80 SERIES
Modular timers 16 A
80
SERIES
80.01
Multi-function and mono-function timer range
80.11
80.01 - Multi-function & multi-voltage
80.11 - On-delay, multi-voltage
• 17.5 mm wide
• Six time scales from 0.1 s to 24 h
• High input/output isolation
• 35 mm rail (EN 60715) mount
• “Blade + cross” - both flat blade and cross head
screw drivers can be used to adjust the range
and function selectors, the timing trimmer, and
to disengage the rail mounting clip
• New multi-voltage versions with “PWM clever”
technology
80.01 / 80.11
Screw terminal
• Multi-voltage
• Multi-function
• Multi-voltage
• Mono-function
AI: On-delay
DI: Interval
SW: Symmetrical flasher (starting pulse on)
BE: Off-delay with control signal
CE: On- and off-delay with control signal
DE: Interval with control signal on
AI: On-delay
For UL ratings see:
“General technical information” page V
Wiring diagram
(without control signal)
For outline drawing see page 6
Wiring diagram
(with control signal)
Wiring diagram
Contact specification
Contact configuration
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
A
V AC
Rated load AC1
VA
1 CO (SPDT)
1 CO (SPDT)
16/30
16/30
250/400
250/400
4000
4000
Rated load AC15 (230 V AC)
VA
750
750
Single phase motor rating (230 V AC)
kW
0.55
0.55
A
16/0.3/0.12
16/0.3/0.12
mW (V/mA)
500 (10/5)
500 (10/5)
AgNi
AgNi
12…240
24…240
Breaking capacity DC1: 30/110/220 V
Minimum switching load
Standard contact material
H
Supply specification
Nominal voltage (UN)
Rated power AC/DC
Operating range
V AC (50/60 Hz)
V DC
12…240
24…240
VA (50 Hz)/W
很抱歉,暂时无法提供与“80.91.0.240.0000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+861.64088
- 5+848.52986
- 10+834.10670
