  VA 420 230 V incandescent/halogen W 400 Nominal lamp rating: fluorescent tubes with electronic ballast W fluorescent tubes with electromechanical ballast W 100 100  CFL W 50  230 V LED W 50 LV halogen or LED with electronic ballast W LV halogen or LED with electromechanical ballast W Minimum switching load  I 50 100 mW (V/mA) 1000 (10/10) Standard contact material AgNi Supply specification Nominal voltage (UN)  Rated power AC/DC  V AC (50/60 Hz) — 230 V AC/DC 24 — VA (50 Hz)/W 1.4/1.4 2/— AC (50 Hz) (0.9…1.1)UN (0.85…1.1)UN DC (0.9…1.1)UN — Operating range  Technical data Electrical life at rated load in AC1  cycles Type of time switch weekly XI-2017, www.findernet.com Memory locations for switching times* Minimum switching interval  Accuracy  Ambient temperature range  Protection category 50 · 103 30 min s/day °C 1 0.5 –30…+55 IP 20 Approvals (according to type) * Switching times in memory may be used more than once i.e. when selected for different days. 7 12 SERIES 12 SERIES Time switches 16 A Ordering information Example: 12 series digital (analogue style) time switch, 1 CO 16 A contact, (110…230)V AC/DC supply 1 2 . 5 Series Type 0 = Daily, 35.8 mm wide 1 = Daily, 17.5 mm wide 3 = Daily or Weekly, 72 x 72 mm 5 = Digital (analogue style), NFC programming, 35 mm wide 6 = Weekly, NFC programming, 35 mm wide 7 = Weekly, 17.5 mm wide 8 = Astro-switch, NFC programming, 35 mm wide A = Weekly “Astro”, NFC programming, 35 mm wide No. of poles 1 = 1 CO (SPDT), 16 A 1 = 1 NO (SPST), 16 A 2 = 2 CO (DPDT), 16 A 1 . 8 . 2 3 0 . 0 0 0 0 Option 0 = With power back-up 1 = Without power back-up (type 12.11) Option 0 = Standard 0 = Daily only for 12.31 7 = Weekly only for 12.31 Supply voltage 024 = 24 V AC/DC (type 12.71) 024 = 12…24 V AC/DC (types 12.61, 12.A2) 120 = 120 V AC 230 = 230 V AC 230 = (110…230)V AC/DC (types 12.51, 12.61, 12.62, 12.81, 12.A1, 12.A2) Special version 0 = Standard Supply version 0 = AC (50/60 Hz)/DC (types 12.61.0.024, 12.A2.0.024, 12.71.0.024) 8 = AC (50/60 Hz) 8 = AC (50/60 Hz)/DC (types 12.51, 12.81, 12.61, 12.62, 12.A1, 12.A2) Codes 12.01.8.230.0000 12.11.8.230.0000 12.11.8.230.1000 12.31.8.230.0000 12.31.8.230.0007 12.51.8.230.0000 12.71.0.024.0000 12.71.8.230.0000 12.81.8.230.0000 12.61.0.024.0000 12.61.8.230.0000 12.62.8.230.0000 12.A1.8.230.0000 12.A2.0.024.0000 12.A2.8.230.0000 XI-2017, www.findernet.com I 8 12 SERIES Time switches 16 A 12 SERIES Technical data Insulation 12.51, 12.61, 12.62, 12.81, 12.A1, 12.A2 Dielectric strength between supply and contacts  Dielectric strength between open contacts  12.01, 12.11, 12.31, 12.71 V AC 4000 4000 V AC 1000 1000 Rated impulse voltage (between supply and contacts)  kV/(1.2/50)μs 6 6 Rated impulse voltage (between open contacts)  kV/(1.2/50)μs 1.5 1.5 EMC specifications Type of test Electrostatic discharge Reference standard  contact discharge EN 61000-4-2 4 kV 6 kV  air discharge EN 61000-4-2 8 kV 8 kV Radiated electromagnetic field (80…1000 MHz) EN 61000-4-3 10 V/m 10 V/m Fast transients (burst 5/50 ns, 5 and 100 kHz) Voltage pulses on supply terminals (surge 1.2/50 μs) EN 61000-4-4 4 kV 4 kV  common mode EN 61000-4-5 4 kV 2 kV  differential mode EN 61000-4-5 4 kV 2 kV Radiofrequency common mode voltage (0.15…80 MHz) Voltage dips  Short interruptions EN 61000-4-11 10 V 10 V 10 cycles 10 cycles 10 cycles 10 cycles 0.15…30 MHz EN 55014 class B class B 30…1000 MHz EN 55014 class B class B Radio frequency conducted emissions  Radiated emissions  EN 61000-4-6 70% UN , 40% UN EN 61000-4-11 Terminals Screw torque  Nm 0.8 mm2 Max. wire size   Wire strip length  solid cable 1 x 6 / 2 x 4 stranded cable 1 x 4 / 2 x 2.5 1.2 AWG mm2 AWG 1 x 10 / 2 x 12 1 x 6 / 2 x 4 1 x 10 / 2 x 12 1 x 12 / 2 x 14 1 x 6 / 2 x 2.5 1 x 10 / 2 x 14 mm 9 Other data Power back-up (Battery life) 6 years (12.51, 12.61, 12.62, 12.81, 12.A1, 12.A2, 12.71) Battery type CR 2032, 3 V, 230 mAh (12.51, 12.61, 12.62, 12.81, 12.A1, 12.A2) Power back-up 100 h (12.01, 12.11, 12.31 - following 80 h continuous energisation) Power lost to the environment 12.51, 12.61, 12.81, 12.A1 12.62, 12.A2 12.01, 12.11, 12.31 12.71  in stand-by W 0.2 0.2 — —  without contact current W 0.9 0.9 1.5 2  with rated current W 1.5 2.1 2.5 3 (for 1 pole) I L 12 - Rated current v ambient temperature 1 pole XI-2017, www.findernet.com 2 pole 9 12 SERIES 12 SERIES Time switches 16 A Wiring diagrams L L N N Type 12.11 Selector switch: = Permanently OFF = Automatic I = Permanently ON Type 12.01 Selector switch: = Permanently OFF AUTO = Automatic I = Permanently ON L L N N Type 12.71 I Type 12.31 L Type 12.51 12.81 10 XI-2017, www.findernet.com N 12 SERIES Time switches 16 A 12 SERIES Wiring diagrams L/+ L/+ N/– N/– Type 12.61 12.A1 Type 12.62 12.A2 XI-2017, www.findernet.com I 11 12 SERIES 12 SERIES Time switches 16 A Two programming modes for type 12.51, 12.61, 12.62, 12.81, 12.A1, 12.A2 “Smart” “Classic” Mode via smartphones with NFC communication using Finder toolbox Android App. Mode via the joystick Android, Google Play and the Google Play logo are trademarks of Google Inc. Finder Toolbox for programming Once the App FINDER Toolbox is downloaded and installed, you can read an existing program, or program your device with maximum flexibility, changing the smallest details and saving your program directly to your smartphone. At this point you simply touch the time switch with the smartphone to transfer the data. Finder Toolbox for reference Finder Toolbox provides all technical data sheets and news from Finder. Functions type 12.81 The Override feature permits the 12.81 three different ways of functioning: ASTRO ON I ASTRO OFF 1 Classic function where the AstroON and AstroOFF times are determined by the geographic coordinates. These times vary every day. 2 Functions such that the output turns on according to the AstroON time and turns off according to the clock off-time by AstroON at sunset and off 3 1 2 Functions such that the output turns on according to the AstroON time and turns off a ccording to the clock off-time , and then turns back on at the clock on-time (for the remainder of the ASTRO time period). Application example: company car park lighting, on by AstroON at sunset, off end of the evening shift at 23:00 On again at the beginning of the morning shift at 5:00 AstroOFF*. . and off automatically by * Depending on the time of year (summer specifically) it may be that the override ON time will fall after the AstroOFF time. In this case, the output switches off at the AstroOFF time and the override ON time is ignored. XI-2017, www.findernet.com 3 . Application example: shop window lighting on at 00:30 . 12 12 SERIES Time switches 16 A 12 SERIES Outline drawings 12.01 Screw terminal 12.11 Screw terminal 12.31 Screw terminal 12.51/12.81 Screw terminal I XI-2017, www.findernet.com 12.71 Screw terminal 13 12 SERIES 12 SERIES Time switches 16 A Outline drawings 12.61 / 12.A1 Screw terminal 12.62 / 12.A2 Screw terminal Battery replacement type 12.51, 12.61, 12.62, 12.81, 12.A1, 12.A2 Power-save mode If the 230 V AC supply is not connected, the time switch enters power-save mode: only the clock is maintained active whilst the display turns off so as to guarantee a long life for the built-in back-up battery. With a press to the joystick it is possible to “awake” the device and enter Display mode (with the “plug” symbol will enter the program or set-up mode as explained in the Display mode displayed). A further press to section above. After about 1 minute of inactivity the power-save mode will start again. During program or set-up the current absorption is higher than in power-save mode, thus influencing the battery life. In this mode the display back-light is not active. It is activated following a press to the joystick only with the 230 V AC supply connected, but after about 1 minute of inactivity the display back-light will turn off, and to activate it again it is necessary to press the joystick again. Note: the output relay only functions if the power supply is connected. Accessories type 12.51, 12.61, 12.62, 12.81, 12.A1, 12.A2 Adaptor for panel mounting, 35 mm wide 011.01 XI-2017, www.findernet.com I 011.01 14 Please see general technical information
12.81.8.230.0000 价格&库存
很抱歉,暂时无法提供与“12.81.8.230.0000”相匹配的价格&库存,您可以联系我们找货
  • 1+901.239711+116.46910
  • 10+818.9590710+105.83580
库存:23
