7T.81.0.000.2303
7T.81.0.000.2303
    FINDER
    支架 恒温器
7T.81.0.000.2303 数据手册
7T SERIES Panel Thermostat 7T SERIES Panel thermostat 7T.81.0.000.240x • Small, compact size (17.5 mm wide) • Snap action themostatic Bimetal sensor • Wide temperature setting range • Long electrical life • 35 mm rail (EN 60715) mount • Heating control 7T.81.0.000.230x • Ventilation control Max Min Heating control - Should the panel temperature fall below the (minimum) set temperature the contact will close to call for heat. The contact will open when this set temperature is exceeded. Ventilation control - Should the panel temperature exceed the (maximum) set temperature then the contact will close to call for cooling. The contact will open when the temperature falls below this set temperature. For outline drawing see page 2 G Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage 1 NC 1 NO 10/20 10/20 250/250 250/250 A V AC Rated load AC1 VA 2500 2500 Rated load AC15 (230 V AC) VA 250 250 Single phase motor rating AC3 (230 V AC)kW 1.1 1.1 Breaking capacity DC1: 30/110/220 V Minimum switching load A 1/0.3/0.15 1/0.3/0.15 mW (V/mA) 500 (12/10) 500 (12/10) AgNi AgNi Standard contact material Temperature setting range Setting range (ventilation) Switch temperature differential Setting range (heating) Switch temperature differential °C — K — °C K –20…+40 –20…+40 +0…+60 7 ± 4 +0…+60 — 7 ± 4 — 100 · 103 100 · 103 –45…+80 –45…+80 IP 20 IP 20 Technical data Electrical life at rated load AC1 Ambient temperature range Protection category cycles °C IX-2016, www.findernet.com Approvals (according to type) 1 7T SERIES 7T SERIES Panel Thermostat Ordering information Example: 7T Series, thermostat for ventilation control, contact activates ventilation should the panel temperature exceed the set value (max+60 °C), 35 mm rail (EN 60715) mount. 7 T . 8 1 . 0 . 0 0 0 . 2 3 0 3 Control function (Temperature only) 1 = (–20…+40)°C 3 = (0…+60)°C Series Type 8 = 35 mm rail (EN 60715) mount No. of contacts 1 = 1 contact Contact configuration 3 = 1 NO contact 4 = 1 NC contact Voltage type 0 = No operating voltage required Monitoring function 2 = Temperature, adjustable Rated operating voltage 000 = No operating voltage required Technical data Insulation Dielectric strength between open contacts V AC 500 Nm 0.5 0.5 solid cable stranded cable Other data Screw torque  Max. wire size mm 2 AWG 1 x 2.5 1 x 1.5 1 x 12 1 x 16 G Outline drawings IX-2016, www.findernet.com 7T.81  Screw terminal 2
7T.81.0.000.2303 价格&库存
很抱歉,暂时无法提供与“7T.81.0.000.2303”相匹配的价格&库存,您可以联系我们找货
7T.81.0.000.2303
    • 1+224.656281+29.07171
    • 5+205.348985+26.57324
    • 10+198.1752110+25.64492
    • 25+189.5892325+24.53385
    • 50+183.7211150+23.77448
    • 100+178.33674100+23.07772
    • 500+167.48344500+21.67324
    库存:939
    7T.81.0.000.2303
      • 1+268.25929
      • 5+263.27644
      库存:29
