83 SERIES
Modular timers 12 - 16 A
83
SERIES
83.01
Multi-function timer range
83.01 - Multi-function & multi-voltage, 1 Pole
83.02 - Multi-function & multi-voltage,
2 Pole (timed + instantaneous
options), external time setting
potentiometer option
83.52 - Multi-function & multi-voltage,
potentiometer option, pause function
option
• 22.5 mm wide
• Eight time scales from 0.05 s to 10 days
• High input/output isolation
• Wide supply range (24…240)V AC/DC
• 35 mm rail (EN 60715) mount
• “Blade + cross” - both flat blade and cross head
screw drivers can be used to adjust the range
and function selectors, the timing trimmer, and
to disengage the rail mounting clip
• Multi-voltage versions with “PWM clever”
technology
• Complies with EN 45545-2:2013 (protection
against fire of materials), EN 61373 (resistance
against random vibrations and shock,
Category 1, Class B), EN 50155 (resistance to
temperature and humidity, T1 class)
• Multi-voltage
• Multi-function
83.02
83.52
• Multi-voltage
• Multi-function
• Timing can be regulated using ext.
Potentiometer
• 2 timed contacts or 1 timed + 1
• Multi-voltage
• Multi-function
Potentiometer
instantaneous contact
• 3 functions with pause option
AI: On-delay
DI: Interval
GI: Pulse delayed
SW: Symmetrical flasher
(starting pulse on)
BE: Off-delay with control signal
CE: On- and off-delay with control
signal
DE: Interval with control signal on
WD: Watchdog (Retriggerable
interval with control signal on)
AE:
On-delay with control signal
GE:
Pulse delayed with control
signal on
IT:
Timing step
FE:
on and off
EEa:
off (retriggerable)
DEp:
on and pause signal
BEp:
and pause signal
SHp: “Shower” function
AI: On-delay
DI: Interval
GI: Pulse delayed
SW:
Symmetrical flasher
(starting pulse on)
CE:
signal
Wiring diagram
(without control signal)
Wiring
diagram
Wiring
diagram
(with control signal and external
potentiometer connection)
Wiring
diagram
(with control signal)
Wiring
diagram
and pause signal)
Wiring diagram
For outline drawing see page 5
Contact specification
Contact configuration
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
A
V AC
1 CO (SPDT)
2 CO (DPDT)
2 CO (DPDT)
16/30
12/30
12/30
250/400
250/400
250/400
Rated load AC1
VA
4000
3000
3000
Rated load AC15 (230 V AC)
VA
750
750
750
Single phase motor rating (230 V AC)
kW
0.5
0.5
0.5
16/0.3/0.12
12/0.3/0.12
12/0.3/0.12
300 (5/5)
300 (5/5)
300 (5/5)
AgNi
AgNi
AgNi
24…240
24…240
24…240
24…240
Breaking capacity DC1: 30/110/220 V
Minimum switching load
A
mW (V/mA)
Standard contact material
H
Supply specification
Nominal voltage (UN)
Rated power AC/DC
Operating range
V AC (50/60 Hz)
V DC
24…240
24…240
VA (50 Hz)/W
很抱歉,暂时无法提供与“83.01.0.240.0000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+665.964221+85.97040
- 10+597.5120610+77.13380
- 50+558.2965050+72.07140
