43.41.7.006.2000
43.41.7.006.2000
    FINDER
43.41.7.006.2000 数据手册
43 SЕRIES Low profile PCB relays 10 - 16 A Medical and dentistry Alarm systems Air conditioners Burners, boilers and furnaces Electric and electronic toys and games Door and gate openers Electronic circuit boards Vending machines FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 43 SERIES Low profile PCB relays 10 - 16 A 43 SERIES 43.41 1 Pole - Low profile (15.4 mm height) Type 43.41 - 1 Pole, 10 A (3.2 mm pin pitch) Type 43.41-0300 - 1 Pole NO, 10 A (5 mm pin pitch) Type 43.61-0300 - 1 Pole NO, 16 A (5 mm pin pitch) 43.41-0300 43.61-0300 A PCB mount - direct or via PCB socket (43.41 version) • Sensitive DC coil: - 250 mW (10 A version) - 400 mW (16 A version) • Very high coil-contact isolation 10 mm, 6 kV (1.2/50 µs) • Cadmium Free contacts (preferred version) • Flux proof: RT II standard, (RT III option) • 3.2 mm contact pin pitch • 1 Pole CO, 10 A • PCB direct or via socket • 5.0 mm contact pin pitch • 1 Pole NO, 10 A • PCB mount • 5.0 mm contact pin pitch • 1 Pole NO, 16 A • PCB mount For UL ratings see: “General technical information” page V For outline drawing see page 5 Copper side view Copper side view Copper side view 1 CO (SPDT) 1 NO (SPST-NO) 1 NO (SPST-NO) 10/15 10/15 16/25 250/400 250/400 250/400 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC Rated load AC1 VA 2500 2500 4000 Rated load AC15 (230 V AC) VA 500 500 750 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Standard contact material — — — 10/0.3/0.12 10/0.3/0.12 16/0.3/0.12 300 (5/5) 300 (5/5) 300 (5/5) AgNi AgNi AgNi — — — 3 - 6 - 9 - 12 - 18 - 24 - 36 - 48 3 - 6 - 9 - 12 - 18 - 24 - 36 - 48 12 - 24 - 48 —/0.25 —/0.25 —/0.4 Coil specification Nominal voltage (UN) V AC (50/60 Hz) Rated power AC/DC VA (50 Hz)/W V DC Operating range AC — — — DC (0.7…1.5)UN (0.7…1.5)UN (0.7…1.2)UN Holding voltage AC/DC —/0.4 UN —/0.4 UN —/0.4 UN Must drop-out voltage AC/DC —/0.05 UN —/0.05 UN —/0.05 UN Mechanical life AC/DC cycles —/10 · 106 —/10 · 106 —/10 · 106 Electrical life at rated load AC1 cycles 100 · 103 100 · 103 50 · 103 ms 6/4 6/2 6/2 kV 6 (10 mm) 6 (10 mm) 6 (10 mm) 1000 1000 1000 –40…+85 –40…+85 –40…+85 RT II RT II RT II Technical data IX-2018, www.findernet.com Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Environmental protection V AC °C Approvals (according to type) 3 43 SERIES Low profile PCB relays 10 - 16 A 43 SERIES Ordering information Example: 43 series low-profile PCB relay, 1 CO (SPDT), 24 V DC coil. A 4 3 . 4 A B C 1 . 7 . 0 2 4 . 2 0 0 . 0 Series A: Contact material 0 = AgNi 2 = AgCdO 4 = AgSnO2 5=A  gNi + Au Type 4 = PCB - 3.2 mm pinning (CO/SPDT, 10 A) PCB - 5 mm pinning (NO/SPST-NO, 10 A) 6 = PCB - 5 mm pinning (NO/SPST-NO, 16 A) D D: Special versions 0 = Flux proof (RT II) 1 = Wash tight (RT III) C: Options 0 = None B: Contact circuit 0=C  O (SPDT) - (for 43.41 only) 3=N  O (SPST) No. of poles 1 = 1 pole Coil version 7 = Sensitive DC (only for 43.41) 9 = DC (only for 43.61) Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Coil voltage See coil specifications Type Coil version A B C D 43.41 sensitive DC 43.61 DC 0-2-4-5 0-3 0 0-1 0-2-4 3 0 0 Technical data Insulation according to EN 61810-1 Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 250 Pollution degree 3 400 2 Insulation between coil and contact set Type of insulation Reinforced (10 mm) Overvoltage category III Rated impulse voltage kV (1.2/50 µs) 6 Dielectric strength V AC 4000 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50 µs) 1000/1.5 Insulation between coil terminals Rated impulse voltage (surge) differential mode (according to EN 61000-4-5) kV(1.2/50 µs) 2 Other data Bounce time: NO/NC ms 3/6 Vibration resistance (5…55)Hz: NO/NC g 15/3 Shock resistance g 15 Power lost to the environment without contact current W 0.25 (43.41) with rated currentW 1.3 (43.41) 2 (43.61) mm ≥ 5 IX-2018, www.findernet.com Recommended distance between relays mounted on PCB  0.4 (43.61) 4 43 SERIES Low profile PCB relays 10 - 16 A 43 SERIES Contact specification H 43 - Maximum DC1 breaking capacity DC breaking current (A) F 43 - Electrical life (AC) v contact current Cycles Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 A 43.61 current limit 43.41 current limit limit for 43.41 DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100 · 103 for 43.41 and ≥ 50 · 103 for 43.61 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. Coil specifications DC coil data - 0.25 W sensitive (type 43.41) Nominal voltage Coil code Umin UN V R 43 - DC coil operating range v ambient temperature Resistance Rated coil consumption Umax R I at UN Ω Operating range V V 3 7.003 2.2 4.5 6 7.006 4.2 9 150 40 9 7.009 6.5 13.5 324 27.7 12 7.012 8.4 18 580 20.7 18 7.018 13 27 1300 13.8 24 7.024 16.8 36 2200 10.9 36 7.036 25.2 54 5200 6.9 48 7.048 33.6 72 9200 5.2 36 mA 83.5 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. DC coil data - 0.4 W standard (type 43.61) Nominal voltage Coil code Operating range Resistance Rated coil consumption I at UN UN Umin Umax R V V V Ω mA 12 9.012 8.4 14.4 360 33.3 24 9.024 16.8 28.8 1400 17.1 48 9.048 33.6 57.6 5760 8.3 Outline drawings Types 43.41-0300/43.61-0300 IX-2018, www.findernet.com Type 43.41 5 43 SERIES A 95 SERIES Sockets and accessories for 43 series relays 95.23 Approvals (according to type): PCB socket (for changeover contacts only) For relay type Accessories Metal retaining clip (supplied with socket - packaging code SNA) Technical data Rated values Insulation Protection category Ambient temperature 95.23 (blue) 43.41 95.23.0 (black) 43.41 095.43 10 A - 250 V 6 kV (1.2/50 µs) between coil and contacts IP 20 °C –40…+70 43.41 Copper side view Packaging codes How to code and identify retaining clip and packaging options for sockets. Example: 9 5 . 2 3 S N A A Standard packaging 9 5 . 2 6 3 IX-2018, www.findernet.com SN Metal retaining clip Without retaining clip Please see general technical information
43.41.7.006.2000 价格&库存
很抱歉,暂时无法提供与“43.41.7.006.2000”相匹配的价格&库存,您可以联系我们找货
