81 SERIES
Modular timers 16 A
81
SERIES
81.01
Multi-function and multi-voltage timer
• One module 17.5 mm wide housing
• Seven functions (4 with supply start and
3 with control signal)
• Additional Reset function
• Six time ranges from 0.1 s to 10 h
• 35 mm rail (EN 60715) mounting
81.01
Screw terminal
• Multi-voltage (DC non polarized)
• Multi-function
AI: On-delay
DI: Interval
SW: Symmetrical flasher (starting pulse on)
SP: Symmetrical flasher (starting pulse off )
BE: Off-delay with control signal
DE: Interval with control signal on
EEb: Interval with control signal off
Wiring diagram
(supply START)
Wiring diagram
(control signal)
Contact specification
Contact configuration
1 CO (SPDT)
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
A
V AC
Rated load AC1
VA
16/30
4000
Rated load AC15 (230 V AC)
VA
750
Single phase motor rating (230 V AC)
kW
0.55
Breaking capacity DC1: 30/110/220 V
Minimum switching load
A
16/0.3/0.12
mW (V/mA)
500 (10/5)
Standard contact material
H
250/400
AgCdO
Supply specification
Nominal voltage (UN)
Rated power AC/DC
Operating range
V AC (50/60 Hz)
12…230
V DC
12…230 (non polarized)
VA (50 Hz)/W
很抱歉,暂时无法提供与“81.01.0.230.0000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+721.107571+93.58660
- 5+676.005705+87.73320
- 10+630.9908910+81.89110
- 国内价格 香港价格
- 1+942.764401+122.35361
