22.34.0.230.4320
22.34.0.230.4320
    FINDER
    MODULAR CONTACTOR, 4PST-NO 25A,
22.34.0.230.4320 数据手册
22.34.0.XXX.xxx0 UN (12 - 24 - 48 - 60 - 120 - 230)V AC (50/60 Hz) / DC Umin - Umax: (0.8...1.1)UN P 2 VA (50 Hz) / 2.2 W 1 ENGLISH 2 22.34 MODULAR CONTACTOR 25 A Contact gap ≥ 3 mm for NO contacts only. NC contacts ≥ 1.5 mm. Compliant with EN 61095: 2009. AC/DC silent coil (with varistor protection). 1 CONNECTION DIAGRAM 22.34...x3x0 22.34...x7x0 2 OUTLINE DRAWINGS 22.34...x6x0 25 A 440 V AC (EN 61095) 22.34 AC1 / AC-7a (250 V AC) 6250 VA AC3 / AC-7b 10 A AC15 (230 V AC) 1800 VA M 3 3 FRONT VIEW A = Selector (22.34.0.xxx.xx40) The three-position manual selector has the following functions: 3 ~ (400 - 440 V AC) 4 kW 10 A (22.34...4xx0) AC - 7c (230 V AC) ON position The contacts are latched in the operated state (NO contacts - closed and NC contacts - open), the mechanical indicator is visible in its window, the LED is not illuminated. 800 W 2000 W (22.34...4xx0) AUTO position The state of contacts, mechanical indicator and LED follow the coil supply voltage. A (230 V AC) 300 W 800 W (22.34...4xx0) CFL - LED 100 W 200 W (22.34...4xx0) B OFF position Even if terminals A1 - A2 are supplied with rated voltage, the coil is not energized, and so the contacts remain in the non-operated state, the mechanical indicator is not visible and the LED is not illuminated. C (–20…+50)°C B = LED IP20 C = Mechanical indicator 4 • Open Type Device - Pollution degree 2 Installation Environment • Maximum Surrounding Air Temperature 50°C • Minimum distance among modular contactors 9 mm • Field Wiring Terminals: Use 60/75°C copper conductor only and wire ranges No. 10-12-18-24 AWG, Solid only Terminal tightening torque 7.0 lb.in. (0.8 Nm) • Suitable for use on a circuit capable of delivering not more than 5000 ARMS Symmetrical, 240 V AC, when protected by Listed Cartridge Fuses, rated K5 Class (No Current Limiting, Non-Time Delay, max 600 V AC, 30 A, 50 kA A.I.C.) or RK5 Class (Current Limiting, Time Delay, max 600 Vac, 15 A, 50 kA A.I.C.) or equivalent. • For use in a circuit protected by Type1 or Type2 Surge Protective Devices with “Max Voltage Protection” rating of 3.7 kVpk and “Minimum Nominal Discharge Current” of 5 kA (at 6 kV). Utility Model - IB2234001 - 09/17 - FINDER S.p.A. - 10040 ALMESE (TO) - ITALY 22.34 + (022.33 / 022.35) 4 ACCESSORIES Auxiliary contact module available, “Quick assembly” with the main contactor 022.33/022.35. 022.33 022.35 022.33 2 NO (DPST-NO) 022.35 1 NO (SPST-NO) + 1NC (SPST-NC) AC1 AC15(230 V AC) 6A 700 VA OTHER DATA It is suggested an air gap of 9 mm between adjacent relays for installations and working conditions close to the limit (that is, ambient temperature > 40 °C, coil operated for a prolonged period of time, all contacts loaded with current > 20 A).
22.34.0.230.4320 价格&库存
很抱歉,暂时无法提供与“22.34.0.230.4320”相匹配的价格&库存,您可以联系我们找货
  • 1+428.577021+55.48300
库存:7
