12.71.0.024.0000
12.71.0.024.0000
    FINDER
    RLY WEEK TMER SPDT 16A 24VAC/DC
12.71.0.024.0000 数据手册
12 Series - Time switches 16 A Features 12.01 12.11 12.31 Mechanical time switches - Daily time setting * - Weekly time setting ** Type 12.01 - 1 Pole 16 A CO (SPDT) 35.8 mm width • Type 12.11 - 1 Pole 16 A NO (SPST-NO) 17.6 mm width • Type 12.31-0000 daily 1 Pole 16 A CO (SPDT) • Type 12.31-0007 weekly 1 Pole 16 A CO (SPDT) • Minimum time interval setting: 1h (12.31-0007) 30 min (12.01) 15 min (12.11 - 12.31-0000) • Mechanical daily time switch 1 CO (SPDT) • 35 mm rail (EN 60715) mount Mechanical daily time switch 1 NO (SPST-NO) • 35 mm rail (EN 60715) mount Mechanical daily or weekly 1 CO (SPDT) • Front panel mounting • • • • • • * Same program every day ** Different program possible for each of the 7 days of the week For outline drawing see page 10 Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 1 NO (SPST-NO) 1 CO (SPDT) 16/— 16/30 16/— 250/— 250/— 250/— Rated load AC1 VA 4,000 4,000 4,000 Rated load AC15 (230 V AC) VA 750 420 420 2,000 (NO contact) 2,000 2,000 750 (NO contact) 750 750 uncompensated fluorescent (230 V) W 1,000 (NO contact) 1,000 1,000 halogen (230 V) W 2,000 (NO contact) 2,000 2,000 1,000 (10/10) 1,000 (10/10) 1,000 (10/10) AgCdO AgCdO AgCdO 230 230 120 - 230 — — — Nominal lamp rating: incandescent (230 V) W compensated fluorescent (230 V) W Minimum switching load mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W Operating range AC (50 Hz) DC Technical data Electrical life at rated load in AC1 cycles Type of time switch XII-2012, www.findernet.com Switching intervals /day Minimum switching interval Accuracy Ambient temperature range Protection category 2/— 2/— 2/— (0.85...1.1)UN (0.85…1.1)UN (0.85…1.1)UN — — — — — 50 · 103 50 · 103 daily daily daily weekly 48 96 96 24 (168/week) 15 50 · 103 min 30 15 s/day 1.5 1.5 1.5 –5…+50 –5…+50 –10…+50 IP 20 IP 20 IP 20 °C 60 Approvals (according to type) 1 12 Series - Time/Astro-Switch 16 A Features 12.51 12.81 12.51 - Digital (analogue-style) time switch, daily/weekly programming 30 minutes interval setting Easily configurable for daily or weekly programming • • 12.81 - Digital astro-switch Astro program: calculation of sunrise and sunset times through date, time and location coordinates • Location coordinates easily settable for most European countries trough post codes • Offset function: allows programming of switching times offset from the astronomical time (up to +– 90’, with 10’ steps) • Digital time switch 1 CO (SPDT) • 35 mm rail (EN 60715) mount Astro- time switch 1 CO (SPDT) • 35 mm rail (EN 60715) mount • • • • Summer/winter European time 1 CO 16 A output contact • LCD status indication, set-up and programming • Back-light display • Internal battery for set-up and programming without supply, easily replaceable from the front • Protective separation between supply and contacts • 35 mm rail (EN 60715) mount • Cadmium free contact material • • For outline drawing see page 10 Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 1 CO (SPDT) 1 CO (SPDT) 16 / 30 (120 A – 5 ms) 16 / 30 (120 A – 5 ms) 250/400 250/400 Rated load AC1 VA 4,000 4,000 Rated load AC15 (230 V AC) VA 750 750 2,000 2,000 750 750 Nominal lamp rating: incandescent (230 V) W compensated fluorescent (230 V) W energy saving (CFL, LED) (230 V) W halogen (230 V) W Minimum switching load mW (V/mA) Standard contact material 200 200 2,000 2,000 1,000 (10/10) 1,000 (10/10) AgSnO2 AgSnO2 230 230 Supply specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power VA (50 Hz)/W Operating range AC (50 Hz) DC — — 6.6/2.9 6.6/2.9 (0.8...1.1)UN (0.8...1.1)UN — — 100 · 103 100 · 103 48 — 30 — 1 1 –20…+50 –20…+50 IP 20 IP 20 Electrical life at rated load in AC1 cycles Switching intervals Minimum switching interval Accuracy Ambient temperature range Protection category Approvals (according to type) 2 min s/day °C XII-2012, www.findernet.com Technical data 12 Series - Time switches 16 A Features 12.21 12.22 12.71 Electronic digital time switches - Weekly time setting Type 12.21 - 1 Pole 16 A CO (SPDT) 35.8 mm width • Type 12.22 - 2 Pole 16 A CO (DPDT) 35.8 mm width • Type 12.71 - 1 Pole 16 A CO (SPDT) 17.6 mm width • Available for 230 V AC or 12, 24 V AC/DC supply • Minimum time interval setting - 1 minute • Internal battery for set-up without supply • Impulse output function: - 1s... 59: 59(mm:ss) • Automatic adjustment for daylight saving • 35 mm rail (EN 60715) mount • Digital weekly time switch 1 CO (SPDT) • 35 mm rail (EN 60715) mount Digital weekly time switch 2 CO (DPDT) • 35 mm rail (EN 60715) mount Digital weekly time switch 1 CO (SPDT) • 35 mm rail (EN 60715) mount • • • • • • For outline drawing see page 10, 11 Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current 2 CO (DPDT) 1 CO (SPDT) A 16/30 16/30 16/30 Rated voltage/Maximum switching voltage V AC 250/— 250/— 250/— Rated load AC1 VA 4,000 4,000 4,000 Rated load AC15 (230 V AC) VA 750 750 420 2,000 (NO contact) 2,000 (NO contact) 2,000 (NO contact) 420 (NO contact) 420 (NO contact) 750 (NO contact) uncompensated fluorescent (230 V) W 1,000 (NO contact) 1,000 (NO contact) 1,000 (NO contact) halogen (230 V) W 2,000 (NO contact) 2,000 (NO contact) 2,000 (NO contact) 1,000 (10/10) 1,000 (10/10) 1,000 (10/10) AgCdO AgCdO AgNi Nominal lamp rating: incandescent (230 V) W compensated fluorescent (230 V) W Minimum switching load mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) V AC/DC Rated power AC/DC VA (50 Hz)/W Operating range AC (50 Hz) DC — 120 - 230 — 120 - 230 — 230 12 - 24 — 24 — 24 — 1.4/1.4 2/— 1.4/1.4 2/— 1.4/1.4 2/— (0.9…1.1)UN (0.85...1.1)UN (0.9…1.1)UN (0.85…1.1)UN (0.9…1.1)UN (0.85…1.1)UN (0.9...1.1)UN (0.9...1.1)UN — (0.9...1.1)UN — — Technical data Electrical life at rated load in AC1 cycles XII-2012, www.findernet.com Type of time switch Memory locations for switching times * Minimum interval setting Accuracy Ambient temperature range Protection category min s/day °C 50 · 103 50 · 103 50 · 103 weekly weekly weekly 30 30 30 1 1 1 0.5 0.5 0.5 –30…+55 –30…+55 –30…+55 IP 20 IP 20 IP 20 Approvals (according to type) * Switching times in memory may be used more than once i.e. when selected for different days. 3 12 Series - Time switches 16 A Features 12.91...0000 12.91...0090 12.92 Electronic digital time switches - weekly time setting Type 12.91...0000 “ZENITH” 1 pole 16 A CO (SPDT) 35.8 mm width • Type 12.91...0090 “ZENITH” 1 pole 16 A CO (SPDT) 35.8 mm width version for programming via PC by a special Key Memory (included) • Type 12.92 “ZENITH” 2 Pole 16 A CO (DPDT) 35.8 mm width • Astro program: calculation of sunrise and sunset times through date, time and location coordinates (longitude and latitude) • Offset function: allows programming of switching times offset (+ or -) from the astrological time • Minimum time interval setting - 1 minute • Internal battery for set-up without supply • Automatic adjustment for daylight saving • 35 mm rail (EN 60715) mount • Digital weekly time switch 1 CO (SPDT) • 35 mm rail (EN 60715) mount Digital weekly time switch 1 CO (SPDT) • Version for programming via PC by a special key memory • 35 mm rail (EN 60715) mount Digital weekly time switch 2 CO (DPDT) • 35 mm rail (EN 60715) mount • • • • • • For outline drawing see page 11 Contact specification Contact configuration 1 CO (DPDT) Rated current/Maximum peak current 1 CO (DPDT) 2 CO (DPDT) A 16/30 16/30 16/30 Rated voltage/Maximum switching voltage V AC 250/— 250/— 250/— Rated load AC1 VA 4,000 4,000 4,000 Rated load AC15 (230 V AC) VA 750 750 750 2,000 (NO contact) 2,000 (NO contact) 2,000 (NO contact) Nominal lamp rating: incandescent (230 V) W compensated fluorescent (230 V) W 420 (NO contact) 420 (NO contact) 420 (NO contact) uncompensated fluorescent (230 V) W 1,000 (NO contact) 1,000 (NO contact) 1,000 (NO contact) halogen (230 V) W 2,000 (NO contact) 2,000 (NO contact) 2,000 (NO contact) 1,000 (10/10) 1,000 (10/10) 1,000 (10/10) AgSnO2 AgSnO2 AgSnO2 Minimum switching load mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) 230 230 230 Rated power AC/DC VA (50 Hz)/W 2/— 2/— 2/— (0.85...1.1)UN (0.85...1.1)UN (0.85...1.1)UN 50 · 103 50 · 103 50 · 103 weekly weekly weekly 60 60 60 Operating range AC (50 Hz) Electrical life at rated load in AC1 cycles Type of time switch Memory locations for switching times * Minimum interval setting Accuracy Ambient temperature range Protection category min s/day °C 1 1 1 0.5 0.5 0.5 –30…+55 –30…+55 –30…+55 IP 20 IP 20 IP 20 Approvals (according to type) 4 * Switching times in memory may be used more than once i.e. when selected for different days. XII-2012, www.findernet.com Technical data 12 Series - Time switches 16 A Ordering information Example: 12 series digital/analogue time switch, 1 CO 16 A contact, 230 V AC supply 1 2 . 5 Series Type 0 = Daily, 35.8 mm wide 1 = Daily, 17.5 mm wide 3 = Daily or Weekly, 72x72 mm 5 = Digital/analogue time switch, 35 mm wide 2 = Weekly, 35.8 mm wide 7 = Weekly, 17.5 mm wide 8 = Astro-switch, 35 mm wide 9 = Weekly “Astro”, 35.8 mm wide 0 0 0 Option 0 = With power back-up 1 = Without power back-up (type 12.11) Option 0 = Standard 0 = Daily only for 12.31 7 = Weekly only for 12.31 Supply voltage 012 = 12 V AC/DC 024 = 24 V AC/DC 120 = 120 V AC 230 = 230 V AC Special version 0 = Standard 9 = Programming via PC type 12.91.8.230.0090 Supply version 0 = AC (50/60 Hz)/DC (types 12.21.0.012, 12.21.0.024, 12.22.0.024, 12.71.0.024) 8 = AC (50/60 Hz) XII-2012, www.findernet.com No. of poles 1 = 1 CO (SPDT), 16 A 2 = 2 CO (DPDT), 16 A (type 12.22 and 12.92) 1 . 8 . 2 3 0 . 0 5 12 Series - Time switches 16 A Technical data Insulation 12.01, 12.11, 12.31 12.21, 12.22, 12.71, 12.91, 12.92 Dielectric strength between open contacts V AC 1,000 1,000 Other data 12.01, 12.11, 12.31 12.21, 12.22, 12.71, 12.91, 12.92 Power back-up 100 h (following 80 h continuous energisation) 6 years Power lost to the environment without contact current W 1.5 2 with rated current W 2.5 3 (for 1 pole) Nm 1.2 Screw torque Max. wire size mm2 AWG 4 (for 2 pole) 1.2 solid cable stranded cable solid cable stranded cable 1x6 / 2x4 1x6 / 2x2.5 1x6 / 2x4 1x6 / 2x2.5 1x10 / 2x12 1x10 / 2x14 1x10 / 2x12 1x10 / 2x14 Technical data type 12.51 and 12.81 Insulation Dielectric strength Impulse (1.2/50 µs) between supply and contacts 4,000 V AC 6 kV between open contacts 1,000 V AC 1.5 kV EMC specifications Type of test Electrostatic discharge Reference standard contact discharge EN 61000-4-2 4 kV air discharge EN 61000-4-2 8 kV Radiated electromagnetic field (80 … 1,000 MHz) EN 61000-4-3 10 V/m Fast transients (burst 5/50 ns, 5 and 100 kHz) EN 61000-4-4 4 kV Voltage pulses on supply terminals (surge 1.2/50 µs) common mode EN 61000-4-5 4 kV differential mode EN 61000-4-5 4 kV Radiofrequency common mode voltage (0.15…80 MHz) EN 61000-4-6 10 V Voltage dips EN 61000-4-11 10 cycles EN 61000-4-11 10 cycles 70 % UN , 40 % UN Short interruptions Radio frequency conducted emissions Radiated emissions 0.15…30 MHz EN 55014 class B 30…1,000 MHz EN 55014 class B Terminals Screw torque Max. wire size 0.8 Nm solid cable stranded cable Wire strip length 1 x 6 / 2 x 4 mm2 1 x 10 / 2 x 12 AWG 1 x 4 / 2 x 2.5 mm2 1 x 12 / 2 x 14 AWG 9 mm Other data Power back-up (Battery life) 6 years Battery type CR 2032, 3 V, 230 mAh Power lost to the environment in stand-by 1.4 W 2.9 W with rated current 3.5 W XII-2012, www.findernet.com without contact current 6 12 Series - Time switches 16 A Wiring diagrams L L N N Type 12.01 Selector switch: I = Permanently OFF O AUTO = Automatic I = Permanently ON Type 12.11 Selector switch: O = Automatic I = Permanently ON L L N N Type 12.21 12.22 12.91 12.92 XII-2012, www.findernet.com Type 12.31 L L N N Type 12.71 Type 12.51 12.81 7 12 Series - Time switches 16 A Accessories for type 12.71 and 12.91 PC programming kit for type 12.71, 12.91.8.230.0090 012.90 This special PC programming kit, permits fast and easy programming of the Time Switch with a PC or Laptop. The program transfer can be done by the special Key Memory (supplied with the 12.91.8.230.0090) or directly by the Time switch 12.71. Contents: Programming adaptor, USB cable (1.8 meter length), Software. 2. Start Software 1. Connect adaptor 012.90 PC Adaptor Software PC Adaptor 3. Connect time switch Key Time switch 12.71 PC Adaptor 4. Transfer the Program Key Time switch 12.71 PC Programming software XII-2012, www.findernet.com Easy and intuitive software to create programs for the Time Switch, in a few fast steps. For Windows 2000/XP/Vista. 8 12 Series - Time switches 16 A Battery replacement type 12.51 and 12.81 Accessories type 12.51 and 12.81 Adaptor for panel mounting, 35 mm wide 011.01 XII-2012, www.findernet.com 011.01 9 12 Series - Time switches 16 A Outline drawings 12.11 Screw terminal 12.21 Screw terminal 12.22 Screw terminal 12.31 Screw terminal 12.51/12.81 Screw terminal XII-2012, www.findernet.com 12.01 Screw terminal 10 12 Series - Time switches 16 A Outline drawings 12.91...0000 Screw terminal 12.91...0090 Screw terminal 12.92 Screw terminal XII-2012, www.findernet.com 12.71 Screw terminal 11 12 Series - Time Switch 16 A Functions type 12.51 All the functions and the values can be set through the front joystick and are displayed on the front LCD. Display mode During normal operation, with AC supply connected, the following is displayed: - the current time (hours and minutes) - the status (ON/OFF and symbol of contact open/closed) of the 11-14 output contact - the program for the current day (each solid segment represents an half-hour interval set to ON) From Display mode it is possible to enter in Program mode or Setup mode respectively with a short or long (> 2”) press to the joystick centre . Hand mode From Display mode it is also possible to enter in Hand mode, where (independently from the program) the 11-14 output contact is forced to the ON or OFF position with a long (> 2”) press to the joystick or directions, respectively. The “hand” symbol is then displayed. A long press in the opposite direction will exit the hand mode. Setup mode In this mode it is possible to set (in the following order): - daily/weekly function - current year - current day - current month - current hour - current minute - enable/disable european summer time. With a short press of the joystick or , it is possible to pass from one setup step to another (confirming the set values); in any step it is possible to modify the set values with a short press to the joystick or . A sustained (> 1”) press results in the fast increasing (or decreasing) of values. A short press to the joystick centre will restore the Display mode. XII-2012, www.findernet.com Note: the product is supplied factory set to Central Europe time with european summer time enabled. 12 12 Series - Time Switch 16 A Functions type 12.51 Program mode (daily) In this mode it is possible to set the “pattern” of time segments, which define the ON time of the 11-14 output contact. This “pattern” will be the same for all days of the week (daily). Entering Programming mode (from Display mode) with a short press to takes the digital time to 00:00 (and any previously programmed segment pattern is displayed). Stepping backwards forwards or in time displays the appropriate segment time and the appropriate open or closed contact status for that time segment. At any step it is possible to change the segment status with a short press to the joystick (for ON) or (for OFF) as appropriate, and this also automatically advances the time to the next segment, and always in a clockwise direction. If the joystick is pressed several times in, say, the direction then each successive segment will assume the ON status. If it is then pressed several times in the direction then each successive segment will assume the OFF status. This allows the rapid setting of many consecutive segments with the same status. A short press to the joystick centre will restore the display to the Display mode. Program mode (weekly) In this mode it is possible to set a different “pattern” of time segments for each day of the week (weekly). Entering Programming mode (from Display mode) with a short press to programming mode, for the current day. With a subsequent short press to takes the display to the or it is possible to pass from one day to another (Monday is day 1). With the desired day selected it is possible to enter the programming mode for that day by pressing . Program the segments for that day by following the same procedure as described above for daily mode. When all 48 segments have been set, accept with a short press to pressing the joystick in the or . Then progress to the next day by direction. Repeat programming for the next day, and then repeat for other remaining days. At any time return to the Display mode with a short press to the joystick centre . COPY FUNCTION View the particular day to be copied (using or as described above) and copy with a short press to (the “copy icon” will then appear). Then select another day, using or , and paste the copied program with a short press to . This can be repeated for other days. A short press to the joystick centre , or , will exit the copy function. Power-save mode If the 230 V AC supply is not connected, the time switch enters power-save mode: only the clock is maintained active whilst the display turns off so as to guarantee a long life for the built-in back-up battery. With a press to the joystick it is possible to “awake” the device and enter Display mode (with the “plug” symbol displayed). A further press to will enter the program or set-up mode as explained in the Display mode section above. XII-2012, www.findernet.com After about 1 minute of inactivity the power-save mode will start again. During program or set-up the current absorption is higher than in power-save mode, thus influencing the battery life. In this mode the display back-light is not active. It is activated following a press to the joystick only with the 230 V AC supply connected, but after about 1 minute of inactivity the display back-light will turn off, and to activate it again it is necessary to press the joystick again. 13 12 Series - Astro-Switch 16 A Functions type 12.81 All the functions and the values can be set through the front joystick and are displayed on the front LCD. Display mode During normal operation, with AC supply connected, the following is displayed: - the current time (hours and minutes) - the status (ON/OFF and symbol of contact open/closed) of the 11-14 output contact From Display mode it is possible to enter in Program mode or Setup mode respectively with a short or long (> 2”) press to the joystick centre . Hand mode From Display mode it is also possible to enter in Hand mode, where (independently from the program) the 11-14 output contact is forced to the ON or OFF position with a long (> 2”) press to the joystick or directions, respectively. The “hand” symbol is then displayed. A long press in the opposite direction will exit the hand mode. Setup mode In this mode it is possible to set (in the following order): - country (using Internet websites extension, e.g. IT, DE, FR..) - post-code (CP, setting only the first 2 digits, 00 to 99), - current year - current day - current month - current hour - current minute - enable/disable european summer time. With a short press of the joystick or , it is possible to pass from one setup step to another (confirming the set values); in any step it is possible to modify the set values with a short press to the joystick or . A sustained (> 1”) press results in the fast increasing (or decreasing) of values. A short press to the joystick centre will restore the Display mode. When the post-code is set to – – (between 99 and 00), the manual setting of geographic coordinates is possible: moving right side the joystick, it is visualized the latitude (settable between 30 and 64°North), then the longitude (settable between 16°West and 50°East), finally the Time Zone (Gmt, settable to 00-Greenwich time, 01-Central Europe time, 02-Eastern Europe time or 03-European Russia time); then year and the other setting follows. Note: the product is supplied with the following factory settings: - Central Europe time, - european summer time enabled, - country Italy, XII-2012, www.findernet.com - post-code 00 (the capital city Rome). 14 12 Series - Astro-Switch 16 A Functions type 12.81 Program mode (anticipate/delay setting) In this mode it is possible to set independently: - the anticipate (or the delay) of the light turn-off time in the morning with respect to the “astronomic” sunrise time, depending on the area (post-code or geographical coordinates) set and on the actual day; - the anticipate (or the delay) of the light turn-on time in the evening with respect to the “astronomic” sunset time. After entering in Program mode, it is displayed the “astronomic” sunrise time (indicated by the rising sun following the moon, the OFF and the open contact symbols); with a short pressure of the joystick respectively or , it is possible to delay/anticipate, with 10 minutes step, the light turn-off time. This setting will be obviously valid all days, that is the light will always turn-off, for example, 30 minutes after the “astronomic” sunrise. A short pressure of the joystick or side will show the “astronomic” sunset time (indicated by the falling sun preceding the moon, the ON and the closed contact symbols); with a short pressure of the joystick respectively or , it is possible to delay/anticipate, with 10 minutes step, the light turn-on time. This setting will be obviously valid all days, that is the light will always turn-on, for example, 30 minutes before the “astronomic” sunset. A short pressure of the joystick or side will continue to alternate the display/setting of turn-off time (sunrise) with the turn-on time (sunset). A short press to the joystick centre will restore the display to the Display mode. Power-save mode If the 230 V AC supply is not connected, the time switch enters power-save mode: only the clock is maintained active whilst the display turns off so as to guarantee a long life for the built-in back-up battery. With a press to the joystick it is possible to “awake” the device and enter Display mode (with the “plug” symbol displayed). A further press to will enter the program or set-up mode as explained in the Display mode section above. After about 1 minute of inactivity the power-save mode will start again. During program or set-up the current absorption is higher than in power-save mode, thus influencing the battery life. In this mode the display back-light is not active. It is activated following a press to the joystick only with the 230 V AC supply connected, but after about 1 minute of inactivity the display back-light will turn off, XII-2012, www.findernet.com and to activate it again it is necessary to press the joystick again. 15
12.71.0.024.0000 价格&库存
很抱歉,暂时无法提供与“12.71.0.024.0000”相匹配的价格&库存,您可以联系我们找货
  • 1+1051.634861+136.31190
  • 5+976.574135+126.58260
库存:4
