90.20SMA
90.20SMA
    FINDER
90.20SMA 数据手册
90 Series - Socket overview for 60 series relays Module Socket Relay Description 99.02 90.02 60.12 Screw terminal (Box clamp) socket 90.03 60.13 Double A1 terminal Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Jumper link - Timer modules - Metal retaining clip Module Socket Relay Description 99.01 90.20 60.12 Screw terminal (Box clamp) socket 90.21 60.13 Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Coil indication and EMC suppression modules - Metal retaining clip Module Socket Relay Description — 90.82.3 60.12 Screw terminal (Box clamp) socket — 90.83.3 60.13 Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Metal retaining clip Module Socket Relay Description — 90.22 60.12 Screw terminal (Box clamp) socket — 90.23 60.13 Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Metal retaining clip Module Socket Relay Description — 90.26 60.12 Screw terminal (Plate clamp) socket — 90.27 60.13 Mounting Panel or 35 mm rail (EN 50022) mount Accessories - Metal retaining clip Module Socket Relay Description — 90.12 60.12 Flange mount solder socket — 90.13 60.13 Mounting M3 screw fixing Accessories — Module Socket Relay Description — 90.14 60.12 PCB socket — 90.14.1 60.12 — 90.15 60.13 — 90.15.1 60.13 Mounting PCB Accessories — 90.03 See page 90 90.21 See page 91 60 90.83.3 See page 92 90.23 See page 92 90.26 See page 93 90.12 See page 93 90.15 See page 93 89 90 Series - Sockets and accessories for 60 series relays Screw terminal (Box clamp) socket panel or 35 mm rail (EN 50022) mount For relay type Accessories Metal retaining clip 6-way jumper link Identification tag Modules (see table below) Timer modules (see table below) Technical data Rated values Dielectric strength Protection category Ambient temperature Screw torque Wire strip length Max. wire size for 90.02 and 90.03 sockets °C Nm mm 35.5 34 9 32 8 24 7 22 5 14 3 12 4 A2 10 31 11 21 6 A1 2 11 1 A1 2 4 23.4 26.9 6-way jumper link for 90.02 and 90.03 sockets Rated values 090.06 10 A - 250 V 86.00 Approvals (according to type): 38 38 38 38 49.5 86 series timer modules (see technical data pages 181/182/187) Multi-voltage: (12…240)V AC/DC; Multi-functions: AI, DI, SW, BE, CE, DE, EE, FE; (0.05 s…100 h) Mono-function: (12…24)V AC/DC; function AI; (1.5 s…60 min) Mono-function: (12…24)V AC/DC; function DI; (1.5 s…60 min) 15 23 15 23 15 49.5 86.00.0.240.0000 86.10.0.024.0000 86.20.0.024.0000 Approvals (according to type): 99.02 Approvals (according to type): * Modules in Black housing are available on request. 90 0.7 13.7 38 090.06 23.4 26.9 30.5 99.02 coil indication and EMC suppression modules (see technical data pages 247/248) Blue* Diode (+A1, standard polarity) (6...220)V DC 99.02.3.000.00 Diode (+A2, non-standard polarity) (6...220)V DC 99.02.2.000.00 LED (6...24)V DC/AC 99.02.0.024.59 LED (28...60)V DC/AC 99.02.0.060.59 LED (110...240)V DC/AC 99.02.0.230.59 LED + Diode (+A1, standard polarity) (6...24)V DC 99.02.9.024.99 LED + Diode (+A1, standard polarity) (28...60)V DC 99.02.9.060.99 LED + Diode (+A1, standard polarity) (110...220)V DC 99.02.9.220.99 LED + Diode (+A2, non-standard polarity) (6...24)V DC 99.02.9.024.79 LED + Diode (+A2, non-standard polarity) (28...60)V DC 99.02.9.060.79 LED + Diode (+A2, non-standard polarity) (110...220)V DC 99.02.9.220.79 LED + Varistor (6...24)V DC/AC 99.02.0.024.98 LED + Varistor (28...60)V DC/AC 99.02.0.060.98 LED + Varistor (110...240)V DC/AC 99.02.0.230.98 RC circuit (6...24)V DC/AC 99.02.0.024.09 RC circuit (28...60)V DC/AC 99.02.0.060.09 RC circuit (110...240)V DC/AC 99.02.0.230.09 Residual current by-pass (62 kΩ/1W) (110...240)V AC 99.02.8.230.07 2.7 30.5 COIL COM COM START COM COIL 90.03 4 90.02 16.8 COIL COM COIL COM COIL 21.6 34.8 3.2 3.2 A1 2 33.5 11 A1 2 NC 16.8 11 1 NO 11 21 8 NC 20.4 A2 7 NO 35.5 14 3 NC 77.5 12 4 11 22 5 38 NO 49.7 24 6 stranded wire 1x4 / 2x2.5 1x12 / 2x14 33.5 20.4 NO 77.5 NC 10 A - 250 V ≥ 2 kV AC IP 20 –40...+70 0.6 10 solid wire 1x6 / 2x2.5 1x10 / 2x14 49.7 38 NO NC 90.03.0 Black 090.33 090.06 090.00.2 99.02 86.00, 86.10, 86.20 mm2 AWG 60 90.03 Blue 60.13 21.6 Approvals (according to type): 90.02.0 Black 34.8 90.03 90.02 Blue 60.12 12.8 90 Series - Sockets and accessories for 60 series relays NO NC NO NC NO NC 24 6 34 32 24 22 14 12 9 8 7 5 3 4 12 4 14 3 21 8 11 1 A1 2 30 38 90.20 99.01 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. 90.21.0 Black 090.33 99.01 10 A - 250 V ≥ 2 kV AC IP 20 –40…+70 0.5 10 solid wire 1x6 / 2x2.5 1x10 / 2x14 stranded wire 1x6 / 2x2.5 1x10 / 2x14 60 18 3.2 27.5 3.2 27.5 A2 7 COIL COM COM COIL 90.21 Blue 60.13 35 22 5 90.20.0 Black 14 NO NC NC NO 67 Approvals (according to type): 90.20 Blue 60.12 67 90.21 Screw terminal (Box clamp) socket panel or 35 mm rail (EN 50022) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Modules (see table below) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 90.20 and 90.21 sockets mm2 AWG A2 10 31 11 21 6 11 1 30 38 A1 2 COIL COM COM COM COIL 22 25.5 90.21 99.01 coil indication and EMC suppression modules for 90.20 and 90.21 sockets See technical data pages 247/248 Diode (+A1, standard polarity) (6...220)V DC Diode (+A2, non-standard polarity) (6...220)V DC LED (6...24)V DC/AC LED (28...60)V DC/AC LED (110...240)V DC/AC LED + Diode (+A1, standard polarity) (6...24)V DC LED + Diode (+A1, standard polarity) (28...60)V DC LED + Diode (+A1, standard polarity) (110...220)V DC LED + Diode (+A2, non-standard polarity) (6...24)V DC LED + Diode (+A2, non-standard polarity) (28...60)V DC LED + Diode (+A2, non-standard polarity) (110...220)V DC LED + Varistor (6...24)V DC/AC LED + Varistor (28...60)V DC/AC LED + Varistor (110...240)V DC/AC RC circuit (6...24)V DC/AC RC circuit (28...60)V DC/AC RC circuit (110...240)V DC/AC Residual current by-pass (62 kΩ/1W) (110...240)V AC Blue* 99.01.3.000.00 99.01.2.000.00 99.01.0.024.59 99.01.0.060.59 99.01.0.230.59 99.01.9.024.99 99.01.9.060.99 99.01.9.220.99 99.01.9.024.79 99.01.9.060.79 99.01.9.220.79 99.01.0.024.98 99.01.0.060.98 99.01.0.230.98 99.01.0.024.09 99.01.0.060.09 99.01.0.230.09 99.01.8.230.07 91 90 Series - Sockets and accessories for 60 series relays 90.83.3 Approvals (according to type): Screw terminal (Box clamp) socket panel or 35 mm rail (EN 50022) mount For relay type Accessories Metal retaining clip Technical data Rated values Dielectric strength Protection category Ambient temperature Screw torque Max. wire size for 90.82.3 and 90.83.3 sockets 90.82.3 Blue 60.12 10 A - 250 V ≥ 2 kV AC IP 20 °C –40…+70 Nm 0.8 solid wire mm2 1x6 / 2x4 AWG 1x10 / 2x14 NC NO com 24 6 32 8 12 4 14 3 90.83.3 Blue 60.13 90.83.30 Black 090.33 NO NC NC NO 22 5 90.82.30 Black 24 7 21 6 stranded wire 1x6 / 2x4 1x10 / 2x14 NC 22 5 NC 5.6 5.6 12 4 Ø 3.2 32 60 21 8 11 1 14 3 NO A2 10 A1 2 COIL COIL COM COM COIL 31 11 11 1 COM COM 29.5 29.5 38 38 90.82.3 90.23 Approvals (according to type): A1 2 COIL 27 90.83.3 Screw (Box clamp) terminal socket panel or 35 mm rail (EN 50022) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max wire size for 90.22 and 90.23 sockets mm2 AWG 90.22 (blue) 90.23 (blue) 60.12 60.13 090.33 10 A - 250 V ≥ 2 kV AC IP 20 –40…+70 0.5 7 solid wire 1x6 / 2x2.5 1x10 / 2x14 stranded wire 1x6 / 2x2.5 1x10 / 2x14 30 30 NO NC NC NO 31 8 11 1 a 2 38 COIL COM COM COIL 90.22 92 24 7 21 6 22 5 12 4 66 b 7 32 8 22.9 34 b 31 11 9 10 11 1 5.5 3.5 14 3 40.5 12 4 66 32 5 5.5 3.5 34 6 NC NO COM NC NC a 14 2 3 40.5 A2 7 34 9 NO 32 65 Ø 3.2 38 NO COIL COM COM COIL NO 90.23 22.9 90 Series - Sockets and accessories for 60 series relays 20 33 NC 22 5 6 10 14 3 NO NO A2 10 23 31 11 11 1 °C 32.8 90.12 90.13 Blue Blue For relay type Technical data Rated values Dielectric strength Ambient temperature 45° °C 45° 1.5 32°43'38" 32°43'38" 1.5 1.5 20.5 17.5 22 19 90.14 90.14.1 90.15 90.15.1 124 225 143 246 111 218 A27 90.14 = 90.13 (black) 60.13 10 A - 250 V ≥ 2 kV AC –40…+70 Ø 28.5 38 38 90.12 (black) 60.12 16.2 32.8 A12 27.6 31 43 21.5 3.2 47.4 3.2 1.5 60 90.27 Flange mount solder socket mount with M3 screw For relay type Technical data Rated values Dielectric strength Ambient temperature 47.4 Approvals (according to type): A1 2 COIL COM COM COIL PCB socket 90.15 fl 8.2 56 35 4.2 51 25.5 34 9 90.26 90.12 35 12 4 41 COIL COM COM COIL stranded wire 1x4 / 2x2.5 1x12 / 2x14 NC A2 21 11 A1 7 8 1 2 Approvals (according to type): 10 A - 250 V ≥ 2 kV AC IP 20 –40…+70 0.8 10 solid wire 1x4 / 2x2.5 1x12 / 2x14 32 8 21 6 90.27.0 Black 090.33 NC NO com 24 7 90.27 Blue 60.13 35 NO NC NC NO 24 22 12 14 6 5 4 3 90.26.0 Black = Approvals (according to type): 90.26 Blue 60.12 4.2 28 90.26 Screw terminal (Plate clamp) socket panel or 35 mm rail (EN 50022) mount For relay type Accessories Metal retaining clip (supplied with socket - packaging code SMA) Technical data Rated values Dielectric strength Protection category Ambient temperature °C Screw torque Nm Wire strip length mm Max. wire size for 90.26 and 90.27 sockets mm2 AWG 225 216 90.14 90.14.1 (Ø 17.5mm) 60.12 90.15 90.15.1 (Ø 19mm) 60.13 10 A - 250 V ≥ 2 kV AC –40…+70 27 28 90.14 90.15 18.5 13.5 247 124 143 328 349 111 3111 A12 A210 90.15 93 90 Series - Sockets and accessories for 60 series relays Packaging code How to code and identify retaining clip and packaging options for sockets. Code options according to the last three letters: 9 0 . 2 1 S M A A Standard packaging SM Metal retaining clip 9 0 . 2 60 94 1 Without retaining clip
90.20SMA 价格&库存
很抱歉,暂时无法提供与“90.20SMA”相匹配的价格&库存,您可以联系我们找货
90.20SMA
  • 1+65.666571+8.49760
  • 50+44.8838050+5.80820
  • 100+40.34303100+5.22060
库存:105
90.20SMA
  • 10+55.8412710+7.22616
