95.75SMA
95.75SMA
    FINDER
95.75SMA 数据手册
95 Series - Sockets and Accessories for 40 Series Relays Relay type Screw terminal socket: panel or 35 mm rail (EN 50022) mount BLUE BLACK* 095.01 Identification tag 095.00.4 095.00.4 Modules 99.02 99.02 Timer modules 86.10, 86.20 86.10, 86.20 8-way jumper link for 95.03 and 95.05 sockets 095.18 095.18 - RATED VALUES: 10 A - 250 V with a current >10 A, the contact terminal must be connected in parallel (21 with 11, 24 with 14, 22 with 12) - INSULATION: ≥ 6 kV (1.2/50µs) between coil and contacts - PROTECTION CATEGORY: IP 20 - AMBIENT TEMPERATURE: (-40…+70) °C - TORQUE: 0.5 Nm - MAX WIRE SIZE: flexible wire 1x6 / 2x2.5 1x4 / 2x2.5 AWG 1x14 / 2x12 1x14 / 2x12 mm 78.6 Ø 3.2 15.8 Ø 3.2 17.5 A2 32 15.8 COM 21 11 COM 14 NO 24 14 NO 12 NC 22 12 NC A1 COIL A2 A1 COIL 11 95.05 95.03 99 Series modules for 95.03 and 95.05 sockets BLUE BLACK* Diode (6...220) V DC 99.02.3.000.00 99.02.3.000.00.0 Diode (inverted polarity) (6...220) V DC 99.02.2.000.00 99.02.2.000.00.0 (6...24) V DC/AC 99.02.0.024.59 99.02.0.024.59.0 LED 99.02 17.5 = 22.4 28.3 solid wire 2 75.3 60.9 35.4 US 95.05.0 095.01 = ® C 95.03.0 Retaining and release clip (supplied with socket) 28.3 Approvals (according to type): 40.51, 40.52, 40.61 95.05 78.6 95.05 40.31 95.03 LED (28...60) V DC/AC 99.02.0.060.59 99.02.0.060.59.0 LED (110...240) V DC/AC 99.02.0.230.59 99.02.0.230.59.0 LED + Diode (6...24) V DC 99.02.9.024.99 99.02.9.024.99.0 LED + Diode (28...60) V DC 99.02.9.060.99 99.02.9.060.99.0 LED + Diode (110...220) V DC 99.02.9.220.99 99.02.9.220.99.0 LED + Diode (inverted polarity) (6...24) V DC 99.02.0.024.79 99.02.0.024.79.0 LED + Diode (inverted polarity) (28...60) V DC 99.02.9.060.79 99.02.9.060.79.0 LED + Diode (inverted polarity) (110...220) V DC 99.02.9.220.79 99.02.9.220.79.0 LED + Varistor (6...24) V DC/AC 99.02.0.024.98 99.02.0.024.98.0 LED + Varistor (28...60) V DC/AC 99.02.0.060.98 99.02.0.060.98.0 LED + Varistor 99.02.0.230.98.0 (110...240) V DC/AC 99.02.0.230.98 RC (6...24) V DC/AC 99.02.0.024.09 99.02.0.024.09.0 RC (28...60) V DC/AC 99.02.0.060.09 99.02.0.060.09.0 RC (110...240) V DC/AC 99.02.0.230.09 99.02.0.230.09.0 (110...240) V AC 99.02.8.230.07 99.02.8.230.07.0 No - remanence 8-way jumper link for 95.03, and 95.05 sockets 095.18 15 *Available on request 15.8 15.8 15.8 15.8 15.8 15 10.3 - RATED VALUES: 10 A - 250 V 5.1 7 095.18 3.3 110.5 95 Series - Sockets and Accessories for 40 Series Relays Relay type Screw terminal socket: panel or 35 mm rail (EN 50022) mount BLUE BLACK* 40.51, 40.52, 40.61 95.63 95.65 95.75 95.75.0 95.63.0 95.65.0 Retaining clip (supplied with socket) 095.71 095.71 095.71 Modules 99.01 — 99.01 8-way jumper link for 95.63 and 95.75 sockets 095.08 095.08 095.08 23.4 38 95.65 Ø 3.5 Approvals (according to type): COM 11 12 NC 14 NO ® C solid wire mm 27 35.5 15.5 1x6 / 2x2.5 1x4 / 2x2.5 1x14 / 2x12 COIL 95.63 35 19.1 11 COM 22 12 NC 24 14 NO 21 11 COM 24 14 NO A2 A1 COIL A2 A1 COIL 22 12 NC 95.75 95.65 99 Series modules for 95.63 and 95.75 sockets BLUE BLACK* Diode (6...220) V DC 99.01.3.000.00 99.01.3.000.00.0 Diode (inverted polarity) (6...220) V DC 99.01.2.000.00 99.01.2.000.00.0 LED (6...24) V DC/AC 99.01.0.024.59 99.01.0.024.59.0 LED (28...60) V DC/AC 99.01.0.060.59 99.01.0.060.59.0 LED (110...240) V DC/AC 99.01.0.230.59 99.01.0.230.59.0 LED + Diode (6...24) V DC 99.01.9.024.99 99.01.9.024.99.0 LED + Diode (28...60) V DC 99.01.9.060.99 99.01.9.060.99.0 LED + Diode (110...220) V DC 99.01.9.220.99 99.01.9.220.99.0 LED + Diode (inverted polarity) (6...24) V DC 99.01.0.024.79 99.01.0.024.79.0 LED + Diode (inverted polarity) (28...60) V DC 99.01.9.060.79 99.01.9.060.79.0 LED + Diode (inverted polarity) (110...220) V DC 99.01.9.220.79 99.01.9.220.79.0 LED + Varistor (6...24) V DC/AC 99.01.0.024.98 99.01.0.024.98.0 LED + Varistor (28...60) V DC/AC 99.01.0.060.98 99.01.0.060.98.0 LED + Varistor (110...240) V DC/AC 99.01.0.230.98 99.01.0.230.98.0 (6...24) V DC/AC 99.01.0.024.09 99.01.0.024.09.0 RC (28...60) V DC/AC 99.01.0.060.09 99.01.0.060.09.0 RC (110...240) V DC/AC 99.01.0.230.09 99.01.0.230.09.0 (110...240) V AC 99.01.8.230.07 99.01.8.230.07.0 RC No - remanence *Available on request A1 54 flexible wire AWG 1x14 / 2x12 99.01 A2 28 15.5 21 US - RATED VALUES: 10 A - 250 V with a current >10 A, the contact terminal must be connected in parallel (21 with 11, 24 with 14, 22 with 12) - INSULATION: ≥ 6 kV (1.2/50µs) - between coil and contacts - PROTECTION CATEGORY: IP 20 - AMBIENT TEMPERATURE: (-40…+70) °C - TORQUE: 0.5 Nm - MAX WIRE SIZE: 2 27 11.1 11 27 35.5 15.5 73.1 35.4 68 35.5 Ø 3.2 27 68 65 Ø 3.2 95.75 GOST 25 18.5 18.5 23.5 19 95.63 40.31 95 Series - Sockets and Accessories for 40 Series Relays 8-way jumper link for 95.63, 95.65 and 95.75 sockets 095.08 113.1 095.08 13.9 7 10 3 - RATED VALUES: 10 A - 250 V 0.75 15.8 Relay type P.C.B. socket BLUE BLACK* 95.13 15.8 15.8 15.8 15.8 15.8 15.8 40.31 40.51, 40.52, 40.61 95.13 95.15 95.13.0 95.15.0 Metal retaining clip 095.51 095.51 Plastic retaining clip 095.52 095.52 4 10 13 Ø 3.2 30 30 Ø 3.2 95.15 4 10 13 7.5 7.5 Approvals (according to type): 55 95.13 *Available on request 30 20 3.5 1.5 RATED VALUES: 10 A - 250 V INSULATION: ≥ 6 kV (1.2/50µs) between coil and contacts PROTECTION CATEGORY: IP 20 AMBIENT TEMPERATURE: (-40…+70) °C 1.5 - US 30 20 C 13 7.5 3.5 13 7.5 ® 95.15 95 Series - Sockets and Accessories for 41 Series Relays Relay type Screw terminal socket: panel or 35 mm rail (EN 50022) mount BLUE BLACK* 95.05 Approvals (according to type): ® 95.03.0 095.00.4 095.00.4 Modules 99.02 99.02 Timer modules 86.10, 86.20 86.10, 86.20 8-way jumper link for 95.03 and 95.05 sockets 095.18 095.18 US 75.3 60.9 1x4 / 2x2.5 1x14 / 2x12 = 17.5 Ø 3.2 A2 35.4 78.6 15.8 32 15.8 COM 21 11 COM 14 NO 24 14 NO 12 NC 22 12 NC A1 COIL A2 A1 COIL 11 95.05 95.03 99 Series modules for 95.03 and 95.05 sockets BLUE BLACK* Diode (6...220) V DC 99.02.3.000.00 99.02.3.000.00.0 Diode (inverted polarity) (6...220) V DC 99.02.2.000.00 99.02.2.000.00.0 (6...24) V DC/AC 99.02.0.024.59 99.02.0.024.59.0 LED 99.02 17.5 = 1x6 / 2x2.5 AWG 1x14 / 2x12 Ø 3.2 28.3 flexible wire 22.4 28.3 solid wire mm 95.03.0 Identification tag - RATED VALUES: 10 A - 250 V with a current >10 A, the contact terminal must be connected in parallel (21 with 11, 24 with 14, 22 with 12) - INSULATION: ≥ 6 kV (1.2/50µs) between coil and contacts - PROTECTION CATEGORY: IP 20 - AMBIENT TEMPERATURE: (-40…+70) °C - TORQUE: 0.5 Nm - MAX WIRE SIZE: 2 41.52, 41.61 95.05 78.6 C 41.31 95.03 LED (28...60) V DC/AC 99.02.0.060.59 99.02.0.060.59.0 LED (110...240) V DC/AC 99.02.0.230.59 99.02.0.230.59.0 LED + Diode (6...24) V DC 99.02.9.024.99 99.02.9.024.99.0 LED + Diode (28...60) V DC 99.02.9.060.99 99.02.9.060.99.0 LED + Diode (110...220) V DC 99.02.9.220.99 99.02.9.220.99.0 LED + Diode (inverted polarity) (6...24) V DC 99.02.0.024.79 99.02.0.024.79.0 LED + Diode (inverted polarity) (28...60) V DC 99.02.9.060.79 99.02.9.060.79.0 LED + Diode (inverted polarity) (110...220) V DC 99.02.9.220.79 99.02.9.220.79.0 LED + Varistor (6...24) V DC/AC 99.02.0.024.98 99.02.0.024.98.0 LED + Varistor (28...60) V DC/AC 99.02.0.060.98 99.02.0.060.98.0 LED + Varistor 99.02.0.230.98.0 (110...240) V DC/AC 99.02.0.230.98 RC (6...24) V DC/AC 99.02.0.024.09 99.02.0.024.09.0 RC (28...60) V DC/AC 99.02.0.060.09 99.02.0.060.09.0 RC (110...240) V DC/AC 99.02.0.230.09 99.02.0.230.09.0 (110...240) V AC 99.02.8.230.07 99.02.8.230.07.0 No - remanence 8-way jumper link for 95.03, and 95.05 sockets 095.18 15 *Available on request 15.8 15.8 15.8 15.8 15.8 15 10.3 - RATED VALUES: 10 A - 250 V 5.1 7 095.18 3.3 110.5 23 95 Series - Sockets and Accessories for 41 Series Relays Relay type P.C.B. socket BLUE BLACK* 95.13 41.31 41.52, 41.61 95.13 95.15 95.13.0 95.15.0 Metal retaining clip 095.41 095.41 Plastic retaining clip 095.42 095.42 4 10 13 ® 13 7.5 55 95.13 24 *Available on request 30 20 3.5 1.5 RATED VALUES: 10 A - 250 V INSULATION: ≥ 6 kV (1.2/50µs) between coil and contacts PROTECTION CATEGORY: IP 20 AMBIENT TEMPERATURE: (-40…+70) °C 13 7.5 1.5 - US 7.5 30 20 C 7.5 3.5 Approvals (according to type): Ø 3.2 30 30 Ø 3.2 95.15 4 10 13 95.15 95 Series - Sockets and Accessories for 43 Series Relays P.C.B. socket 43.41 BLUE BLACK* Retaining clip (supplied with socket) 95.23 95.23.0 095.43 95.23 RATED VALUES: 10 A - 250 V INSULATION: ≥ 6 kV (1.2/50µs) between coil and contacts PROTECTION CATEGORY: IP 20 AMBIENT TEMPERATURE: (-40…+70)°C 10 7.5 1.5 3.2 30.5 22.2 - 4.5 10 30.5 Approvals (according to type): 3.2 Relay type 95.23 *Available on request 28 10.5 95 Series - Sockets and Accessories for 44 Series Relays Relay type 44.52, 44.62 Screw terminal socket: panel or 35 mm rail (EN 50022) mount BLUE BLACK* Approvals (according to type): ® C 095.01 Identification tag 095.00.4 Modules 99.02 Timer modules 86.10, 86.20 8-way jumper link for 95.05 sockets 095.18 RATED VALUES: 10 A - 250 V INSULATION: ≥ 6 kV (1.2/50µs) between coil and contacts PROTECTION CATEGORY: IP 20 AMBIENT TEMPERATURE: (-40…+70)°C TORQUE: 0.5 Nm MAX WIRE SIZE: 1x6 / 2x2.5 1x4 / 2x2.5 1x14 / 2x12 17.5 = flexible wire AWG 1x14 / 2x12 17.5 Ø 3.2 = mm 22.4 28.3 solid wire 2 75.3 60.9 78.6 - US 95.05.0 Retaining and release clip (supplied with socket) 35.4 95.05 95.05 32 15.8 21 11 COM 24 14 NO 22 12 NC A2 A1 COIL 95.05 99 Series modules for 95.05 sockets 99.02 BLUE BLACK* Diode (6...220) V DC 99.02.3.000.00 99.02.3.000.00.0 Diode (inverted polarity) (6...220) V DC 99.02.2.000.00 99.02.2.000.00.0 LED (6...24) V DC/AC 99.02.0.024.59 99.02.0.024.59.0 LED (28...60) V DC/AC 99.02.0.060.59 99.02.0.060.59.0 LED (110...240) V DC/AC 99.02.0.230.59 99.02.0.230.59.0 LED + Diode (6...24) V DC 99.02.9.024.99 99.02.9.024.99.0 LED + Diode (28...60) V DC 99.02.9.060.99 99.02.9.060.99.0 LED + Diode (110...220) V DC 99.02.9.220.99 99.02.9.220.99.0 LED + Diode (inverted polarity) (6...24) V DC 99.02.0.024.79 99.02.0.024.79.0 LED + Diode (inverted polarity) (28...60) V DC 99.02.9.060.79 99.02.9.060.79.0 LED + Diode (inverted polarity) (110...220) V DC 99.02.9.220.79 99.02.9.220.79.0 LED + Varistor (6...24) V DC/AC 99.02.0.024.98 99.02.0.024.98.0 LED + Varistor (28...60) V DC/AC 99.02.0.060.98 99.02.0.060.98.0 LED + Varistor (110...240) V DC/AC 99.02.0.230.98 99.02.0.230.98.0 (6...24) V DC/AC 99.02.0.024.09 99.02.0.024.09.0 RC (28...60) V DC/AC 99.02.0.060.09 99.02.0.060.09.0 RC (110...240) V DC/AC 99.02.0.230.09 99.02.0.230.09.0 (110...240) V AC 99.02.8.230.07 99.02.8.230.07.0 RC No - remanence 8-way jumper link for 95.05 sockets 095.18 5.1 - RATED VALUES: 10 A - 250 V 32 *Available on request 15 15.8 15.8 15.8 15.8 15.8 15 10.3 7 095.18 3.3 110.5 95 Series - Sockets and Accessories for 44 Series Relays Relay type 44.52, 44.62 Screw terminal socket: panel or 35 mm rail (EN 50022) mount BLUE BLACK* 95.65 95.65 95.75 95.65.0 95.75.0 Retaining clip (supplied with socket) 095.71 095.71 Modules — 99.01 8-way jumper link for 95.65/75 sockets 095.08 095.08 25 38 19 18.5 23.5 95.75 35 Ø 3.2 35.4 68 73.1 Ø 3.2 Approvals (according to type): ® RATED VALUES: 10 A - 250 V INSULATION: ≥ 6 kV (1.2/50µs) between coil and contacts PROTECTION CATEGORY: IP 20 AMBIENT TEMPERATURE: (-40…+70)°C TORQUE: 0.5 Nm MAX WIRE SIZE: solid wire flexible wire 1x6 / 2x2.5 1x4 / 2x2.5 AWG 1x14 / 2x12 1x14 / 2x12 mm2 27 27 35.5 15.5 28 54 15.5 21 11 COM 22 12 NC 24 14 NO 21 11 COM 24 14 NO A2 A1 COIL A2 A1 COIL 22 12 NC 95.75 95.65 99 Series modules for 95.75 sockets 99.01 19.1 - US 11.1 C BLUE BLACK* Diode (6...220) V DC 99.01.3.000.00 99.01.3.000.00.0 Diode (inverted polarity) (6...220) V DC 99.01.2.000.00 99.01.2.000.00.0 LED (6...24) V DC/AC 99.01.0.024.59 99.01.0.024.59.0 LED (28...60) V DC/AC 99.01.0.060.59 99.01.0.060.59.0 LED (110...240) V DC/AC 99.01.0.230.59 99.01.0.230.59.0 LED + Diode (6...24) V DC 99.01.9.024.99 99.01.9.024.99.0 LED + Diode (28...60) V DC 99.01.9.060.99 99.01.9.060.99.0 LED + Diode (110...220) V DC 99.01.9.220.99 99.01.9.220.99.0 LED + Diode (inverted polarity) (6...24) V DC 99.01.0.024.79 99.01.0.024.79.0 LED + Diode (inverted polarity) (28...60) V DC 99.01.9.060.79 99.01.9.060.79.0 LED + Diode (inverted polarity) (110...220) V DC 99.01.9.220.79 99.01.9.220.79.0 LED + Varistor (6...24) V DC/AC 99.01.0.024.98 99.01.0.024.98.0 LED + Varistor (28...60) V DC/AC 99.01.0.060.98 99.01.0.060.98.0 LED + Varistor (110...240) V DC/AC 99.01.0.230.98 99.01.0.230.98.0 (6...24) V DC/AC 99.01.0.024.09 99.01.0.024.09.0 RC (28...60) V DC/AC 99.01.0.060.09 99.01.0.060.09.0 RC (110...240) V DC/AC 99.01.0.230.09 99.01.0.230.09.0 (110...240) V AC 99.01.8.230.07 99.01.8.230.07.0 RC No - remanence 8-way jumper link for 95.65 and 95.75 sockets 095.08 113.1 095.08 3 13.9 7 10 - RATED VALUES: 10 A - 250 V *Available on request 0.75 15.8 15.8 15.8 15.8 15.8 15.8 15.8 33 95 Series - Sockets and Accessories for 44 Series Relays Relay type P.C.B. socket 44.52, 40.62 BLUE BLACK* 95.15 95.15 95.15.0 Metal retaining clip 095.51 Plastic retaining clip 095.52 Approvals (according to type): 4 10 13 ® - US RATED VALUES: 10 A - 250 V INSULATION: ≥ 6 kV (1.2/50µs) between coil and contacts PROTECTION CATEGORY: IP 20 AMBIENT TEMPERATURE: (-40…+70)°C Ø 3.2 30 C 7.5 1.5 30 20 55 13 7.5 95.15 34 *Available on request
95.75SMA 价格&库存
很抱歉,暂时无法提供与“95.75SMA”相匹配的价格&库存,您可以联系我们找货
95.75SMA
  • 1+56.99746
  • 10+52.34960
  • 20+49.08794
  • 30+46.80478
  • 50+43.54313
  • 100+41.42305
库存:658
95.75SMA
    • 1+51.60057
    • 25+49.67401
    • 50+47.91407
    • 100+47.24758
    • 250+47.04972
    库存:692
    95.75SMA
    • 1+56.897581+7.34500
    • 10+52.2582410+6.74610
    • 20+49.0194520+6.32800
    • 30+46.7435530+6.03420
    • 50+43.5047650+5.61610
    • 100+41.31640100+5.33360
    库存:688
