58 Series - Relay interface modules 7 - 10 A
Features
58.32
58.33
58.34
2, 3 & 4 Pole relay interface modules,
27 mm wide.
Ideal interface for PLC and electronic systems
58.32 - 2 Pole 10 A
58.33 - 3 Pole 10 A
58.34 - 4 Pole 7 A
• AC
coils and DC coils
status indication and coil
suppression module as standard
• Identification label
• Cadmium Free contacts
• UL Listed
• 35 mm rail (EN 50022) mounting
• Supply
83
3 pole 10 A
35 mm rail mounting
4 pole 7 A
35 mm rail mounting
12
41
9
11
COM
9
31
8
21
7
11
COM
12
41
11
31
10
21
9
11
COM
8
44
5
14
NO
6
34
5
24
4
14
NO
8
44
7
34
6
24
5
14
NO
4
42
1
12
NC
3
32
2
22
1
12
NC
4
42
3
32
2
22
1
12
NC
14
A2
13
A1
73
25.9
17.5
17.5
27.5
76
27
2 pole 10 A
35 mm rail mounting
14
A2
32
13
A1
COIL
14
A2
13
A1
COIL
Example: AC
Example: DC
Example: AC
2 CO (DPDT)
3 CO (3PDT)
4 CO (4PDT)
COIL
Contact specification
Contact configuration
Rated current/Maximum peak current
A
Rated voltage/Maximum switching voltage V AC
10/20
10/20
7/15
250/400
250/400
250/250
Rated load AC1
VA
2,500
2,500
1,750
Rated load AC15 (230 V AC)
VA
500
500
350
Single phase motor rating (230 V AC)
kW
Breaking capacity DC1: 30/110/220V
Minimum switching load
A
mW (V/mA)
Standard contact material
0.37
0.37
0.125
10/0.25/0.12
10/0.25/0.12
7/0.25/0.12
300 (5/5)
300 (5/5)
300 (5/5)
AgNi
AgNi
AgNi
58
Coil specification
Nominal voltage (UN)
V AC (50/60 Hz) 12 - 24 - 48 - 110 - 120 - 230 12 - 24 - 48 - 110 - 120 - 230 12 - 24 - 48 - 110 - 120 - 230
V DC
Rated power AC/DC
VA (50 Hz)/W
Operating range
AC
12 - 24 - 48
12 - 24 - 48
12 - 24 - 48
1.5/1
1.5/1
1.5/1
(0.8…1.1)UN
(0.8…1.1)UN
(0.8…1.1)UN
(0.8…1.1)UN
(0.8…1.1)UN
(0.8…1.1)UN
Holding voltage
AC/DC
0.8 UN/0.5 UN
0.8 UN/0.5 UN
0.8 UN/0.5 UN
Must drop-out voltage
AC/DC
0.2 UN/0.1 UN
0.2 UN/0.1 UN
0.2 UN/0.1 UN
DC
Technical data
Mechanical life AC/DC
cycles
20 · 106/50 · 106
20 · 106/50 · 106
20 · 106/50 · 106
Electrical life at rated load AC1
cycles
200 · 103
200 · 103
150 · 103
9/3 (AC) - 9/15 (DC)
3.6
3.6
3.6
1,000
1,000
1,000
–40…+70
–40…+70
–40…+70
IP 20
IP 20
IP 20
Operate/release time
ms
Insulation between coil and contacts (1.2/50 µs) kV
Dielectric strength between open contacts
Ambient temperature range
Protection category
V AC
°C
Approvals relay (according to type)
139
Ordering information
Example: 58 series 35 mm rail (EN 55022) mounting interface module, 4 CO (4PDT), 24 V DC coil, green LED + diode.
5 8 . 3
A
B
C
D
4 . 9 . 0 2 4 . 0
Series
Type
3 = 35 mm rail mount
No. of poles
2 = 2 pole, 10 A
3 = 3 pole, 10 A
4 = 4 pole, 7 A
A: Contact material
0 = AgNi Standard
D: Special versions
0 = Standard
B: Contact circuit
0 = CO (nPDT)
C: Options
5 = Standard DC: green LED + diode
(polarity +A1)
6 = Standard AC: green LED + Varistor
Coil version
8 = AC (50/60 Hz)
9 = DC
Coil voltage
see coil specifications
Technical data
Insulation
Insulation according to EN 61810-1 ed. 2
58
insulation rated voltage
rated impulse withstand voltage
pollution degree
overvoltage category
V 400 (2-3 pole)
kV 3.6 (2-3 pole)
250 (4 pole)
2.5 (4 pole)
2
III
kV 3.6
V AC 1,000
Dielectric strength between adjacent contacts
V AC 2,000 (58.32,58.33)
1,550 (58.34)
Conducted disturbance immunity
Burst (5...50)ns, 5 kHz, on A1 - A2
EN 61000-4-4
level 4 (4 kV)
Surge (1.2/50 µs) on A1 - A2 (differential mode)
EN 61000-4-5
level 4 (4 kV)
Other data
Bounce time: NO/NC
ms 1/4
Vibration resistance (10…55)Hz, max. ± 1 mm: NO/NC
Power lost to the environment
Wire strip length
Screw torque
Max. wire size
140
g/g 6/6
without contact current
W 1
with rated current
W 3 (58.32, 58.34)
4 (58.33)
mm 8
Nm 0.5
solid cable
stranded cable
mm2 1x6 / 2x2.5
1x4 / 2x2.5
AWG 1x10 / 2x14
1x12 / 2x14
F 58 - Electrical life (AC) v contact current
2 & 3 pole relays
4 pole relay
7
7
10
Resistive load - cosϕ = 1
Inductive load - cosϕ = 0.4
6
10
Cycles
Cycles
10
6
10
5
5
10
10
8
12
(A)
4
8
12
16
(A)
H 58 - Maximum DC1 breaking capacity
DC breaking current (A)
2 & 3 pole current limit
4 pole current limit
10
6
4
1
2
2
4 contacts in series
3
• When switching a resistive load (DC1) having voltage and current
values under the curve, an electrical life of ≥ 100·103 can be expected.
• In the case of DC13 loads, the connection of a diode in parallel with
the load will permit a similar electrical life as for a DC1 load.
Note: the release time for the load will be increased.
1
0.2
0.1
100
140
180
220
DC voltage (V)
58
Coil specifications
DC coil data
Nominal
voltage
UN
V
12
24
48
AC coil data
Coil
code
Operating range
Umin
V
9.6
19.2
38.4
9.012
9.024
9.048
Umax
V
13.2
26.4
52.8
Resistance Rated coil
absorption
R
I at UN
Ω
mA
140
86
600
40
2,400
R 58 - DC coil operating range v ambient temperature
Nominal
voltage
UN
V
12
24
48
110
120
230
Coil
code
Operating range
Umin
V
9.6
19.2
38.4
88
96
184
8.012
8.024
8.048
8.110
8.120
8.230
Umax
V
13.2
26.4
52.8
121
132
253
absorption
R
I at UN (50Hz)
Ω
mA
50
97
190
53
770
25
4,000
12.5
4,700
12
17,000
6
R 58 - AC coil operating range v ambient temperature
U 2.0
UN
U 2.0
UN
1
1.5
1.0
1.5
1.0
2
0.5
-20
40
60
1 - Max. permitted coil voltage.
2 - Min. pick-up voltage with coil at ambient temperature.
80
(°C)
2
0.5
-20
60
80
(°C)
141
Combinations
Code
Type of socket
Type of relay
Module
Retaining clip
58.32
94.02
55.32
99.02
094.01
58.33
94.03
55.33
99.02
094.01
58.34
94.04
55.34
99.02
094.01
Accessories
6-way jumper link
094.06
Rated values
10 A - 250 V
094.06
3.3
135
10.3
7
5.1
0.75
26.25
27
27
27
26.25
Sheet of marker tags, plastic, 72 tags, 6x12 mm
060.72
060.72
58
Packaging codes
How to code and identify retaining clip and packaging options for relay interface module.
Code options according to the last three letters:
5 8 . 3
4 . 9 . 0 2 4 . 0
S
P
A
A
B
Standard packaging
Blister packaging
SP Plastic retaining clip
142
58.34.8.230.0060SMA 价格&库存
很抱歉,暂时无法提供与“58.34.8.230.0060SMA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+206.867161+26.76970
- 5+194.380035+25.15380
- 10+181.8055810+23.52660
