Modular monostable
relays 20 A
Hotel room
energy-enabling
units
Garden and
night lighting
Streetlights and
car park lighting
Bathrooms
lighting
control
Office lighting
control
Pump control
22
SЕRIES
22 SERIES
Modular monostable relays 20 A
1 or 2 pole, 20 A relay
for direct 35 mm rail (EN 60715) mounting
22
SERIES
22.21
22.22
• 17.4 mm wide
• Test button
• Identification label
• AC coils and DC coils
• 35 mm rail (EN 60715) mount
• Cadmium free contact material
X-2017, www.findernet.com
22.21/22
Screw terminals
For outline drawing see page 6
Contact specification
Contact configuration
A
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
V AC
Rated load AC1
VA
VA
Rated load AC15 (230 V AC)
Single phase motor rating (230 V AC)
kW
Breaking capacity DC1: 30/110/220 V
A
Nominal lamp rating:
230 V incandescent/halogen W
fluorescent tubes with
electronic ballast W
electromechanical ballast W
CFL W
230 V LED W
LV halogen or LED with
mW (V/mA)
Minimum switching load
Standard contact material
Coil specification
V AC (50/60 Hz)
Nominal voltage (UN)
V DC
Rated power AC/DC
VA (50 Hz)/W
Operating range
AC (50 Hz)
DC
Technical data
Mechanical life AC/DC
cycles
Electrical life at rated load in AC1
cycles
Operate/release time
ms
Maximum impulse duration
Insulation between coil
and contacts (1.2/50 μs)
kV
Ambient temperature range
°C
Protection category
• Single phase switch 1 NO
• Double phase switch 2 NO
(SPST-NO)
1 NO (SPST-NO)
20/30
2 NO (DPST-NO)
20/30
250/400
5000
1000
20/0.3/0.12
250/400
5000
1000
20/0.3/0.12
1000
1000
400
400
360
200
200
360
200
200
200
200
400
1000 (10/10)
AgSnO2
400
1000 (10/10)
AgSnO2
(DPST-NO)
12 - 24 - 230
12 - 24
3/1.25
(0.85…1.1)UN
(0.9…1.1)UN
12 - 24
3/1.25
(0.85…1.1)UN
(0.9…1.1)UN
500 · 103
50 · 103
15/8
continuous
500 · 103
50 · 103
15/8
continuous
4
–40…+40
IP 20
4
–40…+40
IP 20
L
Approvals relay (according to type)
3
22
SERIES
22 SERIES
22.23
22.24
• 17.4 mm wide
• Test button
22.23/24
Screw terminals
• Double phase switc 1 NO + 1 NC • Double phase switch 2 NC
(SPST-NO + SPST-NC)
(DPST-NC)
• 35 mm rail (EN 60715) mount • 35 mm rail (EN 60715) mount
4
2 NC (DPST-NC)
20/30
250/400
5000
1000
20/0.3/0.12
1000
400
360
200
200
200
400
1000 (10/10)
AgSnO2
12 - 24
3/1.25
(0.85…1.1)UN
(0.9…1.1)UN
500 · 103
50 · 103
15/8
continuous
4
–40…+40
IP 20
L
1 NO + 1 NC (SPST-NO + SPST-NC)
A
20/30
Rated voltage/
V AC
250/400
Rated load AC1
VA
5000
VA
1000
kW
A
20/0.3/0.12
1000
400
360
CFL W
200
230 V LED W
200
200
400
mW (V/mA)
1000 (10/10)
AgSnO2
Coil specification
V AC (50/60 Hz)
12 - 24 - 230
V DC
12 - 24
Rated power AC/DC
VA (50 Hz)/W
3/1.25
Operating range
AC (50 Hz)
(0.85…1.1)UN
DC
(0.9…1.1)UN
Technical data
cycles
500 · 103
cycles
50 · 103
ms
15/8
continuous
kV
4
°C
–40…+40
Protection category
IP 20
22 SERIES
22
SERIES
Ordering information
Example: 22 series 35 mm rail mount relay, 1 NO (SPST-NO) 20 A contact, coil rated 24 V DC, contact material AgSnO2.
2 2 . 2
1 . 9 . 0 2 4 . 4
Series
Contact material
4 = AgSnO2
Type
2 = 35 mm rail (EN 60715) mount
Coil voltage
See coil specifications
No. of poles
1 = 1 NO (SPST-NO)
2 = 2 NO (DPST-NO)
3 = 1 NO + 1 NC (SPST-NO + SPST-NC)
4 = 2 NC (DPST-NC)
Coil version
8=A
C (50/60 Hz)
9=D
C
Technical data
Insulation
Dielectric strength
between supply and contacts V AC 3500
between open contacts
V AC 2000
between adjacent contacts
V AC 2000
Other data
Bounce time: NO/NC
ms 5/10
Power lost to the environment
without contact current
W 1.2
with rated current
W 3.2 (22.21, 22.23)
Screw torque
5.2 (22.22, 22.24)
Nm 0.8
0.8
Coil terminals
Max. wire size
solid cable
mm2 1 x 4 / 2 x 2.5
AWG 1 x 12 / 2 x 14
Contact terminals
stranded cable
solid cable
stranded cable
1 x 2.5 / 2 x 2.5
1 x 6 / 2 x 6
1 x 6 / 2 x 4
1 x 14 / 2 x 14
1 x 10 / 2 x 10
1 x 10 / 2 x 12
If the coil is operated for a prolonged period of time, adequate ventilation of the relays must be provided - suggested gap of 9 mm between adjacent
relays.
Coil specifications
DC version data
Nominal
voltage
Coil
code
UN
AC version data
Operating range
Umin
R
I at UN
Nominal
voltage
Coil
code
UN
Operating range
Umin
Resistance Consumption
Umax
R
Ω
I at UN (50 Hz)
V
V
Ω
mA
V
V
V
12
9.012
10.8
13.2
115
104
12
8.012
10.2
13.2
13.5
245
24
9.024
21.6
24.6
460
24
8.024
20.4
26.4
41
135
230
8.230
52.2
196
253
4200
mA
L
12.5
V
Umax
5
22
SERIES
22 SERIES
Outline drawing
Type 22.21
Screw terminal
Type 22.22
Screw terminal
Type 22.23
Screw terminal
Type 22.24
Screw terminal
Accessories
Adaptor for panel mounting, 17.5 mm wide
020.01
Sheet of marker tags, plastic, 24 tags, 9 x 17 mm
020.24
Separator for rail mounting, plastic, 9 mm wide
022.09
020.01
020.24
L
022.09
6
Please see general technical information
很抱歉,暂时无法提供与“22.23.9.012.4000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+677.57040
- 200+270.35640
- 500+261.32760
- 1000+256.85640
- 国内价格 香港价格
- 1+411.317451+53.46994
