50 SERIES
Forcibly guided contacts relay 8 A
50
SERIES
50.12…1000
PCB Relay with forcibly guided contacts
according to EN 50205 type B
2 CO contacts*
50.12…5000
• High physical separation between adjacent
contacts
• Cadmium Free contact materials
• 8 mm, 6 kV (1.2/50 µs) isolation, coil-contacts
• Flux proof: RT II
• For medium duty switching,
suggested for DC loads
• 2 Pole 8 A
• 5 mm pinning
• PCB mounting
• For safety applications
• Gold plate contacts for low
level switching capability
C
• 5 mm pinning
• PCB mounting
*A
ccording to E N 50205 only 1 NO and 1 NC
(11-14 and 21-22 or 11-12 and 21-24) shall be
used as forcibly guided contacts.
For UL ratings see:
“General technical information” page V
Copper side view
Copper side view
2 CO (DPDT)
2 CO (DPDT)
8/15
8/15
Contact specification
Contact configuration
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
A
250/400
250/400
Rated load AC1
VA
2000
2000
Rated load AC15 (230 V AC)
VA
500
500
Single phase motor rating (230 V AC)
kW
0.37
0.37
Breaking capacity DC1: 30/110/220 V
A
8/0.65/0.2
8/0.65/0.2
mW (V/mA)
500 (10/10)
50 (5/5)
AgNi
AgNi + Au
Minimum switching load
V AC
Standard contact material
Coil specification
Nominal voltage (UN)
V AC (50/60 Hz)
V DC 5 - 6 - 12 - 24 - 48 - 60 - 110 - 125 5 - 6 - 12 - 24 - 48 - 60 - 110 - 125
Rated power AC/DC
Operating range
VA (50 Hz)/W
AC (50 Hz)
DC
—/0.7
—/0.7
(0.75…1.2)UN
(0.75…1.2)UN
Holding voltage
AC/DC
—/0.4 UN
—/0.4 UN
Must drop-out voltage
AC/DC
—/0.1 UN
—/0.1 UN
Mechanical life AC/DC
cycles
—/10 · 106
—/10 · 106
Electrical life at rated load AC1
cycles
100 · 10
100 · 103
ms
10/4
10/4
kV
6 (8 mm)
6 (8 mm)
Technical data
I-2016, www.findernet.com
Operate/release time
Insulation between coil
and contacts (1.2/50 µs)
Dielectric strength
between open contacts
Ambient temperature range
Environmental protection
V AC
°C
3
1500
1500
–40…+70
–40…+70
RT II
RT II
Approvals (according to type)
1
50 SERIES
50
SERIES
Ordering information
Example: 50 series forcibly guided contacts, 2 CO (DPDT) 8 A contacts, 24 V DC coil.
5 0 . 1
A
B
C
D
2 . 9 . 0 2 4 . 5
Series
A: Contact material
1 = Standard AgNi
5 = AgNi + Au
Type
1 = PCB - 5 mm pinning
C: Options
0 = None
B: Contact circuit
0 = CO (DPDT)
No. of poles
2 = 2 pole 8 A
Coil version
9 = DC
Coil voltage
See coil specifications
Selecting features and options: only combinations in the same row are possible.
Preferred selections for best availability are shown in bold.
Type
Coil version
A
B
C
D
50.12
DC
1-5
Technical data
Insulation according to EN 61810-1
Nominal voltage of supply system
V AC 230/400
Rated insulation voltage
V AC 250
Pollution degree
3
400
2
Insulation between coil and contact set
Type of insulation
Reinforced (8 mm)
Overvoltage category
III
Rated impulse voltage
kV (1.2/50 µs) 6
Dielectric strength
V AC 4000
Insulation between adjacent contacts
Type of insulation
Basic
III
kV (1.2/50 µs) 4
Dielectric strength
V AC 3000
Insulation between open contacts
Type of disconnection
Micro-disconnection
Dielectric strength
V AC/kV (1.2/50 µs) 1500/2.5
Conducted disturbance immunity
Burst (5…50)ns, 5 kHz, on A1 - A2
EN 61000-4-4
level 4 (4 kV)
Surge (1.2/50 µs) on A1 - A2 (differential mode)
EN 61000-4-5
level 3 (2 kV)
Other data
Bounce time: NO/NC
ms 2/10
Vibration resistance (10…200)Hz: NO/NC
Shock resistance NO/NC
Power lost to the environment
g 20/5
without contact current
W 0.7
with rated current
W 1.2
Recommended distance between relays mounted on PCB
2
g 20/6
mm ≥ 5
C
D: Special versions
0 = Flux proof (RT II)
50 SERIES
50
SERIES
H 50 - Maximum DC1 breaking capacity
DC breaking current (A)
F 50 - Electrical life (AC) v contact current
Resistive load - cosφ = 1
Cycles
Inductive load - cosφ = 0.4
C
DC voltage (V)
• When switching a resistive load (DC1) having voltage and current values
under the curve, an electrical life of ≥ 100 · 103 can be expected.
• In the case of DC13 loads, the connection of a diode in parallel with the
load will permit a similar electrical life as for a DC1 load.
Note: the release time for the load will be increased.
Alternative selection of NO and NC
contacts to provide Forcibly guided
(mechanically linked) contacts, in
accordance with EN 50205 (type B).
Coil specifications
R 50 - DC coil operating range v ambient temperature
Standard coil
DC coil data
Nominal
voltage
UN
V
5
6
12
24
48
60
110
125
Coil
code
9.005
9.006
9.012
9.024
9.048
9.060
9.110
9.125
Operating range
Resistance
Umin
Umax
R
Rated coil
consumption
I at UN
V
3.8
4.5
9
18
36
45
82.5
93.7
V
6
7.2
14.4
28.8
57.6
72
131
150
Ω
35
50
205
820
3280
5140
17250
22300
mA
143
120
58.5
29.3
14.4
11.7
6.4
5.6
1 - Max. permitted coil voltage.
2 - Min. pick-up voltage with coil at ambient temperature.
3
很抱歉,暂时无法提供与“50.12.9.005.1000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+127.1697450+16.45280
- 国内价格 香港价格
- 1+179.233141+23.18859
