7H.51.8.230.0400
7H.51.8.230.0400
    FINDER
    PANEL HEATER 230VAC 400W
7H.51.8.230.0400 数据手册
Panel Heaters 25 - 50 - 100 - 150 250 - 400 W Drying kilns 7H SЕRIES Hoists and cranes Road / tunnel lighting Plastic moulding machines Automatic car-washes Panels for electrical distribution Control panels Forced-air ventilators FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 7H 7H SERIES Panel Heaters 25 - 50 - 100 - 150 W SERIES 7H.51.0.230.0025 Panel heaters 7H.51.0.230.0050 Type 7H.51.0.230.0025 - Heating power 25 W Type 7H.51.0.230.0050 - Heating power 50 W • Nominal voltage (110...230)V AC/DC • Safe touch • PTC resistor, self regulating heating system • Clip for 35 mm rail (EN 60715) mount • Heating power 25 W • Nominal voltage 7H.51.0025/0050 Screw terminal (110…230)V AC/DC • Safe touch • Heating power 50 W • Nominal voltage (110…230)V AC/DC • Safe touch G * At 20°C ambient temperature ** Except upper protection grille For outline drawings see page 7 Heating specification Heating power * W Heater 25 50 PTC resistor, self-regulating heating system Surface temperature** °C Housing ≤ 100 ≤ 100 Plastic according to UL94 – V0, black Supply specification Nominal voltage (UN) V AC (50/60 Hz)/DC Rated current Operating range A V AC/DC 110…230 110…230 0.13 0.20 88…253 88…253 Technical data IV-2020, www.findernet.com Radiator Alluminium profile Electrical connection Screw terminals Fitting position Ambient temperature Protection category Vertical °C –45…+50 –45…+50 IP 20 IP 20 Approvals (according to type) 3 7H SERIES 7H SERIES Panel Heaters 25 - 50 - 100 - 150 W 7H.51.0.230.0100 Panel heaters 7H.51.0.230.0150 Type 7H.51.0.230.0100 - Heating power 100 W Type 7H.51.0.230.0150 - Heating power 150 W • Nominal voltage (110...230)V AC/DC • Safe touch • PTC self regulating heating system • Clip for 35 mm rail (EN 60715) mount • Heating power 100 W • Nominal voltage 7H.51.0100/0150 Screw terminal (110…230)V AC/DC • Safe touch • Heating power 150 W • Nominal voltage (110…230)V AC/DC • Safe touch G * At 20°C ambient temperature ** Except upper protection grille For outline drawings see page 8 Heating specification Heating power * W Heater 100 150 PTC resistor, self-regulating heating system Surface temperature** °C Housing ≤ 80 ≤ 80 Plastic according to UL94 – V0, black Supply specification Nominal voltage (UN) V AC (50/60 Hz)/DC Rated current Operating range A V AC/DC 110…230 110…230 0.45 0.70 88…253 88…253 Technical data Alluminium profile Electrical connection Screw terminals Fitting position Ambient temperature Protection category Approvals (according to type) 4 Vertical °C –45…+50 –45…+50 IP 20 IP 20 IV-2020, www.findernet.com Radiator 7H 7H SERIES Panel Heaters 250 - 400 W SERIES Panel heaters fan assisted 7H.51.8.230.0250 7H.51.8.230.0400 • Heating power 250 W • Nominal voltage 230 V AC • Fan assisted • Heating power 400 W • Nominal voltage 230 V AC • Fan assisted Type 7H.51.8.230.0250 - Heating power 250 W Type 7H.51.8.230.0400 - Heating power 400 W • Nominal voltage 230 V AC • Safe touch • PTC resistor, self regulating heating system • Fast wiring terminals • Clip for 35 mm rail (EN 60715) mount 7H.51.0250/0400 Push-in terminal G * At 20°C ambient temperature ** Except upper protection grille For outline drawings see page 8 Heating specification Heating power * W Heater Surface temperature** Air flow rate Fan - Life time at 25 °C 250 400 PTC resistor, self-regulating heating system °C ≤ 30 m3/h h Housing ≤ 30 30 50 000 50 000 Plastic according to UL94 – V0, black Supply specification Nominal voltage (UN) Rated current Operating range V AC (50/60 Hz) A V AC 230 230 1 1.7 184...253 184...253 IV-2020, www.findernet.com Technical data Radiator Alluminium profile Electrical connection Screwless terminal Fitting position Ambient temperature Protection category Vertical °C -40…+50 -40…+50 IP 20 IP 20 Approvals (according to type) 5 7H 7H SERIES Panel Heaters SERIES Ordering information Example: 7H series, Panel heaters, heating power 50 W, 110…230 V AC/DC. 7 H . 5 1 . 0 . 2 3 0 . 0 0 5 0 Series Type 51 = Panel heaters safe touch Supply version 0 = AC (50/60 Hz)/DC 8 = AC (50/60 Hz) only fan assisted version Supply voltage 230 = 110…230 V 230 = 230 V only fan assisted version Heater power 0025 = 25 W 0050 = 50 W 0100 = 100 W 0150 = 150 W 0250 = 250 W 0400 = 400 W General data Terminals stranded cable 2 x 1.5 2 x 1.5  mm2  AWG 2 x 16 2 x 16 Max. wire size (screw terminals)  mm2 1 x 2.5 1 x 1.5  AWG 1 x 12 Screw torqueNm 1 x 16 0.5 Wiring diagrams Fan assisted version NOTE: Separate supply (L) terminals for the heater and the internal fan allow them to be powered independently. So,dependent on the specific situation, the installer might wish the heating element to be controlled by an upstream thermostat but require the fan to run continuously (although the latter will significantly reduce the product’s life). 7T.81.0.000.240x 1 = L (heater) 2=N 3 = L (fan) F = aM 6.3 A IV-2020, www.findernet.com G solid cable Max. wire size (push-in terminals) 6 7H 7H SERIES Panel Heaters SERIES Wiring diagrams NOT Fan assisted versions AC version DC version SAFETY NOTE For reasons of safety and performance , heaters must be mounted in the following way: 1. keep a distance of 100 mm. from components above and below and of 60 mm from side components 2. install vertically (cables below heater) in the bottom part of cabinet 3. do not mount heaters over easily inflammable materials 4. do not operate in corrosive ambient air WARNING Do not cover the heater. The 7H.51 Heater surface is very hot for 15-20 minutes after disconnecting. During working and maintenance, don’t touch it. Caution: risk of burns, temperatur of the side less than +100 °C.. G Outline drawings Type 7H.51.0050 Screw terminal IV-2020, www.findernet.com Type 7H.51.0025 Screw terminal 7 7H SERIES 7H SERIES Panel Heaters Outline drawings Type 7H.51.0100 Screw terminal Type 7H.51.0150 Screw terminal G IV-2020, www.findernet.com Types 7H.51.0250 / 0400 Push-in terminal 8 Please see general technical information
7H.51.8.230.0400 价格&库存
很抱歉,暂时无法提供与“7H.51.8.230.0400”相匹配的价格&库存,您可以联系我们找货
7H.51.8.230.0400
  • 1+1136.174301+147.66840
库存:2
