322170482300
322170482300
    FINDER
    FINDER - 322170482300 - Power Relay, SPST-NO, 48 VDC, 6 A, 32 Series, Through Hole
322170482300 数据手册
32 Series - Subminiature PCB relays 6 A Features 32.21-x000 32.21-x300 Printed circuit mount 6 A relay 1 Pole changeover contacts or 1 Pole normally open contact • Subminiature, low profile package • Sensitive DC coil - 200 mW • Wash tight: RT III • Cadmium Free contact material option • 1 CO (SPDT), 6 A Low coil power • PCB mount 1 NO (SPST-NO), 6 A Low coil power • PCB mount • • • • Copper side view Copper side view 1 CO (SPDT) 1 NO (SPST-NO) Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 6/15 6/15 250/400 250/400 Rated load AC1 VA 1,500 1,500 Rated load AC15 (230 V AC) VA 250 250 0.185 0.185 A 3/0.35/0.2 3/0.35/0.2 mW (V/mA) 500 (10/5) 500 (10/5) AgCdO AgCdO Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V Minimum switching load Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC — 5 - 12 - 24 - 48 —/0.2 —/0.2 AC — — DC VA (50 Hz)/W Operating range — 5 - 12 - 24 - 48 (0.78...1.5)UN (0.78...1.5)UN Holding voltage AC/DC —/0.4 UN —/0.4 UN Must drop-out voltage AC/DC —/0.1 UN —/0.1 UN Mechanical life AC/DC cycles —/20 · 106 —/20 · 106 Electrical life at rated load AC1 cycles 100 · 103 100 · 103 6/4 6/2 5 5 Technical data Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range Environmental protection °C 1,000 1,000 –40…+85 –40…+85 RT III RT III Approvals (according to type) 1 32 Series - Subminiature PCB relays 6 A Ordering information Example: 32 series PCB, 1 NO (SPDT-NO) - 6 A contacts, 24 V sensitive DC coil. 3 2. 2 A B C D 1 . 7 . 0 2 4 . 2 3 0 0 A: Contact material 2 = Standard AgCdO 4 = AgSnO2 Series Type 2 = PCB mount B: Contact circuit 0 = CO (SPDT) 3 = NO (SPST) No. of poles 1 = 1 pole, 6 A Coil version 7 = Sensitive DC D: Special versions 0 = Wash tight (RT III) C: Options 0 = None Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Type Coil version A B C D 32.21 sens. DC 2-4 0-3 0 0 Technical data Insulation according to EN 61810-1 Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 250 Pollution degree 2 Insulation between coil and contact set Type of insulation Basic Overvoltage category III Rated impulse voltage kV (1.2/50 µs) Dielectric strength V AC 5 4,000 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50 µs) 1,000/1.5 Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 µs) on A1 - A2 (differential mode) EN 61000-4-5 level 3 (2 kV) Other data Bounce time: NO/NC ms Vibration resistance (5…55)Hz: NO/NC Shock resistance Power lost to the environment 2/— (normally open) 10/10 (changeover) 10/— (normally open) g 20 without contact current W 0.2 with rated current W 0.5 mm ≥ 5 Recommended distance between relays mounted on PCB 2 2/10 (changeover) g 32 Series - Subminiature PCB relays 6 A Contact specification F 32 - Electrical life (AC) v contact current Cycles Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 DC breaking current (A) H 32 - Maximum DC1 breaking capacity DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. Coil specifications DC coil data - 0.2 W sensitive Nominal voltage UN V 5 12 24 48 Coil code 7.005 7.012 7.024 7.048 R 32 - DC coil operating range v ambient temperature Operating range Umin V 3.9 9.4 18.7 37.4 Umax V 7.5 18 36 72 Resistance Rated coil consumption R I at UN Ω mA 125 40 720 16 2,880 8.3 11,520 4 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 3
322170482300 价格&库存
很抱歉,暂时无法提供与“322170482300”相匹配的价格&库存,您可以联系我们找货
