93.61.7.024
93.61.7.024
    FINDER
93.61.7.024 数据手册
93 Series - Sockets and accessories for 34 series relays 93.61 Screw terminal socket 35mm rail mounting (EN 60715) Common features - Space saving 6.2 mm wide - Connections for 16-way jumper link - Integral coil indication and protection circuit - Secure retention and easy ejection by plastic clip - Dual screw head (blade+cross) terminals For technical data and supply versions, refer to the MasterINTERFACE 39 Series – “Relay interface module” Electromechanical Relay - EMR Socket type (reference with the 39 Series) 93.62 Supply voltage 6 V AC/DC 12 V AC/DC 24 V AC/DC 93.63 Relay type MasterBASIC (39.11…..) MasterPLUS (39.31…..) MasterINPUT MasterOUTPUT MasterTIMER (39.41…..) (39.21…..) (39.81…..) 34.51.7.005.xx10 93.61.7.024 93.63.7.024 93.64.0.024 93.62.7.024 — 34.51.7.012.xx10 93.61.7.024 93.63.7.024 93.64.0.024 93.62.7.024 93.68.0.024 34.51.7.024.xx10 93.61.7.024 93.63.7.024 93.64.0.024 93.62.7.024 93.68.0.024 60 V AC/DC (110…125)V AC * 34.51.7.060.xx10 34.51.7.060.xx10 — — 93.63.7.060 93.63.3.125 — — — — (220…240)V AC * (110…125)V AC/DC (220…240)V AC (110…125) V DC 220 V DC 34.51.7.060.xx10 — 93.63.3.230 — — 34.51.7.060.xx10 — 93.63.0.125 93.64.0.125 93.62.0.125 34.51.7.060.xx10 93.61.8.230 93.63.8.230 93.64.8.230 93.62.8.230 34.51.7.060.xx10 — 93.63.7.125 — — 34.51.7.060.xx10 — 93.63.7.220 — — — — — — — — — * Leakage current suppression 93.64 Solid State Relay - SSR 93.68 Supply voltage Relay type 12 V AC/DC 24 V AC/DC (110…125)V AC * (220…240)V AC * (110…125)V AC/DC (220…240)V AC 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx MasterBASIC (39.10…..) — — — — — 93.61.8.230 Socket type (reference with the 39 Series) MasterPLUS MasterINPUT MasterOUTPUT MasterTIMER (39.30…..) (39.40…..) (39.20…..) (39.80…..) — — — 93.68.0.024 93.63.0.024 93.64.0.024 — 93.68.0.024 93.63.3.125 — — — 93.63.3.230 — — — 93.63.0.125 93.64.0.125 93.62.0.125 — 93.63.8.230 93.64.8.230 93.62.8.230 — 6 V DC 34.81.7.005.xxxx 93.61.7.024 93.63.7.024 93.64.0.024 93.62.7.024 — 12 V DC 24 V DC 60 V DC (110…125) V DC 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 93.61.7.024 93.61.7.024 — — 93.63.7.024 93.64.0.024 93.62.7.024 93.63.7.024 93.64.0.024 93.62.7.024 93.63.7.060 — — 93.63.7.125 — — — — — — 220 V DC 34.81.7.060.xxxx — 93.63.7.220 — — — * Leakage current suppression Accessories 16-way jumper link Dual-purpose plastic separator 093.16 (blue), 093.16.0 (black), 093.16.1 (red) 093.60 Sheet of marker tags Technical data Rated values 093.64 6 A – 250 V Dielectric strength Protection category 6 kV (1.2/50 μs) between coil and contacts IP20 Ambient temperature Screw torque °C Nm −40…+70 0.5 Wire strip length Max wire size mm 10 Solid wire and stranded wire mm2 AWG 1 x 2.5 / 2 x 1.5 1 x 14 / 2 x 16 6 Courtesy of Steven Engineering, Inc.-230 Ryan Way, South San Francisco, CA 94080-6370-Main Office: (650) 588-9200-Outside Local Area: (800) 258-9200-www.stevenengineering.com 93 Series - Sockets and accessories for 34 series relays 93.51 Homologaciones (según los tipos): Certain relay/socket combinations Screw less terminal socket 35mm rail mounting (EN 60715) Common features - Space saving 6.2 mm wide - Connections for 20-way jumper link - Integral coil indication and protection circuit - Secure retention and easy ejection by plastic clip For technical data and supply versions, refer to the 38 Series – “Relay interface module” Electromechanical Relay - EMR and Solid State Relay - SSR Supply voltage Relay type (reference with the 38 Series) Electromechnanical relay - EMR Solid State Relay - SSR Socket type 12 V AC/DC (38.61…..) 34.51.7.012.xx10 (38.81…..) — 93.51.0.024 24 V AC/DC (110…125)V AC/DC (220…240)V AC/DC 34.51.7.024.xx10 34.51.7.060.xx10 34.51.7.060.xx10 — 34.81.7.060.xxxx 34.81.7.060.xxxx 93.51.0.024 93.51.0.125 93.51.0.240 (110…125)V AC/DC * (220…240)V AC * 34.51.7.060.xx10 34.51.7.060.xx10 34.81.7.060.xxxx 34.81.7.060.xxxx 93.51.3.125 93.51.3.240 (220…240)V AC 12 V DC 24 V DC 60 V DC 34.51.7.060.xx10 34.51.7.012.xx10 34.51.7.024.xx10 34.51.7.060.xx10 34.81.7.060.xxxx 34.81.7.012.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 93.51.8.240 93.51.7.024 93.51.7.024 93.51.7.060 * Leakage current suppression Accessories 20-way jumper link Plastic separator Sheet of marker tags Technical data Rated values Dielectric strength Protection category Ambient temperature (UN≤ 60 V/> 60 V) Wire strip length 093.20 093.01 093.64 °C mm Max wire size mm2 AWG 6 A – 250 V 6 kV (1.2/50 μs) between coil and contacts IP20 −40...+70/−40...+55 10 Solid wire and stranded wire 1 x 2.5 / 2 x 1.5 1 x 14 / 2 x 16 7 Courtesy of Steven Engineering, Inc.-230 Ryan Way, South San Francisco, CA 94080-6370-Main Office: (650) 588-9200-Outside Local Area: (800) 258-9200-www.stevenengineering.com 93 Series - Sockets and accessories for 34 series relays PCB socket with retaining and release clip 93.11 (blue) For relay type 34.51, 34.81 Technical data 93.11 Approvals (according to type): Rated values 6 A - 250 V Dielectric strength ≥ 6 kV (1.2/50 μs) between coil and contacts Protection category Ambient temperature IP 20 °C –40…+70 Retaining and release clip use: Copper side view A2 A1 12 11 14 (+) (A) 8 Courtesy of Steven Engineering, Inc.-230 Ryan Way, South San Francisco, CA 94080-6370-Main Office: (650) 588-9200-Outside Local Area: (800) 258-9200-www.stevenengineering.com
93.61.7.024 价格&库存
很抱歉,暂时无法提供与“93.61.7.024”相匹配的价格&库存,您可以联系我们找货
  • 1+70.377931+9.08520
  • 3+62.499803+8.06820
  • 5+61.974595+8.00040
库存:621
93.61.7.024
  • 10+82.1008110+10.59853
  • 1+65.88548
  • 3+58.46521
  • 5+57.97596
库存:616
