48 Series - Relay interface modules 8 - 10 - 16 A
Features
48.31
48.52
48.61
1 & 2 Pole relay interface modules,
15.8 mm wide.
Ideal interface for PLC and electronic systems
48.31 - 1 Pole 10 A
48.52 - 2 Pole 8 A
48.61 - 1 Pole 16 A
• AC
coils or DC sensitive coils
ejection of relay using plastic
retaining clip
• Supply status indication and EMC coil
suppression module as standard
• Identification label
• UL Listed
• 35 mm rail (EN 50022) mounting
• Instant
1 pole 10 A
35 mm rail mounting
75.3
COM
11
17.5
17.5
2 pole 8 A
35 mm rail mounting
1 pole 16 A
35 mm rail mounting
21
11
COM
21
11
COM
21
11
COM
21
11
COM
24
14
NO
24
14
NO
24
14
NO
24
14
NO
22
12
NC
22
12
NC
22
12
NC
22
12
NC
14 NO
12 NC
12 NC
78.6
25.9
COM
11
14 NO
60.9
A2
A1
A2
A1
AC
15.8
15.8
DC
A2
A1
A2
A1
AC
DC
A2
A1
A2
AC
A1
DC
32
48
48.31 48.52/61
Contact specification
1 CO (SPDT)
Contact configuration
Rated current/Maximum peak current
A
Rated voltage/Maximum switching voltage V AC
2 CO (DPDT)
1 CO (SPDT)
10/20
8/15
16/30
250/400
250/250
250/400
Rated load AC1
VA
2,500
2,000
4,000
Rated load AC15 (230 V AC)
VA
500
400
750
Single phase motor rating (230 V AC)
kW
Breaking capacity DC1: 30/110/220V
Minimum switching load
A
mW (V/mA)
Standard contact material
0.37
0.3
0.55
10/0.3/0.12
8/0.3/0.12
16/0.3/0.12
300 (5/5)
300 (5/5)
500 (10/5)
AgNi
AgNi
AgCdO
12 - 24 - 110 - 120 - 230
12 - 24 - 125
12 - 24 - 125
12 - 24 - 125
Coil specification
Nominal voltage (UN)
V AC (50/60 Hz)
V DC
Rated power AC/sens. DC
VA (50 Hz)/W
Operating range
AC
1.2/0.5
1.2/0.5
1.2/0.5
(0.8…1.1)UN
(0.8…1.1)UN
(0.8…1.1)UN
sens. DC
(0.73…1.75)UN
(0.73…1.75)UN
(0.8…1.5)UN
Holding voltage
AC/DC
0.8 UN /0.4 UN
0.8 UN /0.4 UN
0.8 UN /0.4 UN
Must drop-out voltage
AC/DC
0.2 UN /0.1 UN
0.2 UN /0.1 UN
0.2 UN /0.1 UN
Technical data
Mechanical life AC/DC
cycles
10 · 106/20 · 106
10 · 106/—
10 · 106/20 · 106
Electrical life at rated load AC1
cycles
200 · 10
100 · 10
100 · 103
Operate/release time
ms
Insulation between coil and contacts (1.2/50 µs) kV
Dielectric strength between open contacts
Ambient temperature range
Protection category
V AC
°C
3
3
7/4 (AC) - 12/12 (DC)
6 (8 mm)
6 (8 mm)
6 (8 mm)
1,000
1,000
1,000
–40…+70
–40…+70
–40…+70
IP 20
IP 20
IP 20
Approvals relay (according to type)
125
Features
48.62
2 Pole relay interface module,
15.8 mm wide.
48.62 - 2 Pole 10 A
• DC
sensitive coil
retaining clip
• Cadmium Free contacts
• UL Listed
• Instant
2 pole 10 A
35 mm rail mounting
75.3
60.9
17.5
17.5
21
11
COM
24
14
NO
22
12
NC
78.6
25.9
A2
A1
DC
15.8
48
32
48.62
2 CO (DPDT)
A
10/20
250/400
Rated load AC1
VA
2,500
VA
500
kW
A
mW (V/mA)
0.37
10/0.3/0.12
300 (5/5)
AgNi
Coil specification
V AC (50/60 Hz)
V DC
VA (50 Hz)/W
Operating range
AC
12 - 24 - 125
—/0.5
sens. DC
(0.8…1.5)UN
Holding voltage
AC/DC
—/0.4 UN
AC/DC
—/0.1 UN
cycles
—/20 · 106
cycles
100 · 103
Technical data
ms
Protection category
126
V AC
°C
12/12 (DC)
6 (8 mm)
1,000
–40…+70
IP 20
Ordering information
Example: 48 series, 35 mm rail (EN 50022) mount relay interface module, 2 CO (DPDT) 8 A contacts, 24 V sensitive DC coil,
green LED + diode.
4 8 . 5
A
B
C
D
2 . 7 . 0 2 4 . 0
Series
Type
3 = 35 mm rail mount
5 = 35 mm rail mount
6 = 35 mm rail mount
A: Contact material
0 = Standard
D: Special versions
0 = Standard
B: Contact circuit
0 = CO (nPDT)
C: Options
5 = Standard for DC:
green LED + diode (polarity +A1)
6 = Standard for AC:
green LED + Varistor
No. of poles
1 = 1 pole for 48.31, 10 A
48.61, 16 A
2 = 2 pole for 48.52, 8 A
48.62, 10 A, DC only
Coil version
7 = Sensitive DC
8 = AC (50/60 Hz)
Coil voltage
see coil specifications
48
Technical data
Insulation
Insulation according to EN 61810-1 ed. 2
48.31/61/62 48.52
insulation rated voltage
rated impulse withstand voltage
V 250
kV 4
48.31/52/61/62
250
400
4
4
pollution degree
3
2
2
overvoltage category
III
III
III
kV 6 (8 mm)
V AC 1,000
Dielectric strength between adjacent contacts
V AC 2,000 (48.52); 2,500 (48.62)
Conducted disturbance immunity
Burst (5...50)ns, 5 kHz, on A1 - A2
EN 61000-4-4
level 4 (4 kV)
Surge (1.2/50 µs) on A1 - A2 (differential mode)
Other data
EN 61000-4-5
level 3 (2 kV)
Bounce time: NO/NC
ms 2/5
Vibration resistance (5…55)Hz, max. ± 1 mm: NO/NC
Power lost to the environment
without contact current
with rated current
Wire strip length
Screw torque
Max. wire size
g/g 10/4 (for 1 pole)
15/3 (for 2 pole)
W 0.7
W 1.2 (48.31)
1.3 (48.52)
1.2 (48.61)
1.2 (48.62)
mm 8
Nm 0.5
solid cable
stranded cable
mm2 1x6 / 2x2.5
1x4 / 2x2.5
AWG 1x10 / 2x14
1x12 / 2x14
127
F 48 - Electrical life (AC) v contact current
Types 48.31/61
Type 48.62
7
7
10
Resistive load - cosϕ = 1
Inductive load- cosϕ = 0.4
6
Cycles
Cycles
10
10
6
10
Inductive load - cosϕ = 0.4
limit for 48.31
5
5
10
10
8
12
(A)
4
8
12
16
(A)
Types 48.52
7
Cycles
10
6
10
5
48
10
2
6
8
(A)
H 48 - Maximum DC1 breaking capacity
Types 48.31/52/61
10
6
4
48.61 current limit
48.31 current limit
48.52 current limit
2
DC breaking current (A)
Type 48.62
2 x 48.52 contacts in series
1
0.2
single contact
60
100
140
180
220
DC voltage (V)
• When switching a resistive load (DC1) having voltage and current
values under the curve, an electrical life of ≥ 100·103 can be expected.
• In the case of DC13 loads, the connection of a diode in parallel with
the load will permit a similar electrical life as for a DC1 load.
Note: the release time for the load will be increased.
128
2
2 x 48.62 contacts in series
1
0.2
single contact
0.1
0.1
6
4
100
140
180
220
DC voltage (V)
Coil specifications
DC coil data (0.5 W sensitive)
Nominal
voltage
UN
V
12
24
125
AC coil data
Coil
code
Operating range
Umin*
V
8.8
17.5
92
7.012
7.024
7.125
Rated coil
consumption
I at UN
mA
41
22.2
4
Umax
V
21
42
218
Nominal
voltage
UN
V
12
24
110
120
230
*Umin = 0.8 UN for 48.61 and 48.62
R 48 - DC coil operating range v ambient temperature
U 2.0
UN
48.61/62
Operating range
Umin
V
9.6
19.2
88
96
184
8.012
8.024
8.110
8.120
8.230
Rated coil
consumption
I at UN (50Hz)
mA
90.5
46
10.1
11.8
7.0
Umax
V
13.2
26.4
121
132
253
R 48 - AC coil operating range v ambient temperature
U 2.0
UN
48.31/52
1
1.5
Coil
code
1.5
1
1.0
1.0
48.61/62
2
2
48.31/52
0.5
0.5
-20
60
-20
80
(°C)
60
80
(°C)
1 - Max. permitted coil voltage.
2 - Min. pick-up voltage with coil at ambient temperature.
Combinations
Code
Type of socket
Type of relay
Module
Retaining clip
48.31
95.03
40.31
99.02
095.01
48.52
95.05
40.52
99.02
095.01
48.61
95.05
40.61
99.02
095.01
48.62
95.05
44.62
99.02
095.01
48
Accessories
8-way jumper link
095.18
Rated values
10 A - 250 V
095.18
3.3
110.5
15
15.8
15.8
15.8
15.8
15.8
15
Sheet of marker tags, plastic, 72 tags, 6x12 mm
10.3
7
5.1
060.72
060.72
129
Packaging codes
How to code and identify retaining clip and packaging options for relay interface module.
Code options according to the last three letters:
4 8 . 5
2 . 7 . 0 2 4 . 0
S
P
A
A
B
Standard packaging
Blister packaging
SP Plastic retaining clip
48
130
48.62.7.024.0050SPA 价格&库存
很抱歉,暂时无法提供与“48.62.7.024.0050SPA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+180.28811
- 10+170.58468
- 20+160.79971
- 50+141.31130
- 国内价格
- 1+332.16480
- 200+132.53760
- 500+128.10960
- 1000+125.92800
