14.01.8.230.0000
14.01.8.230.0000
    FINDER
    TIMER RLY SPST-NO 16A 230VAC
14.01.8.230.0000 数据手册
14 SERIES Electronic staircase timers16 A 14 SERIES Multi-function electronic staircase timers 1 NO 16 A 17.5 mm wide Type 14.01 --8 functions --Switch-off “early warning” options Type 14.71 --3 functions • Time setting from 30 seconds to 20 minutes • “Zero crossing” load switching • “Switch-off early warning” - model 14.01 • Suitable for 3 or 4 wire systems, with automatic recognition • Compatible with movement detectors (18 series) • LED status indicators • Cadmium free contact material • Can be used with illuminated push - buttons • “Blade + cross” - both flat blade and cross head screw drivers can be used to adjust the function selector, the timing trimmer, and to disengage the 35 mm rail mounting clip • 35 mm rail (EN 60715) mount • European Patent 14.01/71 Screw terminal 14.01 14.71 • 8 functions: --Staircase timer -- Staircase timer + • 3 functions: --Staircase timer --Staircase timer + maintenance function --Staircase timer with early maintenance function -- Light ON warning --Staircase timer with early warning + maintenance function --Timing step relay --Timing step relay with early warning --Step relay --Light ON For outline drawing see page 8 Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/ Maximum switching voltage V AC 1 NO (SPST-NO) 1 NO (SPST-NO) 16/30 (120 A - 5 ms) 16/30 (120 A - 5 ms) 230/— 230/— Rated load AC1 VA 3700 3700 Rated load AC15 (230 V AC) VA 750 750 230 V incandescent/halogenW 3000 3000 Nominal lamp rating: fluorescent tubes with electronic ballast W fluorescent tubes with electromagnetic ballast W 1500 1500 1000 1000 CFL W 600 600 230 V LED W 600 600 600 600 1500 1500 1000 (10/10) 1000 (10/10) AgSnO2 AgSnO2 230 230 LV halogen or LED with electronic ballast W LV halogen or LED with electromagnetic ballast W Minimum switching load mW (V/mA) Standard contact material I Supply specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power Operating range — — 3/1.2 3/1.2 (0.8…1.1)UN (0.8…1.1)UN — — cycles 100 · 103 100 · 103 min 0.5…20 0.5…20 30 30 continuous continuous –10…+60 –10…+60 IP 20 IP 20 VA (50 Hz)/W AC (50 Hz) DC Technical data Electrical life at rated load in AC1 I-2016, www.findernet.com Delay setting Max no. of illuminated push-button (≤ 1 mA) Maximum impulse duration Ambient temperature range Protection category °C Approvals (according to type) 1 14 SERIES 14 SERIES Electronic staircase timers16 A Mono-function electronic staircase timers 1 NO 16 A 17.5 mm wide Type 14.81 --Staircase timer + maintenance function Type 14.91 --Signal ON pulse timer • Time setting from 30 seconds to 20 minutes • “Zero crossing” load switching • Wiring compatible with mechanical versions and with old type (low emission) illuminated pushbuttons • Suitable for 3 or 4 wire systems, via “pushbutton configuration” • 110…125 V AC supply version available (14.81) • Cadmium free contact material • Can be used with illuminated push - buttons • “Blade + cross” - both flat blade and cross head screw drivers can be used to adjust the function selector, the timing trimmer, and to disengage the 35 mm rail mounting clip • 35 mm rail (EN 60715) mount 14.81 • Mono-function: --Staircase timer + maintenance function • All 4 terminal on same side 14.91 • Mono-function: --Signal ON pulse timer • All 3 terminal on same side 14.81/91 Screw terminal For outline drawing see page 8 Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/ Maximum switching voltage V AC 1 NO (SPST-NO) 1 NO (SPST-NO) 16/30 (120 A - 5 ms) 16/30 (120 A - 5 ms) 230/— 230/— Rated load AC1 VA 3700 3700 Rated load AC15 (230 V AC) VA 750 750 230 V incandescent/halogenW 3000 3000 Nominal lamp rating: I fluorescent tubes with electronic ballast W fluorescent tubes with electromagnetic ballast W 1500 1500 1000 1000 CFL W 600 600 230 V LED W 600 600 600 600 1500 1500 1000 (10/10) 1000 (10/10) AgSnO2 AgSnO2 110…125/230 230 LV halogen or LED with electronic ballast W LV halogen or LED with electromagnetic ballast W Minimum switching load mW (V/mA) Standard contact material Supply specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power Operating range — — 3/1.2 3/1.2 (0.8…1.1)UN (0.8…1.1)UN — — cycles 100 · 103 100 · 103 min 0.5…20 0.5…20 25 25 continuous continuous –10…+60 –10…+60 IP 20 IP 20 VA (50 Hz)/W AC (50 Hz) DC Electrical life at rated load in AC1 Delay setting Max no. of illuminated push-button (≤ 1 mA) Maximum impulse duration Ambient temperature range Protection category Approvals (according to type) 2 °C I-2016, www.findernet.com Technical data 14 SERIES Electronic staircase timers16 A 14 SERIES Ordering information Example: 14 series multi-function timer, 1 NO (SPDT-NO) 16 A contact, supply rated at 230 V AC. 1 4 . 0 1 . 8 . 2 3 0 . 0 Series 0 0 0 Supply voltage 120 = 110…125 V AC (14.81 only) 230 = 230 V Type 0 = 35 mm rail (EN 60715) mount, 8 functions 7 = 35 mm rail (EN 60715) mount, 3 functions 8 = 35 mm rail (EN 60715) mount mono-function, all terminals on same side 9 = 35 mm rail (EN 60715) mount, mono-function, 3 terminals Supply version 8 = AC (50/60 Hz) No. of poles 1 = 1 NO 16 A contact Technical data Insulation Dielectric strength between open contacts V AC 1000 Other data Power lost to the environment without contact current W 1.2 with rated current  W 2 Maximum cable length for push-button connection Screw torque m 200 Nm 0.8 Max. wire size solid cable stranded cable mm2 1 x 6 / 2 x 4 1 x 4 / 2 x 2.5 AWG 1 x 10 / 2 x 12 1 x 12 / 2 x 14 Zero crossing switching I 1 - Lower inrush current protects and increases lamp life 2 - Lower inrush current reduces the possibility of contact welding 3 - The current at switch-off is also lower, reducing stress and wear on the contacts Note Using the type 14.91, the lamps are switched on directly by the push-button Accessories Adaptor for panel mounting, 17.5 mm wide 020.01 Sheet of marker tags, plastic, 72 tags, 6 x 12 mm 060.72 I-2016, www.findernet.com 020.01 060.72 3 14 SERIES 14 SERIES Electronic staircase timers16 A Wiring diagrams Type 14.01 14.71 Red LED indication: Continuous = relay ON Blinking = relay OFF L L N N 4 wire connection 3 wire connection Type 14.81 (push-button configuration procedure, as per the Installation manual) L L N N I 3 wire connection 4 wire connection Type 14.91 (the push-buttons must be rated for the load current) L I-2016, www.findernet.com N 4 14 SERIES Electronic staircase timers16 A 14 SERIES Wiring diagrams - 14.01 or 14.71 without Staircase maintenance function, triggered by PIR movement detector (18 series). 3 wire connection (with 18.21.8.230.0300 or 18.31.8.230.0300 only) 4 wire connection (with 18.21.8.230.0300 or 18.31.8.230.0300 only) L L N N 4 wire connection (with 18.01.8.230.0000 or 18.11.8.230.0000 only) L N I-2016, www.findernet.com I 5 14 SERIES Electronic staircase timers16 A 14 SERIES Functions Type 14.01 Functions selectable with front rotary selector (BE) Staircase timer On initial impulse the output contact closes and timing starts for the pre-set duration; subsequent impulses during the timing period will extend the timing period by the full pre-set value. On expiry of the time delay, the output contact opens. BE + (ME) Staircase timer + Staircase maintenance In addition to the Staircase timer function (BE), an impulse of ≥ 5 seconds will close the output contact for 60 minutes, after which time the contact will open. Ideal for maintenance or cleaning activities. The 60 minute timing can be interrupted by a further impulse of ≥ 5 seconds, and the output contact then opens (BP) Staircase timer with early warning On initial impulse the output contact closes and the timing starts for the pre-set duration. After the timing period, the output contact blinks off once; 10secs later the contact blinks off twice, and after a further 10secs the contact opens. During the pre-set and 20 second warning time, it is possible, by a further impulse, to extend the time by the full pre-set value. BP + (MP) Staircase timer with early warning + Staircase maintenance In addition to the Staircase timer function (BP), an impulse of ≥ 5 seconds will close the output contact for 60 minutes, after which time the contact will open. Ideal for maintenance or cleaning activities. The 60 minute timing can be interrupted by a further impulse of ≥ 5 seconds, and the output contact then opens I (IT) Timing step relay On initial impulse the output contact closes and timing starts for the pre-set duration; On expiry of the time delay, the output contact opens. During the timing period it is possible to immediately open the contact with a further impulse. (IP) Timing step relay with early warning On initial impulse the output contact closes and timing starts for the pre-set duration; After the timing period, the output contact blinks off once; 10 secs later the contact blinks off twice, and after a further 10 secs the contact opens. During the pre-set and 20 second warning time, it is possible to immediately open the output contact by a further impulse. (RI) Step relay After every impulse, the output contact changes state - alternately switching from open to closed and vice versa. NOTE: The blinking within the Early Warning functions (BP and IP) could cause re-start problems for fluorescent lamps with electromagnetic chokes (both conventional and compact types); We consequently suggest not to use such lamps with these functions. 6 I-2016, www.findernet.com Light ON With this function set - the output contact stays permanently closed. 14 SERIES Electronic staircase timers16 A 14 SERIES Functions Type 14.71  Functions selectable with front selector 3-function front selector Staircase timer + Staircase maintenance Light ON Staircase timer (compatible with 18 series movement detectors) Staircase timer On initial impulse the output contact closes and timing starts for the pre-set duration; subsequent impulses during the timing period will extend the timing period by the full pre-set value. On expiry of the time delay, the output contact opens. Staircase maintenance An impulse of ≥ 5 seconds will close the output contact for 60 minutes, after which time the contact will open. Ideal for maintenance or cleaning activities. The 60’ timing can be interrupted by a further impulse of ≥ 5 seconds, the output contact opens. Light ON With this function set - the output contact stays permanently closed. Type 14.81 Staircase timer On initial impulse the output contact closes and timing starts for the pre-set duration; subsequent impulses during the timing period will extend the timing period by the full pre-set value. On expiry of the time delay, the output contact opens. I “Staircase maintenance” function An impulse of ≥ 5 seconds will close the output contact for 60 minutes, after which time the contact will open. Ideal for maintenance or cleaning activities. The 60’ timing can be interrupted by a further impulse of ≥ 5 seconds, which will re-establish the staircase timer function; so on expiry of the staircase time delay, the output contact opens. Type 14.91 I-2016, www.findernet.com Signal ON pulse On initial impulse the output contact closes, and remain so for the duration of the preset delay. On expiry of the time delay, the output contact opens. 7 14 SERIES 14 SERIES Electronic staircase timers16 A Outline drawings 14.01 Screw terminal 14.71 Screw terminal 14.81 Screw terminal 14.91 Screw terminal I-2016, www.findernet.com I 8
14.01.8.230.0000 价格&库存
很抱歉,暂时无法提供与“14.01.8.230.0000”相匹配的价格&库存,您可以联系我们找货
  • 1+512.54824
  • 5+496.86500
  • 10+485.45143
库存:60
