44.52.7.024.0000
44.52.7.024.0000
    FINDER
44.52.7.024.0000 数据手册
44 SERIES PCB/Plug-in relays from 6 to 10 A 44 SERIES 44.52 2 CO power relays with high separation between adjacent contacts Direct PCB or socket mount 44.62 A Type 44.52 -- 2 CO 6 A (5 mm pin pitch) Type 44.62 -- 2 CO 10 A (5 mm pin pitch) • DC coils (Standard or sensitive) • Cadmium Free contact materials • 8 mm, 6 kV (1.2/50 μs) isolation, coil-contacts • UL Listing (certain relay/socket combinations) • 95 series sockets for PCB or 35 mm rail • 2 CO 6 A • PCB or 95 series sockets • 2 CO 10 A • PCB or 95 series sockets Copper side view Copper side view 2 CO (DPDT) 2 CO (DPDT) 6/10 10/20 250/400 250/400 VA 1500 2500 Rated load AC15 (230 V AC)VA 250 500 mounting (EN 60715) with Screw, Screwless or Push-in terminals • Coil Indication and EMC suppression modules 99 series and Timer module 86.30 options • Environmental protection: RT II - flux proof (Standard) 12.4 25 29 1 5 0.4 For UL ratings see: “General technical information” page V Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC Rated load AC1 Single phase motor rating (230 V AC)kW 0.185 0.37 Breaking capacity DC1: 30/110/220 VA 6/0.3/0.13 10/0.3/0.13 Minimum switching load 300 (5/5) 300 (5/5) AgNi AgNi — — mW (V/mA) Standard contact material Coil specification Nominal voltage (UN)  V AC (50/60 Hz) V DC Rated power AC/DC/sens. DC Operating range VA (50 Hz)/W/W AC 6 - 9 - 12 - 14 - 24 - 28 - 48 - 60 - 110 - 125 —/0.65/0.5 —/0.65/0.5 — — (0.73…1.5)UN / (0.73…1.7)UN (0.73…1.5)UN / (0.8…1.7)UN Holding voltage AC/DC —/0.4 UN —/0.4 UN Must drop-out voltage AC/DC —/0.1 UN —/0.1 UN Mechanical life AC/DC cycles —/20 · 106 —/20 · 106 Electrical life at rated load AC1 cycles 150 · 103 100 · 103 ms 8/5 - (12/5 sensitive) 8/5 - (12/5 sensitive) kV 6 (8 mm) 6 (8 mm) 1000 1000 –40…+85 –40…+85 RT II RT II  DC/sens. DC Technical data II-2016, www.findernet.com Operate/release time Insulation between coil and contacts (1.2/50 μs) Dielectric strength between open contacts Ambient temperature range Environmental protection V AC °C Approvals (according to type) 1 44 SERIES PCB/Plug-in relays from 6 to 10 A 44 SERIES Ordering information Example: 44 series PCB relay, 2 CO 10 A contacts, 24 V DC coil. A 4 4 . 6 A B C D 2 . 9 . 0 2 4 . 0 0 0 0 Series A: Contact material 0 = Standard AgNi 4 = AgSnO2 for 44.62 only 5 = AgNi + Au for 44.52 only Type 5 = PCB - 5 mm pinning 6 = PCB - 5 mm pinning No. of poles 2 = 2 pole for 44.52, 6 A 44.62, 10 A D: Special versions 0 = Flux proof (RT II) C: Options 0 = None B: Contact circuit 0 = CO (DPDT) Coil version 7 = Sensitive DC 9 = DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version B C D 44.52 DC - sens. DC 0 - 5 A 0 0 0 44.62 DC - sens. DC 0 - 4 0 0 0 Technical data Insulation according to EN 61810-1 Nominal voltage of supply system V AC 230/400 Rated insulation voltage  V AC 250 Pollution degree 3 400 2 Insulation between coil and contact set Type of Insulation Reinforced (8 mm) Overvoltage category III Rated impulse voltage kV (1.2/50 μs) 6 Dielectric strength V AC 4000 Insulation between adjacent contacts Type of insulation Basic Overvoltage category III Rated impulse voltage kV (1.2/50 μs) 4 Dielectric strength V AC 2500 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50 μs) 1000/1.5 Conducted disturbance immunity Burst (5…50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 μs) on A1 - A2 (differential mode) EN 61000-4-5 level 3 (2 kV) Other data ms 4/4 Vibration resistance (5…55)Hz: NO/NC Shock resistance Power lost to the environment g 16 without contact current with rated current Recommended distance between relays mounted on PCB 2 g 15/12 W 0.6 W 1.2 (44.52) mm ≥5 2.7 (44.62) II-2016, www.findernet.com Bounce time: NO/NC 44 SERIES PCB/Plug-in relays from 6 to 10 A 44 SERIES Contact specification F 44 - Electrical life (AC) v contact current H 44 - Maximum DC1 breaking capacity A DC breaking current (A) 44.62 current limit Cycles Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 limit for 44.52 44.52 current limit 2 contacts in series single contact DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. Coil specifications DC coil data - 0.65 W standard Nominal Coil code voltage DC coil data - 0.5 W sensitive Operating range Resistance Rated coil consumption Nominal Coil code voltage Operating range Resistance Rated coil consumption UN Umin Umax R I at UN UN Umin Umax R I at UN V V V Ω mA V V V Ω mA 6 9.006 4.4 9 55 109 6 7.006 4.4 10.2 75 80 9 9.009 6.6 13.5 125 72 9 7.009 6.6 15.3 160 56 12 9.012 8.8 18 220 55 12 7.012 8.8 20.4 300 40 14 9.014 10.2 21 300 47 14 7.014 10.2 23.8 400 35 24 9.024 17.5 36 900 27 24 7.024 17.5 40.8 1200 20 28 9.028 20.5 42 1200 23 28 7.028 20.5 47.6 1600 17.5 48 9.048 35 72 3500 14 48 7.048 35 4800 10 60 9.060 43.8 90 5500 11 60 7.060 43.8 102 7200 8.4 110 9.110 80.3 165 18000 6.2 110 7.110 80.3 187 23500 4.7 125 9.125 91.2 188 23500 5.3 125 7.125 219 32000 3.9 100 81.6 * Umin = 0.8 UN for 44.62 R 44 - DC coil operating range v ambient temperature Standard coil R 44 - DC coil operating range v ambient temperature Sensitive coil 1 1 2 2 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. II-2016, www.findernet.com 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 3 44 SERIES 95 SERIES Socket overview for 44 series relays Module Socket Relay 99.02 44.52 44.62 95.P5 A 95.P5 Description Mounting Accessories Push-in terminal sockets Panel or 35 mm rail (EN 60715) mount --Coil indication and EMC --For fast cable connection --Top terminals - Contacts --Bottom terminals - Coil See page 5 suppression modules --Jumper link --Timer modules --Plastic retaining and release clip Module Socket Relay 99.02 44.52 44.62 95.05 Description Mounting Screw terminal (Box clamp) socket Panel or 35 mm rail (EN 60715) mount --Top terminals - Contacts --Bottom terminals - Coil 95.05 See page 7 Accessories --Coil indication and EMC suppression modules --Jumper link --Timer modules --Plastic retaining and release clip Module Socket Relay 99.02 44.52 44.62 95.55 Description Mounting Accessories Screwless terminal socket Panel or 35 mm rail (EN 60715) mount --Coil indication and EMC --For fast cable connections --Top terminals - Contacts --Bottom terminals - Coil suppression modules --Timer modules --Plastic retaining and release clip 95.55 See page 8 Module Socket 99.80 Relay 95.85.3 44.52 44.62 Description Mounting Screw terminal (Box clamp) socket Panel or 35 mm rail (EN 60715) mount Accessories --Coil indication and EMC suppression modules --Plastic retaining and release clip 95.85.3 See page 9 Module Socket 99.80 Relay 95.95.3 44.52 44.62 Description Mounting Screw terminal (Box clamp) socket Panel or 35 mm rail --Top terminals - Contacts (EN 60715) mount --Bottom terminals - Coil Accessories --Coil indication and EMC suppression modules --Plastic retaining and release clip 95.95.3 See page 10 Module Socket — Relay Description 44.52 44.62 Screw terminal (Box clamp) socket Panel or 35 mm rail (EN 60715) mount --Metal retaining clip Relay Description Mounting Accessories 95.15.2 44.52 44.62 PCB socket PCB mounting --Metal retaining clip 95.65 Mounting Accessories 95.65 See page 11 Module Socket — 95.15.2 See page 12 Bottom terminals 4 II-2016, www.findernet.com Top terminals 95 SERIES Sockets and accessories for 44 series relays 95.P5 Approvals (according to type): 095.91.3 060.72 060.48 44 SERIES Push-in terminal socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link 2-way jumper link (12.5 mm pitch) 2-way jumper link (4.6 mm pitch) Marker tag holder (for tags 060.48 and 060.72 types) Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.91.3 and for marker tag holder 097.00, 48 tags, 6 x 12 mm, for CEMBRE's thermal transfert printer Sheet of marker tags for plastic retaining and release clip 095.91.3 and for marker tag holder 097.00, 72 tags, 6 x 12 mm, for plotter printing Technical data Rated values Dielectric strength Protection category Ambient temperature °C Wire strip length mm Min. wire size for 95.P5 socket mm2 AWG Max. wire size for 95.P5 socket mm2 AWG  95.P5 44.52, 44.62 A 095.71 095.91.3 097.58 097.52 097.42 097.00 095.00.4 99.02 86.30 060.48 060.72 10 A - 250 V 6 kV (1.2/50 µs) between coil and contacts IP 20 –40…+70 (see diagram L95) 8 solid wire stranded wire 0.5 0.5 21 21 solid wire stranded wire 2 x 1.5 / 1 x 2.5 2 x 1.5 / 1 x 2.5 2 x 18 / 1 x 14 2 x 18 / 1 x 14 Total socket current (A) L 95 - Total socket current vs ambient temperature 95.P5 95.P5 8-way jumper link for 95.P5 socket Rated values 097.58 10 A - 250 V 2-way jumper link for 95.P5 socket Rated values 097.52 10 A - 250 V II-2016, www.findernet.com 097.58 097.52 5 44 SERIES 95 SERIES Sockets and accessories for 44 series relays 2-way jumper link for 95.P5 socket Rated values 097.42 10 A - 250 V Marker tag holder for 95.P5 sockets 097.00 86 series timer modules (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) (110…125)V AC; Bi-function: AI, DI; (0.05 s…100 h) (230…240)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.0.024.0000 86.30.8.120.0000 86.30.8.240.0000 A 097.42 097.00 86.30 99.02 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 95.P5 socket Diode (+A1, standard polarity) (6…220)V DC LED(6…24)V DC/AC LED(28…60)V DC/AC LED(110…240)V DC/AC LED + Diode (+A1, standard polarity) (6…24)V DC LED + Diode (+A1, standard polarity) (28…60)V DC LED + Diode (+A1, standard polarity) (110…220)V DC LED + Varistor (6…24)V DC/AC LED + Varistor (28…60)V DC/AC LED + Varistor (110…240)V DC/AC RC circuit (6…24)V DC/AC RC circuit (28…60)V DC/AC RC circuit (110…240)V DC/AC Residual current by-pass (110…240)V AC 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 II-2016, www.findernet.com DC Modules with non-standard polarity (+A2) on request. Approvals (according to type): 6 95 SERIES Sockets and accessories for 44 series relays 95.05 Approvals (according to type): Certain relay/socket combinations 095.01 44 SERIES Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Marker tag holder (for tags 060.48 and 060.72 types) Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.01 and for marker tag holder 097.00, 48 tags, 6 x 12 mm, for CEMBRE’s thermal transfer printers Sheet of marker tags for plastic retaining and release clip 095.01 and for marker tag holder 097.00, 72 tags, 6 x 12 mm, for plotter printing Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Wire strip length Max. wire size for 95.05 socket 060.72 95.05 (blue) 44.52, 44.62 95.05.0 (black) A 095.71 095.01 095.18 095.01.0 095.18.0 097.00 095.00.4 99.02 86.30 060.48 060.72 10 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 –40…+70 (see diagram L95) Nm 0.5 mm 8 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 Total socket current (A) L 95 - Total socket current vs ambient temperature P A PEAN N T E O O T 8-way jumper link for 95.05 socket Rated values 095.18 (blue) 10 A - 250 V 86 series timer modules (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.0.024.0000 095.18.0 (black) EUR EUR 060.48 PEAN 095.18 Approvals (according to type): 86.30 II-2016, www.findernet.com 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 99.02 coil indication and EMC suppression modules for 95.05 socket Diode (+A1, standard polarity) (6…220)V DC LED(6…24)V DC/AC LED(28…60)V DC/AC LED(110…240)V DC/AC LED + Diode (+A1, standard polarity) (6…24)V DC LED + Diode (+A1, standard polarity) (28…60)V DC LED + Diode (+A1, standard polarity) (110…220)V DC LED + Varistor (6…24)V DC/AC LED + Varistor (28…60)V DC/AC LED + Varistor (110…240)V DC/AC RC circuit (6…24)V DC/AC RC circuit (28…60)V DC/AC RC circuit (110…240)V DC/AC Residual current by-pass (110…240)V AC 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 7 44 SERIES 95 SERIES Sockets and accessories for 44 series relays Screwless terminal socket panel or 35 mm rail mount For relay type 95.55 (blue) 44.52, 44.62 95.55.0 (black) Accessories A 95.55 Approvals (according to type): 095.91.3 Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) Modules (see table below) Timer modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.91.3, 48 tags, 6 x 12 mm, for CEMBRE’s thermal transfer printers Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6 x 12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature °C Wire strip length mm Max. wire size for 95.55 socket mm2 AWG 095.71 095.91.3 99.02 86.30 060.48 060.72 10 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 –25…+70 (see diagram L95) 8 solid wire stranded wire 2 x (0.2…1.5) 2 x (0.2…1.5) 2 x (24…18) 2 x (24…18) 060.48 Total socket current (A) L 95 - Total socket current vs ambient temperature 86 series timer modules (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.0.024.0000 Approvals (according to type): 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 8 99.02 coil indication and EMC suppression modules for 95.55 socket Diode (+A1, standard polarity) (6…220)V DC LED(6…24)V DC/AC LED(28…60)V DC/AC LED(110…240)V DC/AC LED + Diode (+A1, standard polarity) (6…24)V DC LED + Diode (+A1, standard polarity) (28…60)V DC LED + Diode (+A1, standard polarity) (110…220)V DC LED + Varistor (6…24)V DC/AC LED + Varistor (28…60)V DC/AC LED + Varistor (110…240)V DC/AC RC circuit RC circuit RC circuit Residual current by-pass 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 (6…24)V DC/AC 99.02.0.024.09 (28…60)V DC/AC 99.02.0.060.09 (110…240)V DC/AC 99.02.0.230.09 (110…240)V AC 99.02.8.230.07 II-2016, www.findernet.com 86.30 95 SERIES Sockets and accessories for 44 series relays 44 SERIES Screw terminal (Box clamp) socket panel or 35 mm rail mount 95.85.3 (blue) For relay type 44.52, 44.62 95.85.30 (black) Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Identification tag Modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.91.3, 48 tags, 6 x 12 mm, for CEMBRE's thermal transfert printer Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6 x 12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature °C 95.85.3 Approvals (according to type): 095.91.3 Screw torque Wire strip length Max. wire size for 95.85.3 socket 060.48 A 095.71 095.91.3 095.08 095.91.30 095.08.0 095.00.4 99.80 060.48 060.72 10 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 –40…+70 (see diagram L95) Nm 0.5 mm 7 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 P A PEAN N T E O O T 8-way jumper link for 95.85.3 socket Rated values 095.08 (blue) 10 A - 250 V 095.08.0 (black) EUR EUR Total socket current (A) L 95 - Total socket current vs ambient temperature PEAN 095.08 II-2016, www.findernet.com 99.80 coil indication and EMC suppression modules for 95.85.3 socket Diode (+A1, standard polarity) (6…220)V DC LED(6…24)V DC/AC LED(28…60)V DC/AC LED(110…240)V DC/AC 99.80 LED + Diode (+A1, standard polarity) (6…24)V DC Approvals LED + Diode (+A1, standard polarity) (28…60)V DC (according to type): LED + Diode (+A1, standard polarity) (110…220)V DC LED + Varistor (6…24)V DC/AC LED + Varistor (28…60)V DC/AC LED + Varistor (110…240)V DC/AC * Modules in Black (6…24)V DC/AC housing are available on RC circuit RC circuit (28…60)V DC/AC request. Green LED is standard. RC circuit (110…240)V DC/AC Red LED available on Residual current by-pass (110…240)V AC request. Blue* 99.80.3.000.00 99.80.0.024.59 99.80.0.060.59 99.80.0.230.59 99.80.9.024.99 99.80.9.060.99 99.80.9.220.99 99.80.0.024.98 99.80.0.060.98 99.80.0.230.98 99.80.0.024.09 99.80.0.060.09 99.80.0.230.09 99.80.8.230.07 9 44 SERIES 95 SERIES Sockets and accessories for 44 series relays Screw terminal (Box clamp) socket panel or 35 mm rail mount 95.95.3 (blue) For relay type 44.52, 44.62 95.95.30 (black) Accessories A Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Identification tag Modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.91.3 and for marker tag holder 097.00, 48 tags, 6 x 12 mm, for CEMBRE's thermal transfer printers Sheet of marker tags for retaining and release clip 095.91.3 plastic, 72 tags, 6 x 12 mm Technical data Rated values Dielectric strength Protection category Ambient temperature °C 95.95.3 Approvals (according to type): 095.91.3 Screw torque Wire strip length Max. wire size for 95.95.3 socket 060.48 095.71 095.91.3 095.08 095.91.30 095.08.0 095.00.4 99.80 060.48 060.72 10 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 –40…+70 (see diagram L95) Nm 0.5 mm 8 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 P A PEAN N T E O O T 8-way jumper link for 95.95.3 socket Rated values 095.08 (blue) 10 A - 250 V 095.08.0 (black) EUR EUR Total socket current (A) L 95 - Total socket current vs ambient temperature PEAN 095.08 99.80 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. 10 Diode (+A1, standard polarity) (6…220)V DC LED(6…24)V DC/AC LED(28…60)V DC/AC LED(110…240)V DC/AC LED + Diode (+A1, standard polarity) (6…24)V DC LED + Diode (+A1, standard polarity) (28…60)V DC LED + Diode (+A1, standard polarity) (110…220)V DC LED + Varistor (6…24)V DC/AC LED + Varistor (28…60)V DC/AC LED + Varistor (110…240)V DC/AC RC circuit RC circuit RC circuit Residual current by-pass Blue* 99.80.3.000.00 99.80.0.024.59 99.80.0.060.59 99.80.0.230.59 99.80.9.024.99 99.80.9.060.99 99.80.9.220.99 99.80.0.024.98 99.80.0.060.98 99.80.0.230.98 (6…24)V DC/AC 99.80.0.024.09 (28…60)V DC/AC 99.80.0.060.09 (110…240)V DC/AC 99.80.0.230.09 (110…240)V AC 99.80.8.230.07 II-2016, www.findernet.com 99.80 coil indication and EMC suppression modules for 95.95.3 socket 95 SERIES Sockets and accessories for 44 series relays 44 SERIES Screw terminal (Box clamp) socket panel or 35 mm rail mount 95.65 (blue) For relay type 44.52, 44.62 Accessories Metal retaining clip 8-way jumper link Modules Technical data Rated values Dielectric strength Protection category Ambient temperature 95.65 Approvals (according to type): Screw torque Wire strip length Max. wire size for 95.65 socket A 095.71 095.08 — 10 A - 250 V 2 kV AC IP 20 °C –40…+70 (see diagram L95) Nm 0.5 mm 7 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 P A PEAN N T E O O T 8-way jumper link for 95.65 socket Rated values 095.08 (blue) 10 A - 250 V EUR EUR Total socket current (A) L 95 - Total socket current vs ambient temperature PEAN II-2016, www.findernet.com 095.08 11 44 SERIES 95 SERIES Sockets and accessories for 44 series relays PCB socket For relay type 95.15.20 (black) Accessories 95.15.2 Approvals (according to type): Metal retaining clip (supplied with socket - packaging code SMA) Plastic retaining clip Technical data Rated values Dielectric strength Protection category Ambient temperature 095.51 095.52 10 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 °C –40…+70 Copper side view Packaging codes How to code and identify retaining clip and packaging options for sockets. Example: 9 5 . P 5 S P A A Standard packaging SM Metal retaining clip SP Plastic retaining clip 12 II-2016, www.findernet.com A 95.15.2 (blue) 44.52, 44.62
44.52.7.024.0000 价格&库存
很抱歉,暂时无法提供与“44.52.7.024.0000”相匹配的价格&库存,您可以联系我们找货
