7E.64.8.230.0210
7E.64.8.230.0210
    FINDER
    FINDER - 7E.64.8.230.0210 - Energy Meter, 7E Series, Single Phase, 40 A, 230 Vac, SO Output, RS485,...
7E.64.8.230.0210 数据手册
Energy meters 7E SЕRIES Panels for electrical distribution Control panels Electrical energy control Industrial robots Road / tunnel lighting Elevators and lifts FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 7E SERIES Energy meters 7E SERIES 7E.12.8.230.0002 kWh Energy meter 1-phase with electromechanical display and SO pulse output 7E.13.8.230.0010 7E.16.8.230.0010 Type 7E.12.8.230.0002 10 (25) A , kWh, No MID, horizontal display Type 7E.13.8.230.0010 5 (32) A , kWh, MID, 1 module wide Type 7E.16.8.230.0010 10 (65) A, kWh, MID, horizontal display • Complies with EN 62053-21 and EN 50470 • Certified by PTB (7E.13 and 7E.16) (Physikalisch - Technischen Bundesanstalt) • Nominal current 10 A • Accuracy class 1/B (25 A Maximum) • Protection class II • 1-phase 230 V AC • SO pulse output for remote energy monitoring • SO pulse output according to EN 62053-31 • 35 mm wide • Tamper-proof cover with lead seal facility available as an accessory • Nominal current 5 A • Nominal current 10 A (32 A Maximum) • MID certified (50 Hz) • 1-phase 230 V AC • SO pulse output • 17.5 mm wide • MID certified (50 Hz) • 1-phase 230 V AC • SO pulse output • 35 mm wide (65 A Maximum) • Space saving small size • 35 mm rail (EN 60715) mount E For outline drawing see page 15 Specification Nominal/Maximum current  A Minimum measured current  A 0.04 0.02 0.04 Current range (within accuracy class)  A 0.5…25 0.25…32 0.5…65 Maximum peak current  A 750 (10 ms) 960 (10 ms) 1950 (10 ms) Supply (& monitored) voltage (UN)  V AC Operating range 10/25 5/32 10/65 230 230 230 (0.8…1.15)UN (0.8…1.15)UN (0.8…1.15)UN Frequency  Hz 50 50 50 Power consumption  W
7E.64.8.230.0210 价格&库存
很抱歉,暂时无法提供与“7E.64.8.230.0210”相匹配的价格&库存,您可以联系我们找货
