93.01.0.125
93.01.0.125
    FINDER
    继电器 插口 DIN 轨道
93.01.0.125 数据手册
38 Series - Relay interface modules 0.1 - 2 - 3 - 5 - 6 - 8 - 16 A Common features Instant ejection of relay by plastic retaining clip • Integral coil indication and protection circuit • 35 mm rail (EN 60715) mounting • 6.2 mm wide EMR Electromechanical Relays SSR Solid State Relays 38.51/38.61 38.81/38.91 38 SERIES EMR - DC, AC or AC/DC coil versions SSR - DC or AC/DC input versions • Screw and Screwless terminal options • • B • 1 CO - 6 A 250VAC Single solid state output: Options 0.1A 48VDC, 2A 24VDC, 2A 240VAC • Silent, high speed switching • Long electrical life • Page 1 6.2 mm wide Page 2 38.51.3… - 38.61.3… 38.81.3… - 38.91.3… Special coil / input leakage current suppression types • EMR - AC or AC/DC coil versions • SSR - AC or AC/DC input versions • Screw and Screwless terminal options • • 1 CO - 6 A 250VAC Single solid state output: Options 0.1A 48VDC, 2A 24VDC, 2A 240VAC • Silent, high speed switching • Long electrical life • Page 1 Page 2 38.21 6.2 mm wide 38.21...9024-8240 Timed Interface module 4 functions & 4 time scales 0.1s … 6h • EMR - AC/DC (12 or 24V) supply versions • SSR - AC/DC (24V) supply • Screw terminals • • • 1 CO - 6 A 250VAC Single solid state output: Options 2A 24VDC, 2A 240VAC • Silent, high speed switching • Long electrical life • Page 3 14 mm wide Page 3 38.01/38.52/38.11/38.62 38.31/38.41 2 pole 8 A or 1 pole 16 A EMR - DC or AC/DC coil versions • SSR - DC input versions • Screw and Screwless terminal options • II-2014, www.findernet.com • • • 1 CO - 16 A 250VAC 2 CO - 8 A 250VAC Single solid state output: Options 5A 24VDC, 3A 240VAC • Silent, high speed switching • Long electrical life • Page 4 Page 5 38 SERIES 38 Series - Relay interface modules - 1 Pole 6 A EMR Features 38.51/61 38.51.3 / 38.61.3 1 Pole - 6 A electromechanical relay interface modules, 6.2 mm wide. Ideal interface for PLC and electronic systems Sensitive DC coil or AC/DC coil versions Integral coil indication and protection circuit • Instant ejection of relay using plastic retaining clip • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • • 38.51 / 38.51.3 Screw terminal B 1 pole electromechanical relay Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting 38.61 / 38.61.3 Screwless terminal • • Leakage current suppression 1 pole electromechanical relay • Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting • • * Special version for max ambient temperature +70°C. For outline drawing see page 12 Contact specification 1 CO (SPDT) Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 1 CO (SPDT) 6/10 6/10 250/400 250/400 Rated load AC1 VA 1,500 1,500 Rated load AC15 (230 V AC) VA 300 300 Single phase motor rating (230 V AC) kW 0.185 0.185 A 6/0.2/0.12 6/0.2/0.12 mW (V/mA) 500 (12/10) 500 (12/10) AgNi AgNi Breaking capacity DC1: 30/110/220 V Minimum switching load Standard contact material Coil specification Nominal voltage (UN) Rated power AC/DC 12 - 24 - 48 - 60 - (110…125) - (220…240) (110…125) — V AC (230...240)* — (230...240) V DC 6 - 12 - 24 - 48 - 60 (non polarized) — — See page 9 1/1 0.5/— AC/DC (0.8...1.1)UN (94...138)V — AC (184...264)V — (184...264)V V AC/DC VA (50 Hz)/W Operating range (0.8...1.2)UN — Holding voltage AC/DC 0.6 UN / 0.6 UN 0.6 UN / 0.6 UN Must drop-out voltage AC/DC 0.1 UN / 0.05 UN DC 44 V 72 V Technical data Mechanical life AC/DC cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 60 · 103 60 · 103 5/6 5/6 Insulation between coil and contacts (1.2/50 µs) kV 6 (8 mm) 6 (8 mm) Dielectric strength between open contacts V AC 1,000 1,000 Ambient temperature range (UN≤ 60 V/>60V) °C –40…+70/–40...+55 —/–40...+55 IP 20 IP 20 II-2014, www.findernet.com Operate/release time Protection category ms Approvals relay (according to type) 1 38 SERIES 38 Series - Relay interface modules - Single output SSR Features 38.81/38.91 38.81.3/38.91.3 Single output - solid state relay interface modules, 6.2 mm wide. Ideal interface for PLC and electronic systems DC, AC or AC/DC input versions Supplied with integral coil indication and protection circuit • Silent, high switching speed and long electrical life • Instant ejection of relay using plastic retaining clip • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • • 38.81 / 38.81.3 Screw terminal AC or DC output switching SSR relay - DC input voltage • Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting Leakage current suppression AC or DC output • SSR relay - AC or AC/DC input voltage • Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting • • • • 38.91 / 38.91.3 Screwless terminal For outline drawing see page 12 Output specification Contact configuration 1 NO (SPST-NO) Rated current/Maximum peak current (10 ms) A Rated voltage/Maximum blocking voltage Switching voltage range Repetitive peak off-state voltage 1 NO (SPST-NO) 2/20 0.1/0.5 2/40 2/20 0.1/0.5 2/40 V 24/33 DC 48/60 DC 240/— AC 24/33 DC 48/60 DC 240/— AC V (1.5…24)DC (1.5…48)DC (12...275)AC (1.5…24)DC (1.5…48)DC (12…275)AC — — 600 — — 600 Vpk Minimum switching current mA 1 0.05 22 1 0.05 22 Max. “OFF-state” leakage current mA 0.001 0.001 1.5 0.001 0.001 1.5 1 1.6 0.12 1 1.6 Max. “ON-state” voltage drop V Input specification 0.12 0...24 0...48 — V AC Nominal voltage (UN) 6 - 24 - 60 — (110...125) - (220...240) 110...125 V DC See page 10 See page 10 mA See page 10 See page 10 V DC See page 10 See page 10 V DC V AC/DC Operating range Control current Release voltage 230...240 Technical data Operate/release time: ON/OFF (DC input) ms Dielectric strength between input/output V AC Ambient temperature range Environmental protection °C 0.2/0.6 0.04/0.11 12/12 0.2/0.6 0.04/0.11 2,500 2,500 –20...+55 –20...+55 IP20 IP20 12/12 Approvals relay (according to type) II-2014, www.findernet.com B 2 38 SERIES 38 Series - Timed interface modules - EMR & SSR Features 38.21 38.21...9024-8240 Slim timed interface module, 6.2 mm wide. 1 pole, 6 A - electromechanical relay 1 output, 2 A DC or AC - solid state relay Electromechanical or solid state output Multi-functions timer • AC/DC supply • 4 time scales from 0.1s to 6h • Instant ejection of relay using plastic retaining clip • 6.2 mm wide, 35 mm rail (EN 60715) mounting • • 38.21 Screw terminal B DC or AC solid state output relays 24V AC/DC supply voltage • Screw terminal • 35 mm rail (EN 60715) mounting • 1 pole electromechanical output relay 12 or 24 V AC/DC supply • Screw terminal • 35 mm rail (EN 60715) mounting • • • AI: On-delay DI: Interval GI: Pulse delayed SW: Symmetrical flasher (starting pulse on) AI: On-delay DI: Interval GI: Pulse delayed SW: Symmetrical flasher (starting pulse on) For outline drawing see page 12 Contact specification Contact configuration 1 CO (SPDT) — 6/10 — 250/400 — 1,500 — A 6/0.2/0.12 — mW (V/mA) 500 (12/10) — Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC Rated load AC1 VA Breaking capacity DC1: 30/110/220 V Minimum switching load Standard contact material AgNi — Output specification Output configuration DC output (...9024) AC output (...8240) — 1 NO (SPST-NO) 1 NO (SPST-NO) A — 2/20 2/40 Rated voltage/Maximum blocking voltage V — (24/33)DC (240/—)AC Switching voltage range V — (1.5...24)DC (12...275)AC Repetitive peak off-state voltage Vpk — — 600 Minimum switching current mA — 1 22 Max. “OFF-state” leakage current mA — 0.001 1.5 V — 0.12 1.6 Rated current/Maximum peak current Max. “ON-state” voltage drop Supply specification Nominal voltage (UN) V AC (50/60Hz)/DC Rated power Operating range VA/W 12 - 24 24 0.5 0.5 AC (0.8...1.1)UN (0.8...1.1)UN DC (0.8...1.1)UN (0.8...1.1)UN Technical data II-2014, www.findernet.com Specified time range (0.1...3)s, (3...60)s, (1...20)min, (0.3...6)h Repeatability % ±1 Recovery time ms ≤ 50 Setting accuracy-full range Ambient temperature Protection category % °C 5% –40…+70 –20…+55 IP 20 Approvals relay (according to type) 3 38 SERIES 38 Series - Relay interface modules - 1 Pole 16A and 2 Pole 8A EMR Features 38.01/38.11 38.52/38.62 Electromechanical relay interface modules, 14 mm wide. 38.01 and 38.11 - 1 Pole 16 A 38.52 and 38.62 - 2 Pole 8 A Ideal interface for PLC and electronic systems Sensitive DC coil or AC/DC coil versions Integral coil indication and protection circuit • Instant ejection of relay using plastic retaining clip • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • • 38.01/52 Screw terminal 38.11/62 Screwless terminal Screw terminal and screwless terminal 1 pole electromechanical relay • 35 mm rail (EN 60715) mounting Screw terminal and screwless terminal 2 pole electromechanical relay • 35 mm rail (EN 60715) mounting • • • • * For currents >10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). For outline drawing see page 12 Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/Maximum switching voltage V AC 1 CO (DPDT) 2 CO (DPDT) 16*/30 8/15 250/400 250/400 VA 4,000 2,000 Rated load AC15 (230 V AC) VA 750 400 Single phase motor rating (230 V AC) kW 0.5 0.3 16/0.3/0.12 8/0.3/0.12 300 (5/5) 300 (5/5) AgNi AgNi 24 - 60 - (110...125) - (220...240) 24 - 60 - (110...125) - (220...240) Rated load AC1 Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material Coil specification Nominal voltage (UN) Rated power AC/DC V AC/DC V AC 230...240 230...240 V DC 12 - 24 - 60 12 - 24 - 60 VA (50 Hz)/W See page 9 See page 9 0.8...1.1 0.8...1.1 Operating range AC/DC DC (0.8...1.2)UN (0.8...1.2)UN Holding voltage AC/DC 0.6 / 0.6 UN 0.6 / 0.6 UN Must drop-out voltage AC/DC 0.1 / 0.05 UN 0.1 / 0.05 UN Technical data Mechanical life AC/DC cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 50 · 103 60 · 103 Operate/release time ms 8 / 10 8 / 10 Insulation between coil and contacts (1.2/50 µs) kV 6 (8 mm) 6 (8 mm) Dielectric strength between open contacts V AC 1,000 1,000 Ambient temperature range (UN≤ 60 V/>60V) °C –40…+70 / –40…+55 –40…+70 / –40…+55 IP 20 IP 20 Protection category Approvals relay (according to type) 4 II-2014, www.findernet.com B 38 Series - Relay interface modules - Single output SSR Features 38 SERIES 38.31/38.41 Single output - solid state relay interface modules, 14 mm wide. Ideal interface for PLC and electronic systems DC input versions Supplied with integral coil indication and protection circuit • Silent, high switching speed and long electrical life • Instant ejection of relay using plastic retaining clip • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting • • 38.31 Screw terminal 38.41 Screwless terminal B Screw terminal and screwless terminal AC or DC output switching • SSR relay - DC input voltage • 35 mm rail (EN 60715) mounting • • For outline drawing see page 12 Output specification Contact configuration Rated current/Maximum peak current (10 ms) A 1 NO (SPST-NO) 1 NO (SPST-NO) 5/40 3/40 Rated voltage/Maximum blocking voltage V (24/35)DC (240/—)AC Switching voltage range V (1.5…24)DC (12…275)AC Repetitive peak off-state voltage Vpk — 600 Minimum switching current mA 1 50 Max. “OFF-state” leakage current mA 0.01 1 0.3 1.1 0...24 0...48 Max. “ON-state” voltage drop V Input specification Nominal voltage (UN) Operating range Control current Release voltage V AC/DC 24 V DC 12 - 24 V DC See page 10 mA See page 10 V DC See page 10 Technical data Operate/release time: ON/OFF (DC input) ms Dielectric strength between input/output V AC Ambient temperature range Environmental protection °C 0.05/0.25 12/12 2,500 –20...+55 IP20 II-2014, www.findernet.com Approvals relay (according to type) 5 38 SERIES 38 Series - Relay interface modules - Ordering information Ordering information Electromechanical relay - 1 or 2 Pole Example: 38 series screw terminal relay interface module, 1 CO (SPDT), sensitive 12 V DC coil. B C D 1 . 7 . 0 1 2 . 0 0 5 0 Series D: Special versions 0 = Standard Type 0 = Electromechanical 16 A relay, with screw terminal 1 = Electromechanical 16 A relay, with screwless terminal 2 = Timer multifunction (AI, DI, GI, SW), with screw terminal 5 = Electromechanical relay, with screw terminal 6 = Electromechanical relay, with screwless terminal C: Options 5 = Standard DC 6 = Standard AC or AC/DC B: Contact circuit 0 = CO (nPDT) A: Contact material 0 = AgNi Standard 4 = AgSnO2 5 = AgNi + Au No. of poles 1 = 1 pole, 6 or 16 A 2 = 2 pole, 8 A Coil version 0 = AC (50/60 Hz)/ DC 3 = Leakage current suppression for (110…125)V AC/DC - (230…240)V AC 7 = Sensitive DC, (6, 12, 24, 48, 60)V only 8 = AC (50/60 Hz) Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Type B C D 38.01/11 7 Coil version A 0-4 0 5 0 38.01/11 0 - 8 0-4 0 6 0 38.51/61 7 0-4-5 0 5 0 38.51/61 0 - 3 - 8 0-4-5 0 6 0 38.52/62 7 0-5 0 5 0 38.52/62 0 - 8 0-5 0 6 0 38.21 0 0 6 0 0 II-2014, www.findernet.com B 3 8 . 5 A 6 38 Series - Relay interface modules - Ordering information 38 SERIES Ordering information Solid state relay - Single output - 6.2 & 14 mm wide Example: 38 series screw terminal SSR relay interface module, 6.2 mm wide, 2 A output, 24 V DC input. 3 8 . 8 1 . 7 . 0 2 4 . 9 0 2 4 Series Output version 9024 = 2 A 9024 = 5 A 7048 = 0.1 A 8240 = 2 A 8240 = 3 A - Type 21 = Timer SSR 6.2mm wide, with screw terminal 31 = SSR 14mm wide, with screw terminal 41 = SSR 14mm wide, with screwless terminal 81 = SSR 6.2mm wide, with screw terminal 91 = SSR 6.2mm wide, with screwless terminal B 24 24 48 240 240 V V V V V DC (38.21, 38.81 & 38.91) DC (38.31 & 38.41) DC (38.81 & 38.91) AC (38.21, 38.81 & 38.91) AC (38.31 & 38.41) Input version 0 = AC/DC 3 = Leakage current suppression for (110...125)V AC/DC and (230...240)V AC SSR only 7 = DC, (6, 24, 60)V SSR only Input voltage See input specifications Selecting features and options: only combinations in the same row are possible. Type Input version Output version 38.81/91 7 9024 - 7048 - 8240 38.81/91 0 - 3 9024 - 7048 - 8240 38.31/41 0 - 7 9024 - 8240 38.21 9024 - 8240 II-2014, www.findernet.com 0 7 38 SERIES 38 Series - Relay interface modules - Technical data Technical data - 1 & 2 Pole Electromechanical Relays Insulation Insulation according to EN 61810-1 V 250 kV 4 3 III kV 6 (8 mm) V AC 1,000 ms g W W mm Nm mm2 AWG Wire strip length Screw torque Max. wire size mm Nm mm2 AWG 400 4 2 III EN 61000-4-4 EN 61000-4-5 1 Pole 6 A 1/6 10/5 0.2 (12 V) - 0.9 (240 V) 0.5 (12 V) - 1.5 (240 V) 38.21 / 38.51 10 0.5 solid cable stranded cable 1x2.5/2x1.5 1x2.5/2x1.5 1x14/2x16 1x14/2x16 38.01 / 38.52 10 0.5 solid cable stranded cable 1x2.5/2x1.5 1x2.5/2x1.5 1x14/2x16 1x14/2x16 level 4 (4 kV) level 3 (2 kV) 1 Pole 16 A - 2 Pole 8 A 2/5 15/2 0.5 (24 V) - 0.9 (240 V) 1.3 (24 V) - 1.7 (240 V) 38.61 10 — solid cable stranded cable 1x2.5 1x2.5 1x14 1x14 38.11 / 38.62 10 — solid cable stranded cable 1x2.5 1x2.5 1x14 1x14 Contact specification - 1 & 2 Pole Electromagnetic Relays Cycles Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 H 38 - Maximum DC1 breaking capacity, 1 Pole 6 A DC breaking current (A) F 38 - Electrical life (AC) v contact current, 1 Pole 6 A DC voltage (V) Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 38.01/11 limit current 38.52/62 limit current 2 contacts in series single contact DC voltage (V) : 2 Pole 8 A : 1 Pole 16 A 8 • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 60·103 (1 Pole) or ≥ 80·103 ( 2 Pole) can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. II-2014, www.findernet.com Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 H 38 - Maximum DC1 breaking capacity, 1 Pole 16 A and 2 Pole 8 A DC breaking current (A) F 38 - Electrical life (AC) v contact current, 1 Pole 16 A and 2 Pole 8 A Cycles B insulation rated voltage rated impulse withstand voltage pollution degree overvoltage category Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Conducted disturbance immunity Burst (5...50)ns, 5 kHz, on A1 - A2 Surge (1.2/50 µs) on A1 - A2 (differential mode) Other data Bounce time: NO/NC Vibration resistance (10…55)Hz: NO/NC Power lost to the environment without contact current with rated current Terminals Wire strip length Screw torque Max. wire size 38 SERIES 38 Series - Relay interface modules - Technical data Coil specifications - 1 Pole 6 A Electromechnical Relay Coil data sensitive DC, 1 Pole Nominal voltage UN V 6 12 24 48 60 Coil code 7.006 7.012 7.024 7.048 7.060 Coil data AC/DC, 1 Pole Operating range Umin V 4.8 9.6 19.2 38.4 48 Umax V 7.2 14.4 28.8 57.6 72 Rated coil Power consumption consumption I at UN P at UN mA W 35 0.2 15.2 0.2 10.4 0.3 6.3 0.3 7 0.4 Nominal voltage UN V 12 24 48 60 110…125 220…240 Coil code 0.012 0.024 0.048 0.060 0.125 0.240 Operating range Umin V 9.6 19.2 38.4 48 88 176 Umax V 13.2 26.4 52.8 66 138 264 Rated coil Power consumption consumption I at UN P at UN mA VA/W 16 0.2/0.2 12 0.3/0.2 6.9 0.3/0.3 7 0.5/0.5 5(*) 0.6/0.6(*) 4(*) 1/0.9(*) (*) Rated coil consumption and power consumption values relate to UN = 125 and 240 V. Coil data AC, 1 Pole (indicated for max ambient temperature +70°C) Nominal voltage UN V (230…240) AC Coil code Operating range Umin V 184 8.240 Umax V 264 Rated coil Power consumption consumption P at UN I at UN mA VA/W 3 0.7/0.3 Coil data, leakage current suppression types, 1 Pole Nominal voltage UN V (110…125) AC/DC (230…240) AC Coil code Operating range Umin V 94 184 3.125 3.240 Umax V 138 264 Rated coil Power consumption consumption P at UN I at UN mA VA/W 8(*) 1/1(*) 7(*) 1.7/0.5(*) The 38 Series interface modules (supply version 3) have built-in leakage current suppression to address industry concerns of the contacts not dropping-out when there is residual current in the circuit; at (110...125)V AC and (230...240)V AC. This problem can occur, for example, when connecting the interface modules to PLC‚s with triac outputs or when (*) Rated coil consumption and power consumption values relate to UN = 125 and 240 V. connecting via relatively long cables. Coil specifications - 1 Pole 16 A and 2 Pole 8 A Electromechanical Relay Coil data sensitive DC, 1 Pole 16 A and 2 Pole 8 A Nominal voltage UN V 12 24 60 Coil code 7.012 7.024 7.060 Operating range Umin V 9.6 19.2 48 Umax V 14.4 28.8 72 Rated coil Power consumption consumption P at UN I at UN mA W 41 0.5 19.5 0.5 8 0.5 Coil data AC/DC, 1 Pole 16 A and 2 Pole 8 A Nominal voltage UN V 24 60 110...125 220...240 Coil code 0.024 0.060 0.125 0.240 Operating range Umin V 19.2 48 88 184 Umax V 26.4 66 138 264 Rated coil consumption I at UN mA 20 7.1 4.6 3.8 Power consumption P at UN VA/W 0.5/0.5 0.5/0.5 0.6/0.6 0.9/0.9 Coil data AC, 1 Pole 16 A and 2 Pole 8 A Nominal voltage UN V 230...240 Coil code 8.230 Operating range Umin V 184 Umax V 264 Rated coil Power consumption consumption P at UN I at UN mA VA/W 5.3 1.2/0.6 Coil specification - 1 & 2 Pole Electromagnetic Relays R 38 - DC coil operating range v ambient temperature 1 Pole and 2 Pole 1 II-2014, www.findernet.com 2 3 4 1 2 3 4 - Max. permitted coil voltage at nominal load (DC coil). Max. permitted coil voltage at nominal load (AC/DC coils U ≤ 60 V). Max. permitted coil voltage at nominal load (AC/DC coils U > 60 V). Min pick-up voltage with coil at ambient temperature. 9 B 38 SERIES 38 Series - Relay interface modules - Technical data Technical data - Solid State Relays Other data 38.81/38.91 Power lost to the environment W 0.25 (24 V DC) 0.5 with rated current W 0.4 2.2 (DC output) / 3 (AC output) Terminals 38.81 Wire strip length Screw torque 38.91 mm 10 10 Nm 0.5 — Max. wire size solid cable mm 2 1x2.5 / 2x1.5 AWG 1x14 / 2x16 stranded cable solid cable stranded cable 1x2.5 / 2x1.5 1x2.5 1x2.5 1x14 / 2x16 1x14 1x14 38.31 Wire strip length Screw torque 38.41 mm 10 10 Nm 0.5 — Max. wire size solid cable mm2 1x2.5 / 2x1.5 AWG 1x14 / 2x16 stranded cable solid cable stranded cable 1x2.5 / 2x1.5 1x2.5 1x2.5 1x14 / 2x16 1x14 1x14 Input specifications - Solid State Relays type 38.81 and 38.91 - 6.2 mm wide Input data AC/DC Input data DC Nominal voltage UN V 6 24 60 Supply code 7.006 7.024 7.060 Operating range Umin V 5 16.8 35.6 Umax V 7.2 30 72 Release Rated coil Power voltage consumption consumption U I at UN P V mA W 2.4 7 0.2 10 10.5 0.3 20 6.5 0.4 Nominal Supply voltage code UN V 110...125 0.125 220...240 0.240 Operating range Umin V 88 184 Umax V 138 264 Release Rated coil voltage consumption U I at UN V mA 22 5.5* 44 3.5* Power consumption P VA/W 0.7/0.7 1/0.9 (*) Rated coil consumption and power consumption values relate to UN = 125 and 240 V. Input data - Leakage current suppression types Nominal voltage UN V 110…125 AC/DC 230…240 AC Supply Operating range Release Rated coil Power code voltage consumption consumption I at UN P at UN Umin Umax U V V mA W 3.125 94 138 44 8(*) 1/1(*) 3.240 184 264 72 6.5(*) 1.6/0.6(*) (*) Rated coil consumption and power consumption values relate to UN = 125 and 240 V. The 38 Series interface modules (supply version 3) have built-in leakage current suppression to address industry concerns of the contacts not dropping-out when there is residual current in the circuit; at (110...125)V AC and (230...240)V AC. This problem can occur, for example, when connecting the interface modules to PLC‚s with triac outputs or when connecting via relatively long cables. Input specification - Solid State Relay types 38.31 and 38.41 - 14 mm wide Input data AC/DC Input data DC Nominal Supply voltage code UN V 12 7.012 24 7.024 Operating range Umin V 9.6 16.8 Umax V 18 30 Release Rated coil Power voltage consumption consumption U I at UN P V mA W 5 9 0.2 5 12 0.3 Nominal Supply voltage code UN V 24 0.024 Operating range Umin V 16.8 Umax V 30 Release Rated coil Power voltage consumption consumption U I at UN P V mA W 9 16.5 0.3 II-2014, www.findernet.com B 38.31/38.41 without output current 10 38 SERIES 38 Series - Timed interface modules Additional technical data - Timed Interface Module EMC specifications Type of test Reference standard Electrostatic discharge contact discharge EN 61000-4-2 4 kV air discharge EN 61000-4-2 8 kV Radio-frequency electromagnetic field (80 ÷ 1,000 MHz) EN 61000-4-3 10 V/m Fast transients (burst) (5-50 ns, 5 kHz) on Supply terminals EN 61000-4-4 4 kV Surges (1.2/50 µs) on Supply terminals common mode EN 61000-4-5 4 kV differential mode EN 61000-4-5 B 4 kV Radio-frequency common mode (0.15 ÷ 80 MHz) on Supply terminals EN 61000-4-6 10 V Radiated and conducted emission EN 55022 class B Other data EMR SSR Power lost to the environment without contact current W 0.1 0.1 with rated current 0.5 Terminals W 0.6 38.21 Wire strip length mm 10 Screw torque Nm 0.5 Max. wire size solid cable stranded cable mm2 1x2.5 / 2x1.5 1x2.5 / 2x1.5 (3...60)s (0.1...3)s 1x14 / 2x16 1 2 3 4 1 2 3 4 1 2 3 4 Times scales 1 2 3 4 AWG 1x14 / 2x16 (0.3...6)h (1...20)min Functions LED U = Supply voltage 1 2 3 4 1 2 3 4 II-2014, www.findernet.com 1 2 3 4 1 2 3 4 Wiring diagram Supply voltage NO contact/output OFF Open ON Open (time in progress) ON Closed = Output contact (AI) On-delay. Apply power to timer. Output contacts transfer after preset time has elapsed. Reset occurs when power is removed. (DI) Interval. Apply power to timer. Output contacts transfer immediately. After the preset time has elapsed, contacts reset. (GI) Pulse delayed. Apply power to timer. Output contacts transfer after preset time has elapsed. Reset occurs after a fixed time of 0.5s. (SW) Symmetrical flasher (starting pulse on). Apply power to timer. Output contacts transfer immediately and cycle between ON and OFF for as long as power is applied. The ratio is 1:1 (time on = time off). 11 38 SERIES 38 Series - Relay interface modules - Dimensional data Outline drawings 38.21 38.51 / 38.51.3 38.81 / 38.81.3 Screw terminal 38.01 38.31 38.52 Screw terminal 38.61 / 38.61.3 38.91 / 38.91.3 Screwless terminal 38.11 38.41 38.62 Screwless terminal II-2014, www.findernet.com B 12 93 Series - Sockets and accessories for 38 series 38 SERIES II-2014, www.findernet.com Electromechanical Relay & Socket Combinations Screw terminal - 1 Pole relay 6 A Interface Module Code Coil voltage 38.51.0.012.0060 12 V AC/DC 38.51.0.024.0060 24 V AC/DC 38.51.0.048.0060 48 V AC/DC 38.51.0.060.0060 60 V AC/DC 93.01 38.51.0.125.0060 (110...125)V AC/DC 38.51.0.240.0060 (220...240)V AC/DC 38.51.3.125.0060 (110...125)V AC/DC 38.51.3.240.0060 (230...240)V AC 38.51.7.006.0050 6 V DC 38.51.7.012.0050 12 V DC 38.51.7.024.0050 24 V DC 38.51.7.048.0050 48 V DC 38.51.7.060.0050 60 V DC 93.51 38.51.8.240.0060 (230...240)V AC Screwless terminal - 1 Pole relay 6 A Interface Module Code Coil voltage 38.61.0.012.0060 12 V AC/DC 38.61.0.024.0060 24 V AC/DC 38.61.0.125.0060 (110...125)V AC/DC 38.61.0.240.0060 (220...240)V AC/DC 38.61.3.125.0060 (110...125)V AC/DC 38.61.3.240.0060 (230...240)V AC 38.61.7.012.0050 12 V DC 38.61.7.024.0050 24 V DC 38.61.8.240.0060 (230...240)V AC 93.02 Screw terminal - 1 Pole relay 16 A Interface Module Code Coil voltage 38.01.7.012.0050 12 V DC 38.01.7.024.0050 24 V DC 38.01.7.060.0050 60 V DC 38.01.0.024.0060 24 V AC/DC 38.01.0.060.0060 60 V AC/DC 38.01.0.125.0060 125 V AC/DC 38.01.0.240.0060 240 V AC/DC 38.01.8.230.0060 230 V AC Screwless terminal - 1 Pole relay 16 A 93.52 Interface Module Code Coil voltage Approvals 38.11.7.012.0050 12 V DC (according to type): 38.11.7.024.0050 24 V DC 38.11.7.060.0050 60 V DC 38.11.0.024.0060 24 V AC/DC 38.11.0.060.0060 60 V AC/DC 38.11.0.125.0060 125 V AC/DC Certain relay/socket 38.11.0.240.0060 240 V AC/DC combinations 38.11.8.230.0060 230 V AC Screw terminal - 2 Pole relay 8 A Interface Module Code Coil voltage 38.52.0.024.0060 24 V AC/DC 38.52.0.060.0060 60 V AC/DC 38.52.0.125.0060 (110...125)V AC/DC 38.52.0.240.0060 (220...240)V AC/DC 38.52.7.012.0050 12 V DC 38.52.7.024.0050 24 V DC 38.52.7.060.0050 60 V DC 38.52.8.230.0060 (230...240)V AC Screwless terminal - 2 Pole relay 8 A Interface Module Code Coil voltage 38.62.0.024.0060 24 V AC/DC 38.62.0.060.0060 60 V AC/DC 38.62.0.125.0060 (110...125)V AC/DC 38.62.0.240.0060 (220...240)V AC/DC 38.62.7.012.0050 12 V DC 38.62.7.024.0050 24 V DC 38.62.7.060.0050 60 V DC 38.62.8.230.0060 (230...240)V AC Relay 34.51.7.012.0010 34.51.7.024.0010 34.51.7.048.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.005.0010 34.51.7.012.0010 34.51.7.024.0010 34.51.7.048.0010 34.51.7.060.0010 34.51.7.060.0010 Socket 93.01.0.024 93.01.0.024 93.01.0.060 93.01.0.060 93.01.0.125 93.01.0.240 93.01.3.125 93.01.3.240 93.01.7.024 93.01.7.024 93.01.7.024 93.01.7.060 93.01.7.060 93.01.8.240 Relay 34.51.7.012.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.012.0010 34.51.7.024.0010 34.51.7.060.0010 Socket 93.51.0.024 93.51.0.024 93.51.0.125 93.51.0.240 93.51.3.125 93.51.3.240 93.51.7.024 93.51.7.024 93.51.8.240 Relay 41.61.9.012.0010 41.61.9.024.0010 41.61.9.060.0010 41.61.9.024.0010 41.61.9.060.0010 41.61.9.110.0010 41.61.9.110.0010 41.61.9.110.0010 Socket 93.02.7.024 93.02.7.024 93.02.7.060 93.02.0.024 93.02.0.060 93.02.0.125 93.02.0.240 93.02.8.230 Relay 41.61.9.012.0010 41.61.9.024.0010 41.61.9.060.0010 41.61.9.024.0010 41.61.9.060.0010 41.61.9.110.0010 41.61.9.110.0010 41.61.9.110.0010 Socket 93.52.7.024 93.52.7.024 93.52.7.060 93.52.0.024 93.52.0.060 93.52.0.125 93.52.0.240 93.52.8.230 Relay 41.52.9.024.0010 41.52.9.060.0010 41.52.9.110.0010 41.52.9.110.0010 41.52.9.012.0010 41.52.9.024.0010 41.52.9.060.0010 41.52.9.110.0010 Socket 93.02.0.024 93.02.0.060 93.02.0.125 93.02.0.240 93.02.7.024 93.02.7.024 93.02.7.060 93.02.8.230 Relay 41.52.9.024.0010 41.52.9.060.0010 41.52.9.110.0010 41.52.9.110.0010 41.52.9.012.0010 41.52.9.024.0010 41.52.9.060.0010 41.52.9.110.0010 Socket 93.52.0.024 93.52.0.060 93.52.0.125 93.52.0.240 93.52.7.024 93.52.7.024 93.52.7.060 93.52.8.230 B 13 38 SERIES 93 Series - Sockets and accessories for 38 series Solid State Relay & Socket Combinations - 6.2 mm wide 93.01 B 93.51 Approvals (according to type): Certain relay/socket combinations Screw terminal Interface Module Code 38.81.7.006.xxxx 38.81.7.024.xxxx 38.81.7.060.xxxx 38.81.0.125.xxxx 38.81.0.240.xxxx 38.81.3.125.xxxx 38.81.3.240.xxxx Screwless terminal Interface Module Code 38.91.7.006.xxxx 38.91.7.024.xxxx 38.91.7.060.xxxx 38.91.0.125.xxxx 38.91.0.240.xxxx 38.91.3.125.xxxx 38.91.3.240.xxxx Input voltage 6 V DC 24 V DC 60 V DC (110...125)V AC/DC (220...240)V AC/DC (110...125)V AC/DC (230...240)V AC Relay 34.81.7.005.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx Socket 93.01.7.024 93.01.7.024 93.01.7.060 93.01.0.125 93.01.0.240 93.01.3.125 93.01.3.240 Input voltage 6 V DC 24 V DC 60 V DC (110...125)V AC/DC (220...240)V AC/DC (110...125)V AC/DC (230...240)V AC Relay 34.81.7.005.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx Socket 93.51.7.024 93.51.7.024 93.51.7.060 93.51.0.125 93.51.0.240 93.51.3.125 93.51.3.240 Example: .xxxx .9024 .7048 .8240 Solid State Relay & Socket Combinations - 14 mm wide 93.52 Approvals (according to type): Screw terminal Interface Module Code 38.31.0.024.xxxx 38.31.7.012.xxxx 38.31.7.024.xxxx Screwless terminal Interface Module Code 38.41.0.024.xxxx 38.41.7.012.xxxx 38.41.7.024.xxxx Input voltage 24 V AC/DC 12 V DC 24 V DC Relay 41.81.7.024.xxxx 41.81.7.012.xxxx 41.81.7.024.xxxx Socket 93.02.0.024 93.02.7.024 93.02.7.024 Input voltage 24 V AC/DC 12 V DC 24 V DC Relay 41.81.7.024.xxxx 41.81.7.012.xxxx 41.81.7.024.xxxx Socket 93.52.0.024 93.52.7.024 93.52.7.024 Relay 34.51.7.012.0010 34.51.7.024.0010 34.81.7.024.xxxx Socket 93.21.0.024 93.21.0.024 93.21.0.024 SSR / EMR & Timer Socket Combinations Screw terminal Interface Module Code 38.21.0.012.0060 38.21.0.024.0060 38.21.0.024.xxxx Input / Coil voltage 12 V AC/DC 24 V AC/DC 24 V AC/DC 14 II-2014, www.findernet.com 93.21 Approvals (according to type): 38 SERIES 93 Series - Sockets and accessories for 38 series P A PEAN N T E O O T EUR EUR Accessories 20-way jumper link for 38.21/51/61/81/91 093.20 (blue) Rated values 36 A - 250 V 093.20.0 (black) 093.20.1 (red) PEAN 093.20 B P A PEAN N T E O O T EUR EUR Approvals (according to type): 8-way jumper link for 38.01/11/31/41/52/62 093.08 (blue) Rated values 10 A - 250 V 093.08.0 (black) 093.08.1 (red) PEAN 093.08 Approvals (according to type): 093.01 Plastic separator 093.01 Thickness 2 mm, required at the start and the end of a group of interfaces. Can be used for visual separation group, must be used for: - protective separation of different voltages of neighbouring PLC interfaces according to VDE 0106-101 - protection of cut jumper links Sheet of marker tags for 38.21/51/61/81/91, plastic, 64 tags, 6x10 mm 093.64 Sheet of marker tags for 38.01/11/31/41/52/62, plastic, 72 tags, 6x12 mm 060.72 093.64 II-2014, www.findernet.com 060.72 15
93.01.0.125 价格&库存
很抱歉,暂时无法提供与“93.01.0.125”相匹配的价格&库存,您可以联系我们找货
    • 1+92.736571+12.00060
    • 5+86.274705+11.16440
    • 250+76.84386250+9.94400
    • 1+84.35208
    库存:60
