99
SERIES
99 Series - Coil indication and EMC suppression modules
99.01
FUNCTION / OPERATING RANGE
Sockets
90.20
90.21
94.72
94.73
94.74
94.82
95.63
Relays
60.12
60.13
55.32
55.33
55.32, 55.34
55.32
40.31
96.72
96.74
56.32
56.34
99.02
Sockets
90.02
90.03
92.03
94.02
94.03
94.04
94.54
95.03
95.05
Relays
60.12
60.13
62.32, 62.33
55.32
55.33
55.32, 55.34
55.32, 55.34
40.31
40.51/52/61
44.52, 44.62
95.55
40.51/52/61
44.52, 44.62
96.02
56.32
96.04
56.34
97.01/97.51 46.61
97.02/97.52 46.52
99.80
Sockets
94.82.3
94.84.3
94.84.2
94.92.3
94.94.3
95.55.3
95.83.3
95.85.3
95.93.3
95.95.3
97.51.3
97.52.3
Relays
55.32
55.32, 55.34
55.32, 55.34
55.32
55.32, 55.34
40.51/52/61
44.52, 44.62
40.31
40.51/52/61
44.52/62
40.31
40.51/52/61
44.52, 44.62
46.61
46.52
CODE
CODE
CODE
99.01.9.024.99
99.01.9.060.99
99.01.9.220.99
99.02.9.024.99
99.02.9.060.99
99.02.9.220.99
99.80.9.024.99
99.80.9.060.99
99.80.9.220.99
99.01.9.024.79
99.01.9.060.79
99.01.9.220.79
99.02.9.024.79
99.02.9.060.79
99.02.9.220.79
99.80.9.024.79
99.80.9.060.79
99.80.9.220.79
99.01.0.024.98
99.01.0.060.98
99.01.0.230.98
99.02.0.024.98
99.02.0.060.98
99.02.0.230.98
99.80.0.024.98
99.80.0.060.98
99.80.0.230.98
99.01.0.024.59
99.01.0.060.59
99.01.0.230.59
99.02.0.024.59
99.02.0.060.59
99.02.0.230.59
99.80.0.024.59
99.80.0.060.59
99.80.0.230.59
99.01.3.000.00
99.02.3.000.00
99.80.3.000.00
99.01.2.000.00
99.02.2.000.00
99.80.2.000.00
99.01.0.024.09
99.01.0.060.09
99.01.0.230.09
99.02.0.024.09
99.02.0.060.09
99.02.0.230.09
99.80.0.024.09
99.80.0.060.09
99.80.0.230.09
99.01.8.230.07
99.02.8.230.07
99.80.8.230.07
Green LED + diode module (standard polarity)
6 - 24 V DC
28 - 60 V DC
110 - 220 V DC
Green LED + diode module (non-standard polarity)
6 - 24 V DC
28 - 60 V DC
110 - 220 V DC
Green LED + Varistor module
6 - 24 V AC/DC
28 - 60 V AC/DC
110 - 240 V AC/DC
Green LED module
6 - 24 V AC/DC
28 - 60 V AC/DC
110 - 240 V AC/DC
Diode module (standard polarity)
6 - 220 V DC
Diode module (non-standard polarity)
6 - 220 V DC
X-2013, www.findernet.com
RC module
6 - 24 V AC/DC
28 - 60 V AC/DC
110 - 240 V AC/DC
Residual current bypass module
110 - 240 V AC
1
99
SERIES
Voltage-current characteristic when
switching a resistive load (fig. 1).
Switching Relay Coils.
When switching a resistive load, the current follows
the phase of the voltage directly (Fig 1).
U
I
U
R
ON
When switching relay coils the current and voltage
waveforms are different due to the inductive nature
of the coil (Fig 2). A brief explanation of this
mechanism is as follows.
OFF
I
t
switching a relay coil (fig. 2).
U
R
L
I
U
I
ON
OFF
t
On energisating the coil, the build up of the
magnetic field gives rise to counter electromotive
forces which in turn delay the rise in coil current.
On de-energisation, the sudden interruption of the
coil current causes a sudden collapse of the
magnetic field, which in turn induces a high voltage
of reverse polarity across the coil. This reverse
polarity voltage peak can reach a value typically 15
times higher than the supply voltage, and as a
consequence can disturb or destroy electronic
devices.
Diagrams
To counteract this potentially damaging effect,
relays coils can be suppressed with a Diode, a
Varistor (voltage dependent resistor) or a RC
(resistor/capacitor) module – dependent on the
operating voltage. (See below for descriptions of
the various Modules available.)
Whilst the above description is based on the
working of a DC coil, the reverse polarity voltage
peak on de-energisation applies similarly to AC
coils. However, when energising AC coils there will
also be a coil inrush current of 1.3 to 1.7 times the
nominal coil current – dependent on coil size. If
coils are fed via a transformer (and particularly if
several are energised at the same time) then this
may need to taken into account when calculating
the VA rating of the transformer.
Functions
99.01.9.xxx.99 only
99.80.9.xxx.99 only
99.02.9.xxx.99 only
Recovery diode modules + LED are used for DC only. The reverse voltage peaks of
the coil are short circuited by the recovery diode (positive to terminal A1).
The release time increases by an approximate factor of 3.
If an increase of the release time is undesirable use a Varistor or RC module.
The LED indicator lights up when the coil is energized.
99.01.9.xxx.79 only
99.80.9.xxx.79 only
99.02.9.xxx.79 only
the coil are short circuited by the recovery diode (positive to terminal A2).
LED modules + Varistor are used for both AC and DC coils.
The reverse voltage peaks of the relay coil are limited by the Varistor to approximately
2.5 times the nominal voltage of the supply. When using DC coils it is essential that
positive is connected to terminal A1. The relay release time increases insignificantly.
99.01.3.000.00 only
99.80.3.000.00 only
99.02.3.000.00 only
Recovery diode modules are used for DC only. The reverse voltage
peaks of the coil are short circuited by the recovery diode (positive to terminal A1).
99.01.2.000.00 only
99.80.2.000.00 only
99.02.2.000.00 only
peaks of the coil are short circuited by the recovery diode (positive to terminal A2).
RC module
RC circuit modules are used for AC and DC coils. The reverse voltage peaks
of the coil are limited by the RC module to approximately 2.5 times the
nominal voltage of the supply. The relay release time increases insignificantly.
Bypass modules are advisable if 110 or 230v AC relays show any tendency to fail to
release. Failure to release can be caused by residual currents from AC proximity
switches or inductive coupling caused through long parallel lying AC control lines.
2
Green LED module
LED modules are used for AC and DC.
When using DC it is essential that positive is connected to terminal A1.
很抱歉,暂时无法提供与“99.80.9.024.99”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+40.03684
- 10+36.44902
- 50+33.59507
