32.21.7.005.2000
32.21.7.005.2000
    FINDER
32.21.7.005.2000 数据手册
32 SЕRIES Subminiature PCB relays 6 A Copiers Hi-Fi systems Washing machines Control systems Electronic kits Medical and dentistry Electronic circuit boards Programmable controllers FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 32 SERIES Subminiature PCB relays 6 A 32 SERIES 32.21-4000 Printed circuit mount 6 A relay 32.21-4300 • 1 Pole changeover contacts or 1 Pole normally open contact A • Subminiature, low profile package • Sensitive DC coil - 200 mW • Wash tight: RT III • Cadmium Free contacts • 1 CO (SPDT), 6 A • Low coil power • PCB mount For outline drawing see page 5 • 1 NO (SPST-NO), 6 A • Low coil power • PCB mount Copper side view Copper side view 1 CO (SPDT) 1 NO (SPST-NO) 6/15 6/15 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A 250/400 250/400 Rated load AC1 V AC VA 1500 1500 Rated load AC15 (230 V AC) VA 250 250 Single phase motor rating (230 V AC) kW 0.185 0.185 Breaking capacity DC1: 30/110/220 V Minimum switching load A 3/0.35/0.2 3/0.35/0.2 mW (V/mA) 500 (10/5) 500 (10/5) AgSnO2 AgSnO2 Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W — — 5 - 12 - 24 - 48 5 - 12 - 24 - 48 —/0.2 —/0.2 Operating range AC — — DC (0.78…1.5)UN (0.78…1.5)UN Holding voltage AC/DC —/0.4 UN —/0.4 UN Must drop-out voltage AC/DC —/0.1 UN —/0.1 UN Mechanical life AC/DC cycles —/20 · 106 —/20 · 106 Electrical life at rated load AC1 cycles 50 · 103 50 · 103 ms 6/4 6/2 kV 5 5 1000 1000 –40…+85 –40…+85 RT III RT III Technical data XI-2018, www.findernet.com Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Environmental protection V AC °C Approvals (according to type) 3 32 SERIES Subminiature PCB relays 6 A 32 SERIES Ordering information Example: 32 series PCB, 1 NO (SPDT-NO) - 6 A contacts, 24 V sensitive DC coil. A A 3 2 . 2 B C D 1 . 7 . 0 2 4 . 4 . 3 . 0 . 0 Series Type 2 = PCB mount No. of poles 1 = 1 pole, 6 A A: Contact material 4 = Standard AgSnO2 D: Special versions 0 = Wash tight (RT III) B: Contact circuit 0=C  O (SPDT) 3=N  O (SPST) C: Options 0 = None Coil version 7 = Sensitive DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version 32.21 sens. DC A 4 B 0-3 C 0 D 0 Technical data Insulation according to EN 61810-1 Nominal voltage of supply system  V AC 230/400 Rated insulation voltage  V AC 250 Pollution degree 2 Insulation between coil and contact set Type of insulation Basic Overvoltage category III Rated impulse voltage kV (1.2/50 µs) 5 Dielectric strength V AC 4000 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50 µs) 1000/1.5 Insulation between coil terminals Rated impulse voltage (surge) differential mode (according to EN 61000-4-5) kV(1.2/50 µs) 2 Other data Bounce time: NO/NC ms 2/10 (changeover) Vibration resistance (5…55)Hz: NO/NC Shock resistance Power lost to the environment g 10/10 (changeover) 2/— (normally open) 10/— (normally open) g 20 without contact current with rated current  W 0.5 mm ≥ 5 XI-2018, www.findernet.com Recommended distance between relays mounte d on PCB W 0.2 4 32 SERIES Subminiature PCB relays 6 A 32 SERIES Contact specification F 32 - Electrical life (AC) v contact current H 32 - Maximum DC1 breaking capacity DC breaking current (A) A Cycles Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 50 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. Coil specifications DC coil data - 0.2 W sensitive Nominal voltage Coil code R 32 - DC coil operating range v ambient temperature Operating range Resistance Rated coil consumption UN Umin Umax R I at UN V V V Ω mA 7.5 125 40 720 16 5 7.005 3.9 12 7.012 9.4 18 24 7.024 18.7 36 2880 48 7.048 37.4 72 11520 8.3 4 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. Outline drawing XI-2018, www.findernet.com Types 32.21-4000/4300 Please see general technical information 5
32.21.7.005.2000 价格&库存
很抱歉,暂时无法提供与“32.21.7.005.2000”相匹配的价格&库存,您可以联系我们找货
