94 Series - Sockets and accessories for 55 series relays
Relay type
55.32
Colour
BLUE
BLACK BLUE
55.33
BLACK BLUE
BLACK
Clamp terminal socket: panel or 35 mm rail (EN 50022) mount
retaining clip 094.01 supplied with socket packaging code SPA
94.02
94.02.0 94.03
94.03.0 94.04
94.04.0
Metal retaining clip
94.04
Approvals
(according to type):
094.71
Plastic retaining and release clip
094.01
6-way jumper link for 94.02, 94.03 and 94.04 sockets
094.06 094.06.0 094.06 094.06.0 094.06 094.06.0
Identification tag
094.00.4
Modules (see table below)
Sheet of marker tags for retaining and release clip 094.01
060.72
83
Rated values: 10 A - 250 V
Dielectric strength: ≥ 2 kV AC
Protection category: IP 20
Ambient temperature: (–40…+70)°C
Screw torque: 0.5 Nm
Wire strip length: 8 mm
Max wire size:
solid wire
stranded wire
27
25.9
27
60.9
17.5
17.5
Ø3
35.6
Ø3
18.9
34.9
34.9
34.9
mm2 1x6 / 2x2.5 1x4 / 2x2.5
Ø 3.2
Ø3
76
Ø 3.2
21.5
27
76
AWG 1x10 / 2x14 1x12 / 2x14
32
094.01
41
12
11
9
44
8
42
4
COM
31
9
94 02 145
NO
34
6
12
1
NC
32
3
21
8
11
7
94245 03 144
22
2
12
1
COM
41
12
31
11
21
10
11
9
NO
44
8
34
24
14
94
04
7
6
5
NO
NC
42
4
32
3
22
2
NC
A2
14
A1
13
12
1
35.5
COM
060.72
A2
14
FOR 94.02, 94.03 AND 94.04 SOCKETS:
A1
13
COIL
94.02
A2
14
A1
13
COIL
6-way jumper link
COIL
94.04
94.03
094.06
135
3.3
- Rated values: 10 A - 250 V
094.06
5.1
10.3
7
55
US
86.10, 86.20
Ø 3.2
C
99.02
Timer modules (see table below)
76
55.32, 55.34
0.75
86.10
27
BLUE
Mono-function: (12…24)V AC/DC; function AI; (1.5s…60min)
86.10.0.024.0000
Mono-function: (12…24)V AC/DC; function DI; (1.5s…60min)
86.20.0.024.0000
Approvals
27
27
26.25
C
US
99.02 coil indication and EMC suppression modules
(see technical data page 209)
Diode** (+A1, standard polarity)
(6...220)V DC
Diode (+A2, non standard polarity)
(6...220)V DC
LED (Green)
(6...24)V DC/AC
99.02
LED
(28...60)V DC/AC
Approvals
LED
(Green)
(110...240)V
DC/AC
LED (Green)+ Diode** (+A1, standard polarity)
(6...24)V DC
C
US
LED + Diode** (+A1, standard polarity)
(28...60)V DC
(110...220)V DC
LED + Diode (+A2, non standard polarity)
(6...24)V DC
(28...60)V DC
(110...220)V DC
LED + Varistor
(6...24)V DC/AC
* Modules in Black
LED + Varistor
(28...60)V DC/AC
housing are
LED + Varistor
(110...240)V DC/AC
available on request.
RC circuit
(6...24)V DC/AC
RC
circuit
(28...60)V
DC/AC
**For DC supply,
RC
circuit
(110...240)V
DC/AC
apply the positive
to terminal A1.
Residual current by-pass (62 kΩ/1W)
(110...240)V AC
55
26.25
86 series module timers (see technical data pages 151/155)
BLUE*
99.02.3.000.00
99.02.2.000.00
99.02.0.024.59 (99.01.0.024.50=Red)
99.02.0.060.59
99.02.0.230.59 (99.01.0.230.50=Red)
99.02.9.024.99 (99.01.9.024.90=Red)
99.02.9.060.99
99.02.9.220.99
99.02.9.024.79
99.02.9.060.79
99.02.9.220.79
99.02.0.024.98
99.02.0.060.98
99.02.0.230.98
99.02.0.024.09
99.02.0.060.09
99.02.0.230.09
99.02.8.230.07
Relay type
55.32
Colour
BLUE
BLACK BLUE
55.33
BLACK BLUE
BLACK
Screw terminal socket: panel or 35 mm rail (EN 50022) mount
retaining clip 094.71 supplied with socket packaging code SMA
94.72
94.72.0 94.73
94.73.0 94.74
94.74.0
94.74
094.71
14.5
16.5
99.01
16.5
Approvals
55.32, 55.34
Ø3
solid wire
stranded wire
Ø3
23
24
30
35
36.3
19
19
19
36.3
Ø 4.1
Ø 4.2
35
70.5
Ø3
35
70.5
Max wire size:
Ø 4.2
US
68.5
C
24
23
24
23
30
27
26
30
55
27
44
8
14
5
NO
34
6
24
5
14
4
NO
44
8
34
7
24
6
14
5
NO
42
4
12
1
NC
32
3
22
2
12
1
NC
42
4
32
3
22
2
12
1
NC
A2
14
A1
13
COIL
A1
COIL
A2
14
A1
13
COIL
COM
41
12
31
11
21
10
11
9
COM
mm2 1x2.5 / 2x1.5 1x2.5 / 2x1.5
AWG 1x14 / 2x16 1x14 / 2x16
41
12
11
9
A2
31
9
COM
21
8
11
7
94.74
94.73
94.72
Relay type
55.32
Colour
BLUE
BLACK
Screw terminal socket: panel or 35 mm rail (EN 50022) mount, 23 mm wide 94.82
Approvals
094.71
99.01
42
4
12
1
NC
44
8
14
5
NO
41
12
11
9
COM
A2
14
A1
13
COIL
23
29.5
US
stranded wire
mm 1x2.5 / 2x1.5 1x2.5 / 2x1.5
26
99.01 coil indication and EMC suppression modules
(see technical data pag. 209)
99.01
35
solid wire
2
FOR 94.72, 94.73, 94.74 AND 94.82 SOCKETS:
Approvals
Ø 4.2
- Max wire size:
LED
BLUE*
(6...220)V DC 99.01.3.000.00
(6...220)V DC 99.01.2.000.00
(6...24)V DC/AC 99.01.0.024.59
LED
(28...60)V DC/AC 99.01.0.060.59
LED
(110...240)V DC/AC 99.01.0.230.59
(6...24)V DC 99.01.9.024.99
(28...60)V DC 99.01.9.060.99
(110...220)V DC 99.01.9.220.99
* Modules in Black
housing are
available on request. LED + Diode (+A2, non standard polarity)
LED + Varistor
**For DC supply,
LED + Varistor
apply the positive
LED + Varistor
to terminal A1.
RC circuit
Green LED is standard. RC circuit
RC circuit
Red LED available on
request.
40.3
Wire strip length: 9 mm
71.3
C
15.5
20.8
94.82
94.82.0
(6...24)V DC 99.01.9.024.79
(28...60)V DC 99.01.9.060.79
(110...220)V DC 99.01.9.220.79
(6...24)V DC/AC 99.01.0.024.98
(28...60)V DC/AC 99.01.0.060.98
(110...240)V DC/AC 99.01.0.230.98
(6...24)V DC/AC 99.01.0.024.09
(28...60)V DC/AC 99.01.0.060.09
(110...240)V DC/AC 99.01.0.230.09
(110...240)V AC 99.01.8.230.07
56
094.91.3
Approvals
BLUE
BLACK
55.32, 55.34
BLUE
BLACK
94.82.3
94.82.30
94.84.3
94.84.30
094.71
094.91.3
Identification tag
094.80.2
99.80
US
86
65
Wire strip length: 7 mm
Max wire size:
27
42
4
12
1
stranded wire
solid wire
NO
44
8
34
7
24
6
14
5
NO
NC
42
4
32
3
22
2
12
1
NC
47
20.8
14
5
76.2
44
8
A2
14
mm 1x6 / 2x2.5 1x4 / 2x2.5
A1
13
COIL
A2
14
A1
13
31
11
21
10
35.6
C
55
55.32
Colour
94.84.3
Relay type
COIL
41
12
11
9
COM
94.82.3
41
12
11
9
19.9
2
COM
94.84.3
30
34
Relay type
094.92
94.54.1
Approvals
55.32, 55.34
Colour
BLUE
BLACK
Screwless terminal socket: 35 mm rail (EN 50022) mount
94.54.1
94.54.10
094.71
094.92
Sheet of marker tags for retaining and release clip 094.92
020.24
99.80
80
42.5
31
31
11
21
10
11
9
COM
44
8
34
7
24
6
14
5
NO
42
4
32
3
22
2
12
1
NC
30
24
41
12
mm2 2x(0.2…1.5) 2x(0.2…1.5)
35
Ambient temperature: (–25…+70)°C
Max wire size:
solid wire
stranded wire
2.5 mm
33.2
AWG 2x(24…18) 2x(24…18)
A1
13
COIL
30
A2
14
6
94.54.1
15.45
020.24
FOR 94.82.3, 94.84.3 AND 94.54.1 SOCKETS:
99.80 coil indication and EMC suppression modules
99.80
Approvals
BLUE*
(6...220)V DC 99.80.3.000.00
LED
(6...24)V DC/AC 99.80.0.024.59
LED
(28...60)V DC/AC 99.80.0.060.59
LED
(110...240)V DC/AC 99.80.0.230.59
(6...24)V DC 99.80.9.024.99
(28...60)V DC 99.80.9.060.99
* Modules in Black
LED + Varistor
housing are
available on request. LED + Varistor
(6...24)V DC/AC 99.80.0.024.98
**For DC supply,
apply the positive
to terminal A1.
LED + Varistor
(110...220)V DC 99.80.9.220.99
(28...60)V DC/AC 99.80.0.060.98
(110...240)V DC/AC 99.80.0.230.98
RC circuit
(6...24)V DC/AC 99.80.0.024.09
RC circuit
(28...60)V DC/AC 99.80.0.060.09
RC circuit
57 request.
(110...240)V DC/AC 99.80.0.230.09
(110...240)V AC 99.80.8.230.07
27
Relay type
55.32
Colour
BLUE
BLACK BLUE
55.33
BLACK BLUE
BLACK
P.C.B. socket
retaining clip 094.51 supplied with socket packaging code SMA
94.12
94.12.0 94.13
94.13.0 94.14
94.14.0
094.51
Approvals
3.7 11.5
29.5
21.5
29.5
21.5
29.5
21.5
25.5
94.14
55.32, 55.34
US
8.5
= 13.2 =
6.6
29.5
1.5
5.3
4.1
Copper side view
6.3
5.3
4.1
6.3
7.5
5.3
4.1
6.3
21.5
21.5
222
323
424
121
222
323
121
222
323
424
145
119
246
2110
347
3111
448
4112
144
245
346
117
218
319
145
119
246
2110
347
3111
448
4112
A214
A113
94.12
55
7.5
121
A113
A214
A113
94.13
A214
94.15
Relay type
55.32
Colour
BLUE
BLACK
Panel mount solder socket: 1 mm thick panel
94.22
94.22.0 94.23
55.33
Approvals
7.5
21.5
94.22
4.4
29.5
1.5
- Dielectric strength: ≥ 2 kV AC
- Ambient temperature: (–40…+70)°C
29.5
1.5
C
BLUE
55.32, 55.34
BLACK BLUE
BLACK
94.23.0 94.24
94.24.0
094.51
21.5
17
21.5
1
21.5
94.34
25.5
29.5
29.5
25.8
US
29.5
C
21.8
9.5
94.22
94.23
2
94.24
Relay type
55.32
Colour
BLUE
BLACK BLUE
55.33
BLACK BLUE
BLACK
Panel mount socket: M3 screw mount - solder connections
94.32
94.32.0 94.33
94.33.0 94.34
94.34.0
55.32, 55.34
094.51
Approvals
7.5
21.5
21.5
21.5
Ø 3.2
17
8.5 3
US
40.5
40.5
40.5
34
26.5
C
7.5
22.5
94.32
94.33
94.34
58
PACKAGING CODES
How to code and identify retaining clip and packaging options for sockets.
Code options according to the last three letters:
9 4 . 0
4
S P
A
A
Standard packaging
SM Metal retaining clip
SP Plastic retaining clip
9 4 . 0
55
59
4
Without retaining clip
很抱歉,暂时无法提供与“94.74SMA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+66.392401+8.62940
- 10+59.1807810+7.69206
- 30+55.9985030+7.27844
- 50+54.5770650+7.09369
- 100+52.70401100+6.85024
- 250+50.32498250+6.54102
- 500+48.59550500+6.31623
- 1000+46.924851000+6.09909
