9023SMA
9023SMA
    FINDER
    FINDER - 9023SMA - Relay Socket, DIN Rail, Panel, Screw, 11 Pins, 10 A, 250 V, 90 Series
9023SMA 数据手册
90 Series - Socket overview for 60 series relays Module Socket 99.02 90.02 90.03 Relay Description 60.12 Screw terminal (Box clamp) socket 60.13 Double A1 terminal Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Timer modules - Metal retaining clip Module Socket 99.01 90.20 90.21 Relay Description 60.12 Screw terminal (Box clamp) socket 60.13 Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Coil indication and EMC suppression modules - Metal retaining clip Module Socket Relay Description — 90.82.3 60.12 Screw terminal (Box clamp) socket — 90.83.3 60.13 Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Metal retaining clip Module Socket — 90.22 — 90.23 Relay Description 60.12 Screw terminal (Box clamp) socket 60.13 Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Metal retaining clip Module Socket — 90.26 — 90.27 Relay Description 60.12 Screw terminal (Plate clamp) socket 60.13 Mounting Panel or 35 mm rail (EN 60715) mount Accessories - Metal retaining clip Module Socket — 90.12 — 90.13 Relay Description 60.12 Flange mount solder socket 60.13 Mounting M3 screw fixing Accessories — Module — — — — Relay Description 60.12 PCB socket 60.12 60.13 60.13 Mounting PCB Accessories — 90.03 See page 8 90.21 See page 9 90.83.3 See page 10 90.23 See page 10 90.26 See page 11 90.12 See page 11 90.15 See page 12 Socket 90.14 90.14.1 90.15 90.15.1 7 90 Series - Sockets and accessories for 60 series relays Screw terminal (Box clamp) socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip 90.03 6-way jumper link Approvals Identification tag (according to type): Modules (see table below) Timer modules (see table below) Technical data Rated values Dielectric strength Certain relay/socket Protection category combinations Ambient temperature Screw torque Wire strip length Max. wire size for 90.02 and 90.03 sockets 90.02 Blue 60.12 °C Nm mm 10 A - 250 V 2 kV AC IP 20 –40...+70 0.6 10 solid wire 1x6 / 2x2.5 1x10 / 2x14 6-way jumper link for 90.02 and 90.03 sockets Rated values 86.00 86.30 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 8 90.03 Blue 60.13 90.03.0 Black 090.33 090.06 090.00.2 99.02 86.00, 86.30 mm2 AWG 090.06 90.02.0 Black stranded wire 1x4 / 2x2.5 1x12 / 2x14 090.06 (blue) 10 A - 250 V Approvals (according to type): 86 series timer modules Multi-voltage: (12…240)V AC/DC; Multi-functions: AI, DI, SW, BE, CE, DE, EE, FE; (0.05 s…100 h) (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) (110...125)V AC; Bi-function: AI, DI; (0.05s…100h) 86.00.0.240.0000 86.30.0.024.0000 86.30.8.120.0000 (230...240)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.8.240.0000 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 90.02 and 90.03 sockets Diode (+A1, standard polarity) (6...220)V DC 99.02.3.000.00 LED (6...24)V DC/AC 99.02.0.024.59 LED (28...60)V DC/AC 99.02.0.060.59 LED (110...240)V DC/AC 99.02.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.02.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.02.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.02.9.220.99 LED + Varistor (6...24)V DC/AC 99.02.0.024.98 LED + Varistor (28...60)V DC/AC 99.02.0.060.98 LED + Varistor (110...240)V DC/AC 99.02.0.230.98 RC circuit (6...24)V DC/AC 99.02.0.024.09 RC circuit (28...60)V DC/AC 99.02.0.060.09 RC circuit (110...240)V DC/AC 99.02.0.230.09 Residual current by-pass (110...240)V AC 99.02.8.230.07 90 Series - Sockets and accessories for 60 series relays 90.21 Approvals (according to type): Screw terminal (Box clamp) socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Modules (see table below) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 90.20 and 90.21 sockets mm2 AWG 90.20 90.20 Blue 60.12 90.20.0 Black 90.21 Blue 60.13 90.21.0 Black 090.33 99.01 10 A - 250 V 2 kV AC IP 20 –40…+70 0.5 10 solid wire 1x6 / 2x2.5 1x10 / 2x14 stranded wire 1x6 / 2x2.5 1x10 / 2x14 90.21 99.01 coil indication and EMC suppression modules for 90.20 and 90.21 sockets 99.01 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. Diode (+A1, standard polarity) Diode (+A2, non-standard polarity) LED LED LED LED + Diode (+A1, standard polarity) LED + Diode (+A1, standard polarity) LED + Diode (+A1, standard polarity) LED + Diode (+A2, non-standard polarity) LED + Diode (+A2, non-standard polarity) LED + Diode (+A2, non-standard polarity) LED + Varistor LED + Varistor LED + Varistor RC circuit RC circuit RC circuit Residual current by-pass (6...220)V DC (6...220)V DC (6...24)V DC/AC (28...60)V DC/AC (110...240)V DC/AC (6...24)V DC (28...60)V DC (110...220)V DC (6...24)V DC (28...60)V DC (110...220)V DC (6...24)V DC/AC (28...60)V DC/AC (110...240)V DC/AC (6...24)V DC/AC (28...60)V DC/AC (110...240)V DC/AC (110...240)V AC Blue* 99.01.3.000.00 99.01.2.000.00 99.01.0.024.59 99.01.0.060.59 99.01.0.230.59 99.01.9.024.99 99.01.9.060.99 99.01.9.220.99 99.01.9.024.79 99.01.9.060.79 99.01.9.220.79 99.01.0.024.98 99.01.0.060.98 99.01.0.230.98 99.01.0.024.09 99.01.0.060.09 99.01.0.230.09 99.01.8.230.07 9 90 Series - Sockets and accessories for 60 series relays 90.83.3 Approvals (according to type): Screw terminal (Box clamp) socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip Technical data Rated values Dielectric strength Protection category Ambient temperature Screw torque Max. wire size for 90.82.3 and 90.83.3 sockets 90.82.3 Blue 60.12 90.23 10 A - 250 V 2 kV AC IP 20 °C –40…+70 Nm 0.8 solid wire mm2 1x6 / 2x4 AWG 1x10 / 2x14 Screw (Box clamp) terminal socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max wire size for 90.22 and 90.23 sockets mm2 AWG 90.22 10 90.83.3 Blue 60.13 090.33 90.82.3 Approvals (according to type): 90.82.30 Black stranded wire 1x6 / 2x4 1x10 / 2x14 90.83.3 90.22 Blue 60.12 90.23 Blue 60.13 090.33 10 A - 250 V 2 kV AC IP 20 –40…+70 0.5 7 solid wire 1x6 / 2x2.5 1x10 / 2x14 stranded wire 1x6 / 2x2.5 1x10 / 2x14 90.23 90.83.30 Black 90 Series - Sockets and accessories for 60 series relays 90.26 Approvals (according to type): Screw terminal (Plate clamp) socket panel or 35 mm rail (EN 60715) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 90.26 and 90.27 sockets mm2 AWG 90.12 Approvals (according to type): 90.26.0 Black 90.27 Blue 60.13 90.27.0 Black 090.33 10 A - 250 V 2 kV AC IP 20 –40…+70 0.8 10 solid wire 1x4 / 2x2.5 1x12 / 2x14 stranded wire 1x4 / 2x2.5 1x12 / 2x14 90.27 90.26 Flange mount solder socket mount with M3 screw For relay type Technical data Rated values Dielectric strength Ambient temperature 90.26 Blue 60.12 90.12 (black) 60.12 °C 90.13 (black) 60.13 10 A - 250 V 2 kV AC –40…+70 11 90 Series - Sockets and accessories for 60 series relays PCB socket 90.15 Approvals (according to type): Blue Blue For relay type Technical data Rated values Dielectric strength Ambient temperature °C 90.14 90.14 (Ø 20.5 mm) 90.14.1 (Ø 17.5 mm) 60.12 10 A - 250 V 2 kV AC –40…+70 90.15 Packaging code How to code and identify retaining clip and packaging options for sockets. Example: 9 0 . 2 1 S M A A Standard packaging SM Metal retaining clip 9 0 . 2 12 1 Without retaining clip 90.15 (Ø 22 mm) 90.15.1 (Ø 19 mm) 60.13
9023SMA 价格&库存
很抱歉,暂时无法提供与“9023SMA”相匹配的价格&库存,您可以联系我们找货
