097.01
097.01
    FINDER
    夹,压紧 46 和 86 系列
097.01 数据手册
97 Series - Sockets and accessories for 46 series relays ERED U MM NI ST TY CO D E S I ERED U MM NI TY E S I Rated current (A) CO D 16 A - 250 V AC 8 A - 250 V AC 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 (see diagram L97) 0.8 8 solid wire stranded wire 1x6 / 2x2.5 1x4 / 2x2.5 1x10 / 2x14 1x12 / 2x14 N REG I ST 095.18 (blue) I L 97 - Rated current vs ambient temperature (for 46.61 relay / 97.01 socket combination) 097.71 095.00.4 095.18.0 (black) 99.02 86.30 REG 097.01 97.02.0 (black) 097.01 N Approvals (according to type): 97.01.0 (black) 97.02 (blue) 46.52 G 97.01 97.01 (blue) 46.61 G Screw terminal socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Plastic retain and release clip (supplied with socket - packaging code SPA) Metal retaining clip Identification tag 8-way jumper link Modules (see table below) Timer modules (see table below) Technical data Rated current Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 97.01 and 97.02 sockets mm2 AWG P A PEAN N T E O O T EUR EUR 97.01 97.01 97.02 97.02 8-way jumper link for 97.01 and 97.02 sockets 095.18 (blue) Rated values 10 A - 250 V 095.18.0 (black) PEAN 095.18 86 series timer module 86.30 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. (12…24)V AC/DC; Bi-function: AI, DI; (0.05s…100h) 86.30.0.024.0000 (110...125)V AC; Bi-function: AI, DI; (0.05s…100h) 86.30.8.120.0000 (230...240)V AC; Bi-function: AI, DI; (0.05s…100h) 86.30.8.240.0000 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 97.01 and 97.02 Diode (+A1, standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (110...240)V AC sockets 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 5 97 Series - Sockets and accessories for 46 series relays 097.01 Metal retaining clip Modules (see table below) Timer modules (see table below) Technical data Rated current Dielectric strength Protection category Ambient temperature Wire strip length Max. wire size for 97.51 and 97.52 sockets °C mm 97.51 I ST ERED REG ITY ITY G N UN MM CO D E S I G I REG M CO D 097.01 10 A - 250 V AC 8 A - 250 V AC 6 kV (1.2/50 µs) between coil and contacts IP 20 –25…+70 8 solid wire stranded wire 2x(0.2...1.5) 2x(0.2...1.5) 2x(24...18) 2x(24...18) ERED N MU E S I 97.51 97.52 97.52 86 series timer module 86.30 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 6 97.52.0 (black) 097.71 99.02 86.30 mm2 AWG ST 97.51.0 (black) 97.52 (blue) 46.52 N 97.51 Approvals (according to type): Screwless terminal socket panel or 35 mm rail (EN 60715) mount 97.51 (blue) For relay type 46.61 Accessories Plastic retain and release clip (supplied with socket - packaging code SPA) (12…24)V AC/DC; Bi-function: AI, DI; (0.05s…100h) 86.30.0.024.0000 (110...125)V AC; Bi-function: AI, DI; (0.05s…100h) 86.30.8.120.0000 (230...240)V AC; Bi-function: AI, DI; (0.05s…100h) 86.30.8.240.0000 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 97.51 and 97.52 Diode (+A1, standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (110...240)V AC sockets 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07
097.01
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
097.01 价格&库存
很抱歉,暂时无法提供与“097.01”相匹配的价格&库存,您可以联系我们找货
    • 1+4.329781+0.56274
    • 10+4.0515610+0.52658
    • 50+3.8168150+0.49607
    库存:361
    097.01
      • 1+4.65499
      库存:184
