REPORT
7T Series
Multifunction panel
Thermo-Hygrostat
Type 7T.51
Multifunction panel
Thermo-Hygrostat.
Maintains the desired humidity,
depending on ambient temperature,
in control panels and enclosures.
pending
Features
Small, compact size (17.5mm wide)
4 functions
Nominal voltage 110...230 V AC/DC
Temperature range from +10 ° to +60°C
Humidity range up to 90%
LED status indication
35 mm rail mount (EN 60715)
7T SERIES
Panel Thermo-Hygrostat
Type 7T.51.0.230.4360 Thermo-Hygrostat
FINDER reserves the right to alter characteristics at any time without notice.FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products.
1 NO 10 A
Power supply voltage: 110...230 V AC/DC
4 functions
Thermostat full range accuracy: –1...+ 3K
Hygrostat setting accuracy: 5%
Dimensions (w x h x d): 17.5 x 88.8 x 47.8 mm
35 mm rail (EN 60715) mounting
Screw terminal
Wiring diagram
7H/7F
SERIES
PRODUCTS
findernet.com
ADV7T51EN - June 2018 - Report 7T Series - On-line updates
很抱歉,暂时无法提供与“7T.51.0.230.4360”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+713.15814
- 5+697.62268
- 25+627.87478
- 国内价格 香港价格
- 1+712.590221+92.06110
- 5+668.069735+86.30940
- 10+623.5492410+80.55770
