Modular relays with
forcibly guided
contacts 6 - 10 A
Chemical and
petrolchemical
Hoists and cranes
Woodprocessing
machines
Carousel
warehouses
Escalators
Elevators
and lifts
Process
Industry
Automatic
car-washes
7S
SЕRIES
FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products.
7S SERIES
Modular relays with forcibly guided contacts 6 A
7S
SERIES
7S.12/32....5110
7S.14/34....4xx0
7S.16/36....5420
Type 7S.12/32
- 2 pole 6 A (1 NO + 1 NC)
Type 7S.14/34
- 4 pole 6 A (2 NO + 2 NC and 3 NO + 1 NC)
Type 7S.16/36
- 6 pole 6 A (4 NO + 2 NC)
• For safety applications, with class A forcibly
guided contact relays EN 61810-3 (previously
EN 50205)
• For functional reliability in machinery and
plant engineering according to EN 13849-1
• For railway applications; materials compliant
with fire and smoke characteristics EN 45545;
mechanical and climatic characteristics
compliant with EN 61373 and EN 50155
• DC and AC supply versions
• 24 and 110 V DC versions with extended
operating range (0.7…1.25)UN
• Coil status visual indication with LED
• 35 mm rail (EN 60715) mount
Screwless terminal
• 2 pole (1 NO + 1 NC)
• 4 pole :
• 6 pole (4 NO + 2 NC)
(2 NO + 2 NC) type
7S.xxxxx.4220
(3 NO + 1 NC) type
7S.xxxxx.4310
C
Screw terminal
For outline drawing see page 12
Contact specification
Contact configuration
Rated current/Max. peak current
Rated switching voltage
A
1 NO + 1 NC
2 NO + 2 NC, 3 NO + 1 NC
4 NO + 2 NC
6/15
6/15
6/15
V AC (50/60 Hz)
250
250
250
VA
1500
1500
1500
Rated current AC15 (230 V AC)
A
3
3
3
Rated current AC15 (400 V AC)
A
2
Breaking capacity DC1: 30/110/220 V
A
6/0.6/0.2
6/0.9/0.3
6/0.9/0.3
Rated load AC1
Breaking capacity DC13: 24 V
Minimum switching load
A
mW (V/mA)
Standard contact material
1
3
3
60 (5/5)
60 (5/10)
60 (5/10)
AgNi + Au
AgSnO2
AgSnO2+Au
110…125 - 230…240
110…125 - 230…240
110…125 - 230…240
12 - 24
12 - 24 - 110
12 - 24 - 110
Coil specification
Nominal voltage (UN)
V AC (50/60 Hz)
V DC
Rated power
Operating range
VA (50 Hz)/W
AC
2.3/1
2.3/1
2.3/1
(0.85…1.1)UN
(0.85…1.1)UN
(0.85…1.1)UN
DC
(0.8…1.2)UN
(0.8…1.2)UN
(0.8…1.2)UN
DC extended range (24 and 110 V only)
(0.7…1.25)UN
(0.7…1.25)UN
(0.7…1.25)UN
Holding voltage
AC/DC
0.45 UN / 0.45 UN
0.55 UN / 0.55 UN
0.55 UN / 0.55 UN
Must drop-out voltage
AC/DC
0.1 UN / 0.1 UN
0.1 UN / 0.1 UN
0.1 UN / 0.1 UN
Mechanical life
cycles
10 · 106
10 · 106
10 · 106
Electrical life at rated load AC1
cycles
100 · 103
100 · 103
100 · 103
7/11
12/10
12/10
6
6
6
Technical data
I-2019, www.findernet.com
Operate/release time
ms
Insulation between coil and contacts (1.2/50 µs) kV
Dielectric strength between open contacts V AC
Ambient temperature
Protection category
°C
1500
1500
1500
–40….+70
–40….+70
–40….+70
IP 20
IP 20
IP 20
Approvals (according to type)
3
7S
SERIES
7S SERIES
Modular relays with forcibly guided contacts 10 A
7S.23
Type 7S.23
- 3 pole (2 NO + 1 NC)
• 3 pole (2 NO + 1 NC)
Screw terminal
2 NO + 1 NC
A
10/20
V AC (50/60 Hz)
250
VA
2500
A
5
A
6/0.6/0.2
A
5
Rated load AC1
mW (V/mA)
60 (5/5)
AgNi + Au
Coil specification
Rated power
V DC
12 - 24 - 48 -110
W
1
Operating range
DC
(0.8…1.2)UN
Holding voltage
DC
0.45 UN
DC
0.1 UN
Mechanical life
cycles
10 · 106
cycles
100 · 103
Technical data
ms
Ambient temperature
Protection category
4
°C
7/11
6
1500
–40….+70
IP 20
C
EN 50205)
• DC coil
• Cadmium free contacts
• 17.5 mm wide
7S SERIES
for SIL3 safety applications
7S
SERIES
7S.43/63....0211
Type 7S.43/63
-2 NO safety contacts
- 1 NC feedback contact
- 1 auxiliary signalling contact
• For safety application, with class A forcicbly
EN 50205) for safety application up to SIL 3
• Double channel architecture (12) with
2 NO contact, 1 feedback contact and
1 auxiliary contact
• SIL 3 evaluated according to EN 61508, for use
in functional safety application according to
EN 62061 up to SIL 3 and according to
IEC 13849-1 up to PL e
• From 12 up to 110 V DC version with operating
range (0.85…1.1)UN
Screwless terminal
• 1 auxliary contact
C
Screw terminal
2 NO + 1 NC + 1 AUX
A
6/15
V AC (50/60 Hz)
250
VA
1500
Rated load AC1
A
3
A
6/0.6/0.2
A
mW (V/mA)
3
60 (5/10)
AgSnO2 & AgNi+Au
Coil specification
Rated power
V DC
12 - 24 - 48 -110
W
1.7
Operating range
DC
(0.85…1.1)UN
Holding voltage
DC
0.55 UN
DC
0.1 UN
Mechanical life
cycles
10 · 106
cycles
100 · 103
Technical data
Operate/release time of NO contacts
ms
10/7
Operate/release time of NC contacts
ms
5/30
Ambient temperature
Protection category
°C
6
1500
–40….+70
IP 20
5
7S
SERIES
7S SERIES
Modular relays with forcibly guided contacts 6 - 10 A
Ordering information
Example: 7S series Modular relay with forcibly guided contacts, 6 contact (4 NO + 2 NC) 6 A, supply voltage 24 V DC.
7 S . 1
6 . 9 . 0 2 4 . 5
4 2
Special versions
0 = Standard
1 = NO auxliary contact
Series
Type
1 = 22.5 mm wide, screwless terminals
2 = 17.5 mm wide, screw terminals
3 = 22.5 mm wide, screw terminals
4 = 22.5 mm wide, screwless terminals
6 = 22.5 mm wide, screw terminals
C
NO and NC contatcs
11 = 1 NO + 1 NC
21 = 2 NO + 1 NC
22 = 2 NO + 2 NC
31 = 3 NO + 1 NC
42 = 4 NO + 2 NC
Output
2 = 2 contacts
3 = 3 contacts
4 = 4 contacts
6 = 6 contacts
Contact material
0 = AgNi +Au (7S.23) only
0 = AgSnO2 & AgNi + Au
(7S.43/63) only
4 = AgSnO2 (7S.14/34) only
5 = AgNi +Au (7S.12/32) only
5 = AgSnO2 + Au (7S.16/36) only
Supply version
8 = AC (50 /60 Hz)
9 = DC
Supply voltage
See page 10
Codes, Preferred selections for best availability are shown in bold.
7S.12.9.012.5110
7S.14.9.012.4220
7S.16.9.012.5420
7S.12.9.024.5110
7S.14.9.012.4310
7S.16.9.024.5420
7S.12.8.120.5110
7S.14.9.024.4220
7S.16.9.110.5420
7S.12.8.230.5110
7S.14.9.024.4310
7S.16.8.120.5420
7S.14.9.110.4220
7S.16.8.230.5420
7S.32.9.012.5110
7S.14.9.110.4310
7S.32.9.024.5110
7S.14.8.120.4220
7S.36.9.012.5420
7S.32.8.120.5110
7S.14.8.120.4310
7S.36.9.024.5420
7S.32.8.230.5110
7S.14.8.230.4220
7S.36.9.110.5420
7S.14.8.230.4310
7S.36.8.120.5420
7S.43.9.012.0211
7S.36.8.230.5420
7S.43.9.024.0211
7S.34.9.012.4220
7S.43.9.048.0211
7S.34.9.012.4310
7S.23.9.012.0210
7S.43.9.110.0211
7S.34.9.024.4220
7S.23.9.024.0210
7S.34.9.024.4310
7S.23.9.048.0210
7S.23.9.110.0210
7S.63.9.012.0211
7S.34.9.110.4220
7S.63.9.024.0211
7S.34.9.110.4310
7S.63.9.048.0211
7S.34.8.120.4220
7S.63.9.110.0211
7S.34.8.120.4310
7S.34.8.230.4220
7S.34.8.230.4310
6
7S SERIES
7S
SERIES
Technical data
Insulation according to EN 61810-1
Nominal voltage of supply system
V AC 230/400
Rated insulation voltage
V AC 250
Pollution degree
2
Insulation between coil and contact set
Type of Insulation
Reinforced
Overvoltage category
III
Rated impulse voltage
kV (1.2/50 µs) 6
Dielectric strength
V AC 4000
C
Insulation between adjacent contacts
Type of Insulation
Basic
III
kV (1.2/50 µs) 4
Dielectric strength
V AC 2500
Insulation between open contacts
Type of disconnection
Micro-disconnection
Dielectric strength
V AC/kV (1.2/50 µs) 1500/2.5
Insulation between coil terminals
Rated impulse voltage (surge) differential mode
(according to EN 61000-4-5)
kV(1.2/50 µs) 1.5
Terminals
Screw Terminal
Min. wire size
solid cable
Screwless Terminal
stranded cable solid cable
0.5
0.5
0.5
AWG 21
21
21
21
Screw Terminal
Max. wire size
solid cable
Wire strip length
stranded cable
mm2 0.5
Screwless Terminal
stranded cable
mm2 1 x 6 / 2 x 2.5
1 x 4 / 2 x 2.5
1 x 1.5
1 x 1.5
AWG 1 x 10 / 2 x 14
1 x 12 / 2 x 14
1 x 14
1 x 16
mm 9
Other data
7S.12/32
Bounce time: NO/NC
ms 2/8
7S.14/34
7S.16/36
7S.23
7S.43/63
2/10
2/10
2/15
1/8
Vibration resistance (10…200)Hz: NO/NC
g 10/5
20/6
20/6
10/2
10/2
Shock resistance: NO/NC
g 20/6
20/5
20/5
20/6
20/5
without contact current
W 0.8
0.8
0.8
0.8
1.7
with rated current
W 1.4
2.3
2.8
1.4
3.8
Power lost to the environment
7
7S SERIES
7S
SERIES
Contact specifications
Contact diagrams
7S.12/7S.32
7S.14....4310
7S.14/34....4220
7S.16/36....5420
12
11
7S.23
34
33
11 12
43
C
54 33 34
7S.43/7S.63
23
23
24
24
11
33 23
12
12
34 24
24
47
47
48
48
33 23
11 47 48
47 48
F 7S12 - Electrical life (AC) v contact current - 7S.12
H 7S12* - Maximum DC breaking capacity - 7S.12
Corrente DC (A)
Resistive load
Cycles
Resistive load - cosϕ = 1
Inductive load - AC15
Inductive load - DC13
Tensione DC (V)
F 7S14 - Electrical life (AC) v contact current - 7S.14/34
H 7S14* - Maximum DC breaking capacity - 7S.14/34
2
4
6
8
Tensione DC (V)
* When switching a load having voltage and current values under the
curve, an electrical life of ≥ 100 · 103 can be expected.
8
Cycles
Corrente DC (A)
7S SERIES
7S
SERIES
H 7S16* - Maximum DC breaking capacity - 7S.16/36
DC breaking current (A)
Cycles
F 7S16 - Electrical life (AC) v contact current - 7S.16/36
2
4
6
8
DC voltage (V)
H 7S23* - Maximum DC breaking capacity - 7S.23
Cycles
F 7S23 - Electrical life (AC) v contact current - 7S.23
C
Resistive load
DC voltage (V)
H 7S43* - Maximum DC breaking capacity - 7S.43/63
F 7S43 - Electrical life (AC) v contact current - 7S.43/63
Cycles
2
4
6
8
Resistive load
DC voltage (V)
9
7S SERIES
7S
SERIES
Coil specifications
DC coil data - type 7S.12/32
Nominal
Coil
Operating range
voltage
code
UN
V
12
24
Umax
V
14.4
30
DC coil data - type 7S.14/34 / 7S.16/36
Operating range
Nominal
Coil
voltage
code
UN
V
12
24
110
9.012
9.024
9.110
Umin
V
9.6
16.8
77
Umax
V
14.4
30
138
Rated
power
at UN
Rated input
current
Rated
power
at UN
at UN
IN
mA
64.7
42.2
11.6
W
0.7
0.9
W
0.8
1
1.4
Coil
code
Operating range
Rated input
current
at UN
UN
Umin
V
UN
V
110…125
230…240
8.120
8.230
Umin
V
93
195
Umax
V
138
264
AC coil data - type 7S.14/34 / 7S.16/36
Nominal
Coil
Operating range
voltage
code
UN
V
110…125
230…240
8.120
8.230
Umin
V
93
195
Umax
V
138
264
Rated input
current
at UN
IN
mA
9.8
11.8
Rated input
current
at UN
IN
mA
10.2
11.8
Rated
power
at UN
VA/W
1.2/1.1
2.8/1.2
Rated
power
at UN
VA/W
1.3/1.1
2.9/1.2
DC coil data - type 7S.43/63
DC coil data - type 7S.23
Nominal
voltage
AC coil data - type 7S.12/32
Nominal
Coil
Operating range
voltage
code
Umax
Rated
power
at UN
IN
Nominal
voltage
Coil
code
Operating range
Rated input
current
at UN
UN
Umin
Umax
V
V
mA
W
V
12
9.012
9.6
14.4
47.1
0.6
12
24
9.024
16.8
30
26.6
0.6
24
9.024
20.4
48
9.048
33.6
60
16.2
0.8
48
9.048
40.8
110
9.110
77
138
8.8
1
110
9.110
93.5
121
9.012
Rated
power
at UN
IN
V
V
mA
W
10.2
13.2
105
1.3
26.4
60
1.45
52.8
36
1.6
R 7S - DC coil operating range v ambient temperature 7S.12/32 / 7S.23 / 7S.14/34 / 7S.16/36
R 7S - AC coil operating range v ambient temperature 7S.12/32 / 7S.14/34 / 7S.16/36
1 - Max. permitted coil voltage.
2 - Min. pick-up voltage with coil at ambient temperature.
- - - - - 24 and 110 V DC coils only (extended range) excluding 7S.23
R 7S - DC coil operating range v ambient temperature - 7S.43/63
10
C
9.012
9.024
Umin
V
9.6
16.8
Rated input
current
at UN
IN
mA
55
38.2
7S SERIES
7S
SERIES
Example wiring diagrams
Type 7S.x2
Type 7S.x4....4220
Safety PLC
feedback
output
Safety PLC
feedback
output
C
feedback
Type 7S.43
Safety PLC
L
feedback
output
K1
K2
K3
K4
23
47
48
K2
K3
K1
K4
feedback
3
4
11
7S
SERIES
7S SERIES
Outline drawings
Types 7S.12/14/16/43
Screwless terminal
Type 7S.23
Screw terminal
C
Type 7S.63
Screw terminal
96
78.8
4.3
30.5
86.2
22.5
59.5
Type 7S.36
Screw terminal
Type 7S.34
Screw terminal
33.8
Type 7S.32
Screw terminal
Accessories
060.48
Sheet of marker tags, plastic, 48 tags, 6 x 12 mm, for CEMBRE thermal transfer printers
060.48
12
Please see general technical information
很抱歉,暂时无法提供与“7S.12.9.024.5110”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+681.416011+87.96510
- 10+606.8262110+78.33618
- 25+579.4203325+74.79831
- 50+559.4949650+72.22612
- 100+540.24725100+69.74140
- 国内价格 香港价格
- 1+391.280241+50.51100
- 5+366.770515+47.34700
- 10+339.8973510+43.87790
