49.52.7.012.0050SPA
49.52.7.012.0050SPA
    FINDER
49.52.7.012.0050SPA 数据手册
49 Series - Relay interface modules 8 - 10 - 16 A Features 49.31-50x0 49.52/72-50x0 1 & 2 Pole relay interface modules 5 µm Gold plate contacts for low level switching capability 49.31-50x0 - 1 Pole 10 A (screw terminal) 49.52-50x0 - 2 Pole 8 A (screw terminal) 49.72-50x0 - 2 Pole 8 A (screwless terminal) 15.5 mm wide Ideal interface for PLC and electronic systems • AC coils & DC coils • Instant ejection of relay using plastic retaining clip • Supply status indication and coil suppression module • Identification labels • 35 mm rail (EN 50022) mounting • • 49.31-50x0 / 49.52 Screw terminal 1 pole, 10 A AgNi + Au (5 µm) contact material • Screw terminal • 35 mm rail (EN 50022) mounting 2 pole, 8 A AgNi + Au (5 µm) contact material • Screw terminal and screwless terminal • 35 mm rail (EN 50022) mounting • • • • COM 11 COM 11 14 NO 14 NO 12 NC 12 NC 11 COM 24 14 NO 22 12 NC 11 COM 21 24 14 NO 22 12 NC 21 49.72-50x0 Screwless terminal A2 A1 A2 — AC A1 DC 8.xxx0060 + 7.xxx.0050 A2 A1 A2 — AC A1 DC 8.xxx0060 + 7.xxx.0050 ** By external parallel connection of the contacts the values within [1 (0.1/1)] can be acheived. For outline drawing see page 8 Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 2 CO (DPDT) 10/20 8/15 250/400 250/250 Rated load AC1 VA 2,500 2,000 Rated load AC15 (230 V AC) VA 500 400 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material 0.37 0.3 10/0.3/0.12 8/0.3/0.12 50 (5/2) 50 (5/2) - [1 (0.1/1)]* AgNi + Au (5 µm) AgNi + Au (5 µm) Coil specification Nominal voltage (UN) 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 V DC 12 - 24 - 125 12 - 24 - 125 Rated power AC/DC/sens.DC VA (50 Hz)/W/W 1.2/0.65/0.5 1.2/0.65/0.5 Operating range (0.8…1.1)UN (0.8…1.1)UN V AC (50/60 Hz) AC DC/sensitiv DC (0.73…1.5)UN/(0.73…1.7)UN (0.73…1.5)UN/(0.73…1.7)UN Holding voltage AC/DC 0.8 UN /0.4 UN 0.8 UN /0.4 UN Must drop-out voltage AC/DC 0.2 UN /0.1 UN 0.2 UN /0.1 UN Technical data Mechanical life AC/DC cycles 10 · 106/20 · 106 10 · 106/20 · 106 Electrical life at rated load AC1 cycles 150 · 103 150 · 103 7/4 (AC) - 12/12 (DC) 7/4 (AC) - 12/12 (DC) 6 (8 mm) 6 (8 mm) Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range Protection category °C 1,000 1,000 –40…+70 –40…+70 IP 20 IP 20 Approvals relay (according to type) 1 49 Series - Relay interface modules 8 - 10 - 16 A Features 49.31-00x0 49.52/72-00x0 1 & 2 Pole relay interface modules AgNi contacts for medium duty switching 49.31-00x0 - 1 Pole 10 A (screw terminal) 49.52-00x0 - 2 Pole 8 A (screw terminal) 49.72-00x0 - 2 Pole 8 A (screwless terminal) 15.5 mm wide Ideal interface for PLC and electronic systems • AC coils & DC coils • Instant ejection of relay using plastic retaining clip • Supply status indication and coil suppression module • Identification labels • 35 mm rail (EN 50022) mounting • • 49.31-00x0 / 49.52 Screw terminal 1 pole, 10 A AgNi contact material • Screw terminal • 35 mm rail (EN 50022) mounting 2 pole, 8 A AgNi contact material • Screw terminal and screwless terminal • 35 mm rail (EN 50022) mounting • • • • COM 11 COM 11 14 NO 14 NO 12 NC 12 NC 11 COM 24 14 NO 22 12 NC 11 COM 21 24 14 NO 22 12 NC 21 49.72-00x0 Screwless terminal A2 A1 A2 — AC A1 DC 8.xxx0060 + 7.xxx.0050 A2 A1 A2 — AC A1 DC 8.xxx0060 + 7.xxx.0050 For outline drawing see page 8 Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 2 CO (DPDT) 10/20 8/15 250/400 250/250 Rated load AC1 VA 2,500 2,000 Rated load AC15 (230 V AC) VA 500 400 Single phase motor rating (230 V AC) kW 0.37 0,3 10/0.3/0.12 8/0.3/0.12 300 (5/5) 300 (5/5) AgNi AgNi 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 V DC 12 - 24 - 125 12 - 24 - 125 Rated power AC/DC/sens.DC VA (50 Hz)/W/W 1.2/0.65/0.5 1.2/0.65/0.5 Operating range (0.8…1.1)UN (0.8…1.1)UN Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) AC (0.73…1.5)UN/( 0.73…1.7)UN (0.73…1.5)UN/( 0.73…1.7)UN Holding voltage AC/DC 0.8 UN /0.4 UN 0.8 UN /0.4 UN Must drop-out voltage AC/DC 0.2 UN /0.1 UN 0.2 UN /0.1 UN DC/sensitiv DC Technical data Mechanical life AC/DC cycles 10 · 106/20 · 106 10 · 106/20 · 106 Electrical life at rated load AC1 cycles 200 · 103 150 · 103 7/4 (AC) - 12/12 (DC) 7/4 (AC) - 12/12 (DC) 6 (8 mm) 6 (8 mm) Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range Protection category Approvals relay (according to type) 2 °C 1,000 1,000 –40…+70 –40…+70 IP 20 IP 20 49 Series - Relay interface modules 8 - 10 - 16 A Features 49.31-20x0 49.52/72-20x0 1 & 2 Pole relay interface modules AgCdO contacts for heavy duty switching 49.31-20x0 - 1 Pole 10 A (screw terminal) 49.52-20x0 - 2 Pole 8 A (screw terminal) 49.72-20x0 - 2 Pole 8 A (screwless terminal) 15.5 mm wide Ideal interface for PLC and electronic systems • AC coils & DC coils • Instant ejection of relay using plastic retaining clip • Supply status indication and coil suppression module • Identification labels • 35 mm rail (EN 50022) mounting • • 49.31-20x0 / 49.52 Screw terminal 1 pole, 10 A AgCdO contact material • Screw terminal • 35 mm rail (EN 50022) mounting 2 pole, 8 A AgCdO contact material • Screw terminal and screwless terminal • 35 mm rail (EN 50022) mounting • • • • COM 11 COM 11 14 NO 14 NO 12 NC 12 NC 11 COM 24 14 NO 22 12 NC 11 COM 21 24 14 NO 22 12 NC 21 49.72-20x0 Screwless terminal A2 A1 A2 — A1 + AC DC 8.xxx0060 7.xxx.0050 A2 A1 A2 — AC A1 DC 8.xxx0060 + 7.xxx.0050 For outline drawing see page 8 Contact specification 1 CO (SPDT) Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 2 CO (DPDT) 10/20 8/15 250/400 250/250 Rated load AC1 VA 2,500 2,000 Rated load AC15 (230 V AC) VA 500 400 0.37 0.3 10/0.3/0.12 8/0.3/0.12 500 (10/5) 500 (10/5) AgCdO AgCdO 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 V DC 12 - 24 - 125 12 - 24 - 125 Rated power AC/DC/sens.DC VA (50 Hz)/W/W 1.2/0.65/0.5 1.2/0.65/0.5 Operating range (0.8…1.1)UN (0.8…1.1)UN Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) AC (0.73…1.5)UN/(0.73…1.75)UN (0.73…1.5)UN/(0.73…1.75)UN Holding voltage AC/DC 0.8 UN /0.4 UN 0.8 UN /0.4 UN Must drop-out voltage AC/DC 0.2 UN /0.1 UN 0.2 UN /0.1 UN DC/sensitiv DC Technical data Mechanical life AC/DC cycles 10 · 106/20 · 106 10 · 106/20 · 106 Electrical life at rated load AC1 cycles 200 · 103 150 · 103 7/4 (AC) - 12/12 (DC) 7/4 (AC) - 12/12 (DC) 6 (8 mm) 6 (8 mm) Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range Protection category °C 1,000 1,000 –40…+70 –40…+70 IP 20 IP 20 Approvals relay (according to type) 3 49 Series - Relay interface modules 8 - 10 - 16 A Features 49.61/81-20x0 49.61/81-40x0 1 Pole relay interface module AgCdO contacts for heavy duty switching 49.61-20x0 - 1 Pole 16 A (screw terminal) 49.81-20x0 - 1 Pole 16 A (screwless terminal) AgSnO2 contacts for heavy duty, high current inrush switching 49.61-40x0 - 1 Pole 16 A (screw terminal) 49.81-40x0 - 1 Pole 16 A (screwless terminal) 15.5 mm wide Ideal interface for PLC and electronic systems • AC coils & DC coils • Instant ejection of relay using plastic retaining clip • Supply status indication and coil suppression module • Identification labels • 35 mm rail (EN 50022) mounting • • 49.61 Screw terminal 1 pole, 16 A AgCdO contact material • Screw terminal and screwless terminal • 35 mm rail (EN 50022) mounting 1 pole, 16 A AgSnO2 contact material • Screw terminal and screwless terminal • 35 mm rail (EN 50022) mounting • • • • 21 11 COM 21 11 COM 21 11 COM 21 11 COM 24 14 NO 24 14 NO 24 14 NO 24 14 NO 22 12 NC 22 12 NC 22 12 NC 22 12 NC 49.81-20x0/40x0 Screwless terminal A2 A1 A2 — AC DC 8.xxx0060 For outline drawing see page 8 A1 + 7.xxx.0050 A2 A1 A2 — AC A1 DC 8.xxx0060 + 7.xxx.0050 * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). 1 CO (SPDT) 1 CO (SPDT) Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 16*/30 16*/100 (5 ms) 250/400 250/400 Rated load AC1 VA 4,000 4,000 Rated load AC15 (230 V AC) VA 750 750 Single phase motor rating (230 V AC) kW 0.55 0.55 16/0.3/0.12 16/0.3/0.12 500 (5/5) 1,000 (10/10) AgCdO AgSnO2 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 V DC 12 - 24 - 125 12 - 24 - 125 Rated power AC/DC/sens.DC VA (50 Hz)/W/W 1.2/0.65/0.5 1.2/0.65/0.5 Operating range (0.8…1.1)UN (0.8…1.1)UN Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) AC DC/sensitiv DC (0.73…1.5)UN/(0.8…1.5)UN (0.73…1.5)UN/(0.8…1.5)UN Holding voltage AC/DC 0.8 UN /0.4 UN 0.8 UN /0.4 UN Must drop-out voltage AC/DC 0.2 UN /0.1 UN 0.2 UN /0.1 UN Technical data Mechanical life AC/DC cycles 10 · 106/20 · 106 10 · 106/20 · 106 Electrical life at rated load AC1 cycles 100 · 103 100 · 103 7/4 (AC) - 12/12 (DC) 7/4 (AC) - 12/12 (DC) 6 (8 mm) 6 (8 mm) Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range Protection category Approvals relay (according to type) 4 °C 1,000 1,000 –40…+70 –40…+70 IP 20 IP 20 49 Series - Relay interface modules 8 - 10 - 16 A Ordering information Example: 49 series, 35 mm rail (EN 50022) mount screw terminal relay interface module, 2 CO (DPDT) 8 A contacts, 24 V sensitive DC coil, green LED + diode (polarity +A1), 99.80 coil indication. 4 9 . 5 A B C D 2 . 7 . 0 2 4 . 0 0 5 0 A: Contact material 0 = Standard AgNi for 49.31/52/72, AgCdO for 49.61/81 2 = AgCdO for 49.31/52/72 4 = AgSnO2 for 49.61/81 only 5 = AgNi + Au (5 µm) not for 49.61/81 Series Type 3, 5, 6 = 35 mm rail (EN 50022) mount, screw terminal 7, 8 = 35 mm rail (EN50022) mount, screwless terminal No. of poles 1 = 1 pole for 49.31, 10 A 49.61, 49.81, 16 A 2 = 2 pole for 49.52, 49.72, 8 A D: Special versions 0 = Standard C: Options 5 = Standard for DC: green LED + diode (polarity +A1) 6 = Standard for AC: green LED + Varistor B: Contact circuit 0 = CO (nPDT) Coil version 7 = Sensitive DC (500 mW) 8 = AC (50/60 Hz) 9 = DC (650 mW) Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best avaliability are shown in bold. Type 49.31/52/72 49.31/52/72 49.61/81 49.61/81 Coil version AC DC AC DC A 0 0 0 0 -2-5 -2-5 -4 -4 B 0 0 0 0 C 6 5 6 5 D 0 0 0 0 Technical data Insulation Insulation according to EN 61810-1 insulation rated voltage rated impulse withstand voltage V kV pollution degree overvoltage category Insulation between coil and contacts (1.2/50 µs) kV 49.31/61 49.52/72 250 250 49.31/61/81 400 4 4 4 3 2 2 III III III 6 (8 mm) Dielectric strength between open contacts V AC 1,000 Dielectric strength between adjacent contacts V AC 2,000 (49.52/72) Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 µs) on A1 - A2 (differential mode) EN 61000-4-5 level 3 (2 kV) Other data Bounce time: NO/NC ms Vibration resistance (5…55)Hz: NO/NC Power lost to the environment g 2/5 10/4 (for 1 pole) without contact current W 0.7 with rated current W 1.2 (49.31/61/81) Wire strip length mm 8 Screw torque Nm 0.5 Screw terminal Max. wire size mm2 AWG 15/3 (for 2 pole) 1.3 (49.52/72) Screwless terminal solid cable stranded cable solid cable stranded cable 1x6 / 2x2.5 1x4 / 2x2.5 2x(0.2...1.5) 2x(0.2...1.5) 1x10 / 2x14 1x12 / 2x14 2x(24...18) 2x(24...18) 5 49 Series - Relay interface modules 8 - 10 - 16 A Contact specification F 49 - Electrical life (AC) v contact current Types 49.52/72 F 49 - Electrical life (AC) v contact current Types 49.31/61/81 7 7 10 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 6 Cycles Cycles 10 10 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 6 10 limit for 49.31 5 5 10 10 0 4 8 12 16 (A) H 49 - Maximum DC1 breaking capacity Types 49.31/52/61/72/81 DC breaking current (A) 20 10 6 4 49.61/81 current limit 49.31 current limit 49.52/72 current limit 2 49.52/72 - 2 contacts in series 1 single contact 0.2 0.1 20 60 100 140 180 220 DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. 6 0 2 4 6 8 (A) 49 Series - Relay interface modules 8 - 10 - 16 A Coil specifications DC coil data (0.5 W sensitive) Nominal voltage UN V 12 24 125 AC coil data Coil code 7.012 7.024 7.125 Operating range Umin* V 8.8 17.5 91.2 Rated coil consumption I at UN mA 41 22.2 4 Umax** V 21 42 212.5 *Umin = 0.8 UN for 49.61 and 49.81 **Umax = 1.5 UN for 49.61 and 49.81 Nominal voltage UN V 12 24 110 120 230 Coil code 8.012 8.024 8.110 8.120 8.230 Operating range Umin V 9.6 19.2 88 96 184 Umax V 13.2 26.4 121 132 253 Rated coil consumption I at UN (50Hz) mA 90.5 46 10.1 11.8 7.0 DC coil data (0.65 W) Nominal voltage UN V 12 24 125 Coil code 9.012 9.024 9.125 Operating range Umin V 8.8 17.5 91.2 Rated coil consumption I at UN mA 56 29 6 Umax V 18 36 187.5 R 49 - DC coil operating range v ambient temperature Standard (650 mW) R 49 - AC coil operating range v ambient temperature U 2.0 UN U 2.0 UN 1 1.5 1.5 1 1.0 1.0 2 2 0.5 0.5 -20 0 20 40 60 80 (°C) 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. -20 0 20 40 60 80 (°C) 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. R 49 - DC coil operating range v ambient temperature Sensitive coil (500 mW) U 2.0 UN 49.31/52/72 49.61/81 1 1.5 1.0 49.61/81 2 0.5 49.31/52/72 -20 0 20 40 60 80 (°C) 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 7 49 Series - Relay interface modules 8 - 10 - 16 A Combinations Code Type of socket Type of relay Module Retaining clip 49.31 95.93.3 40.31 99.80 095.91.3 49.52 95.95.3 40.52 99.80 095.91.3 49.61 95.95.3 40.61 99.80 095.91.3 49.72 95.55.3 40.52 99.80 095.91.3 49.81 95.55.3 40.61 99.80 095.91.3 Outline drawing 73.7 75 64.8 15.5 15.5 24.6 4 4 46.8 21 COM 11 24 NO 14 22 NC 12 34.7 95.6 30.3 78.6 81.9 78.6 81.9 30.6 28.8 A2 COIL A1 29.8 15.8 33.8 22.6 32.5 49.31 49.72 49.81 49.52 49.61 49.72-50x0 / 49.72-00x0 / 49.72-20x0 49.81-20x0 / 49.81-40x0 Screwless terminal 49.31-50x0 / 49.31-00x0 / 49.31-20x0 / 49.52 / 49.61 Screw terminal Accessories 8-way jumper link for screw terminal versions 095.08 (blue) Rated values 10 A - 250 V 095.08 095.08.0 (black) 113.1 7 10 3 13.9 0.75 15.8 15.8 15.8 15.8 15.8 15.8 15.8 Sheet of marker tags, plastic, 72 tags, 6x12 mm 060.72 060.72 Packaging codes How to code and identify retaining clip and packaging options for sockets. Example: 4 9 . 5 2 . 7 . 0 2 4 . 0 0 5 0 S P A A B Standard packaging Blister packaging SP Plastic retaining clip 8
49.52.7.012.0050SPA 价格&库存
很抱歉,暂时无法提供与“49.52.7.012.0050SPA”相匹配的价格&库存,您可以联系我们找货
