80.11.0.240.0000
80.11.0.240.0000
    FINDER
80.11.0.240.0000 数据手册
80 SERIES Modular timers 16 A 80 SERIES 80.01 Multi-function and mono-function timer range 80.11 80.01 - Multi-function & multi-voltage 80.11 - On-delay, multi-voltage • 17.5 mm wide • Six time scales from 0.1 s to 24 h • High input/output isolation • 35 mm rail (EN 60715) mount • “Blade + cross” - both flat blade and cross head screw drivers can be used to adjust the range and function selectors, the timing trimmer, and to disengage the rail mounting clip • New multi-voltage versions with “PWM clever” technology 80.01 / 80.11 Screw terminal • Multi-voltage • Multi-function • Multi-voltage • Mono-function AI: On-delay DI: Interval SW: Symmetrical flasher (starting pulse on) BE: Off-delay with control signal CE: On- and off-delay with control signal DE: Interval with control signal on AI: On-delay For UL ratings see: “General technical information” page V Wiring diagram (without control signal) For outline drawing see page 6 Wiring diagram (with control signal) Wiring diagram (without control signal) Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC Rated load AC1 VA 1 CO (SPDT) 1 CO (SPDT) 16/30 16/30 250/400 250/400 4000 4000 Rated load AC15 (230 V AC) VA 750 750 Single phase motor rating (230 V AC) kW 0.55 0.55 A 16/0.3/0.12 16/0.3/0.12 mW (V/mA) 500 (10/5) 500 (10/5) AgNi AgNi 12…240 24…240 Breaking capacity DC1: 30/110/220 V Minimum switching load Standard contact material H Supply specification Nominal voltage (UN) Rated power AC/DC Operating range V AC (50/60 Hz) V DC 12…240 24…240 VA (50 Hz)/W
80.11.0.240.0000 价格&库存
很抱歉,暂时无法提供与“80.11.0.240.0000”相匹配的价格&库存,您可以联系我们找货
  • 1+489.79400
库存:99
80.11.0.240.0000
  • 2+486.136702+62.90865
  • 5+444.329905+57.49863
  • 10+410.4351110+53.11247
  • 25+372.3688825+48.18650
库存:83
