4C.52.9.024.0050SPA
4C.52.9.024.0050SPA
    FINDER
    Module
4C.52.9.024.0050SPA 数据手册
4C Series - Relay interface modules 8 - 10 - 16 A Features 4C.01 4C.02 1 & 2 pole relay interface modules, screw terminal socket, 15.8 mm wide. Ideal interface for PLC and electronic systems 4C.01 - 1 Pole 16 A 4C.02 - 2 Pole 8 A AC coils or DC coils Instant ejection of relay using plastic retaining clip • Supply status indication and coil suppression module as standard • Identification label • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 50022) mounting • • 1 pole, 16 A Screw terminal connection • 35 mm rail (EN 50022) mounting 2 pole, 8 A Screw terminal connection • 35 mm rail (EN 50022) mounting • • • • COM 11 4C.01 / 4C.02 Screw terminal A2 14 NO 12 NC 12 NC A1 A2 — AC A1 DC + 11 COM 24 14 NO 22 12 NC 11 COM 21 24 14 NO 22 12 NC 21 COM 11 14 NO A2 A1 A2 — AC A1 DC + For outline drawing of 4C.01/02 see page 5 Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 2 CO (DPDT) 16/25 8/15 250/440 250/440 Rated load AC1 VA 4000 2000 Rated load AC15 (230 V AC) VA 750 350 kW 0.55 0.37 16/0.5/0.15 6/0.5/0.15 300 (5/5) 300 (5/5) AgNi AgNi 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 12 - 24 - 125 12 - 24 - 125 Single phase motor rating (230 V AC) Breaking capacity DC1: 30/110/220V Minimum switching load A mW (V/mA) Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W Operating range AC 1.2/0.5 1.2/0.5 (0.8…1.1)UN (0.8…1.1)UN (0.73…1.1)UN (0.73…1.1)UN Holding voltage AC/DC 0.8 UN /0.4 UN 0.8 UN /0.4 UN Must drop-out voltage AC/DC 0.2 UN /0.1 UN 0.2 UN /0.1 UN DC Technical data Mechanical life AC/DC cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 100 · 103 100 · 103 15/5 (AC) - 15/12 (DC) 10/3 (AC) - 10/10 (DC) 6 (8 mm) 6 (8 mm) 1000 1000 Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Protection category V AC °C ≤ 12A: –40…+70/>12A: –40…+50 IP 20 –40…+70 IP 20 Approvals - relay (according to type) 1 4C Series - Relay interface modules 8 - 10 - 16 A Features 4C.51 4C.52 1 & 2 pole relay interface modules, screwless terminal socket, 15.8 mm wide. Ideal interface for PLC and electronic systems 4C.51 - 1 Pole 10 A 4C.52 - 2 Pole 8 A AC coils or DC coils Instant ejection of relay using plastic retaining clip • Supply status indication and coil suppression module as standard • Identification label • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 50022) mounting • • 1 pole, 10 A Screwless terminal connections • 35 mm rail (EN 50022) mounting 2 pole, 8 A Screwless terminal connections • 35 mm rail (EN 50022) mounting • • • • 11 COM 4C.51 / 4C.52 Screwless terminal A2 11 COM 21 14 NO 14 NO 12 NC 12 NC A1 A2 — AC A1 DC + 11 COM 24 14 NO 22 12 NC 11 COM 21 24 14 NO 22 12 NC A2 A1 A2 — AC A1 DC + For outline drawing of 4C.51/52 see page 5 Contact specification Contact configuration 1 CO (SPDT) Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC Rated load AC1 VA Rated load AC15 (230 V AC) Single phase motor rating (230 V AC) Breaking capacity DC1: 30/110/220V Minimum switching load 2 CO (DPDT) 10/20 8/15 250/440 250/440 2500 2000 VA 750 350 kW 0.55 0.37 10/0.5/0.15 6/0.5/0.15 300 (5/5) 300 (5/5) AgNi AgNi 12 - 24 - 110 - 120 - 230 12 - 24 - 110 - 120 - 230 12 - 24 - 125 12 - 24 - 125 A mW (V/mA) Standard contact material Coil specification Nominal voltage (UN) V AC (50/60 Hz) V DC Rated power AC/DC VA (50 Hz)/W Operating range AC 1.2/0.5 1.2/0.5 (0.8…1.1)UN (0.8…1.1)UN (0.73…1.1)UN (0.73…1.1)UN Holding voltage AC/DC 0.8 UN /0.4 UN 0.8 UN /0.4 UN Must drop-out voltage AC/DC 0.2 UN /0.1 UN 0.2 UN /0.1 UN DC Technical data Mechanical life AC/DC cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 100 · 103 100 · 103 15/5 (AC) - 15/12 (DC) 10/3 (AC) - 10/10 (DC) 6 (8 mm) 6 (8 mm) 1000 1000 –25…+70 –25…+70 IP 20 IP 20 Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts Ambient temperature range Protection category Approvals - relay (according to type) 2 V AC °C 4C Series - Relay interface modules 8 - 10 - 16 A Ordering information Example: 4C series, 35 mm rail (EN 50022) mount screw terminal relay interface module, 1 CO (SPDT) 16 A contacts, 24 V DC coil, green LED + diode. A B C D 4 C . 0 1 . 9 . 0 2 4 . 0 Series Type 0 = 35 mm rail (EN 50022) mount screw terminal socket 5 = 35 mm rail (EN 50022) mount screwless terminal socket 0 5 0 A: Contact material 0 = AgNi D: Special version 0 = Standard B: Contact circuit 0 = CO (nPDT) C: Options 5 = Standard for DC: green LED + diode (polarity +A1) 6 = Standard for AC: green LED + Varistor No. of poles 1 = 1 pole 2 = 2 pole Coil version 8 = AC (50/60 Hz) 9 = DC Coil voltage See coil specifications Technical data Insulation Insulation according to EN 61810-1 insulation rated voltage rated impulse withstand voltage pollution degree overvoltage category Insulation between coil and contacts (1.2/50 µs) V 250 440 kV 4 4 3 2 III III kV 6 (8 mm) Dielectric strength between open contacts V AC 1000 Dielectric strength between adjacent contacts V AC 2000 Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 µs) on A1 - A2 (differential mode) EN 61000-4-5 level 3 (2 kV) Other data Bounce time: NO/NC ms 2/6 (4C.01/51) Vibration resistance (10…150)Hz: NO/NC Power lost to the environment without contact current W 0.6 with rated current W 1.6 (4C.01/51) 4C.01/4C.02 Wire strip length Screw torque Max. wire size 1/4 (4C.02/52) g 20/12 2 (4C.02/52) 4C.51/4C.52 mm 8 8 Nm 0.5 — solid cable mm2 1x6/2x2.5 stranded cable solid cable 1x4/2x2.5 AWG 1x10/2x14 1x12/2x14 stranded cable 2x(0.2...1.5) 2x(0.2...1.5) 2x(24...18) 2x(24...18) 3 4C Series - Relay interface modules 8 - 10 - 16 A Contact specification F 4C - Electrical life (AC) v contact current Types 4C.01/51 F 4C - Electrical life (AC) v contact current Types 4C.02/52 7 7 10 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 6 10 Cycles Cycles 10 5 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 6 10 5 10 10 0 4 2 6 8 (A) 0 4 8 12 16 (A) H 4C - Maximum DC1 breaking capacity DC breaking current (A) 20 Current limit 1 CO (SPDT) (*) 10 6 4 Current limit 2 CO (DPDT) 2 1 (*) Type 4C.01= 12 A, Type 4C.51= 10 A 0.2 0.1 20 60 100 140 DC voltage (V) 180 220 • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100·103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. Coil specifications AC coil data DC coil data Nominal voltage UN V 12 24 125 Coil code Operating range Umin V 8.8 17.5 91.2 9.012 9.024 9.125 Umax V 13.2 26.4 137.5 Resistance Rated coil consumption I at UN R Ω mA 300 40 1200 20 32000 3.9 R 4C - DC coil operating range v ambient temperature Nominal voltage UN V 12 24 110 120 230 Coil code Operating range Umin V 9.6 19.2 88 96 184 8.012 8.024 8.110 8.120 8.230 R 4C - AC coil operating range v ambient temperature U 2.0 UN U 2.0 UN 1 Single Pole Relay Contact Current limited to 12 A 1.5 1 1.5 Single Pole Relay Contact Current limited to 12 A 1.0 1.0 2 2 0.5 0.5 -20 0 20 40 60 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 80 (°C) -20 0 20 40 60 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. Temperature limit for the single pole version under full 16 A contact current. 4 Umax V 13.2 26.4 121 132 253 Resistance Rated coil consumption I at UN R Ω mA 80 90 320 45 6900 9.4 9000 8.4 28000 5 80 (°C) 4C Series - Relay interface modules 8 - 10 - 16 A Combinations Code Type of socket Type of relay Module Retaining clip 4C.01 97.01 46.61 99.02 097.01 4C.02 97.02 46.52 99.02 097.01 4C.51 97.51 46.61 99.02 097.01 97.52 46.52 99.02 097.01 Certain relay/socket combinations 4C.52 Outline drawing 15.8 64.6 COIL 4 11 NO 3 14 24 5 NO 4 14 NC 2 12 22 7 NC 2 12 30.6 A1 A2 1 COIL 34.7 3.2 95.6 38.3 5 A1 A2 1 COIL 30.3 8 COIL 3.2 3.2 A2 6 COM 3 12 32 1 A1 21 2 N C 22 5 A2 COM 4 11 61.7 4 4 3 32 1 21 14 7 12 3.6 11 3.2 N C N O 5 24 2 15.8 19.2 38.3 3 14 19.2 35.4 N O C O M 21 23 25.9 6 C O M 3.5 21.6 4 11 15.8 95.6 15.8 8 A1 31.8 19 49.9 4C.01 / Screw terminal 4C.02 4C.51 / Screwless terminal 4C.52 42.2 Accessories 8-way jumper link for 4C.01 and 4C.02 095.18 (blue) Rated values 10 A - 250 V 095.18 3.3 110.5 15 15.8 15.8 15.8 15.8 15.8 10.3 7 5.1 15 Sheet of marker tags, plastic, 72 tags, 6x12 mm 060.72 060.72 Packaging code How to code and identify retaining clip and packaging options for relay interface module. Example: 4 C . 0 1 . 9 . 0 2 4 . 0 0 5 0 S P A A B Standard packaging Blister packaging SP Plastic retaining clip 5
4C.52.9.024.0050SPA 价格&库存
很抱歉,暂时无法提供与“4C.52.9.024.0050SPA”相匹配的价格&库存,您可以联系我们找货
