41.52.8.230.0000
41.52.8.230.0000
    FINDER
41.52.8.230.0000 数据手册
41 SERIES Low profile PCB relays 8 - 12 - 16 A 41 SERIES 41.31 1 & 2 Pole - Low profile (15.7 mm height) 41.31 - 1 Pole 12 A (3.5 mm pin pitch) 41.52 - 2 Pole 8 A (5 mm pin pitch) 41.61 - 1 Pole 16 A (5 mm pin pitch) 41.52 41.61 A PCB mount - direct or via PCB socket 35 mm rail mount - via screw and screwless sockets • AC and DC coils • 8 mm, 6 kV (1.2/50 μs) isolation, coil-contacts • Cadmium Free contact materials • Flux proof: RT II standard, (RT III option) • 3.5 mm contact pin pitch • 1 Pole 12 A • PCB direct or via socket • 5 mm contact pin pitch • 2 Pole 8 A • PCB direct or via socket • 5 mm contact pin pitch • 1 Pole 16 A • PCB direct or via socket Copper side view Copper side view Copper side view 1 CO (SPDT) 2 CO (DPDT) 1 CO (SPDT) 12/25 8/15 16/30 250/400 250/400 250/400 VA 3000 2000 4000 Rated load AC15 (230 V AC)VA 600 400 750 For UL ratings see: “General technical information” page V Contact specification Contact configuration Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage Rated load AC1 A V AC Single phase motor rating (230 V AC)kW 0.5 0.3 0.5 Breaking capacity DC1: 30/110/220 VA 12/0.3/0.12 8/0.3/0.12 16/0.3/0.12 300 (5/5) 300 (5/5) 300 (5/5) AgNi AgNi AgNi V AC (50/60 Hz) 24 - 230 24 - 230 24 - 230 V DC 5 - 6 - 12 - 24 - 48 - 60 - 110 5 - 6 - 12 - 24 - 48 - 60 - 110 5 - 6 - 12 - 24 - 48 - 60 - 110 0.75/0.4 0.75/0.4 0.75/0.4 AC (0.8…1.1)UN (0.8…1.1)UN (0.8…1.1)UN DC (0.7…1.5)UN (0.7…1.5)UN (0.7…1.5)UN Minimum switching load mW (V/mA) Standard contact material Coil specification Nominal voltage (UN)  Rated power AC/DC Operating range  VA (50 Hz)/W Holding voltage AC/DC 0.8/0.4 UN 0.8/0.4 UN 0.8/0.4 UN Must drop-out voltage AC/DC 0.15/0.1 UN 0.15/0.1 UN 0.15/0.1 UN Mechanical life AC/DC cycles 10 · 106 / 10 · 106 10 · 106 / 10 · 106 10 · 106 / 10 · 106 Electrical life at rated load AC1 cycles 60 · 103 60 · 103 50 · 103 ms 8/6 8/6 8/6 kV 6 (8 mm) 6 (8 mm) 6 (8 mm) 1000 1000 1000 –40…+70 (AC); +85 (DC) –40…+70 (AC); +85 (DC) –40…+70 (AC); +85 (DC) RT II RT II RT II Technical data X-2014, www.findernet.com Operate/release time Insulation between coil and contacts (1.2/50 μs) Dielectric strength between open contacts Ambient temperature range Environmental protection V AC °C Approvals (according to type) 1 41 SERIES 41.52.6.xxx 1 & 2 Pole - Polarized bistable, Low profile (15.7 mm height) 41.52 - 2 Pole 8 A (5 mm pin pitch) 41.61 - 1 Pole 16 A (5 mm pin pitch) 41.61.6.xxx Printed Circuit mount • Polarized bistable relay with 2 coils • 10 mm, 6 kV (1.2/50 μs) isolation, coil-contacts • Cadmium Free contact materials • Flux proof: RT II standard • 2 Pole, 8 A • PCB direct mount • 1 Pole, 16 A • PCB direct mount 2 coil version: A3(+) A2 (−) = Set A3(+) A1 (−) = Reset 2 coil version: A3(+) A2 (−) = Set A3(+) A1 (−) = Reset Copper side view Copper side view 2 CO (DPDT) 1 CO (SPDT) 8/15 16/30 250/400 250/400 VA 2000 4000 Rated load AC15 (230 V AC)VA 350 750 Contact specification Contact configuration Rated current/ Maximum peak current (IN/Imax)A Rated voltage/ Maximum switching voltage (UN/Umax)V AC Rated load AC1 Single phase motor rating (230 V AC)kW 0.37 0.55 Breaking capacity DC1: 30/110/220 VA 8/0.3/0.12 16/0.3/0.12 Minimum switching load 500 (5/100) 500 (5/100) AgSnO2 AgSnO2 5 - 12 - 24 5 - 12 - 24 mW (V/mA) Standard contact material Coil specification Nominal voltage (UN)  V DC 0.65 0.65 Operating range  Rated power (PN)W DC (0.7…1.1)UN (0.7…1.1)UN Min. impulse duration ms 20 20 Max. impulse duration s 30 30 Technical data Mechanical life DC cycles 5 · 106 5 · 106 Electrical life at rated load AC1 cycles 30 · 103 30 · 103 ms 10/5 10/10 kV 6 (10 mm) 6 (10 mm) 1000 1000 –40…+85 –40…+85 RT II RT II Operate/release time Insulation between coil and contacts (1.2/50 μs) Dielectric strength between open contacts Ambient temperature range Environmental protection Approvals (according to type) 2 V AC °C — X-2014, www.findernet.com A 41 SERIES Bistable low profile PCB relays 8 - 16 A 41 SERIES Low profile PCB relays (SSR) 3 - 5 A 41 SERIES 41.81 - 9024 Solid State Relays 41.81 - 8240 Printed circuit mount: - direct or via PCB socket 35 mm rail mount: - via screw or screwless sockets) A • Single circuit output switching options - 5 A 24 V DC - 3 A 240 V AC • Silent, high speed switching with long electrical life • LED indicator • Low profile (15.7 mm) • Wash tight: RT III • 2500 V AC insulation, input-output • 5 A, 24 V DC output switching • 3 A, 240 V AC output • PCB or 93 Series sockets switching • Zero crossing switching • PCB or 93 Series sockets Copper side view Copper side view 1 NO (SPST-NO) 1 NO (SPST-NO) A 5/40 3/40 V (24/35)DC (240/—)AC V (1.5…24)DC (12…275)AC — 600 Output circuit Contact configuration Rated current/ Maximum peak current (10 ms) Rated voltage/ Maximum blocking voltage Switching voltage range Repetitive peak off-state voltage Vpk Minimum switching current mA 1 50 Max. “OFF-state” leakage current mA 0.01 1 V 0.3 1.1 Max. “ON-state” voltage drop Input circuit Nominal voltage  V DC 12 24 12 24 Operating range V DC 8…17 14…32 8…17 14…32 Control current mA 5.5 9 8.8 9 Release voltage V DC Impedance Ω 4 9 4 9 1550 2600 1030 2600 Technical data Operate/release time Dielectric strength between input/output Ambient temperature range X-2014, www.findernet.com Environmental protection ms V AC °C 0.05/0.25 10/10 2500 2500 –20…+60 –20…+60 RT III RT III Approvals (according to type) 3 41 SERIES 41 SERIES Low profile PCB relays Ordering information Electromechanical relay (EMR) Example: 41 series low-profile PCB relay, 2 CO (DPDT), 24 V DC coil. A B C D 4 1 . 5 . 2 . 9 . 0 2 4 . 0 . 0 . 1 . 0 Series Type 3 = PCB - 3.5 mm pinning 5 = PCB - 5 mm pinning 6 = PCB - 5 mm pinning No. of poles 1 = 1 pole for 41.31, 12 A 41.61, 16 A 2 = 2 pole for 41.52, 8 A A: Contact material 0 = Standard AgNi 4 = AgSnO2 5=A  gNi + Au D: Special versions 0 = Flux proof (RT II) 1 = Wash tight (RT III) 6 = Bistable version (RT II) B: Contact circuit 0=C  O (nPDT) 3=N  O (nPST) C: Options 0 = Production line 0 1 = Production line 1 Coil version 6 = DC bistable, 2 coils 8 = AC 9 = DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version A B C D 41.31 DC 0-4-5 0-3 1 0-1 41.52 DC 0-5 0-3 1 0-1 41.61 DC 0-4 0-3 1 0-1 41.31/52/61 AC 0 0 0 0 41.52 DC bistable 4 0 1 6 41.61 DC bistable 4 0-3 1 6 Solid state relay (SSR) Example: 4  1 series SSR relay, 5 A output, 24 V DC supply. 4 1 . 8 Series Type 8 = SSR type 1 . 7 . 0 2 4 . 9 0 2 4 Output circuit 9024 = 5 A - 24 V DC 8240 = 3 A - 240 V AC Output 1 = 1 NO (SPST-NO) Input circuit See coil specifications X-2014, www.findernet.com A 4 41 SERIES Low profile PCB relays 41 SERIES Electromechanical relay Technical data A Insulation according to EN 61810-1 1 pole Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 250 Pollution degree 3 1 pole bistable 2 pole 2 pole bistable 230/400 230/400 230/400 400 250 250 400 250 2 2 3 2 2 Reinforced (10 mm) Reinforced (8 mm) Insulation between coil and contact set Type of insulation Reinforced (8 mm) Overvoltage category Rated impulse voltage Reinforced (10 mm) III III III III kV (1.2/50 μs) 6 6 6 6 4000 4000 4000 Dielectric strength V AC 4000 Insulation between adjacent contacts Type of insulation — — Basic Basic Overvoltage category — — III III Rated impulse voltage kV (1.2/50 μs) — — 4 4 V AC — — 2000 2000 Dielectric strength Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength Micro-disconnection V AC/kV (1.2/50 μs) 1000/1.5 1000/1.5 Conducted disturbance immunity Burst (5…50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 μs) on A1 - A2 (differential mode) EN 61000-4-5 level 3 (2 kV) Other data Bounce time: NO/NC ms 4/6 (monostable) - 2/10 (bistable) Vibration resistance (5…55)Hz: NO/NC g 15/2 (monostable) - 5/3 (bistable) Shock resistance g 16 (monostable) - 10 (bistable) Power lost to the environment without contact current W 0.4 (monostable) with rated current W 1.7 (41.31) 1.2 (41.52) 1.8 (41.61) mm ≥ 5 X-2014, www.findernet.com Recommended distance between relays mounted on PCB 5 41 SERIES Low profile PCB relays 41 SERIES Contact specification F 41 - Electrical life (AC) v contact current (monostable) Type 41.52 Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 Cycles Cycles Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 limit for 41.31 H 41- Maximum DC1 breaking capacity DC breaking current (A) F 41 - Electrical life (AC) v contact current (bistable) Cycles 1 pole 2 pole 41.61 limit current 41.31 limit current 41.52 limit current 41.52 -2 contacts in series single contact DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. Coil specifications AC coil data R 41 - AC coil operating range v ambient temperature Nominal voltage Coil code Operating range Resistance Rated coil consumption I at UN UN Umin Umax R V V V Ω mA 19.2 26.4 350 31.6 32500 3.2 24 8.024 230 8.230 184 253 DC coil data Nominal voltage Coil code Operating range Resistance Rated coil consumption I at UN UN Umin Umax R V V V Ω mA 5 9.005 3.5 7.5 62 80 6 9.006 4.2 9 90 66.7 12 9.012 8.4 18 360 33.3 24 9.024 16.8 36 1440 16.7 48 9.048 33.6 72 5760 8.3 60 9.060 42 90 9000 6.6 110 9.110 77 165 24200 4.5 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. R 41 - DC coil operating range v ambient temperature DC coil data (bistable) Nominal voltage 6 Coil code Operating range Resistance Rated coil power UN Set Umin Reset Umin Set/Reset Umax R I at UN V V V V Ω mW 5 6.005 3.5 3.5 5.5 38 650 12 6.012 8.4 8.4 13.2 220 650 24 6.024 16.8 16.8 26.4 885 650 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. X-2014, www.findernet.com A F 41 - Electrical life (AC) v contact current (monostable) Types 41.31/61 41 SERIES Low profile PCB relays 41 SERIES Solid state relay Technical data Other data 41.81 - 9024 Power lost to the environment A 41.81 - 8240 without current W 0.25 0.25 with maximum current W 1.75 3.5 Input specification Input data - DC types Nominal voltage Input code Operating range UN Umin Umax V V V Release voltage Impedance Control current V Ω mA I at UN 12 7.012 8 17 4 1550 5.5 24 7.024 14 32 9 2600 9 Output specification Output current L 41 - Output current v ambient temperature SSR - 3 A AC output types X-2014, www.findernet.com Output current L 41 - Output current v ambient temperature SSR - 5 A DC output types 7 41 SERIES 93 SERIES Sockets and accessories for 41 series relays A 93.02 Approvals (according to type): Screw terminal socket 35 mm (EN 60715) mounting Supply voltage Relay type 6 V AC/DC 41.52.9.005.0010 or 41.61.9.005.0010 12 V AC/DC 41.52.9.012.0010 or 41.61.9.012.0010 24 V AC/DC 41.52/61.9.024.0010 or 41.81.7.024.xxxx 60 V AC/DC 41.52.9.060.0010 or 41.61.9.060.0010 (110…125)V AC/DC 41.52.9.110.0010 or 41.61.9.110.0010 (220…240)V AC/DC 41.52.9.110.0010 or 41.61.9.110.0010 (230…240)V AC 41.52.9.110.0010 or 41.61.9.110.0010 6 V DC 41.52.9.005.0010 or 41.61.9.005.0010 12 V DC 41.52/61.9.012.0010 or 41.81.7.012.xxxx 24 V DC 41.52/61.9.024.0010 or 41.81.7.024.xxxx 48 V DC 41.52.9.048.0010 or 41.61.9.048.0010 60 V DC 41.52.9.060.0010 or 41.61.9.060.0010 Accessories 8-way jumper link 093.08 (see specification next page) Plastic separator 093.01 (see specification next page) Sheet of marker tags, 72 tags 060.72 (see specification next page) Technical data Rated values 10 A - 250 V Dielectric strength 6 kV (1.2/50 μs) between coil and contacts Protection category IP 20 °C –40…+70/–40…+55 Ambient temperature (UN ≤ 60 V / > 60 V) Screw torque Nm 0.5 Wire strip length mm 8 Max. wire size for 93.02 socket solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 Socket type 93.02.0.024 93.02.0.024 93.02.0.024 93.02.0.060 93.02.0.125 93.02.0.240 93.02.8.230 93.02.7.024 93.02.7.024 93.02.7.024 93.02.7.060 93.02.7.060 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 X-2014, www.findernet.com Note: Not for bistable relays 8 93 SERIES Sockets and accessories for 41 series relays 41 SERIES Screw terminal socket 35 mm (EN 60715) mounting Supply voltage Relay type 6 V AC/DC 41.52.9.005.0010 or 41.61.9.005.0010 12 V AC/DC 41.52.9.012.0010 or 41.61.9.012.0010 24 V AC/DC 41.52/61.9.024.0010 or 41.81.7.024.xxxx 60 V AC/DC 41.52.9.060.0010 or 41.61.9.060.0010 (110…125)V AC/DC 41.52.9.110.0010 or 41.61.9.110.0010 (220…240)V AC/DC 41.52.9.110.0010 or 41.61.9.110.0010 (230…240)V AC 41.52.9.110.0010 or 41.61.9.110.0010 6 V DC 41.52.9.005.0010 or 41.61.9.005.0010 12 V DC 41.52/61.9.012.0010 or 41.81.7.012.xxxx 24 V DC 41.52/61.9.024.0010 or 41.81.7.024.xxxx 48 V DC 41.52.9.048.0010 or 41.61.9.048.0010 60 V DC 41.52.9.060.0010 or 41.61.9.060.0010 93.52 Approvals (according to type): Socket type 93.52.0.024 93.52.0.024 93.52.0.024 93.52.0.060 93.52.0.125 93.52.0.240 93.52.8.230 93.52.7.024 93.52.7.024 93.52.7.024 93.52.7.060 93.52.7.060 A Accessories 8-way jumper link Plastic separator Sheet of marker tags, 72 tags Technical data Rated values Dielectric strength Protection category Ambient temperature (UN ≤ 60 V / > 60 V) Wire strip length Max. wire size for 93.52 socket 093.08 (see table below) 093.01 (see table below) 060.72 (see table below) 10 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 °C –40…+70/–40…+55 mm 8 solid wire stranded wire 1 x 2.5 mm2 1 x 2.5 AWG 1 x 14 1 x 14 Note: Not for bistable relays P A PEAN N T E O O T 8-way jumper link for 93.02 and 93.52 sockets Rated values 093.08 (blue) 10 A - 250 V 093.08.0 (black) 093.08.1 (red) EUR EUR Accessories PEAN 093.08 Approvals (according to type): X-2014, www.findernet.com 093.01 Plastic separator for 93.02 and 93.52 sockets 093.01 Thickness 2 mm, required at the start and the end of a group of interfaces. Can be used for visual separation group, must be used for: - protective separation of different voltages of neighbouring PLC interfaces according to VDE 0106-101 - protection of cut jumper links Sheet of marker tags for 38 x 2, plastic, 72 tags, 6 x 12 mm 060.72 060.72 9 41 SERIES 95.13.2 PCB socket 95.13.2 (blue) For relay type 41.31 95.13.20 (black) 95.15.2 (blue) 95.15.20 (black) 41.52, 41.61, 41.81(1) Accessories Plastic retaining clip 095.42 Technical data Rated values 10 A - 250 V* 95.15.2 Dielectric strength 6 kV (1.2/50 μs) between coil and contacts Approvals (according to type): Protection category IP 20 Ambient temperature °C –40…+70 * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). (1) With the relay 41.81 the NO change-over contact will be 11-14. 41.81 - 9024 41.61 41.81 - 8240 1.5 3.5 13 7.5 41.52 3.5 41.31 30 20 95.13.2 95.13. Copper side2view 95.15.2 Copper side view Note: Not for bistable relays Packaging codes How to code and identify retaining clip and packaging options for sockets. Example: 9 5 . 1 9 5 . 1 3 . 2 3 . 2 S L A A Standard packaging SL Plastic retaining clip Without retaining clip X-2014, www.findernet.com A 93 SERIES Sockets and accessories for 41 series relays 10
41.52.8.230.0000 价格&库存
很抱歉,暂时无法提供与“41.52.8.230.0000”相匹配的价格&库存,您可以联系我们找货
    • 1+112.01124
    • 5+100.80595
    库存:25
    41.52.8.230.0000
      • 1+144.607371+18.66760
      • 10+133.1403310+17.18730
      • 50+104.0788050+13.43570
