65 SERIES
Power relays 20 - 30 A
65
SERIES
65.31
20 A Power relays
1 NO + 1 NC (SPST-NO + SPST-NC)
65.61
65.31 Flange mount
Faston 250 connections
65.61 PCB mount
A
• AC coils & DC coils
• Cadmium Free option available
• 20 A rated contacts
• Flange mount/Faston 250
(6.3 x 0.8 mm) connection
• PCB mount bifurcated terminals
65.61
* With the AgSnO2 material the maximum peak
current is 120 A - 5 ms on NO contact.
For UL ratings see:
“General technical information” page V
Copper side view
Contact specification
Contact configuration
1NO + 1NC (SPST-NO+SPST-NC) 1NO + 1NC (SPST-NO+SPST-NC)
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
A
V AC
20/40*
20/40*
250/400
250/400
Rated load AC1
VA
5000
5000
Rated load AC15 (230 V AC)
VA
1000
1000
Single phase motor rating (230 V AC)
kW
Breaking capacity DC1: 30/110/220 V
A
Minimum switching load
mW (V/mA)
Standard contact material
1.1
1.1
20/0.8/0.5
20/0.8/0.5
1000 (10/10)
1000 (10/10)
AgCdO
AgCdO
Coil specification
Nominal voltage (UN)
V AC (50/60 Hz)
V DC
Rated power AC/DC
VA (50 Hz)/W
6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 - 400
6 - 12 - 24 - 48 - 60 - 110 - 125 - 220
2.2/1.3
2.2/1.3
AC
(0.8…1.1)UN
(0.8…1.1)UN
DC
(0.85…1.1)UN
(0.85…1.1)UN
Holding voltage
AC/DC
0.8 UN / 0.6 UN
0.8 UN / 0.6 UN
Must drop-out voltage
AC/DC
0.2 UN / 0.1 UN
0.2 UN / 0.1 UN
Mechanical life AC/DC
cycles
10 · 106 / 30 · 106
10 · 106 / 30 · 106
Electrical life at rated load AC1
cycles
80 · 103
80 · 103
ms
10/12
10/12
kV
4
4
1500
1500
–40…+75
–40…+75
RT I
RT I
Operating range
Technical data
I-2014, www.findernet.com
Operate/release time
Insulation between coil
and contacts (1.2/50 μs)
Dielectric strength
between open contacts
Ambient temperature range
Environmental protection
V AC
°C
Approvals (according to type)
1
65
SERIES
65 SERIES
65.31-0300
30 A Power relays
1 NO (SPST-NO)
65.61-0300
65.31-0300 Flange mount
65.61-0300 PCB mount
A
• ≥ 3 mm contact gap
• 30 A rated contacts
65.61-0300
* Distance between contacts ≥ 3 mm
(EN 60335-1).
** With the AgSnO2 material the maximum peak
Copper side view
For UL ratings see:
Rated voltage/
1 NO (SPST-NO), ≥ 3 mm*
A
30/50**
30/50**
V AC
250/400
250/400
Rated load AC1
VA
7500
7500
VA
1250
1250
kW
A
mW (V/mA)
1.5
1.5
30/1.1/0.7
30/1.1/0.7
1000 (10/10)
1000 (10/10)
AgCdO
AgCdO
Coil specification
V AC (50/60 Hz)
V DC
Rated power AC/DC
VA (50 Hz)/W
6 - 12 - 24 - 48 - 60 - 110 -125 - 220
2.2/1.3
2.2/1.3
AC
(0.8…1.1)UN
(0.8…1.1)UN
DC
(0.85…1.1)UN
(0.85…1.1)UN
Holding voltage
AC/DC
0.8 UN / 0.6 UN
0.8 UN / 0.6 UN
AC/DC
0.2 UN / 0.1 UN
0.2 UN / 0.1 UN
cycles
10 · 106 / 30 · 106
10 · 106 / 30 · 106
cycles
50 · 103
50 · 103
ms
15/4
15/4
kV
4
4
2500
2500
–40…+75
–40…+75
RT I
RT I
Operating range
Dielectric strength
2
V AC
°C
Technical data
65 SERIES
65
SERIES
Ordering information
Example: 65 series power relay, PCB with bifurcated terminals, 1 NO + 1 NC (SPST-NO + SPST-NC) contact, 12 V DC coil.
6 5 . 6
A
B
C
D
1 . 9 . 0 1 2 . 0
Series
A: Contact material
0 = Standard AgCdO
4 = AgSnO2
Type
3 = Faston 250 (6.3 x 0.8 mm)
with rear flange mount
6 = PCB with bifurcated terminals
D: Special versions
0 = Standard
9 = Type 65.31 without rear flange
mount
B: Contact circuit
0 = 1 NO + 1 NC
(SPST-NO + SPST-NC)
3 = NO (≥ 3 mm contact gap)
No. of poles
1 = 1 NO + 1 NC (SPST-NO + SPST-NC)
A
C: Options
0 = None
Coil version
8 = AC (50/60 Hz)
9 = DC
Coil voltage
See coil specifications
Selecting features and options: only combinations in the same row are possible.
Preferred selections for best availability are shown in bold.
Type
Coil version
A
B
C
D
65.31
AC-DC
0-4
0-3
65.61
AC-DC
0-4
0-3
Technical data
Insulation according to EN 61810-1
1 NO + 1 NC
Nominal voltage supply system
V AC 230/400
Rated insulation voltage
V AC 250
Pollution degree
3
1 NO
230/400
400
250
400
2
3
2
Insulation between coil and contact set
Type of insulation
Basic
Basic
III
III
kV (1.2/50 μs) 4
4
Overvoltage category
Rated impulse voltage
Dielectric strength
V AC 2500
2500
Insulation between open contacts
Type of disconnection
Micro-disconnection
Full-disconnection
III
kV (1.2/50 μs) —
4
Dielectric strength
V AC/kV (1.2/50 μs) 1500/2
2500/4
Conducted disturbance immunity
Burst (5…50)ns, 5 kHz, on A1 - A2
EN 61000-4-4
level 4 (4 kV)
Surge (1.2/50 μs) on A1 - A2 (differential mode)
EN 61000-4-5
level 4 (4 kV)
Other data
Bounce time: NO/NC
ms 5/6
7/—
(1 normally open + 1 normally closed) (normally open)
Vibration resistance (10…150)Hz: NO/NC
Shock resistance
Power lost to the environment
g 20/13
g 20
without contact current
with rated current
Recommended distance between relays mounted on PCB
W 1.3
W 2.1 (65.31, 65.61)
3.1 (65.31/.61.0300)
mm ≥ 5
3
65 SERIES
65
SERIES
F 65 - Electrical life (AC) v contact current
H 65 - Maximum DC1 breaking capacity
Cycles
Resistive load - cosφ = 1
Inductive load - cosφ = 0.4
limit for 1NO+1NC types
DC breaking current (A)
A
1 normally open type
1 normally open + 1 normally closed type
DC voltage (V)
• When switching a resistive load (DC1) having voltage and current
values under the curve, an electrical life of ≥ 80 · 103 can be expected.
• In the case of DC13 loads, the connection of a diode in parallel with the
load will permit a similar electrical life as for a DC1 load.
Note: the release time for the load will be increased.
Coil specifications
DC coil data
AC coil data
Coil code
Operating range
Umin
UN
V
Resistance
Rated coil
consumption
Nominal
voltage
Umax
R
I at UN
UN
Ω
mA
V
Coil code
Operating range
Umin
Resistance
Rated coil
consumption
Umax
R
I at UN (50 Hz)
Ω
V
V
V
V
6
9.006
5.1
6.6
28
214
6
8.006
4.8
6.6
12
9.012
10.2
13.2
110
109
12
8.012
9.6
13.2
24
9.024
20.4
26.4
445
48
9.048
40.8
52.8
1770
60
9.060
51
110
9.110
93.5
mA
4.6
19
183
54
24
8.024
19.2
26.4
74
90
27.1
48
8.048
38.4
52.8
290
47
66
2760
21.7
60
8.060
48
66
450
37
121
9420
11.7
110
8.110
88
121
1600
9.125
106
138
12000
10.4
120
8.120
96
132
1940
18.6
220
9.220
187
242
37300
5.8
230
8.230
184
253
7250
10.5
240
8.240
192
264
8500
400
8.400
320
440
19800
R 65 - DC coil operating range v ambient temperature
R 65 - AC coil operating range v ambient temperature
1 - Max. permitted coil voltage.
2 - Min. pick-up voltage with coil at ambient temperature.
4
367
9.2
6
Nominal
voltage
65 SERIES
65
SERIES
Accessories
Top flange mount for types 65.31.xxxx.xxx9
065.05
A
065.05
065.05
065.05 with relay
065.05 with relay
Top 35 mm rail (EN 60715) mount for types 65.31.xxxx.xxx9
065.07
065.07
065.07
065.07 with relay
065.07 with relay
Rear 35 mm rail (EN 60715) mount for types 65.31.xxxx.xxx9
065.08
065.08
065.08 with relay
065.08
065.08 with relay
5
很抱歉,暂时无法提供与“65.31.8.230.0000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+139.792961+18.04610
- 50+102.5031750+13.23230
- 100+97.86383100+12.63340
