96.12SMA
96.12SMA
    FINDER
96.12SMA 数据手册
56 Series - Miniature power relays 12 A Features 56.32 56.32-0300 56.34 Plug-in 12 A Power relay, 2 & 4 pole • Flange mount option (Faston 187, 4.8x0.5 mm termination) • AC coils & DC coils • Lockable test button and mechanical flag indicator - standard on 2 pole types • Cadmium Free contacts (preferred version) • Contact material options • 96 series sockets, coil EMC suppression, accessories 2 pole changeover contact • Plug-in/Faston 187 • 2 pole normally open contact (1.5 mm gap) • Plug-in/Faston 187 • 1 32 4 3 • • 4 pole changeover contact Plug-in/Faston 187 4 1 52 6 3 7 4 8 56 5 6 8 A2 7 A1 14 A2 27.8 36.3 37.7 12 41 6.5 6.5 7.25 5.9 8.6 10 10 11 13 A1 27.7 20.7 27.7 20.7 8 A2 10 35.2 7 A1 9 6 6.5 5 10 10 10 7.25 5.9 4.75 3.85 7.25 5.9 4.753.85 * For 4 CO (4PDT) only. Contact specification 2 CO (DPDT) Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 2 NO (DPST-NO) - 1.5 mm 4 CO (4PDT) 12/20 12/20 12/20 250/400 250/400 250/400 Rated load AC1 VA 3,000 3,000 3,000 Rated load AC15 (230 V AC) VA 500 500 500 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material 0.55 0.55 0.55 12/0.25/0.12 12/0.6/0.3 12/0.25/0.12 500 (10/5) 500 (10/5) 500 (10/5) AgNi AgNi AgNi Coil specification Nominal voltage (UN) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 - 400* V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W Operating range AC 6-12-24-48-60-110-125-220 — 6-12-24-48-60-110-125-220 1.5/1 1.5/— 2/1.3 (0.8…1.1)UN (0.85…1.1)UN (0.8…1.1)UN (0.8…1.1)UN — (0.85…1.1)UN Holding voltage AC/DC 0.8 UN/0.6 UN 0.85 UN/— 0.8 UN/0.6 UN Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/— 0.2 UN/0.1 UN DC Technical data Mechanical life AC/DC cycles 20 · 106/50 · 106 20 · 106/— 20 · 106/50 · 106 Electrical life at rated load AC1 cycles 200 · 103 200 · 103 150 · 103 8/8 8/4 8/8 4 4 5 1,000 2,000 1,000 –40…+70 –40…+70 –40…+70 RT I RT I RT I Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Environmental protection V AC °C Approvals (according to type) 75 56 Series - Miniature power relays 12 A Features 56.42 56.42-0300 56.44 Printed circuit mount 12 A Power relay •2 & 4 pole coils & DC coils • Cadmium Free contacts (preferred version) • Contact material option • AC 27.7 27.7 2 pole changeover contact • PCB mount 3 1 32 4 7.25 5.9 4.75 3.85 4 pole changeover contact PCB mount 1 52 6 3 7 4 8 4 56.42-0300 5 41 27.8 5 6 7 A1 4 5 6 7.25 8 * For 4 CO (4PDT) only 4 5 6 7 14.2 56.44 3 11 5.9 7.25 8 1 12 14 A2 41 10 10 8.6 27.7 2.5 27.7 2.5 2 3 7 7.25 5.9 4.75 3.85 3.85 4.75 5.9 10 13 A1 8 A2 20.7 10 35.2 6.5 10 1 9 6 7 A1 8 A2 20.7 10 10 • 7.25 5.9 8.6 56.42 10 • 2.5 10 14.2 56 2 pole normally open contact (1.5 mm gap) • PCB mount • 6.5 6.5 36.3 37.7 • 27.6 20.7 2 10 3 4 5 6 7 8 9 10 11 12 13 3.85 4.75 5.9 7.25 14 14.2 Copper side view Copper side view Copper side view 2 CO (DPDT) 2 NO (DPST-NO) 1.5 mm 4 CO (4PDT) Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 12/20 12/20 12/20 250/400 250/400 250/400 Rated load AC1 VA 3,000 3,000 3,000 Rated load AC15 (230 V AC) VA 500 500 500 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material 0.55 0.55 0.55 12/0.25/0.12 12/0.6/0.3 12/0.25/0.12 500 (10/5) 500 (10/5) 500 (10/5) AgNi AgNi AgNi Coil specification Nominal voltage (UN) 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 - 400* V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W Operating range AC DC 6-12-24-48-60-110-125-220 — 6-12-24-48-60-110-125-220 1.5/1 1.5/— 2/1.3 (0.8…1.1)UN (0.85…1.1)UN (0.8…1.1)UN (0.8…1.1)UN — (0.85…1.1)UN Holding voltage AC/DC 0.8 UN/0.6 UN 0.85 UN/— 0.8 UN/0.6 UN Must drop-out voltage AC/DC 0.2 UN/0.1 UN 0.2 UN/— 0.2 UN/0.1 UN Technical data Mechanical life AC/DC cycles 20 · 106/50 · 106 20 · 106/— 20 · 106/50 · 106 Electrical life at rated load AC1 cycles 200 · 103 200 · 103 150 · 103 8/8 8/4 8/8 Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Environmental protection Approvals (according to type) 76 V AC °C 4 4 5 1,000 2,000 1,000 –40…+70 –40…+70 –40…+70 RT I RT I RT I 56 Series - Miniature power relays 12 A Ordering information Example: 56 series plug-in relay, 2 CO (DPDT), 12 V DC coil, lockable test button and mechanical indicator. 5 6 . 3 A B C D 2 . 9 . 0 1 2 . 0 0 4 0 D: Special versions 0 = Standard 5 = Top flange mount (56.34 only) 6 = Rear flange mount 7 = Top 35 mm rail mount (56.34 only) 8 = Rear 35 mm rail mount (56.34 only) A: Contact material 0 = Standard AgNi 2 = AgCdO 4 = AgSnO2 Series Type 3 = Plug-in 4 = PCB B: Contact circuit 0 = CO (nPDT) 3 = NO (nPST), 1.5 mm contact gap No. of poles 2 = 2 pole, 12 A 4 = 4 pole, 12 A C: Options 0 = None 1 = Test button 2 = Mechanical indicator 3 = LED (AC) 4 = Lockable test button+mechanical indicator 5 = Lockable test button + LED (AC) 54 = Lockable test button + LED (AC) + mechanical indicator 6 = Double LED (DC non-polarized) 7 = Lockable test button + double LED (DC non-polarized) 74 = Lockable test button + double LED (DC non-polarized) + mechanical indicator 8 = LED + diode (DC, polarity positive to pin 7) 9 = Lockable test button + LED + diode (DC, polarity positive to pin 7) 94 = Lockable test button + LED + diode (DC, polarity positive to pin 7) + mechanical indicator Coil version 8 = AC (50/60 Hz) 9 = DC Coil voltage see coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best avaliability are shown in bold. Type B C 56.32 AC Coil version A 0-2-4 0 0-2-3-4-5 0-6 D AC 0-2-4 0 54 AC 0-2-4 3 0-3-5 DC 0-2-4 0 0-2-4-8-9 0-6 DC 0-2-4 0 94 56.34 AC-DC 0-2-4 0 0-1 0-5-6-7-8 56.42 AC 0-2-4 0-3 0 0 56.44 AC-DC 0-2-4 0 0 0 / 0-6 / Descriptions: Options and Special versions 3.6 41.9 7 A1 C: Option 3, 5, 54 LED (AC) 8 A2 7 A1 C: Option 6, 7, 74 Double LED (DC non-polarized) 8 A2 7 A1 8 A2 C: Option 8, 9, 94 D: Special versions 6 LED + diode (DC, polarity Rear flange mount positive to pin 7) (56.34 only) D: Special versions 8 Rear 35 mm rail mount (56.34 only) Lockable test button and mechanical flag indicator (0040) The dual-purpose Finder test button can be used in two ways: Case 1) The plastic pip (located directly above the test button) remains intact. In this case, when the test button is pushed, the contacts operate. When the test button is released the contacts return to their former state. Case 2) The plastic pip is broken-off (using an appropriate cutting tool). In this case, (in addition to the above function), when the test button is pushed and rotated, the contacts are latched in the operating state, and remain so until the test button is rotated back to its former position. In both cases ensure that the test button actuation is swift and decisive. 77 56 56 Series - Miniature power relays 12 A Technical data Insulation Insulation according to EN 61810-1 ed. 2 insulation rated voltage V 250 rated impulse withstand voltage 4 3 2 III III pollution degree overvoltage category Insulation between coil and contacts (1.2/50 µs) 400 kV 4 kV 4 (2 contacts); 5 (4 contacts) Dielectric strength between open contacts V AC 1,000 (changeover); 2,000 (normally open) Dielectric strength between adjacent contacts V AC 2,500 Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 µs) on A1 - A2 (differential mode) EN 61000-4-5 level 4 (4 kV) Other data Bounce time: NO/NC ms 1/3 (changeover) Vibration resistance (5...55)Hz, max. ± 1 mm: NO/NC Shock resistance g 16 2 pole Power lost in the environment 4 pole without contact current W 1 1.3 with rated current W 3.8 6.9 Recommended distance between relays mounted on PCB mm ≥5 Contact specification F 56 - Electrical life (AC) v contact current 2 pole relays F 56 - Electrical life (AC) v contact current 4 pole relays 7 7 10 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 6 10 Cycles Cycles 10 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 6 10 5 5 10 10 0 4 8 12 0 16 4 8 12 H 56 - Maximum DC1 breaking capacity Changeover version H 56 - Maximum DC1 breaking capacity Normally open version 20 1 2 3 DC breajking current (A) 20 10 6 4 4 contacts in series 2 1 0.2 10 6 4 1 2 contacts in series 2 1 0.2 0.1 0.1 20 16 (A) (A) DC breaking current (A) 56 3/— (normally open) g/g 15/15 60 100 140 DC voltage (V) 180 220 20 60 100 140 180 220 DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time of the load will increased. 78 56 Series - Miniature power relays 12 A Coil specifications DC coil data, 2 pole relay Nominal voltage UN V Coil code AC coil data, 2 pole relay Operating range Umin V Resistance Rated coil consumption R I at UN Ω mA Umax V 6 9.006 12 9.012 9.6 13.2 24 9.024 19.2 26.4 48 9.048 38.4 52.8 60 9.060 48 66 110 9.110 88 121 12,500 125 9.125 100 137.5 17,300 220 9.220 176 242 54,000 4 4.8 6.6 40 Nominal voltage UN Coil code Operating range Resistance Umin* Umax R V V Ω V Rated coil consumption I at UN (50Hz) mA 150 6 8.006 140 86 12 8.012 9.6 13.2 50 97 600 40 24 8.024 19.2 26.4 190 53 2,400 20 48 8.048 38.4 52.8 770 25 4,000 15 60 8.060 48 66 1,200 21 8.8 110 8.110 88 121 3,940 12.5 7.2 120 8.120 96 132 4,700 12 230 8.230 184 253 17,000 6 240 8.240 192 264 19,100 5.3 4.8 6.6 12 200 * Umin = 0.85 UN for normally open version. DC coil data, 4 pole relay Nominal voltage UN V Coil code 56 AC coil data, 4 pole relay Operating range Umin V Resistance Umax V R Ω 6 9.006 5.1 6.6 12 9.012 10.2 13.2 24 9.024 20.4 26.4 48 9.048 40.8 60 9.060 51 110 9.110 93.5 125 9.125 220 9.220 32.5 Rated coil consumption I at UN mA Nominal voltage UN Coil code Operating range Resistance Umin Umax R V V Ω V 185 6 8.006 123 97 12 8.012 9.6 490 49 24 8.024 19.2 52.8 1,800 27 48 8.048 38.4 66 3,000 20 60 8.060 121 10,400 10.5 110 8.110 107 137.5 14,200 8.8 120 8.120 187 242 44,000 5 230 8.230 240 8.240 400 8.400 4.8 6.6 U 2.0 UN U 2.0 UN 1.5 1.5 300 13.2 22 150 26.4 81 90 52.8 380 37 48 66 600 88 121 1,900 16.5 96 132 2,560 13.4 184 253 7,700 192 264 10,000 7.5 320 440 26,000 4.9 1.0 1.0 normally open version 2 changeover version 2 2 0 10 20 30 40 30 9 1 1 -10 mA 5.7 R 56 - AC coil operating range v ambient temperature 2 pole relay R 56 - DC coil operating range v ambient temperature 2 pole relay 0.5 -20 Rated coil consumption I at UN (50Hz) 50 60 70 80 (°C) R 56 - DC coil operating range v ambient temperature 4 pole relay 0.5 -20 -10 0 10 20 30 40 50 60 70 80 (°C) 60 70 80 (°C) R 56 - AC coil operating range v ambient temperature 4 pole relay U 2.0 UN U 2.0 UN 1.5 1.5 1 1.0 1 1.0 2 2 0.5 -20 -10 0 10 20 30 40 50 60 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 70 80 (°C) 0.5 -20 -10 0 10 20 30 40 50 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 79 56 Series - Miniature power relays 12 A Accessories Adaptor with top mount flange for 56.32.x.xxx.xx00 3.6 37.5 44.4 056.05 15 056.05 with relay 56 80 2 34.3 1.7 056.05 96 Series - Sockets and accessories for 56 series relays Approvals (according to type): 96.72 (blue) 56.32 094.71 12 A - 250 V ≥ 2 kV AC IP 20 –40…+70 0.8 10 solid wire 1x4 / 2x4 1x12 / 2x12 21 6 11 5 COM A2 8 A1 7 COIL 22 2 12 1 NC 44 8 34 7 24 6 14 5 NO 41 12 31 11 21 10 11 9 COM 78 A1 13 5 5 A2 14 COIL 6.5 3 27 96.72 56 19.4 NO 32 3 23.6 14 3 42 4 33.5 5 24 4 stranded wire 1x4 / 2x2.5 1x12 / 2x14 3.5 4 5 NC 096.71 99.01 78 12 1 96.74.0 (black) 56.34 3.5 4 22 2 96.72.0 (black) 96.74 (blue) 35 96.72 Screw terminal (Plate clamp) socket panel or 35 mm rail (EN 50022) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Modules (see table below) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 96.72 and 96.74 sockets mm2 AWG 46 27 30 96.74 99.01 coil indication and EMC suppression modules for types 96.72 and 96.74 sockets Blue* See technical data pages 247/248 99.01 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. Diode (+A1, standard polarity) (6...220)V DC Diode (+A2, non-standard polarity) (6...220)V DC 99.01.2.000.00 (6...24)V DC/AC 99.01.0.024.59 LED 99.01.3.000.00 LED (28...60)V DC/AC 99.01.0.060.59 LED (110...240)V DC/AC 99.01.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.01.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.01.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.01.9.220.99 LED + Diode (+A2, non-standard polarity) (6...24)V DC 99.01.9.024.79 LED + Diode (+A2, non-standard polarity) (28...60)V DC 99.01.9.060.79 LED + Diode (+A2, non-standard polarity) (110...220)V DC 99.01.9.220.79 LED + Varistor (6...24)V DC/AC 99.01.0.024.98 LED + Varistor (28...60)V DC/AC 99.01.0.060.98 LED + Varistor (110...240)V DC/AC 99.01.0.230.98 RC circuit (6...24)V DC/AC 99.01.0.024.09 RC circuit (28...60)V DC/AC 99.01.0.060.09 RC circuit (110...240)V DC/AC 99.01.0.230.09 (110...240)V AC 99.01.8.230.07 Residual current by-pass (62 kΩ/1W) 81 96 Series - Sockets and accessories for 56 series relays 96.12 Approvals (according to type): PCB socket For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values Dielectric strength Protection category Ambient temperature °C 96.12 (blue) 56.32 96.12.0 (black) 96.14 (blue) 56.34 094.51 15 A - 250 V ≥ 2 kV AC IP 20 –40…+70 21.5 21.5 25 244 216 4.5 14.3 29.5 222 143 115 29.5 2.5 121 6.1 5.9 4.7 10 11.3 16.6 A113 A214 Copper side view 56 96.12 424 347 3111 448 4112 A113 2.5 32.2 A214 11.3 Copper side4view 96.14 Packaging code How to code and identify retaining clip and packaging options for sockets. Code options according to the last three letters: 9 6 . 7 4 S M A A Standard packaging SM Metal retaining clip 9 6 . 7 82 4 4.5 14.3 41.5 25 323 246 2110 10 29.5 222 145 119 41.5 10 6.1 5.9 4.7 121 29.5 10 Without retaining clip 96.14.0 (black)
96.12SMA 价格&库存
很抱歉,暂时无法提供与“96.12SMA”相匹配的价格&库存,您可以联系我们找货
96.12SMA
    • 1+25.210011+3.25440
    • 10+23.5468510+3.03970
    • 20+22.2338220+2.87020
    • 50+19.5202550+2.51990
