REPORT
Design by MINELLI | FOSSATI
7L Series
New LED Panel Light
Connector
included
Finder’s new LED light for electrical panels - with magnetic mount
“Two in One” mount - direct magnetic mount or through a screw-mounted metallic bracket
Brightness levels: 600 or 1200 lumens
Versions with: direct switching, ON/OFF switch, or motion detector
Power supply - Multi-voltage: 12...48 V AC/DC and 110...240 V AC/DC
New design
Approvals
findernet.com
7L SERIES
New LED Panel Light
Switching via
ON/OFF switch
Switching via
motion detector
Quick and simple wiring system
via push-in connectors for the
connection to a single unit, or
via plug-in connectors for the
or multiple units.
Magnetic mount
via screw-mounted
metallic bracket
Magnetic mount directly
to metallic panel
Multi device connection
Easily connected with plug-in
connectors (max. 7 lamps)
without ON/OFF switch and motion detector
with motion detector
with ON/OFF switch
STOCK
ITEMS
Part Number
Lumen
Supply voltage
Switching
Connections
7L.43.0.024.0100
600
12...48 V AC/DC
Without ON/OFF switch and PIR - motion detector
Push-in connection
7L.43.0.024.0200
600
12...48 V AC/DC
Plug-in connection
7L.43.0.230.0100
600
110...240 V AC/DC
Push-in connection
7L.43.0.230.0200
600
110...240 V AC/DC
Plug-in connection
7L.43.0.024.1100
600
12...48 V AC/DC
ON/OFF switch
Push-in connection
7L.43.0.024.1200
600
12...48 V AC/DC
ON/OFF switch
Plug-in connection
7L.43.0.024.2100
600
12...48 V AC/DC
Push-in connection
7L.43.0.024.2200
600
12...48 V AC/DC
Plug-in connection
7L.43.0.230.1100
600
110...240 V AC/DC
ON/OFF switch
Push-in connection
7L.43.0.230.1200
600
110...240 V AC/DC
ON/OFF switch
Plug-in connection
7L.43.0.230.2100
600
110...240 V AC/DC
Push-in connection
7L.43.0.230.2200
600
110...240 V AC/DC
Plug-in connection
7L.46.0.024.1100
1200
12...48 V AC/DC
ON/OFF switch
Push-in connection
7L.46.0.024.1200
1200
12...48 V AC/DC
ON/OFF switch
Plug-in connection
7L.46.0.024.2100
1200
12...48 V AC/DC
Push-in connection
7L.46.0.024.2200
1200
12...48 V AC/DC
Plug-in connection
7L.46.0.230.1100
1200
110...240 V AC/DC
ON/OFF switch
Push-in connection
7L.46.0.230.1200
1200
110...240 V AC/DC
ON/OFF switch
Plug-in connection
7L.46.0.230.2100
1200
110...240 V AC/DC
Push-in connection
7L.46.0.230.2200
1200
110...240 V AC/DC
Plug-in connection
Male connector
07L.12
FINDER reserves the right to alter characteristics at any time without notice.FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products.
Switching without
ON/OFF switch or
motion detector
- Direct magnetic mount or through a screw-mounted metallic bracket
- Power supply: 12...48 V AC/DC and 110...240 V AC/DC
- Nominal power consumption: 6 W (600 lm), 9 W (1200 lm)
- Radiation angle: 120°
- Light color: 5,000 K
- Protection category: IP20
ADV7LEN_US - XI/20 - Report 7L Series
Type 7L.43 (600 lumens)
Type 7L.46 (1200 lumens)
很抱歉,暂时无法提供与“7L.43.0.230.0200”相匹配的价格&库存,您可以联系我们找货
