48.61.8.024.0060SPA
48.61.8.024.0060SPA
    FINDER
    Module
    RLY INTERFACE SPDT 16A 24VAC
48.61.8.024.0060SPA 数据手册
48 Series - Relay interface modules 8 A Features 48.12 2 Pole Safety relay interface modules, 15.8 mm wide 48.12 - 2 Pole 8 A (screw terminal) DC sensitive coils Relay with forcibly guided contacts according to EN 50205 Type B • 35 mm rail (EN 60715) mounting • • 48.12 Screw terminal 2 pole, 8 A Safety relay • Screw terminal • 35 mm rail (EN 60715) mounting • • According to EN 50205 only 1 NO and 1 NC (11-14 and 21-22 or 11-12 and 21-24) shall be used as forcibly guided contacts. For outline drawing see page 7 Contact specification 2 CO (DPDT) Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 8/15 250/400 Rated load AC1 VA 2,000 Rated load AC15 (230 V AC) VA 500 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) 0.37 8/0.65/0.2 300 (5/5) AgNi Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) Rated power AC/sens. DC — V DC 12 - 24 VA (50 Hz)/W —/0.7 Operating range AC — sens. DC (0.75…1.2)UN Holding voltage AC/DC — /0.4 UN Must drop-out voltage AC/DC — /0.1 UN Mechanical life AC/DC cycles —/10 · 106 Electrical life at rated load AC1 cycles 100 · 103 Technical data Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Protection category V AC °C 10/4 6 (8 mm) 1,500 –40…+70 IP 20 Approvals relay (according to type) 1 48 Series - Relay interface modules 8 - 10 - 16 A Features 48.31 48.52/72 1 & 2 Pole relay interface modules, 15.8 mm wide Ideal interface for PLC and electronic systems 48.31 - 1 Pole 10 A (screw terminal) 48.52 - 2 Pole 8 A (screw terminal) 48.72 - 2 Pole 8 A (screwless terminal) AC coils or DC sensitive coils Instant ejection of relay using plastic retaining clip • Supply status indication and EMC coil suppression module as standard • Identification label • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • • 48.31 / 48.52 Screw terminal 1 pole, 10 A Screw terminal • 35 mm rail (EN 60715) mounting 2 pole, 8 A Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting • • • • 48.72 Screwless terminal For outline drawing see page 7 Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 2 CO (DPDT) 10/20 8/15 250/400 250/250 Rated load AC1 VA 2,500 2,000 Rated load AC15 (230 V AC) VA 500 400 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material 0.37 0.3 10/0.3/0.12 8/0.3/0.12 300 (5/5) 300 (5/5) AgNi AgNi 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 12 - 24 - 125 12 - 24 - 125 Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/sens. DC VA (50 Hz)/W Operating range AC 1.2/0.5 1.2/0.5 (0.8…1.1)UN (0.8…1.1)UN sens. DC (0.73…1.75)UN (0.73…1.75)UN Holding voltage AC/DC 0.8 UN /0.4 UN 0.8 UN /0.4 UN Must drop-out voltage AC/DC 0.2 UN /0.1 UN Mechanical life AC/DC cycles 10 · 106/20 · 106 10 · 106/20 · 106 Electrical life at rated load AC1 cycles 200 · 103 100 · 103 7/4 (AC) - 12/12 (DC) 7/4 (AC) - 12/12 (DC) 6 (8 mm) 6 (8 mm) 1,000 1,000 –40…+70 –40…+70 IP 20 IP 20 0.2 UN /0.1 UN Technical data Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Protection category Approvals relay (according to type) 2 V AC °C 48 Series - Relay interface modules 8 - 10 - 16 A Features 48.62/82 48.61/81 1 & 2 Pole relay interface modules, 15.8 mm wide Ideal interface for PLC and electronic systems 48.61 - 1 Pole 16 A (screw terminal) 48.81 - 1 Pole 16 A (screwless terminal) 48.62 - 2 Pole 10 A (screw terminal) 48.82 - 2 Pole 10 A (screwless terminal) AC coils or DC sensitive coils Instant ejection of relay using plastic retaining clip • Supply status indication and EMC coil suppression module as standard • Identification label • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • • 48.61 / 48.62 Screw terminal 1 pole, 16 A Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting 2 pole, 10 A Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting • • • • 48.81 / 48.82 Screwless terminal * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). For outline drawing see page 7 Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 2 CO (DPDT) 16*/30 10/20 250/400 250/400 Rated load AC1 VA 4,000 2,500 Rated load AC15 (230 V AC) VA 750 500 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material 0.55 0.37 16/0.3/0.12 10/0.3/0.12 500 (10/5) 300 (5/5) AgCdO AgNi 12 - 24 - 110 - 120 - 230 — 12 - 24 - 125 12 - 24 - 125 Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/sens. DC VA (50 Hz)/W Operating range AC 1.2/0.5 —/0.5 (0.8…1.1)UN — sens. DC (0.8…1.5)UN (0.8…1.5)UN Holding voltage AC/DC 0.8 UN /0.4 UN —/0.4 UN Must drop-out voltage AC/DC 0.2 UN /0.1 UN —/0.1 UN Technical data Mechanical life AC/DC cycles 10 · 106/20 · 106 —/20 · 106 Electrical life at rated load AC1 cycles 100 · 103 100 · 103 7/4 (AC) - 12/12 (DC) 12/12 (DC) 6 (8 mm) 6 (8 mm) Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Protection category V AC °C 1,000 1,000 –40…+70 –40…+70 IP 20 IP 20 Approvals relay (according to type) 3 48 Series - Relay interface modules 8 - 10 - 16 A Ordering information Example: 48 series, 35 mm rail (EN 60715) mount, screw terminal relay interface module, 2 CO (DPDT) 8 A contacts, 24 V sensitive DC coil, green LED + diode, 99.02 coil indication. 4 8 . 5 A B C D 2 . 7 . 0 2 4 . 0 0 5 0 A: Contact material 0 = Standard AgNi for 48.31/52/62/72/82 AgCdO, Standard for 48.61/81 1= AgNi, for 48.12 4 = AgSnO2, for 48.61/ 62/81/82 only 5 = AgNi + Au (5 µm), for 48.31/52/72 only Series Type Screw terminal 1 = 35 mm rail (EN safety relay 3 = 35 mm rail (EN 5 = 35 mm rail (EN 6 = 35 mm rail (EN Screwless terminal 7 = 35 mm rail (EN 8 = 35 mm rail (EN 60715) mount, 60715) mount 60715) mount 60715) mount 60715) mount 60715) mount No. of poles 1 = 1 pole for 48.31, 10 A 48.61,48.81, 16 A 2 = 2 pole for 48.12, 48.52, 48.72, 8 A 48.62, 48.82, 10 A (48.62, 48.82 DC only) Coil version 7 = Sensitive DC 8 = AC (50/60 Hz) D: Special versions 0 = Standard 2 = Standard (for 48.12 only) C: Options 0 = Standard (for 48.12 only) 5 = Standard for DC: green LED + diode (polarity +A1) 6 = Standard for AC: green LED + Varistor B: Contact circuit 0 = CO (nPDT) Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type 48.12 48.31/52/72 48.31/52/72 48.61/81 48.61/81 48.62/82 Coil voltage See coil specifications Coil version DC AC DC AC DC DC A 1 0 0 0 0 0 -2-5 -2-5 -4 -4 -4 B 0 0 0 0 0 0 C 0 6 5 6 5 5 D 2 0 0 0 0 0 Technical data Insulation Insulation according to EN 61810-1 48.12/31/61/62 48.52 insulation rated voltage rated impulse withstand voltage V 250 kV 4 48.12/31/61/62 250 400 4 4 pollution degree 3 2 2 overvoltage category III III III Insulation between coil and contacts (1.2/50 µs) kV 6 (8 mm) Dielectric strength between open contacts V AC 1,000; 1,500 (48.12) Dielectric strength between adjacent contacts V AC 2,000 (48.52); 2,500 (48.12/62) Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 µs) on A1 - A2 (differential mode) EN 61000-4-5 level 3 (2 kV) Other data Bounce time: NO/NC ms 2/5; 2/10 (48.12) Vibration resistance (5…55)Hz: NO/NC Power lost to the environment without contact current with rated current Wire strip length Screw torque Max. wire size g 10/4 (for 1 pole) W 1.2 (48.12/31) 1.3 (48.52/72) 1.2 (48.61/62/81/82) mm 8 Nm 0.5 Screw terminal solid cable 4 15/3; 20/6 (48.12) for 2 pole W 0.7 Screwless terminal stranded cable solid cable stranded cable mm2 1x6 / 2x2.5 1x4 / 2x2.5 2x(0.2...1.5) 2x(0.2...1.5) AWG 1x10 / 2x14 1x12 / 2x14 2x(24...18) 2x(24...18) 48 Series - Relay interface modules 8 - 10 - 16 A Contact specification F 48 - Electrical life (AC) v contact current Types 48.62/82 Resistive load - cosϕ = 1 Inductive load- cosϕ = 0.4 Cycles Cycles F 48 - Electrical life (AC) v contact current Types 48.31/61/81 Resistive load - cosϕ = 1 Inductive load- cosϕ = 0.4 limit for 48.31 DC breaking current (A) H 48 - Maximum DC1 breaking capacity Types 48.31/52/61/72/81 48.61/81 current limit 48.31 current limit 48.52/72 current limit 2 contacts in series single contact DC voltage (V) Resistive load - cosϕ = 1 Inductive load- cosϕ = 0.4 Cycles Resistive load - cosϕ = 1 Inductive load- cosϕ = 0.4 F 48 - Electrical life (AC) v contact current Type 48.12 H 48 - Maximum DC1 breaking capacity Types 48.62/82 DC breaking current (A) Cycles F 48 - Electrical life (AC) v contact current Types 48.52/72 2 contacts in series single contact DC voltage (V) DC breaking current (A) H 48 - Maximum DC1 breaking capacity Type 48.12 DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. 5 48 Series - Relay interface modules 8 - 10 - 16 A Coil specifications AC coil data DC coil data (0.5 W sensitive) Nominal voltage UN V 12 24 125 Coil code Operating range Umin* V 8.8 17.5 91 7.012 7.024 7.125 Rated coil consumption I at UN mA 41 22.2 4 Umax** V 21 42 219 *Umin = 0.8 UN for 48.61, 48.62, 48.81 and 48.82 **Umax = 1.5 UN for 48.61, 48.62, 48.81 and 48.82 Nominal voltage UN V 12 24 110 120 230 Coil code 8.012 8.024 8.110 8.120 8.230 Operating range Umin V 9.6 19.2 88 96 184 Umax V 13.2 26.4 121 132 253 DC coil data, 2 pole relay - Type 48.12 Nominal voltage UN V 12 24 Coil code 9.012 9.024 Operating range Umin V 9 18 Umax V 14.4 28.8 Resistance Rated coil consumption R I at UN Ω mA 205 58.5 820 29.3 R 48 - DC coil operating range v ambient temperature R 48 - AC coil operating range v ambient temperature 48.31/52/72 48.61/62/81/82 1 48.61/62/81/82 2 48.31/52/72 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. R 48 - DC coil operating range v ambient temperature Type 48.12 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 6 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. Rated coil consumption I at UN (50Hz) mA 90.5 46 10.1 11.8 7.0 48 Series - Relay interface modules 8 - 10 - 16 A Combinations Code Type of socket Type of relay Module Retaining clip 48.12 95.05.0 50.12 — 095.71 48.31 95.03 40.31 99.02 095.01 48.52 95.05 40.52 99.02 095.01 48.61 95.05 40.61 99.02 095.01 48.62 95.05 44.62 99.02 095.01 48.72 95.55 40.52 99.02 095.91.3 48.81 95.55 40.61 99.02 095.91.3 48.82 95.55 44.62 99.02 095.91.3 Outline drawing 73.7 24.6 75.3 4 4 60.9 17.5 17.5 21 COM 11 24 NO 14 22 NC 12 30.3 78.6 95.6 34.7 30.6 25.9 A2 COIL A1 15.8 32 15.8 15.8 22.6 32.5 48.31 48.52 / 48.61 / 48.62 Screw terminal 48.72 / 48.81 / 48.82 Screwless terminal 64.5 25.9 17.5 17.5 35.4 25.5 78.6 21.6 15.8 32 48.12 Screw terminal 7 48 Series - Relay interface modules 8 - 10 - 16 A Accessories 8-way jumper link for screw terminal version 095.18 (blue) Rated values 10 A - 250 V Sheet of marker tags, plastic, 72 tags, 6x12 mm 060.72 095.18.0 (black) 095.18 060.72 Packaging codes How to code and identify retaining clip and packaging options for sockets. Example: 4 8 . 5 2 . 7 . 0 2 4 . 0 0 5 0 S P A A B Standard packaging Blister packaging SP Plastic retaining clip 8
48.61.8.024.0060SPA 价格&库存
很抱歉,暂时无法提供与“48.61.8.024.0060SPA”相匹配的价格&库存,您可以联系我们找货
48.61.8.024.0060SPA
  • 10+163.2528910+21.09100
