34.51.7.048.0010
34.51.7.048.0010
    FINDER
    插件
    SLIM RELAY SPDT 6A 48V DC
34.51.7.048.0010 数据手册
34 SERIES Slim electromechanical PCB relays 6 A 34 SERIES 34.51 Ultra-slim 1 Pole - 6 A relay 34.51-5010 Printed circuit mount - direct or via PCB socket 35 mm rail mount - via screw, screwless or push-in terminal sockets A • 1 Pole changeover contacts or 1 Pole normally open contact • Ultra slim, 5 mm, package • Sensitive DC coil - 170 mW (Dual AC/DC coil • 5 mm wide • Low coil power • PCB or 93 series sockets • 5 mm wide • Low coil power • PCB or 93 series sockets • Contact AgNi + Au Copper side view Copper side view 1 CO (SPDT) 1 CO (SPDT) 6/10 6/10 drive possible using 93 series sockets) • UL Listing (certain relay/socket combinations) • Cadmium Free contact materials • 8/8 mm clearance/creepage distance • 6 kV (1.2/50 μs) insulation, coil-contacts For UL ratings see: “General technical information” page V For outline drawing see page 5 Contact specification Contact configuration Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage A 250/400 250/400 Rated load AC1 VA 1500 1500 Rated load AC15 (230 V AC) VA 300 300 Single phase motor rating (230 V AC) kW 0.185 0.185 Breaking capacity DC1: 30/110/220 V A 6/0.2/0.12 6/0.2/0.12 mW (V/mA) 500 (12/10) 50 (5/2) AgNi AgNi + Au — — 5 - 12 - 24 - 48 - 60 5 - 12 - 24 - 48 - 60 —/0.17 —/0.17 Minimum switching load V AC Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) Rated power AC/DC VA (50 Hz)/W V DC Operating range AC — — DC (0.7…1.5)UN (0.7…1.5)UN Holding voltage AC/DC —/0.4 UN —/0.4 UN Must drop-out voltage AC/DC —/0.05 UN —/0.05 UN Mechanical life AC/DC cycles —/10 · 106 —/10 · 106 Electrical life at rated load AC1 cycles 60 · 10 60 · 103 ms 5/3 5/3 kV 6 (8mm) 6 (8mm) Technical data I-2017, www.findernet.com Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Environmental protection V AC °C 3 1000 1000 –40…+85 –40…+85 RT II RT II Approvals (according to type) 1 34 SERIES 34 SERIES Slim solid state PCB relays (SSR) 0.1 - 2 A 34.81-9024 Ultra-slim - Solid State Relays 34.81-8240 • Single circuit output switching options - 2 A, 24 V DC - 0.1 A, 48 V DC - 2 A, 240 V AC • Silent, high speed switching with long electrical life • Ultra slim, 5 mm, package • Sensitive DC Input circuits (Dual AC/DC input drive possible using 93 series sockets) • UL Listing (certain relay/socket combinations) • Wash tight: RT III • 2500 V insulation, input-output • 2 A, 24 V DC output switching • 0.1 A, 48 V DC output • PCB or 93 series sockets switching • PCB or 93 series sockets input output For outline drawing see page 5 • 2 A, 240 V AC output switching • Zero crossing switching • PCB or 93 series sockets input output input output Copper side view Copper side view Copper side view 1 NO (SPST-NO) 1 NO (SPST-NO) 1 NO (SPST-NO) 2/20 0.1/0.5 2/40 Output circuit Contact configuration Rated current/ Maximum peak current (10 ms) Rated voltage/ Maximum blocking voltage Switching voltage range A V (24/33)DC (48/60)DC (240/—)AC V (1.5…24)DC (1.5…48)DC (12…275)AC — — 600 Repetitive peak off-state voltage Vpk Minimum switching current mA 1 0.05 22 Max. “OFF-state” leakage current mA 0.001 0.001 1.5 V 0.12 1 1.6 Max. “ON-state” voltage drop Input circuit Nominal voltage Rated power AC/DC Operating range V DC W 5 12 24 60 0.035 0.087 0.17 0.18 V DC 3.5…12 8…17 16…30 35…72 24 60 0.17 0.18 16…30 35…72 5 12 24 60 0.060 0.087 0.17 0.18 3.5…10 8…17 16…30 35…72 Control current mA 7 7.2 7 3 7 3 12 7.2 7 3 Release voltage V DC 1 4 10 20 10 20 1 4 10 20 715 1940 3200 21300 3200 21300 416 1940 3200 21300 Impedance Ω Technical data Operate/release time Dielectric strength between input/output Ambient temperature range Environmental protection ms 0.1/0.6* 0.04/0.6* 12/12* V 2500 2500 2500 °C –20…+60 –20…+60 –20…+60 RT III RT III RT III Approvals (according to type) * Note: all technical data relates to using the relay directly on PCB or PCB socket type 93.11. If the relay is used with 35 mm rail socket type 93.51, refer to the technical data of 38 Series; if used with types 93.60, 93.61, 93.62, 93.63, 93.64, 93.65, 93.66, 93.67,93.68 and 93.69, refer to the technical data of the MasterINTERFACE 39 Series. 2 I-2017, www.findernet.com A 34.81-7048 Printed circuit mount - direct or via PCB socket 35 mm rail mount - via screw, screwless or push-in terminal sockets 34 SERIES Ultra-Slim PCB relays 34 SERIES Ordering information Electromechanical relay (EMR) Example: 34 series slim electromechanical relay, 1 CO (SPDT) 6 A contacts, 24 V sensitive DC coil. 3 4 . 5 A B C D 1 . 7 . 0 2 4 . 0 0 1 0 Series A: Contact material 0 = Standard AgNi 4 = AgSnO2 5 = AgNi + Au Type 5 = Electromechanical type No. of poles 1 = 1 pole, 6 A A D: Special versions 0 = Flux proof (RT II) 9 = Flat version C: Options 1 = None B: Contact circuit 0 = CO (SPDT) 3 = NO (SPST) Coil version 7 = Sensitive DC Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version A B C D 34.51 sens. DC 0-4-5 0-3 1 0 34.51 sens. DC 0-4-5 0 1 9 Solid state relay (SSR) Example: 34 series SSR relay, 2 A output, 24 V DC supply. 3 4 . 8 1 . 7 . 0 2 4 . 9 0 2 4 Output circuit 9024 = 2 A - 24 V DC 7048 = 0.1 A - 48 V DC 8240 = 2 A - 240 V AC Series Type 8 = SSR type Output 1 = 1 NO (SPST-NO) Input circuit See input specifications Flat pack version 14 11 12 A1 Option =34.51.7xxx.x019 A2 I-2017, www.findernet.com Copper side view Environmental protection RT I 3 34 SERIES Ultra-Slim PCB relays 34 SERIES Electromechanical relay Technical data Insulation according to EN 61810-1 Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 250 Pollution degree 400 3 2 Insulation between coil and contact set Type of insulation Reinforced Overvoltage category III Rated impulse voltage kV (1.2/50 μs) 6 Dielectric strength V AC 4000 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50 μs) 1000/1.5 Conducted disturbance immunity Burst (5…50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 μs) on A1 - A2 (differential mode) EN 61000-4-5 level 3 (2 kV) Other data Bounce time: NO/NC ms 1/6 Vibration resistance (5…55)Hz: NO/NC g 10/5 Shock resistance g 20/14 Power lost to the environment without contact current W 0.2 with rated current Recommended distance between relays mounted on PCB W 0.5 mm ≥ 5 Contact specification H 34 - Maximum DC1 breaking capacity DC breaking current (A) F 34 - Electrical life (AC) v contact current Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 Cycles DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 60 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. Coil specifications DC coil data Nominal voltage R 34 - DC coil operating range v ambient temperature Coil code Operating range Resistance Rated coil consumption UN Umin Umax R I at UN V V V Ω mA 5 7.005 3.5 12 7.012 8.4 18 24 7.024 16.8 48 7.048 33.6 60 7.060 42 7.5 130 38.4 840 14.2 36 3350 7.1 72 12300 3.9 90 19700 3 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 4 I-2017, www.findernet.com A 34 SERIES Ultra-Slim PCB relays 34 SERIES Solid state relay Technical data EMC specifications A Reference standard Electrostatic discharge contact discharge EN 61000-4-2 4 kV air discharge EN 61000-4-2 8 kV EN 61000-4-4 2 kV common mode EN 61000-4-5 0.5 kV differential mode EN 61000-4-5 0.5 kV Fast transients on supply terminals (burst 5/50 ns, 5 kHz) Voltage pulses on supply terminals (surge 1.2/50 μs) Other data Power lost to the environment without output current W 0.17 with rated current W 0.4 Input specification Input data - DC types Nominal voltage Input code Operating range UN Umin Umax V V V Release voltage Impedance Control current V Ω mA I at UN 5 7.005 3.5 12 (10*) 1 715 (416*) 7 (12*) 12 7.012 8 17 4 1940 7.2 24 7.024 16 30 10 3200 7 60 7.060 35 72 20 21300 3 * AC Output version. Output specification L 34 - Output current v ambient temperature SSR - 0.1 A DC output types Output current Output current L 34 - Output current v ambient temperature SSR - 2 A DC & AC output types Outline drawings Type 34.81 I-2017, www.findernet.com Type 34.51 5 34 SERIES 93 SERIES Sockets and accessories for 34 series relays A 93.61 Screw terminal socket 35 mm rail mounting (EN 60715) Common features - Space saving 6.2 mm wide - Connections for 16-way jumper link - Integral coil indication and protection circuit - Secure retention and easy ejection by plastic clip - Dual screw head (blade+cross) terminals For technical data and supply versions, refer to the MasterINTERFACE 39 Series – “Relay interface module” Electromechanical Relay - EMR Supply voltage 93.62 93.63 Relay type 6 V AC/DC 34.51.7.005.xx10 12 V AC/DC 34.51.7.012.xx10 24 V AC/DC 34.51.7.024.xx10 60 V AC/DC 34.51.7.060.xx10 (110…125)V AC/DC* 34.51.7.060.xx10 (220…240)V AC* 34.51.7.060.xx10 (110…125)V AC/DC 34.51.7.060.xx10 (24…240)V AC/DC 34.51.7.024.xx10 (220…240)V AC 34.51.7.060.xx10 (110…125)V DC 34.51.7.060.xx10 220 V DC 34.51.7.060.xx10 * Leakage current suppression MasterBASIC (39.11.....) 93.61.7.024 93.61.7.024 93.61.7.024 — — — 93.61.0.125 — 93.61.8.230 — — Socket type (reference with the 39 Series) MasterPLUS MasterINPUT MasterOUTPUT (39.21.....) (39.31.....) (39.41.....) 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.060 — — 93.63.3.125 — — 93.63.3.230 — — 93.63.0.125 93.64.0.125 93.62.0.125 93.63.0.240 — — 93.63.8.230 93.64.8.230 93.62.8.230 93.63.7.125 — — 93.63.7.220 — — MasterTIMER (39.81.....) — 93.68.0.024 93.68.0.024 — — — — — — — — MasterBASIC (39.10.....) — — — — 93.61.0.125 — 93.61.8.230 93.61.7.024 93.61.7.024 93.61.7.024 — — — Socket type (reference with the 39 Series) MasterPLUS MasterINPUT MasterOUTPUT (39.20.....) (39.30.....) (39.40.....) — — — 93.63.0.024 93.64.0.024 — 93.63.3.125 — — 93.63.3.230 — — 93.63.0.125 93.64.0.125 93.62.0.125 93.63.0.240 — — 93.63.8.230 93.64.8.230 93.62.8.230 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.024 93.64.7.024 93.62.7.024 93.63.7.060 — — 93.63.7.125 — — 93.63.7.220 — — MasterTIMER (39.80.....) 93.68.0.024 93.68.0.024 — — — — — — — — — — — Solid State Relay - SSR Supply voltage 93.68 Approvals (according to type): Relay type 12 V AC/DC 34.81.7.012.xxxx 24 V AC/DC 34.81.7.024.xxxx (110…125)V AC/DC* 34.81.7.060.xxxx (220…240)V AC* 34.81.7.060.xxxx (110…125)V AC/DC 34.81.7.060.xxxx (24…240)V AC/DC 34.81.7.024.xxxx (220…240)V AC 34.81.7.060.xxxx 6 V DC 34.81.7.005.xxxx 12 V DC 34.81.7.012.xxxx 24 V DC 34.81.7.024.xxxx 60 V DC 34.81.7.060.xxxx (110…125)V DC 34.81.7.060.xxxx 220 V DC 34.81.7.060.xxxx * Leakage current suppression Accessories 16-way jumper link Dual-purpose plastic separator Sheet of marker tags Technical data Rated values Dielectric strength Protection category Ambient temperature°C Screw torqueNm Wire strip lengthmm Max wire size mm2 AWG 6 093.16 (blue), 093.16.0 (black), 093.16.1 (red) 093.60 060.48 and 093.48 6 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 −40…+70 0.5 10 Solid wire and stranded wire 1 x(0.2…2.5) / 2 x 1.5 1 x (24…14) / 2 x 16 I-2017, www.findernet.com 93.64 93 SERIES Sockets and accessories for 34 series relays 93.60 34 SERIES Push-In terminal socket 35 mm rail mounting (EN 60715) Common features - Space saving 6.2 mm wide - Connections for 16-way jumper link - Terminal doubler 093.62 - Integral coil indication and protection circuit - Secure retention and easy ejection by plastic clip A For technical data and supply versions, refer to the MasterINTERFACE 39 Series – “Relay interface module” Electromechanical Relay - EMR Supply voltage 93.65 93.66 Relay type 6 V AC/DC 34.51.7.005.xx10 12 V AC/DC 34.51.7.012.xx10 24 V AC/DC 34.51.7.024.xx10 60 V AC/DC 34.51.7.060.xx10 110…125)V AC/DC* 34.51.7.060.xx10 (220…240)V AC* 34.51.7.060.xx10 110…125)V AC/DC 34.51.7.060.xx10 24…240)V AC/DC 34.51.7.024.xx10 (220…240)V AC 34.51.7.060.xx10 (110…125)V DC 34.51.7.060.xx10 220 V DC 34.51.7.060.xx10 * Leakage current suppression MasterBASIC (39.01.....) 93.60.7.024 93.60.7.024 93.60.7.024 — — — 93.60.0.125 — 93.60.8.230 — — Socket type (reference with the 39 Series) MasterPLUS MasterINPUT MasterOUTPUT (39.51.....) (39.61.....) (39.71.....) 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.060 — — 93.66.3.125 — — 93.66.3.230 — — 93.66.0.125 93.67.0.125 93.65.0.125 93.66.0.240 — — 93.66.8.230 93.67.8.230 93.65.8.230 93.66.7.125 — — 93.66.7.220 — — MasterTIMER (39.91.....) — 93.69.0.024 93.69.0.024 — — — — — — — — MasterBASIC (39.00.....) — — — — 93.60.0.125 — 93.60.8.230 93.60.7.024 93.60.7.024 93.60.7.024 — — — Socket type (reference with the 39 Series) MasterPLUS MasterINPUT MasterOUTPUT (39.50.....) (39.60.....) (39.70.....) — — — 93.66.0.024 93.67.0.024 — 93.66.3.125 — — 93.66.3.230 — — 93.66.0.125 93.67.0.125 93.65.0.125 93.66.0.240 — — 93.66.8.230 93.67.8.230 93.65.8.230 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.024 93.67.7.024 93.65.7.024 93.66.7.060 — — 93.66.7.125 — — 93.66.7.220 — — MasterTIMER (39.90.....) 93.69.0.024 93.69.0.024 — — — — — — — — — — — Solid State Relay - SSR 93.67 93.69 I-2017, www.findernet.com Approvals (according to type): Supply voltage Relay type 12 V AC/DC 34.81.7.012.xxxx 24 V AC/DC 34.81.7.024.xxxx 110…125)V AC/DC* 34.81.7.060.xxxx (220…240)V AC* 34.81.7.060.xxxx 110…125)V AC/DC 34.81.7.060.xxxx 24…240)V AC/DC 34.81.7.024.xxxx (220…240)V AC 34.81.7.060.xxxx 6 V DC 34.81.7.005.xxxx 12 V DC 34.81.7.012.xxxx 24 V DC 34.81.7.024.xxxx 60 V DC 34.81.7.060.xxxx (110…125)V DC 34.81.7.060.xxxx 220 V DC 34.81.7.060.xxxx * Leakage current suppression Accessories 16-way jumper link Dual-purpose plastic separator Terminal doubler Sheet of marker tags Technical data Rated values Dielectric strength Protection category Ambient temperature°C Wire strip lengthmm Max wire size mm2 AWG 093.16 (blue), 093.16.0 (black), 093.16.1 (red) 093.60 093.62 060.48 and 093.48 6 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 −40…+70 8 Solid wire and stranded wire 1 x(0.2…2.5) 1 x(24…14) 7 34 SERIES 93 SERIES Sockets and accessories for 34 series relays Screw less terminal socket 35 mm rail mounting (EN 60715) Common features - Space saving 6.2 mm wide - Connections for 20-way jumper link - Integral coil indication and protection circuit - Secure retention and easy ejection by plastic clip A 93.51 Approvals (according to type):  ertain relay/socket C combinations For technical data and supply versions, refer to the 38 Series – “Relay interface module” Electromechanical Relay - EMR and Solid State Relay - SSR Relay type (reference with the 38 Series) Electromechnanical relay - EMR Solid State Relay - SSR Supply voltage (38.61.....) (38.81.....) 12 V AC/DC 34.51.7.012.xx10 — 24 V AC/DC 34.51.7.024.xx10 — 110…125)V AC/DC 34.51.7.060.xx10 34.81.7.060.xxxx 220…240)V AC/DC 34.51.7.060.xx10 34.81.7.060.xxxx 110…125)V AC/DC* 34.51.7.060.xx10 34.81.7.060.xxxx (220…240)V AC* 34.51.7.060.xx10 34.81.7.060.xxxx (220…240)V AC 34.51.7.060.xx10 34.81.7.060.xxxx 12 V DC 34.51.7.012.xx10 34.81.7.012.xxxx 24 V DC 34.51.7.024.xx10 34.81.7.024.xxxx 60 V DC 34.51.7.060.xx10 34.81.7.060.xxxx * Leakage current suppression 93.51.0.024 93.51.0.024 93.51.0.125 93.51.0.240 93.51.3.125 93.51.3.240 93.51.8.240 93.51.7.024 93.51.7.024 93.51.7.060 093.20 093.01 093.48 6 A - 250 V 6 kV (1.2/50 μs) between coil and contacts IP 20 −40…+70/−40…+55 10 Solid wire and stranded wire 1 x 2.5 / 2 x 1.5 1 x 14 / 2 x 16 I-2017, www.findernet.com Accessories 20-way jumper link Plastic separator Sheet of marker tags Technical data Rated values Dielectric strength Protection category Ambient temperature (UN ≤ 60 V/> 60 V)°C Wire strip lengthmm Max wire size mm2 AWG Socket type 8 93 SERIES Sockets and accessories for 34 series relays 93.11 Approvals (according to type): PCB socket with retaining and release clip For relay type Technical data Rated values Dielectric strength Protection category Ambient temperature°C 34 SERIES 93.11 (blue) 34.51, 34.81 A 6 A - 250 V ≥ 6 kV (1.2/50 μs) between coil and contacts IP 20 –40…+70 I-2017, www.findernet.com Retaining and release clip use: 9
34.51.7.048.0010 价格&库存
很抱歉,暂时无法提供与“34.51.7.048.0010”相匹配的价格&库存,您可以联系我们找货
  • 20+76.6857420+9.89949
  • 1+95.15885
  • 20+88.79862
  • 100+63.03153
库存:53
34.51.7.048.0010
  • 1+92.436681+11.93280
  • 20+86.3092520+11.14180
  • 100+61.27431100+7.91000
库存:53
34.51.7.048.0010
    • 1+111.10793
    • 25+106.90365
    • 50+102.47179
    • 100+100.61520
    • 250+96.84213
    库存:63
