56.34.9.110.0000T
56.34.9.110.0000T
    FINDER
56.34.9.110.0000T 数据手册
56 SERIES Relays for railway applications 12 A 56 SERIES 56.32T Plug-in power relays - 12 A, 2 and 4 pole 56.34T • Complies with EN 45545-2:2013 (protection against fire of materials), EN 61373 (resistance against random vibrations and shock, Category 1, Class B), EN 50155 (resistance to temperature and humidity, TX class) • DC coils with extended range • Cadmium Free contacts (standard version) • Contact material options • 96 series sockets • Coil EMC suppression modules • Accessories (Sockets and Timer modules) • 2 Pole CO, 12 A • Plug-in/Faston 187 • 4 Pole CO, 12 A • Plug-in/Faston 187 56.32T 56.34T * Short term (10 min) +85°C Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC 2 CO (DPDT) 4 CO (4PDT) 12/20 12/20 250/400 250/400 VA 3000 3000 Rated load AC15 (230 V AC)VA 700 700 Single phase motor rating (230 V AC)kW 0.55 0.55 Breaking capacity DC1: 30/110/220 VA 12/0.5/0.25 12/0.5/0.25 Minimum switching load 500 (10/5) 500 (10/5) AgNi AgNi Rated load AC1 mW (V/mA) Standard contact material Coil specification Nominal voltage (UN)  V AC (50/60 Hz) V DC Rated power Operating range VA (50 Hz)/W 120 - 230 120 - 230 24 - 72 - 110 24 - 72 - 110 1.5/1 2/1.3 AC (0.8…1.1)UN (0.8…1.1)UN DC (0.70…1.25)UN (0.70…1.25)UN Holding voltage 0.6 UN 0.6 UN Must drop-out voltage 0.1 UN 0.1 UN Technical data Mechanical life DC cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 100 · 10 100 · 103 ms 8/8 8/8 kV 4 4 VI-2016, www.findernet.com Operate/release time Insulation between coil and contacts (1.2/50 μs) Dielectric strength between open contacts Ambient temperature range Environmental protection V AC °C 3 1000 1000 –40…+70* –40…+70* RT I RT I Approvals (according to type) 1 56 SERIES Relays for railway applications 12 A 56 SERIES Ordering information Example: 56 series plug-in relay, 4 poles, 24 V DC coil, AgCdO contacts. 5 6 . 3 A B C D 4 . 9 . 0 2 4 . 2 0 0 0 Series A: Contact material 0 = AgNi 2 = AgCdO Type 3 = Plug-in terminals B: Contact circuit 0 = CO (nPDT) No. of poles 2 = 2 pole, 12 A 4 = 4 pole, 12 A T D: Special versions 0 = Standard C: Options 0 = None Coil version 8 = AC (50/60)Hz 9 = DC Coil voltage 024 = 24 V 072 = 72 V 110 = 110 V 120 = 120 V 230 = 230 V Technical data Insulation according to EN 61810-1 Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 250 Pollution degree 3 400 2 Insulation between coil and contact set Type of Insulation Basic Overvoltage category III Rated impulse voltage kV (1.2/50 μs) 4 Dielectric strength V AC 2500 Insulation between adjacent contacts Type of insulation Basic Overvoltage category III Rated impulse voltage kV (1.2/50 μs) 4 Dielectric strength V AC 2500 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50 μs) 1000/1.5 Conducted disturbance immunity Burst (5…50)ns, 5 kHz, on A1 - A2 EN 61000-4-4 level 4 (4 kV) Surge (1.2/50 μs) on A1 - A2 (differential mode) EN 61000-4-5 level 4 (4 kV) Other data Bounce time: NO/NC ms 1/3 Vibration resistance: NO/NC According to EN 61373 Shock resistance According to EN 61373 without contact current W 1 (56.32T)/1.3 ( 56.34T) with rated current W 3.8 (56.32T)/6.9 (56.34T) VI-2016, www.findernet.com Power lost to the environment 2 56 SERIES Relays for railway applications 12 A 56 SERIES Contact specification F 56 - Electrical life (AC) v contact current H 56 - Maximum DC1 breaking capacity DC breaking current (A) contacts in series Cycles Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time of the load will be increased. Coil specifications DC coil data, 2 CO - Type 56.32T Nominal voltage UN V 24 72 110 Coil code 9.024 9.072 9.110 AC coil data, 2 CO - Type 56.32T Operating range Umin V 16.8 50.4 77 Umax V 30 90 137.5 Resistance R Ω 600 5100 12500 Rated coil consumption I at UN mA 40 14 8.8 DC coil data, 4 CO - Type 56.34T Nominal voltage UN V 24 72 110 Coil code 9.024 9.072 9.110 Coil code 8.120 8.230 Operating range Umin V 96 184 Umax V 132 253 Resistance R Ω 4700 17000 Rated coil consumption I at UN mA 12 6 AC coil data, 4 CO - Type 56.34T Operating range Umin V 16.8 50.4 77 Nominal voltage UN V 120 230 Umax V 30 90 137.5 Resistance R Ω 490 4000 10400 Rated coil consumption I at UN mA 49 18 10.5 Nominal voltage UN V 120 230 Coil code 8.120 8.230 Operating range Umin V 96 184 Umax V 132 253 Resistance R Ω 2560 7700 Rated coil consumption I at UN mA 13.4 9 R 56 - DC coil operating range v ambient temperature VI-2016, www.findernet.com 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 3 56 SERIES 96 SERIES Sockets and accessories for 56 series relays Screw terminal (Box clamp) socket panel or 35 mm rail mount (EN 60715) For relay type 96.02.7 SMA* 96.04.7 SMA* 56.32T 56.34T 094.71 094.06 095.00.4 99.02 86.30T 096.71 — 090.00.2 99.02 86.00T, 86.30T Accessories Metal retaining clip (supplied with socket - packaging code SMA) 6-way jumper link Identification tag Modules (see table below) Timer modules (see table below) Technical data Rated values Dielectric strength Protection category Ambient temperature 96.02.7 Approvals (according to type): Screw torque 12 A - 250 V 2 kV AC IP 20 °C –40…+70 (see diagram L96) Nm 0.8 Wire strip length Max. wire size for 96.02.7 and 96.04.7 socket mm 8 solid wire stranded wire 1 x 4 / 2 x 2.5 mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 1 x 12 / 2 x 14 * Complies with EN 45545-2:2013 (protection against fire of materials), EN 61373 (resistance against randomvibrations and shock, Category 1, Class B), EN 50155 (resistance to temperature and humidity, TX class) 96.04.7 Approvals (according to type): Rated current (A) L 96 - Rated current vs ambient temperature P A PEAN N T E O O T EUR EUR 96.02.7 6-way jumper link for 96.02.7 socket Rated values 96.04.7 094.06 10 A - 250 V PEAN 094.06 86.00 Approvals (according to type): 86.30 99.02 99.02 coil indication and EMC suppression modules Diode (+A1, standard polarity) (6…220)V DC LED + Diode (+A1, standard polarity) (6…24)V DC LED + Diode (+A1, standard polarity) (28…72)V DC LED + Diode (+A1, standard polarity) (110…220)V DC LED + Varistor (6…24)V DC/AC LED + Varistor (28…72)V DC/AC LED + Varistor (110…240)V DC/AC Approvals (according to type): 4 86.00.0.240.0000T 86.30.0.024.0000T AI: ON-delay DI: Interval SW: Symmetrical flasher (starting pulse on) BE: Off-delay with control signal CE: On- and off-delay with control signal DE: Interval with control signal on EE: Interval with control signal off FE: Interval with control signal on and off 99.02.3.000.00 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 DC Modules with non-standard polarity (+A2) on request. VI-2016, www.findernet.com 86 series timer modules Multi-voltage: (12…240)V AC/DC; Multi-functions: AI, DI, SW, BE, CE, DE, EE, FE; (0.05 s…100 h) (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h)
56.34.9.110.0000T 价格&库存
很抱歉,暂时无法提供与“56.34.9.110.0000T”相匹配的价格&库存,您可以联系我们找货
56.34.9.110.0000T
    • 1+296.023501+38.30700
    • 5+279.868825+36.21650
    • 10+260.2212510+33.67400
    库存:27
