72
SERIES
72 Series - Monitoring relays
Features
72.01
72.11
Level control relays for conductive liquids
72.01 - Adjustable sensitivity
72.11 - Fixed sensitivity
Emptying or filling functions
LED indicator
• Reinforced insulation (6 kV - 1.2/50 μs) between:
- supply and contacts
- electrodes and supply
- contacts and electrodes
• 35 mm rail (EN 60715) mount
• Control about a single level or between
Min./Max. limits
• 72.01 available also for supply 400 V
• 72.01 available also with sensitivity range
(5...450) kΩ adjustable
• 72.01 available also for contact loads down
to 5 V 1 mA
Sensitivity range (5...150) kΩ adjustable
Delay time (0.5s or 7s) switch selectable
Emptying or filling functions switch selectable
Sensitivity fixed 150 kΩ
Delay time fixed: 1s
Emptying or filling functions link selectable
U = 24 V DC
24 V AC 50/60 Hz
(110...125)V AC 50/60 Hz
(230...240)V AC 50/60 Hz
72.01/11
Screw terminal
U = 24 V DC
24 V AC 50/60 Hz
F = Filling
E
E = Emptying
FOR UL RATINGS SEE:
“General technical information” page V
FL = Filing – 7s delay
FS = Filling – 0.5s delay
ES = Emptying – 0.5s delay
EL = Emptying – 7s delay
For outline drawing see page 8
Contact specification
Contact configuration
Rated current/Maximum peak current
1 CO (SPDT)
1 CO (SPDT)
16/30
16/30
250/400
250/400
4,000
4,000
A
Rated voltage/Maximum switching voltage V AC
Rated load AC1
VA
Rated load AC15 (230 V AC)
Single phase motor rating (230 V AC)
Breaking capacity DC1: 30/110/220 V
Minimum switching load
VA
750
750
kW
0.55
0.55
16/0.3/0.12
16/0.3/0.12
500 (10/5)
500 (10/5)
AgCdO
AgCdO
A
mW (V/mA)
Standard contact material
Supply specification
Nominal voltage (UN)
V AC (50/60 Hz)
24
V DC
24
Rated power AC/DC
VA (50 Hz)/W
Operating range
110...125 230...240
400
24
24
2.5/1.5
230...240
2.5/1.5
V AC (50/60 Hz) 19.2...26.4 90...130 184...253 360...460
V DC 20.4...26.4
110...125
19.2...26.4
90...130
184...253
20.4...26.4
Technical data
Electrical life at rated load AC1
cycles
Electrode voltage
V AC
Electrode current
mA
III-2014, www.findernet.com
Run-on time
Max sensitivity range
s
kΩ
Insulation between supply/contacts/electrode (1.2/50 μs) kV
Ambient temperature
Protection category
°C
100 · 103
100 · 103
4
4
0.2
0.2
0.5 - 7 (selectable)
1
5…150 (adjustable)
150 (fixed)
6
6
–20…+60
–20…+60
IP20
IP20
Approvals (according to type)
1
72
SERIES
Features
72.42
Priority change relay
Special relay for alternating loads,
for applications with pumps, compressors,
air conditioning or refrigeration units
2 independent NO output, 12 A
4 functions
• 2 independent control signals, insulated from
supply
• 110...240 V and 24 V AC/DC supply versions
• Modular housing, 35 mm wide
• Cd-free contact material
Multi-function (MI, ME, M2, M1)
72.42
Screw terminal
E
2 NO (2 DPST-NO)
Rated current / Max. peak current
A
12 / 20
Rated voltage / Max. switching voltage V AC
Rated load AC1
Rated load AC15
250 / 400
VA
3,000
VA
1,000
kW
0.55
A
12 / 0.3 / 0.12
mW (V/mA)
300 (5 / 5)
AgNi
Nominal voltage (UN) V AC (50/60 Hz) / DC
Rated power
in stand-by W
with 2 active relays W/VA(50 Hz)
Operating range
V AC (50/60 Hz)
V DC
24
110 … 240
0.12
0.18
1.1 / 1.7
1.5 / 3.9
16.8…28.8
90…264
16.8…32
90…264
Technical data
cycles
100 x 103
Output delay time (T on function diagrams)
s
0.2...20
Power-on activation time
s
≤ 0.7
Minimum impulse duration
ms
Insulation between supply and contacts (1.2/50 μs) kV
Dielectric strength between open contacts
Ambient temperature
Protection category
2
V AC
°C
50
6
1,000
–20…+50
IP20
72
SERIES
Ordering information
Example: 72 series level control relay, adjustable sensitivity range, (230…240)V AC supply voltage.
7 2 . 0
Series
Type
0 = Level control relay,
sensitivity range adjustable (5...150)kΩ
1 = Level control relay, sensitivity fixed 150 kΩ
4 = Priority change relay
No. of poles
1 = 1 CO (SPDT)
2 = 2 NO (DPST-NO)
1 . 8 . 2 4 0 . 0
Contact material
0 = Standard AgCdO
for 72.01/72.11,
AgNi for 72.42
5 = AgNi + Au**
Supply voltage
024 = 24 V
125 = (110…125)V AC
230 = (110 … 240) V
240 = (230…240)V AC
400 = 400 V AC (72.01 only)
Option
0 = Max. 150 kΩ
2 = Sensitivity range
adjustable (5...450) kΩ
types 72.01.8.024.0002*
72.01.8.240.0002*
72.01.8.240.5002**
Supply version
0 = DC / AC (50/60 Hz)
8 = AC (50/60 Hz)
9 = DC
All versions
72.01.8.024.0000
72.01.8.024.0002*
72.01.8.125.0000
72.01.8.240.0000
72.01.8.240.0002*
72.01.8.240.5002**
72.01.8.400.0000
72.01.9.024.0000
72.11.8.024.0000
72.11.8.125.0000
72.11.8.240.0000
72.11.9.024.0000
72.42.0.230.0000
72.42.0.024.0000
E
* For liquids conductivity up to 2 μSiemens
or a Resistance of 450 kΩ
** For applications with output contact loading down to 5 V
1 mA
3
72
SERIES
Technical data
Insulation
72.01/72.11
Insulation
Dielectric strength
72.42
Impulse (1.2/50 μs)
4,000 V AC
6 kV
6 kV
between supply and control (for 110…240 V version only)
2,500 V AC
4 kV
between electrodes, Z1-Z2 and supply*
4,000 V AC
6 kV
between contacts and electrodes
4,000 V AC
6 kV
1,000 V AC
1.5 kV
1.5 kV
EMC specifications
Type of test
Electrostatic discharge
Radio-frequency electromagnetic field
72.01/72.11
72.42
EN 61000-4-2
4 kV
4 kV
air discharge
EN 61000-4-2
8 kV
8 kV
(80...1,000 MHz)
EN 61000-4-3
10 V/m
(1…2.8 GHz)
EN 61000-4-3
Fast transients
on supply terminals
EN 61000-4-4
4 kV
4 kV
(burst 5/50 ns, 5 and 100 kHz)
on control terminals
EN 61000-4-4
4 kV
Voltage pulses on supply terminals
common mode
EN 61000-4-5
4 kV
4 kV
(surge 1.2/50 μs)
differential mode
EN 61000-4-5
4 kV
4 kV
Radiofrequency common mode
on supply terminals
EN 61000-4-6
10 V
10 V (0.15...230 MHz)
voltage (0.15…280 MHz)
EN 61000-4-6
10 V
Voltage dips
70 % UN
EN 61000-4-11
25 cycles
EN 61000-4-11
1 cycles
Short interruptions
10 V/m
5 V/m
Radiofrequency conducted emissions
(0.15…30 MHz)
CISPR 11
class B
class B
Radiated emissions
(30…1,000 MHz)
CISPR 11
class B
class B
Terminals
Screw torque
Nm
0.8
Wire strip length
mm
9
Max. wire size
mm2
AWG
solid cable
stranded cable
1x6 / 2x4
1x4 / 2x2.5
1x10 / 2x12
1x12 / 2x14
Other data
Current absorption on Z1 and Z2 (type 72.11)
mA
Current absorption on control signal (B1-B3 and B2-B3)
很抱歉,暂时无法提供与“072.51”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+554.408261+72.04677
- 5+512.154675+66.55581
- 10+496.4360810+64.51314
- 25+477.6144025+62.06721
- 50+464.7327150+60.39320
- 100+452.91140100+58.85700
