090.06
090.06
    FINDER
    6 WAY JUMP 90.02/90.03 SOCKET
090.06 数据手册
86 Series - Timer modules Features 86.00 Timer modules for use in conjunction with relay & socket. 86.00 - Multi-function & multi-voltage timer module •Timer module for 90 and 92 series sockets •Wide supply voltage range (12 - 240 V) •LED indicator Time scale: from 0.05s to 100 h Multi-function • Plug-in for use with 90.02, 90.03 and 92.03 sockets • 81.1 35.5 20.4 • BE: Signal OFF delay CE: Signal ON & OFF delay DE: Signal ON pulse EE: Signal OFF pulse FE: Signal ON delay + OFF pulse 4 21.6 AI: ON delay DI: ON pulse SW: Symmetrical recycling: ON start 26.9 90.03 + 60.13 + 86.00 33.5 38 relay +socket relay +socket A2 A2 A1 B1 A1 B1 54 S U U N/– wiring diagram without signal START 10,5 6,3 86.00 N/– L/+ L/+ wiring diagram with signal START Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC Rated load AC1 VA Rated load AC15 (230 V AC) VA see 60 and 62 series relays kW Note: Do not use with relays 62.3x.x012.x300 and 62.3x.x012.x600 Single phase motor rating (230 V AC) Breaking capacity DC1: 30/110/220 V Minimum switching load A 86 mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) 12…240 V DC 12…240 Rated power AC/DC Operating range W 1.2 V AC (50/60 Hz) 10.2…265 DC 10.2…265 Technical data (0.05...1)s, (0.5…10)s, (5…100)s, (0.5…10)min, (5…100)min, (0.5…10)h, (5…100)h Specified time range % ±1 Recovery time ms ≤ 50 Minimun control impulse ms 50 % ±5 Repeatability Setting accuracy full range Electrical life at rated load in AC1 Ambient temperature range Protection category cycles °C see 60 and 62 series relays –20…+50 IP 20 Approvals (according to type) 181 86 Series - Timer modules Features 86.10 86.20 Timer modules for use in conjunction with relay & socket. 86.10 - ON delay timer module 86.20 - ON pulse timer module • Timer module for 90, 92, 94 and 95 series sockets • LED indicator • 76 60.9 • • • Mono-function Plug-in for use with 90.02, 90.03, 92.03, 94.02, 94.03, 94.04, 95.03, 95.05 sockets = 32 Mono-function Plug-in for use with 90.02, 90.03, 92.03, 94.02, 94.03, 94.04, 95.03, 95.05 sockets DI: ON pulse relay +socket relay +socket = 35.4 AI: ON delay 32 95.05 + 40.52 + 86.10 A2 15.8 A1 A2 L/+ N/- A1 10.5 U U L/+ 34 N/- 86.10 , 86.20 wiring diagram without signal START wiring diagram without signal START see 40, 44, 55, 60 and 62 series relays see 40, 44, 55, 60 and 62 series relays 12…24 12…24 V DC 12…24 (non polarized) 12…24 (non polarized) mW 150 150 AC (0.8...1.1)UN (0.8...1.1)UN DC (0.8...1.1)UN (0.8...1.1)UN (1.5…15)s,(6…60)s,(0.8…8)min,(6.4…64)min (1.5…15)s,(6…60)s,(0.8…8)min,(6.4…64)min Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC Rated load AC1 VA Rated load AC15 (230 V AC) VA Single phase motor rating (230 V AC) Breaking capacity DC1: 30/110/220 V 86 Minimum switching load kW A mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) Rated power AC/DC Operating range Technical data Specified time range Repeatability % ±1 ±1 Recovery time ms ≤ 150 ≤ 150 Minimum control impulse ms — — Setting accuracy-full range Electrical life at rated load in AC1 Ambient temperature range Protection category Approvals (according to type) 182 % cycles °C ±5 ±5 see 40, 44, 55, 60 and 62 series relays see 40, 44, 55, 60 and 62 series relays 0…+50 0…+50 IP 20 IP 20 86 Series - Timer modules Ordering information Example: 86 series multi-function timer module, (12...240)V AC/DC supply voltage. 8 6 . 0 0 . 0 . 2 4 0 . 0 0 0 0 Supply voltage 024 = (12...24)V AC/DC (86.10/20 only) 240 = (12...240)V AC/DC (86.00 only) Series Type 0 = Multi-function (AI, DI, SW, BE, CE, DE, EE, FE) 1 = Mono-function (AI) 2 = Mono-function (DI) Supply version 0 = AC (50/60 Hz)/DC No. of poles see 40, 44, 55, 60 and 62 series relays Poles for chosesen relay/socket combination according to chart below Combinations Number of poles 1 1 2 2 2 2 3 3 3 4 Relay type 40.31 40.61 40.52/44.52/44.62 55.32 60.12 62.32 55.33 60.13 62.33 55.34 Socket type 95.03 95.05 95.05 94.02 90.02 92.03 94.03 90.03 92.03 94.04 Timer module 86.10/86.20 86.10/86.20 86.10/86.20 86.10/86.20 86.00/86.10/86.20 86.00/86.10/86.20 86.10/86.20 86.00/86.10/86.20 86.00/86.10/86.20 86.10/86.20 Technical data EMC specifications Type of test Reference standard 86.00 86.10/20 contact discharge EN 61000-4-2 4 kV n.a. air discharge EN 61000-4-2 8 kV 8 kV Radio-frequency electromagnetic field (80 ÷ 1000 MHz) EN 61000-4-3 10 V/m 10 V/m Electrostatic discharge Fast transients (burst) (5-50 ns, 5 kHz) on Supply terminals EN 61000-4-4 2 kV 2 kV Surges (1.2/50 µs) on Supply terminals common mode EN 61000-4-5 2 kV 2 kV differential mode EN 61000-4-5 1 kV — EN 61000-4-6 10 V 10 V EN 55022 class B class B 86.00 86.10, 86.20 Radio-frequency common mode (0.15 ÷ 80 MHz) 86 on Supply terminals Radiated and conducted emission Other data Current absorption on signal control (B1) Power lost to the environment mA 1 — without contact current W 0.1 (12 V) - 1 (230 V) 0.2 with rated current see 40, 44, 55, 60, 62 series relays see 60 and 62 series relays Time scales Type 86.00 1 2 3 (0.05...1)s 1 2 3 (0.5...10)s 1 2 3 (5...100)s 1 2 3 (0.5...10)min 1 2 3 (5...100)min 1 2 3 (0.5...10)h 1 2 3 (5...100)h Type 86.10 Type 86.20 (1.5...15)s (6...60)s (0.8...8)min (6.4...64)min NOTE: time scales and functions must be set before energising the timer. 183 86 Series - Timer modules Functions U = Supply Voltage S = Signal switch LED Type 86.00 LED Type 86.10/20 = Output Contact Supply voltage NO output contact OFF Open ON Open ON Open (timing in progress) ON Closed Without signal Start= Start via contact in supply line (A1). With signal Start = Start via contact into control terminal (B1). Wiring diagram Type 86.00 Without signal START 4 5 6 U t
090.06 价格&库存
很抱歉,暂时无法提供与“090.06”相匹配的价格&库存,您可以联系我们找货
