22 Series - Modular monostable relays 20 A
Features
22.21
22
SERIES
22.22
1 or 2 pole, 20 A relay
for direct 35 mm rail (EN 60715) mounting
17.4 mm wide
Test button
• Identification label
• AC coils and DC coils
• 35 mm rail (EN 60715) mount
• Cadmium free contact material
• Single phase switch 1 NO
• Double phase switch 2 NO
(SPST-NO)
(DPST-NO)
• 35 mm rail (EN 60715) mount • 35 mm rail (EN 60715) mount
Contact specification
Contact configuration
Rated current/Maximum peak current
A
Rated voltage/Maximum switching voltage V AC
1 NO (SPST-NO)
2 NO (DPST-NO)
20/30
20/30
250/400
250/400
VA
5,000
5,000
Rated load AC15 (230 V AC)
VA
1,000
1,000
Single phase motor rating (230 V AC)
kW
Rated load AC1
Breaking capacity DC1: 30/110/220 V
Minimum switching load
A
20/0.3/0.12
20/0.3/0.12
mW (V/mA)
1,000 (10/10)
1,000 (10/10)
AgSnO2
AgSnO2
Standard contact material
Coil specification
Nominal voltage (UN)
V AC (50/60 Hz)
V DC
Rated power AC/DC
VA (50 Hz)/W
Operating range
AC (50 Hz)
DC
12 - 24 - 230
12 - 24
12 - 24
3/1.25
3/1.25
(0.85…1.1)UN
(0.85…1.1)UN
(0.9…1.1)UN
(0.9…1.1)UN
L
Technical data
Mechanical life AC/DC
cycles
500 · 103
500 · 103
Electrical life at rated load in AC1
cycles
50 · 103
50 · 103
15/8
15/8
continuous
continuous
4
4
X-2014, www.findernet.com
Operate/release time
ms
Maximum impulse duration
Insulation between coil and contacts (1.2/50 µs) kV
Ambient temperature range
Protection category
°C
–40…+40
IP 20
–40…+40
IP 20
Approvals (according to type)
1
22
SERIES
Features
22.23
22.24
17.4 mm wide
Test button
• Double phase switch 2 NC
1NO+1NC (SPST-NO+SPST-NC)
(DPST-NC)
A
2 NC (DPST-NC)
20/30
20/30
250/400
250/400
VA
5,000
5,000
VA
1,000
1,000
kW
Rated load AC1
A
mW (V/mA)
20/0.3/0.12
20/0.3/0.12
1,000 (10/10)
1,000 (10/10)
AgSnO2
AgSnO2
Coil specification
V AC (50/60 Hz)
V DC
Rated power AC/DC
VA (50 Hz)/W
Operating range
DC
12 - 24
3/1.25
3/1.25
(0.85…1.1)UN
(0.85…1.1)UN
(0.9…1.1)UN
(0.9…1.1)UN
Technical data
cycles
500 · 103
500 · 103
cycles
50 · 103
50 · 103
15/8
15/8
continuous
continuous
4
4
ms
Protection category
2
°C
–40…+40
IP 20
–40…+40
IP 20
L
AC (50 Hz)
12 - 24 - 230
12 - 24
22
SERIES
Ordering information
Example: 22 series 35 mm rail mount relay, 1 NO (SPST-NO) 20 A contact, coil rated 24 V DC, contact material AgSnO2.
2 2 . 2
1 . 9 . 0 2 4 . 4
Contact material
4 = AgSnO2
Series
Type
2 = 35 mm rail (EN 60715) mount
Coil voltage
See coil specifications
No. of poles
1 = 1 NO (SPST-NO)
2 = 2 NO (DPST-NO)
3 = 1 NO + 1 NC (SPST-NO + SPST-NC)
4 = 2 NC (DPST-NC)
Coil version
8 = AC (50/60 Hz)
9 = DC
Technical data
Contact specifications
Nominal rate lamps
incandescent (230V)
W 1,000
compensated fluorescent (230V) W 360
Insulation
Dielectric strength
between supply and contacts V AC 3,500
between open contacts
V AC 2,000
between adjacent contacts
V AC 2,000
Other data
Bounce time: NO / NC
ms 5 / 10
Power lost to the environment
without contact current
W 1.2
with rated current
Screw torque
W 3.2 (22.21, 22.23)
5.2 (22.22, 22.24)
Nm 0.8
0.8
Coil terminals
Max. wire size
solid cable
mm2 1x4 / 2x2.5
AWG 1x12 / 2x14
Contact terminals
stranded cable
solid cable
stranded cable
1x2.5 / 2x2.5
1x6 / 2x6
1x6 / 2x4
1x14 / 2x14
1x10 / 2x10
1x10 / 2x12
If the coil is operated for a prolonged period of time, adequate ventilation of the relays must be provided - suggested gap of 9 mm between
adjacent relays.
Coil specifications
DC version data
Coil
code
9.012
9.024
AC version data
Operating range
Umin
V
10.8
21.6
Umax
V
13.2
26.4
Resistance Consumption
I at UN
R
Ω
mA
115
104
460
52.2
Nominal
voltage
UN
V
12
24
230
Coil
code
8.012
8.024
8.230
Operating range
Umin
V
10.2
20.4
196
Umax
V
13.2
26.4
253
I at UN
R
(50 Hz)
Ω
mA
13.5
245
41
135
4,200
12.5
Nominal
voltage
UN
V
12
24
3
L
22
SERIES
Accessories
Adaptor for panel mounting, 17.5 mm wide
020.01
Sheet of marker tags, plastic, 24 tags, 9x17 mm
020.24
020.01
020.24
Separator for rail mounting, plastic, 9 mm wide
022.09
022.09
L
4
很抱歉,暂时无法提供与“22.21.9.024.4000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+250.086721+32.28410
- 10+234.4180110+30.26140
