096.71
096.71
    FINDER
    夹,压紧 56和 86 系列
096.71 数据手册
96 Series - Sockets and accessories for 56 series relays 094.91.3 REG I ST L 96 - Rated current vs ambient temperature 86.30 060.72 ST TY — — 090.00.2 99.02 86.00, 86.30 — ERED UN MM CO D E S I ITY Rated current (A) G MM CO D E S I — 12 A - 250 V 2 kV AC IP 20 –40…+70 (see diagram L96) 0.8 8 solid wire stranded wire 1x6 / 2x2.5 1x4 / 2x2.5 1x10 / 2x14 1x12 / 2x14 ERED I UN 096.71 — 094.91.30 094.06.0 96.04.0 Black G Approvals (according to type): 094.06 095.00.4 96.04 Blue 56.34 I 96.04 094.71 094.91.3 REG Approvals (according to type): 96.02.0 Black N 96.02 96.02 Blue 56.32 N Screw terminal (Box clamp) socket panel or 35 mm (EN 60715) rail mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Plastic retaining and release clip (supplied with socket - packaging code SPA) 6-way jumper link Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for retaining and release clip 094.91.3 plastic, 72 tags, 6x12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 94.02/04 sockets mm2 AWG N T E O P A 96.02 96.04 96.04 PEAN T EUR EUR 96.02 O 6-way jumper link for 96.02 socket 094.06 (blue) Rated values 10 A - 250 V 86 series timer modules Multi-voltage: (12…240)V AC/DC; Multi-functions: AI, DI, SW, BE, CE, DE, EE, FE; (0.05 s…100 h) (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) (110...125)V AC; Bi-function: AI, DI; (0.05s…100h) 86.00.0.240.0000 86.30.0.024.0000 86.30.8.120.0000 (230...240)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.8.240.0000 094.06.0 (black) PEAN 094.06 86.00 Approvals (according to type): 86.30 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 99.02 coil indication and EMC suppression modules for 96.02 and 96.04 Diode (+A1, standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (110...240)V AC sockets 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 7 96 Series - Sockets and accessories for 56 series relays 96.72 Approvals (according to type): Screw terminal (Plate clamp) socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Modules (see table below) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 96.72 and 96.74 sockets mm2 AWG 96.72 Blue 56.32 96.72.0 Black 094.71 96.74 Blue 56.34 096.71 99.01 12 A - 250 V 2 kV AC IP 20 –40…+70 0.8 10 solid wire 1x4 / 2x4 1x12 / 2x12 stranded wire 1x4 / 2x2.5 1x12 / 2x14 96.74 Approvals (according to type): 96.72 96.74 99.01 coil indication and EMC suppression modules for types 96.72 and 96.74 sockets Blue* Diode (+A1, standard polarity) (6...220)V DC Diode (+A2, non-standard polarity) (6...220)V DC 99.01.3.000.00 99.01.2.000.00 99.01 LED (6...24)V DC/AC 99.01.0.024.59 Approvals (according to type): LED (28...60)V DC/AC 99.01.0.060.59 LED (110...240)V DC/AC 99.01.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.01.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.01.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.01.9.220.99 LED + Diode (+A2, non-standard polarity) (6...24)V DC 99.01.9.024.79 LED + Diode (+A2, non-standard polarity) (28...60)V DC 99.01.9.060.79 LED + Diode (+A2, non-standard polarity) (110...220)V DC 99.01.9.220.79 LED + Varistor (6...24)V DC/AC 99.01.0.024.98 * Modules in Black housing are available on request. LED + Varistor (28...60)V DC/AC 99.01.0.060.98 LED + Varistor (110...240)V DC/AC 99.01.0.230.98 RC circuit (6...24)V DC/AC 99.01.0.024.09 Green LED is standard. Red LED available on request. RC circuit (28...60)V DC/AC 99.01.0.060.09 RC circuit (110...240)V DC/AC 99.01.0.230.09 (110...240)V AC 99.01.8.230.07 8 Residual current by-pass 96.74.0 Black
096.71 价格&库存
很抱歉,暂时无法提供与“096.71”相匹配的价格&库存,您可以联系我们找货
  • 1+3.367181+0.43502
