7L.43.0.024.0100
7L.43.0.024.0100
    FINDER
    FINDER - 7L.43.0.024.0100 - LED Light Bar, Cool White, 600 lm, 6 W, 48 V, 310.6 mm, IP20
7L.43.0.024.0100 数据手册
REPORT Design by MINELLI | FOSSATI 7L Series New LED Panel Light Connector included Finder’s new LED light for electrical panels - with magnetic mount • • • • • “Two in One” mount - direct magnetic mount or through a screw-mounted metallic bracket Brightness levels: 600 or 1200 lumens Versions with: direct switching, ON/OFF switch, or motion detector Power supply - Multi-voltage: 12...48 V AC/DC and 110...240 V AC/DC New design Approvals findernet.com 7L SERIES New LED Panel Light Switching via ON/OFF switch Switching via motion detector Quick and simple wiring system via push-in connectors for the connection to a single unit, or via plug-in connectors for the connection to a single or multiple units. Magnetic mount via screw-mounted metallic bracket Magnetic mount directly to metallic panel Multi device connection Easily connected with plug-in connectors (max. 7 lamps) without ON/OFF switch and motion detector with motion detector with ON/OFF switch STOCK ITEMS Part Number Lumen Supply voltage Switching Connections 7L.43.0.024.0100 600 12...48 V AC/DC Without ON/OFF switch and PIR - motion detector Push-in connection 7L.43.0.024.0200 600 12...48 V AC/DC Without ON/OFF switch and PIR - motion detector Plug-in connection 7L.43.0.230.0100 600 110...240 V AC/DC Without ON/OFF switch and PIR - motion detector Push-in connection 7L.43.0.230.0200 600 110...240 V AC/DC Without ON/OFF switch and PIR - motion detector Plug-in connection 7L.43.0.024.1100 600 12...48 V AC/DC ON/OFF switch Push-in connection 7L.43.0.024.1200 600 12...48 V AC/DC ON/OFF switch Plug-in connection 7L.43.0.024.2100 600 12...48 V AC/DC PIR - motion detector Push-in connection 7L.43.0.024.2200 600 12...48 V AC/DC PIR - motion detector Plug-in connection 7L.43.0.230.1100 600 110...240 V AC/DC ON/OFF switch Push-in connection 7L.43.0.230.1200 600 110...240 V AC/DC ON/OFF switch Plug-in connection 7L.43.0.230.2100 600 110...240 V AC/DC PIR - motion detector Push-in connection 7L.43.0.230.2200 600 110...240 V AC/DC PIR - motion detector Plug-in connection 7L.46.0.024.1100 1200 12...48 V AC/DC ON/OFF switch Push-in connection 7L.46.0.024.1200 1200 12...48 V AC/DC ON/OFF switch Plug-in connection 7L.46.0.024.2100 1200 12...48 V AC/DC PIR - motion detector Push-in connection 7L.46.0.024.2200 1200 12...48 V AC/DC PIR - motion detector Plug-in connection 7L.46.0.230.1100 1200 110...240 V AC/DC ON/OFF switch Push-in connection 7L.46.0.230.1200 1200 110...240 V AC/DC ON/OFF switch Plug-in connection 7L.46.0.230.2100 1200 110...240 V AC/DC PIR - motion detector Push-in connection 7L.46.0.230.2200 1200 110...240 V AC/DC PIR - motion detector Plug-in connection — Male connector — 07L.12 — FINDER reserves the right to alter characteristics at any time without notice.FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. Switching without ON/OFF switch or motion detector - Direct magnetic mount or through a screw-mounted metallic bracket - Power supply: 12...48 V AC/DC and 110...240 V AC/DC - Nominal power consumption: 6 W (600 lm), 9 W (1200 lm) - Radiation angle: 120° - Light color: 5,000 K - Protection category: IP20 ADV7LEN_US - XI/20 - Report 7L Series Type 7L.43 (600 lumens) Type 7L.46 (1200 lumens)
7L.43.0.024.0100 价格&库存
很抱歉,暂时无法提供与“7L.43.0.024.0100”相匹配的价格&库存,您可以联系我们找货
