83.11.0.240.0000
83.11.0.240.0000
    FINDER
    开 - 延迟 延时继电器 SPDT(1 Form C) 0.05 秒 ~ 240 小时 延时 16A @ 250VAC DIN 轨道
83.11.0.240.0000 数据手册
83 SERIES Modular timers 12 - 16 A 83 SERIES 83.01 Multi-function timer range 83.01 - Multi-function & multi-voltage, 1 Pole 83.02 - Multi-function & multi-voltage, 2 Pole (timed + instantaneous options), external time setting potentiometer option 83.52 - Multi-function & multi-voltage, 2 Pole (timed + instantaneous options), external time setting potentiometer option, pause function option • 22.5 mm wide • Eight time scales from 0.05 s to 10 days • High input/output isolation • Wide supply range (24…240)V AC/DC • 35 mm rail (EN 60715) mount • “Blade + cross” - both flat blade and cross head screw drivers can be used to adjust the range and function selectors, the timing trimmer, and to disengage the rail mounting clip • Multi-voltage versions with “PWM clever” technology • Complies with EN 45545-2:2013 (protection against fire of materials), EN 61373 (resistance against random vibrations and shock, Category 1, Class B), EN 50155 (resistance to temperature and humidity, T1 class) • Multi-voltage • Multi-function 83.02 83.52 • Multi-voltage • Multi-function • Timing can be regulated using ext. Potentiometer • 2 timed contacts or 1 timed + 1 • Multi-voltage • Multi-function • Timing can be regulated using ext. Potentiometer • 2 timed contacts or 1 timed + 1 instantaneous contact • 3 functions with pause option AI: On-delay DI: Interval GI: Pulse delayed SW: Symmetrical flasher (starting pulse on) BE: Off-delay with control signal CE: On- and off-delay with control signal DE: Interval with control signal on WD: Watchdog (Retriggerable interval with control signal on) AE:  On-delay with control signal GE:  Pulse delayed with control signal on IT: Timing step FE:  Interval with control signal on and off EEa:  Interval with control signal off (retriggerable) DEp:  Interval with control signal on and pause signal BEp:  Off-delay with control signal and pause signal SHp: “Shower” function instantaneous contact AI: On-delay DI: Interval GI: Pulse delayed SW:  Symmetrical flasher (starting pulse on) BE: Off-delay with control signal CE:  On- and off-delay with control signal DE: Interval with control signal on WD: Watchdog (Retriggerable interval with control signal on) Wiring diagram (without control signal) Wiring diagram (without control signal) Wiring diagram (with control signal and external potentiometer connection) Wiring diagram (with control signal) Wiring diagram (with control signal and pause signal) Wiring diagram (with control signal) For outline drawing see page 5 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC 1 CO (SPDT) 2 CO (DPDT) 2 CO (DPDT) 16/30 12/30 12/30 250/400 250/400 250/400 Rated load AC1  VA 4000 3000 3000 Rated load AC15 (230 V AC) VA 750 750 750 Single phase motor rating (230 V AC)  kW 0.5 0.5 0.5 16/0.3/0.12 12/0.3/0.12 12/0.3/0.12 300 (5/5) 300 (5/5) 300 (5/5) AgNi AgNi AgNi 24…240 24…240 24…240 24…240 Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material H Supply specification Nominal voltage (UN) Rated power AC/DC Operating range V AC (50/60 Hz) V DC 24…240 24…240 VA (50 Hz)/W
83.11.0.240.0000 价格&库存
很抱歉,暂时无法提供与“83.11.0.240.0000”相匹配的价格&库存,您可以联系我们找货
  • 1+498.422751+64.34220
  • 10+417.3655910+53.87840
库存:16
83.11.0.240.0000
    • 1+480.76521
    库存:6
