40.52.8.012.0000
40.52.8.012.0000
    FINDER
    SOCKETABLE
    RLY GEN PURP DPDT 8A 12VAC
40.52.8.012.0000 数据手册
40 SЕRIES Miniature PCB Relays 8 - 10 - 12 - 16 A Medical and dentistry Control panels Panels for electrical distribution Toys Automation for blinds, grilles and shutters Door and gate openers Electronic circuit boards Vending machines FINDER reserves the right to alter characteristics at any time without notice. FINDER assumes no liability for damage to persons or property, caused as a result of the incorrect use or application of its products. 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A Power relays 1 and 2 pole for direct PCB or socket mount Type 40.31/51 -- 1 CO 12 A (3.5 mm pin pitch) -- 1 CO 12 A (5.0 mm pin pitch) Type 40.52 -- 2 CO 8 A (5.0 mm pin pitch) Type 40.61 -- 1 CO 16 A (5.0 mm pin pitch) • Pin length 3.5 mm for PCB mount • Pin length 5.3 mm for Plug-in mount • DC coils (650 mW or 500 mW) • Cadmium-free contact material available • 8 mm Creepage and Clearance, 6 kV (1.2/50µs) between coil and contact • Meets EN 60335-1 glow wire requirements • 95 series sockets for PCB or 35 mm rail mounting (EN 60715) with Screw, Screwless or Push-in terminals • Coil Indication and EMC suppression modules 99 series and Timer module 86.30 options • Environmental protection: RT II - flux proof (Standard) RT III - wash tight (Option) 40 SERIES 40.31/51 40.52 40.61 A • 1 CO 12 A on PCB, 10 A with socket • 3.5 mm pin pitch (40.31), 5.0 mm pin pitch (40.51) • PCB or 95 Series socket mount • 2 CO 8 A • 1 CO 16 A • 5.0 mm pin pitch • 5.0 mm pin pitch • PCB or 95 Series socket mount • PCB or 95 Series socket mount 40.31 * Mounted on sockets ≤ 10 A ** With the AgSnO2 material the maximum peak current is 120 A - 5 ms on normally open contact. For UL ratings see: “General technical information” page V XI-2018, www.findernet.com For outline drawing see page 12 Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/ Maximum switching voltage V AC Rated load AC1 VA Rated load AC15 (230 V AC) VA Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Standard contact material Coil specification V AC (50/60 Hz) Nominal voltage (UN) V DC Rated power DC/sensitive DC W Operating range AC DC/sensitive DC Holding voltage DC Must drop-out voltage DC Technical data Mechanical life cycles Electrical life at rated load AC1 cycles Operate/release time ms Insulation between coil and contacts (1.2/50 µs) kV Dielectric strength between open contacts V AC Ambient temperature range °C Environmental protection 40.51 Copper side view Pin length 3.5 mm for PCB only Pin length 5.3 mm for PCB or sockets See ordering information Copper side view Pin length 5.3 mm for PCB or sockets See ordering information Copper side view Pin length 3.5 mm for PCB only Pin length 5.3 mm for PCB or sockets See ordering information 1 CO (SPDT) 12*/20 2 CO (DPDT) 8/15 1 CO (SPDT) 16/30** 250/400 3000 1000 0.55 12/0.6/0.25 300 (5/5) AgNi 250/400 2000 750 0.37 8/0.6/0.25 300 (5/5) AgNi 250/400 4000 1000 0.55 16/0.6/0.25 500 (10/5) AgCdO — — — 5 - 6 - 7 - 9 - 12 - 14 - 18 - 21 - 24 - 28 - 36 - 48 - 60 - 90 - 110 - 125 0.65/0.5 0.65/0.5 0.65/0.5 — — — (0.73…1.5)UN/(0.73…1.5)UN (0.73…1.5)UN/(0.8…1.5)UN (0.73…1.5)UN/(0.73…1.5)UN 0.4 UN 0.4 UN 0.4 UN 0.1 UN 0.1 UN 0.1 UN 10 · 106 200 · 103 7/3 (10/3 sensitive) 10 · 106 100 · 103 7/3 (12/4 sensitive) 10 · 106 100 · 103 7/3 (10/3 sensitive) 6 (8 mm) 6 (8 mm) 6 (8 mm) 1000 –40…+85 RT II*** 1000 –40…+85 RT II*** 1000 –40…+85 RT II*** Approvals (according to type) *** See general technical information “Guidelines for automatic flow solder processes” page II. 3 40 SERIES 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A 40.31/51 Power relays 1 and 2 pole for direct PCB or socket mount 40.61 Type 40.31/51 -- 1 CO 10 A (3.5 mm pin pitch) -- 1 CO 10 A (5.0 mm pin pitch) Type 40.52 -- 2 CO 8 A (5.0 mm pin pitch) Type 40.61 -- 1 CO 16 A (5.0 mm pin pitch) • AC or DC coils according to type • Cadmium-free contact material • 8 mm Creepage and Clearance, 6 kV (1.2/50µs) between coil and contact • Meets EN 60335-1 glow wire requirements • 95 series sockets for PCB or 35 mm rail mounting (EN 60715) with Screw, Screwless or Push-in terminals • Coil Indication and EMC suppression modules 99 series and Timer module 86.30 options • Environmental protection: RT II - flux proof (Standard) RT III - wash tight (Option) • 1 CO 10 A • 3.5 mm pin pitch (40.31), 5.0 mm pin pitch (40.51) • PCB or 95 Series socket mount * With the AgSnO2 material the maximum peak current is 120 A - 5 ms on normally open contact. 40.31 For UL ratings see: “General technical information” page V 40.51 For outline drawing see page 12 Contact specification Contact configuration Rated current/Maximum peak current A Rated voltage/ Maximum switching voltage V AC Rated load AC1 VA Rated load AC15 (230 V AC) VA Single phase motor rating (230 V AC) kW Breaking capacity DC1: 30/110/220 V A Minimum switching load mW (V/mA) Standard contact material Coil specification V AC (50/60 Hz) Nominal voltage (UN) Holding voltage Must drop-out voltage Technical data Mechanical life Electrical life at rated load AC1 Operate/release time Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Environmental protection Copper side view Copper side view Copper side view Pin length 5.3 mm for PCB or sockets Pin length 5.3 mm for PCB or sockets Pin length 5.3 mm for PCB or sockets 1 CO (SPDT) 10/20 2 CO (DPDT) 8/15 1 CO (SPDT) 16/30* 250/400 2500 500 0.37 10/0.3/0.12 300 (5/5) AgNi 250/400 2000 400 0.3 8/0.3/0.12 300 (5/5) AgNi 250/400 4000 750 0.55 16/0.3/0.12 500 (10/5) AgCdO 1.2/—/— (0.8…1.1)UN — 0.8 UN/— 0.2 UN/— 6 - 12 - 24 - 48 - 60 - 110 - 120 - 230 - 240 5 - 6 - 7 - 9 - 12 - 14 - 18 - 21 - 24 28 - 36 - 48 - 60 - 90 - 110 - 125 1.2/0.65/0.5 (0.8…1.1)UN (0.73…1.5)UN/(0.73…1.5)UN 0.8 UN/0.4 UN 0.2 UN/0.1 UN 1.2/—/— (0.8…1.1)UN — 0.8 UN/— 0.2 UN/— cycles cycles ms 10 · 106 200 · 103 7/3 10 · 106 100 · 103 7/3 - (12/4 sensitive) 10 · 106 100 · 103 7/3 kV 6 (8 mm) 6 (8 mm) 6 (8 mm) V AC °C 1000 –40…+85 RT II** 1000 –40…+85 RT II** 1000 –40…+85 RT II** V DC Rated power AC/DC/sens. DC Operating range • 2 CO 8 A • 1 CO 16 A • 5.0 mm pin pitch • 5.0 mm pin pitch • PCB or 95 Series socket mount • PCB or 95 Series socket mount VA (50 Hz)/W/W AC DC/sens. DC AC/DC AC/DC — Approvals (according to type) ** See general technical information “Guidelines for automatic flow solder processes” page II. 4 — XI-2018, www.findernet.com A 40.52 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A 40 SERIES Power relays 1 and 2 pole for direct PCB or socket mount 40.xx.6 40.62 40.11 Type 40.62 - 2 CO 10A (5.0 mm pin pitch) - DC coils (650 mW or 500 mW) - Meets EN 60335-1 glow wire requirements A Type 40.11 -- 1 CO 10 A - flat pack -- DC (sensitive) coils Type 40.xx.6 -- Bistable versions of the types 40.31, 40.51, 40.52 and 40.61 -- Bistable (single coil) • Cadmium-free contact material available • 8 mm Creepage and Clearance, 6 kV (1.2/50µs) • 2 CO 10 A • Bistable (single coil) • 1 CO 10 A • 5.0 mm pin pitch • 3.5 or 5.0 mm pin pitch • PCB mount 12.7 mm high • PCB or 95 Series sockets mount • PCB or 95 Series socket mount Bistable version (1 coil) types: between coil and contact • 95 series sockets for PCB or 35 mm rail mounting (EN 60715) with Screw, Screwless or Push-in terminals • Environmental protection: RT II - flux proof (Standard) RT III - wash tight (Option) 40.31.6… 40.51.6… 40.52.6… 40.61.6… Copper side view For UL ratings see: “General technical information” page V Pin length 5.3 mm for PCB or sockets For outline drawing see page 12 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage Rated load AC1 A V AC VA For wiring diagrams see page 11 Copper side view Pin length 5.3 mm for PCB or sockets Pin length 3.5 mm for PCB 2 CO (DPDT) 1 CO (SPDT) 10/20 10/20 250/400 2500 See relays 40.31 250/400 2500 Rated load AC15 (230 V AC) VA 750 40.51 500 Single phase motor rating (230 V AC) kW 0.37 40.52 0.37 10/0.6/0.25 40.61 10/0.3/0.12 300 (5/5) page 4 300 (5/5) Breaking capacity DC1: 30/110/220 V Minimum switching load A mW (V/mA) Standard contact material AgNi AgCdO Coil specification Nominal voltage (UN) V AC (50/60 Hz) Rated power AC/DC/sens. DC V DC VA (50 Hz)/W/W Operating range AC DC/sens. DC — 5 - 6 - 7 - 9 - 12 - 14 - 18 - 21 - 24 - 28 - 48 - 60 - 110 - 125 —/0.65/0.5 — 5 - 6 - 12 - 24 - 48 - 110 1.0/1.0/— 6 - 12 - 24 - 48 - 60 —/—/0.5 — (0.8…1.1)UN — (0.73…1.5)UN / (0.73..1.5) UN (0.8…1.1)UN / — —/(0.73…1.75)UN Holding voltage AC/DC —/0.4 UN — —/0.4 UN Must drop-out voltage AC/DC —/0.1 UN — —/0.1 UN XI-2018, www.findernet.com Technical data Mechanical life cycles 10 · 106 See relays 20 · 106 Electrical life at rated load AC1 cycles 100 · 103 40.31 200 · 103 ms 7/3 (12/4 sensitive) 40.51 12/4 kV 6 (8 mm) 40.52 6 (8 mm) V AC °C 1000 –40…+85 RT II 40.61 Min. impulse duration ≥ 20 ms 1000 –40…+70 RT I** Operate/release time Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts Ambient temperature range Environmental protection Approvals (according to type) ** See general technical information “Guidelines for automatic flow solder processes” page II. 5 40 SERIES 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A Ordering information Example: 40 series PCB relay, 2 CO, 230 V AC coil. A 4 0 . 5 A B C D 2 . 8 . 2 3 0 . 0 0 0 0 A: Contact material See table below Series Type 1 = PCB - 3.5 mm pinning, flat 3 = PCB/Plug-in - 3.5 mm pinning 5 = PCB/Plug-in - 5 mm pinning 6 = PCB/Plug-in - 5 mm pinning B: Contact circuit 0 = CO (nPDT) 3 = NO (nPST) D: Special versions 0 = Standard 1 = Wash tight (RT III) 3 = High temperature (+125 °C) wash tight C: Options 0 = Pin length 5.3 mm (Plug-in relays) 2 = Pin length 3.5 mm (PCB relays) No. of poles 1 = 1 pole 2 = 2 pole Coil version 6 = AC/DC bistable 7 = Sensitive DC, 0.5 W 8 = AC (50/60 Hz) 9 = Standard DC, 0.65 W Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Preferred selections for best availability are shown in bold. Terminal pin Type Coil version A B C D PCB relay, pin length 3.5 mm 40.11 Sensitive DC 2 (AgCdO) - 4 (AgSnO2) 0 0 0 40.31/51 Standard DC/sensitive DC 1 (AgNi) 0-3 2 0-1 40.61 Standard DC/sensitive DC 1 (AgNi) - 2 (AgCdO) 0-3 2 0-1 PCB/Plug-in relay pin length 5.3 mm 40.31/51 AC/sensitive DC 0 (AgNi) - 2 (AgCdO) - 5 (AgNi+Au) 0-3 0 0-1 40.31/51 Standard DC 0 (AgNi) - 2 (AgCdO) - 5 (AgNi+Au) 0-3 0 0-1-3 40.52 AC/sensitive DC 0 (AgNi) - 2 (AgCdO) - 5 (AgNi+Au) 0-3 0 0-1 40.52 Standard DC 0 (AgNi) - 2 (AgCdO) - 5 (AgNi+Au) 0-3 0 0-1-3 0-3 0 0-1 AC/sensitive DC 0 (AgCdO) - 4 (AgSnO2) Standard DC 0 (AgCdO) - 4 (AgSnO2) 0-3 0 0-1-3 40.62 Standard DC/sensitive DC 0 (AgNi) - 4 (AgSnO2) 0 0 0-1 40.31/51/52 Bistable 0 (AgNi) 0 0 0 40.61 Bistable 0 (AgCdO) 0 0 0 XI-2018, www.findernet.com 40.61 40.61 6 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A 40 SERIES Technical data Insulation according to EN 61810-1 1 pole Nominal voltage of supply system V AC 230/400 Rated insulation voltage V AC 250 Pollution degree 3 A 2 pole 230/400 400 250 400 2 3 2 Insulation between coil and contact set Type of insulation Reinforced (8 mm) Reinforced (8 mm) III III kV (1.2/50 µs) 6 6 Overvoltage category Rated impulse voltage Dielectric strength V AC 4000 4000 Insulation between adjacent contacts (40.52, page 4) Type of insulation — Basic Overvoltage category — II Rated impulse voltage kV (1.2/50 µs) — Dielectric strength 2.5 V AC — 2000 — Basic Insulation between adjacent contacts (40.52, page 3 + 40.62) Type of insulation Overvoltage category III Rated impulse voltage kV (1.2/50 µs) — Dielectric strength V AC — 4 2500 Insulation between open contacts Type of disconnection Micro-disconnection Dielectric strength V AC/kV (1.2/50 µs) 1000/1.5 Micro-disconnection 1000/1.5 Insulation between coil terminals Rated impulse voltage (surge) differential mode (according to EN 61000-4-5) kV(1.2/50 µs) 2 Other data Bounce time: NO/NC ms 2/5 Vibration resistance (10…150)Hz: NO/NC g 20/5 (1 changeover) 15/4 (2 changeover) Shock resistance NO/NC g 20/13 (1 changeover) 20/12 (2 changeover) Power lost to the environment without contact current W 0.65 with rated current W 1.2 (40.11/31/51) mm ≥ 5 XI-2018, www.findernet.com Recommended distance between relays mounted on PCB 2 (40.61/52/62) 7 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A 40 SERIES Contact specification F 40.1 - Electrical life (AC) v contact current Types 40.31/51/61 (page 3) F 40.2 - Electrical life (AC) v contact current Type 40.52 (page 3) Limit for 40.31/51 F 40.3 - Electrical life (AC) v contact current Types 40.31/51/61 (page 4) Cycles Cycles Resistive load - cosϕ = 1 Inductive load AC15 Resistive load - cosϕ = 1 Inductive load AC15 F 40.4 - Electrical life (AC) v contact current Type 40.52 (page 4) Cycles Cycles Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 Limit for 40.31/51 F 40.5 - Electrical life (AC) v contact current Type 40.11 (page 5) F 40.6 - Electrical life (AC) v contact current Type 40.62 (page 5) Resistive load - cosϕ = 1 Inductive load - cosϕ = 0.4 Resistive load - cosϕ = 1 Cycles Cycles Inductive load AC15 8 12 XI-2018, www.findernet.com A 8 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A 40 SERIES Contact specification H 40.1 -Maximum DC1 breaking capacity Types 40.31/51/52/61 (page 3) H 40.2 - Maximum DC1 breaking capacity Types 40.31/51/52/61 (page 4) and 40.11 (page 5) 40.61 current limit 40.11/31/51 current limit 40.52 current limit 40.52 - 2 contacts in series single contact DC voltage (V) DC breaking current (A) DC breaking current (A) 40.61 current limit 40.31/51 current limit 40.52 current limit A 40.52 - 2 contacts in series single contact DC voltage (V) DC breaking current (A) H 40.6 -Maximum DC1 breaking capacity Type 40.62 (page 5) 2 contacts in series single contact DC voltage (V) • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 100 · 103 can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. XI-2018, www.findernet.com Note: the release time for the load will be increased. 9 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A 40 SERIES Coil specifications DC coil data - 0.5 W sensitive (types 40.31/51/52/61/62) Nominal Coil Operating range Resistance Rated coil voltage code consumption Umin Umax R I at UN UN V V V mA Ω 5 7.005 3.7 7.5 50 100 6 7.006 4.4 9 75 80 7 7.007 5.1 10.5 100 70 9 7.009 6.6 13.5 160 56 12 7.012 8.8 18 288 42 14 7.014 10.2 21 400 35 18 7.018 13.2 27 650 27.7 21 7.021 15.4 31.5 900 23.4 24 7.024 17.5 36 1150 21 28 7.028 20.5 42 1600 17.5 36 7.036 26.3 54 2600 13.8 48 7.048 35 72 4800 10 60 7.060 43.8 90 7200 8.4 90 7.090 65.7 135 16200 5.6 110 7.110 80.3 165 23500 4.7 125 7.125 91.2 188 32000 3.9 * Umin = 0.8 UN for 40.61 DC coil data - 0.5 W sensitive (types 40.11) Nominal Coil Operating range voltage code Umin Umax UN V V V 6 12 24 48 60 7.006 7.012 7.024 7.048 7.060 4.4 8.8 17.5 35 43.8 10.5 21 42 84 105 AC coil data (types 40.31/51/52/61) Nominal Coil Operating range voltage code Umin Umax UN V V V 6 8.006 4.8 6.6 12 8.012 9.6 13.2 24 8.024 19.2 26.4 48 8.048 38.4 52.8 60 8.060 48 66 110 8.110 88 121 120 8.120 96 132 230 8.230 184 253 240 8.240 192 264 Resistance R Ω 75 300 1200 4600 7200 Resistance R Ω 21 80 320 1350 2100 6900 9000 28000 31500 Rated coil consumption I at UN mA 80 40 20 10.4 8.3 Rated coil consumption I at UN (50 Hz) mA 168 90 45 21 16.8 9.4 8.4 5 4.1 AC/DC coil data - bistable (types 40.31/51/52/61) Nominal Coil Operating range Resistance Rated coil DC: Release consumption resistance** voltage code UN Umin Umax R I at UN RDC V V V mA Ω Ω 5 6.005 4 5.5 23 215 37 6 6.006 4.8 6.6 33 165 62 12 6.012 9.6 13.2 130 83 220 24 6.024 19.2 26.4 520 40 910 48 6.048 38.4 52.8 2100 21 3,600 110 6.110 88 121 11000 10 16,500 ** RDC = Resistance in DC, RAC = 1.3 x RDC 1 W XI-2018, www.findernet.com A DC coil data - 0.65 W standard (types 40.31/51/52/61/62) Nominal Coil Operating range Resistance Rated coil voltage code consumption Umin Umax R I at UN UN V V V mA Ω 5 9.005 3.65 7.5 38 130 6 9.006 4.4 9 55 109 7 9.007 5.1 10.5 75 94 9 9.009 6.6 13.5 125 72 12 9.012 8.8 18 220 55 14 9.014 10.2 21 300 47 18 9.018 13.1 27 500 36 21 9.021 15.3 31.5 700 30 24 9.024 17.5 36 900 27 28 9.028 20.5 42 1200 23 36 9.036 26.3 54 2000 18 48 9.048 35 72 3500 14 60 9.060 43.8 90 5500 11 90 9.090 65.7 135 12500 7.2 110 9.110 80.3 165 18000 6.2 125 9.125 91.2 188 23500 5.3 10 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A 40 SERIES Contact specification R 40 - DC coil operating range v ambient temperature Standard coil R 40 - DC coil operating range v ambient temperature Sensitive coil, types 40.31/51/52/61/62 A 40.61 40.31/51/52/62 R 40 - DC coil operating range v ambient temperature Sensitive coil, type 40.11 R 40 - AC coil operating range v ambient temperature 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. 1 - Max. permitted coil voltage. 2 - Min. pick-up voltage with coil at ambient temperature. XI-2018, www.findernet.com Wiring diagram for 40 series bistable coil version AC Operation On momentary closure of the SET switch the relay is magnetised through the diode and the relay contacts transfer to the set position and remain in this position. On momentary closure of the RESET switch the relay is demagnetised through limiting resistor (RAC) and the contacts return to the reset position. DC Operation On momentary closure of the SET switch the relay is magnetised and the relay contacts transfer to the set position and remain in this position. On momentary closure of the RESET switch the relay is demagnetised through limiting resistor (RDC) and the contacts return to the reset position. Notes: T he minimum SET or RESET impulse time is 20 ms. The maximum time can be continuous. In practice, always ensure that the SET and RESET contacts cannot be operated simultaneously. 11 40 SERIES 40 SERIES PCB/Plug-in relays 8 - 10 - 12 - 16 A Outline drawings Types 40.31/51/52/61/62 (page 3 e 4) Types 40.31/51/52/61 (page 4) Type 40.11 (page 5) A XI-2018, www.findernet.com * (3.5 or 5.3 mm) see ordering code 12 95 SERIES Socket overview for 40 series relays 40 SERIES Module Socket Relay Description Mounting Accessories 99.02 95.P3 40.31 40.51 40.52 40.61 40.62 Panel or 35 mm rail (EN 60715) mount --Coil indication and EMC 95.P5 Push-in terminal sockets --For fast cable connection --Top terminals - Contacts --Bottom terminals - Coil 95.P5 See page 14 Relay Description 99.02 95.03 40.31 95.05 40.51 40.52 40.61 40.62 Screw terminal (Box clamp) socket Panel or 35 mm rail (EN 60715) mount --Top terminals - Contacts --Bottom terminals - Coil See page 16 Mounting Accessories --Coil indication and EMC suppression modules --Jumper link --Timer modules --Plastic retaining and release clip Module Socket Relay Description Mounting Accessories 99.02 40.51 40.52 40.61 40.62 Screwless terminal socket --Top terminals - Contacts --Bottom terminals - Coil Panel or 35 mm rail (EN 60715) mount --Coil indication and EMC 95.55 A clip Module Socket 95.05 suppression modules --Jumper link --Timer modules --Plastic retaining and release suppression modules --Timer modules --Plastic retaining and release clip 95.55 See page 17 Module Socket 99.80 Relay 95.83.3 40.31 95.85.3 40.51 40.52 40.61 40.62 95.85.3 Description Mounting Accessories Screw terminal (Box clamp) socket Panel or 35 mm rail (EN 60715) mount Contacts --Bottom terminals - Coil and NC Contacts --Coil indication and EMC Description Accessories --Top terminals - NO and COM suppression modules --Jumper link --Plastic retaining and release clip See page 18 Module Socket 99.80 Relay 95.93.3 40.31 95.95.3 40.51 40.52 40.61 40.62 95.95.3 Mounting Screw terminal (Box clamp) socket Panel or 35 mm rail (EN 60715) mount --Top terminals - Contacts --Bottom terminals - Coil --Coil indication and EMC suppression modules --Jumper link --Plastic retaining and release clip See page 19 Module Socket 99.01 95.63 40.31 95.65 40.51 40.52 40.61 40.62 95.65 See page 20 Module Socket XI-2018, www.findernet.com 95.13.2 See page 21 — — Relay Description Mounting Screw terminal (Box clamp) socket Panel or 35 mm rail (EN 60715) mount --Top terminals - Contacts --Bottom terminals - Coil Accessories --Metal retaining clip Relay Description Mounting Accessories 95.13.2 40.31 PCB socket PCB mounting --Metal retaining clip --Plastic retaining clip 95.15.2 40.51 40.52 40.61 40.62 13 40 SERIES 95 SERIES Socket and accessories for 40 series relays A 95.P5 Approvals (according to type): 095.91.3 060.48 Push-in terminals socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link 2-way jumper link (12.5 mm pitch) 2-way jumper link (4.6 mm pitch) Marker tag holder (for tags 060.48 type) Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.91.3 and for marker tag holder 097.00, 48 tags, 6 x 12 mm, for CEMBRE thermal transfert printer Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C Wire strip length mm Min. wire size for 95.P3 and 95.P5 sockets mm2 AWG Max. wire size for 95.P3 and 95.P5 sockets mm2 AWG 95.P3 40.31 95.P5 40.51, 40.52, 40.61, 40.62 095.71 095.91.3 097.58 097.52 097.42 097.00 095.00.4 99.02 86.30 060.48 10 A - 250 V* 6 kV IP 20 –40…+70 (see diagram L95) 8 solid wire 0.5 21 solid wire 2 x 1.5 / 1 x 2.5 2 x 16 / 1 x 14 stranded wire 0.5 21 stranded wire 2 x 1.5 / 1 x 2.5 2 x 16 / 1 x 14 * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. Total socket current (A) L 95 - Total socket current v ambient temperature 11 A2 COM 14 NO 12 NC A1 COIL 95.P3 95.P3 95.P5 95.P5 8-way jumper link for 95.P3 and 95.P5 sockets Rated values 097.58 10 A - 250 V 2-way jumper link for 95.P3 and 95.P5 sockets Rated values 097.52 10 A - 250 V 097.58 XI-2018, www.findernet.com 097.52 14 95 SERIES Socket and accessories for 40 series relays 2-way jumper link for 95.P3 and 95.P5 sockets Rated values 40 SERIES 097.42 10 A - 250 V A 097.42 Marker tag holder for 95.P3 and 95.P5 sockets 097.00 86 series timer modules (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) (110…125)V AC; Bi-function: AI, DI; (0.05 s…100 h) (230…240)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.0.024.0000 86.30.8.120.0000 86.30.8.240.0000 097.00 86.30 99.02 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 95.P3 and 95.P5 sockets Diode (+A1, standard polarity) (6…220)V DC 99.02.3.000.00 LED(6…24)V DC/AC 99.02.0.024.59 LED(28…60)V DC/AC 99.02.0.060.59 LED(110…240)V DC/AC 99.02.0.230.59 LED + Diode (+A1, standard polarity) (6…24)V DC 99.02.9.024.99 LED + Diode (+A1, standard polarity) (28…60)V DC 99.02.9.060.99 LED + Diode (+A1, standard polarity) (110…220)V DC 99.02.9.220.99 LED + Varistor (6…24)V DC/AC 99.02.0.024.98 LED + Varistor (28…60)V DC/AC 99.02.0.060.98 LED + Varistor (110…240)V DC/AC 99.02.0.230.98 RC circuit (6…24)V DC/AC 99.02.0.024.09 RC circuit (28…60)V DC/AC 99.02.0.060.09 RC circuit (110…240)V DC/AC 99.02.0.230.09 Residual current by-pass (110…240)V AC 99.02.8.230.07 XI-2018, www.findernet.com DC Modules with non-standard polarity (+A2) on request. Approvals (according to type): 15 95 SERIES Socket and accessories for 40 series relays 40 SERIES A 95.05 Approvals (according to type):  ertain relay/socket C combinations 095.01 Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Marker tag holder (for tags 060.48 type) Identification tag Modules (see table below) Timer modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.01 and for marker tag holder 097.00, 48 tags, 6 x 12 mm, for CEMBRE thermal transfer printers Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C Screw torque 95.03 (blue) 40.31 95.03.0 (black) 95.05 (blue) 95.05.0 (black) 40.51, 40.52, 40.61, 40.62 095.71 095.01 095.18 095.01.0 095.18.0 095.01 095.18 097.00 095.00.4 99.02 86.30 095.01.0 095.18.0 060.48 10 A - 250 V* 6 kV IP 20 –40…+70 (see diagram L95) Nm 0.5 Wire strip length Max. wire size for 95.03 and 95.05 sockets mm 8 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 060.48 Total socket current (A) * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. L 95 - Total socket current v ambient temperature 11 A2 COM 14 NO 12 NC A1 COIL P A PEAN N T E O O T 95.03 95.05 8-way jumper link for 95.03 and 95.05 sockets Rated values 095.18 (blue) 10 A - 250 V 86 series timer modules (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) (110…125)V AC; Bi-function: AI, DI; (0.05 s…100 h) (230…240)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.0.024.0000 86.30.8.120.0000 86.30.8.240.0000 095.18.0 (black) EUR EUR 95.03 PEAN 095.18 99.02 Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. 16 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 95.03 and 95.05 sockets Diode (+A1, standard polarity) (6…220)V DC 99.02.3.000.00 LED(6…24)V DC/AC 99.02.0.024.59 LED(28…60)V DC/AC 99.02.0.060.59 LED(110…240)V DC/AC 99.02.0.230.59 LED + Diode (+A1, standard polarity) (6…24)V DC 99.02.9.024.99 LED + Diode (+A1, standard polarity) (28…60)V DC 99.02.9.060.99 LED + Diode (+A1, standard polarity) (110…220)V DC 99.02.9.220.99 LED + Varistor (6…24)V DC/AC 99.02.0.024.98 LED + Varistor (28…60)V DC/AC 99.02.0.060.98 LED + Varistor (110…240)V DC/AC 99.02.0.230.98 RC circuit (6…24)V DC/AC 99.02.0.024.09 RC circuit (28…60)V DC/AC 99.02.0.060.09 RC circuit (110…240)V DC/AC 99.02.0.230.09 Residual current by-pass (110…240)V AC 99.02.8.230.07 XI-2018, www.findernet.com 86.30 95 SERIES Socket and accessories for 40 series relays 95.55 Approvals (according to type): 095.91.3 Screwless terminal socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) Modules (see table below) Timer modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.91.3, 48 tags, 6 x 12 mm, for CEMBRE thermal transfer printers Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C Wire strip length mm Max. wire size for 95.55 socket mm2 AWG 40 SERIES 95.55 (blue) 40.51, 40.52, 40.61, 40.62 95.55.0 (black) A 095.71 095.91.3 99.02 86.30 060.48 10 A - 250 V* 6 kV IP 20 –25…+70 (see diagram L95) 8 solid wire 2 x (0.5…1.5) 2 x (21…18) stranded wire 2 x (0.5…1.5) 2 x (21…18) * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. 060.48 Total socket current (A) L 95 - Total socket current v ambient temperature 86 series timer modules 86.30 99.02 XI-2018, www.findernet.com Approvals (according to type): DC Modules with non-standard polarity (+A2) on request. (12…24)V AC/DC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.0.024.0000 (110…125)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.8.120.0000 (230…240)V AC; Bi-function: AI, DI; (0.05 s…100 h) 86.30.8.240.0000 Approvals (according to type): 99.02 coil indication and EMC suppression modules for 95.55 socket Diode (+A1, standard polarity) (6…220)V DC LED(6…24)V DC/AC LED(28…60)V DC/AC LED(110…240)V DC/AC LED + Diode (+A1, standard polarity) (6…24)V DC LED + Diode (+A1, standard polarity) (28…60)V DC LED + Diode (+A1, standard polarity) (110…220)V DC LED + Varistor (6…24)V DC/AC LED + Varistor (28…60)V DC/AC LED + Varistor (110…240)V DC/AC RC circuit (6…24)V DC/AC RC circuit (28…60)V DC/AC RC circuit (110…240)V DC/AC Residual current by-pass (110…240)V AC 99.02.3.000.00 99.02.0.024.59 99.02.0.060.59 99.02.0.230.59 99.02.9.024.99 99.02.9.060.99 99.02.9.220.99 99.02.0.024.98 99.02.0.060.98 99.02.0.230.98 99.02.0.024.09 99.02.0.060.09 99.02.0.230.09 99.02.8.230.07 17 40 SERIES 95 SERIES Socket and accessories for 40 series relays Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Identification tag Modules (see table below) Marker tag holder Sheet of marker tags for plastic retaining and release clip 095.91.3, 48 tags, 6 x 12 mm, for CEMBRE thermal transfert printer Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C A 95.85.3 Approvals (according to type): 095.91.3 Screw torque 95.83.3 (blue) 95.83.30 (black) 95.85.3 (blue) 95.85.30 (black) 40.31 40.51, 40.52, 40.61, 40.62 095.71 095.91.3 095.08 095.91.30 095.08.0 095.91.3 095.08 095.00.4 99.80 097.00 095.91.30 095.08.0 060.48 10 A - 250 V* 6 kV IP 20 –40…+70 (see diagram L95) 2 kV Nm 0.5 Wire strip length Max. wire size for 95.83.3 and 95.85.3 sockets 060.48 mm 7 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 Total socket current (A) * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. L 95 - Total socket current v ambient temperature P A PEAN N T E O O T 8-way jumper link for 95.83.3 and 95.85.3 sockets Rated values 95.85.3 095.08 (blue) 10 A - 250 V 095.08.0 (black) EUR EUR 95.83.3 PEAN 99.80 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. 18 99.80 coil indication and EMC suppression modules for 95.83.3 and 95.85.3 sockets Blue* Diode (+A1, standard polarity) (6…220)V DC 99.80.3.000.00 LED(6…24)V DC/AC 99.80.0.024.59 LED(28…60)V DC/AC 99.80.0.060.59 LED(110…240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6…24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28…60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110…220)V DC 99.80.9.220.99 LED + Varistor (6…24)V DC/AC 99.80.0.024.98 LED + Varistor (28…60)V DC/AC 99.80.0.060.98 LED + Varistor (110…240)V DC/AC 99.80.0.230.98 RC circuit (6…24)V DC/AC 99.80.0.024.09 RC circuit (28…60)V DC/AC 99.80.0.060.09 RC circuit (110…240)V DC/AC 99.80.0.230.09 Residual current by-pass (110…240)V AC 99.80.8.230.07 XI-2018, www.findernet.com 095.08 95 SERIES Socket and accessories for 40 series relays 40 SERIES Screw (Box clamp) terminal socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip Plastic retaining and release clip (supplied with socket - packaging code SPA) 8-way jumper link Identification tag Modules (see table below) Sheet of marker tags for plastic retaining and release clip 095.91.3 and for marker tag holder 097.00, 48 tags, 6 x 12 mm, for CEMBRE thermal transfer printers Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C 95.95.3 Approvals (according to type): 095.91.3 Screw torque 95.93.30 (black) 95.95.3 (blue) 95.95.30 (black) 40.51, 40.52, 40.61, 40.62 A 095.71 095.91.3 095.08 095.91.30 095.08.0 095.91.3 095.08 095.00.4 99.80 095.91.30 095.08.0 060.48 10 A - 250 V* 6 kV IP 20 –40…+70 (see diagram L95) Nm 0.5 Wire strip length Max. wire size for 95.93.3 and 95.95.3 sockets 060.48 95.93.3 (blue) 40.31 mm 8 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. Total socket current (A) L 95 - Total socket current v ambient temperature P A N T E O O T 8-way jumper link for 95.93.3 and 95.95.3 sockets Rated values 95.95.3 095.08 (blue) 10 A - 250 V 095.08.0 (black) EUR EUR 95.93.3 PEAN PEAN 095.08 99.80 XI-2018, www.findernet.com Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. 99.80 coil indication and EMC suppression modules for 95.93.3 and 95.95.3 sockets Blue* Diode (+A1, standard polarity) (6…220)V DC 99.80.3.000.00 LED(6…24)V DC/AC 99.80.0.024.59 LED(28…60)V DC/AC 99.80.0.060.59 LED(110…240)V DC/AC 99.80.0.230.59 LED + Diode (+A1, standard polarity) (6…24)V DC 99.80.9.024.99 LED + Diode (+A1, standard polarity) (28…60)V DC 99.80.9.060.99 LED + Diode (+A1, standard polarity) (110…220)V DC 99.80.9.220.99 LED + Varistor (6…24)V DC/AC 99.80.0.024.98 LED + Varistor (28…60)V DC/AC 99.80.0.060.98 LED + Varistor (110…240)V DC/AC 99.80.0.230.98 RC circuit (6…24)V DC/AC 99.80.0.024.09 RC circuit (28…60)V DC/AC 99.80.0.060.09 RC circuit (110…240)V DC/AC 99.80.0.230.09 Residual current by-pass (110…240)V AC 99.80.8.230.07 19 40 SERIES 95 SERIES Socket and accessories for 40 series relays Screw terminal (Box clamp) socket panel or 35 mm rail mount For relay type Accessories Metal retaining clip 8-way jumper link Modules (see table below) Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C A 95.63 Approvals (according to type): Screw torque Wire strip length Max. wire size for 95.63 and 95.65 sockets 95.65 Approvals (according to type): 95.63 40.31 95.65 40.51, 40.52, 40.61, 40.62 095.71 095.08 — 095.08 99.01 10 A - 250 V* 6 kV IP 20 –40…+70 (see diagram L95) 2 kV Nm 0.5 mm 7 solid wire mm2 1 x 6 / 2 x 2.5 AWG 1 x 10 / 2 x 14 stranded wire 1 x 4 / 2 x 2.5 1 x 12 / 2 x 14 * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. Total socket current (A) L 95 - Total socket current v ambient temperature P A PEAN N T E O O T 95.65 8-way jumper link for 95.63 and 95.65 sockets Rated values 095.08 (blue) 10 A - 250 V EUR EUR 95.63 PEAN 095.08 99.01 coil indication and EMC suppression modules for type 95.63 socket Blue* Diode (+A1, standard polarity) (6…220)V DC 99.01.3.000.00 Diode (+A2, non-standard polarity) (6…220)V DC 99.01.2.000.00 LED(6…24)V DC/AC 99.01.0.024.59 Approvals (according to type): * Modules in Black housing are available on request. Green LED is standard. Red LED available on request. LED(28…60)V DC/AC 99.01.0.060.59 LED(110…240)V DC/AC 99.01.0.230.59 LED + Diode (+A1, standard polarity) (6…24)V DC 99.01.9.024.99 LED + Diode (+A1, standard polarity) (28…60)V DC 99.01.9.060.99 LED + Diode (+A1, standard polarity) (110…220)V DC 99.01.9.220.99 LED + Diode (+A2, non-standard polarity) (6…24)V DC 99.01.9.024.79 LED + Diode (+A2, non-standard polarity) (28…60)V DC 99.01.9.060.79 LED + Diode (+A2, non-standard polarity) (110…220)V DC 99.01.9.220.79 LED + Varistor (6…24)V DC/AC 99.01.0.024.98 LED + Varistor (28…60)V DC/AC 99.01.0.060.98 LED + Varistor (110…240)V DC/AC 99.01.0.230.98 RC circuit (6…24)V DC/AC 99.01.0.024.09 RC circuit (28…60)V DC/AC 99.01.0.060.09 RC circuit (110…240)V DC/AC 99.01.0.230.09 Residual current by-pass 20 (110…240)V AC 99.01.8.230.07 XI-2018, www.findernet.com 99.01 95 SERIES Socket and accessories for 40 series relays Approvals (according to type): 95.13.2 (blue) 95.13.20 (black) 95.15.2 (blue) 95.15.20 (black) 40.31 40.51, 40.52, 40.61, 40.62 A 095.51 095.52 12 A - 250 V 6 kV IP 20 –40…+70 10 A - 250 V* * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). With the relay 40.51 the change-over contact will be 21-12-14. 40.51 A1 12 11 14 A2 22 21 24 12 14 22 24 3.5 11 1.5 30 20 13 7.5 3.5 40.31 21 A1 A2 40.52 95.13.2 95.13. 2 95.15.2 = 5 5 1.5 7.5 Copper side view 3 20 29 6 12 .4 95.15.2 PCB socket For relay type Accessories Metal retaining clip (supplied with socket packaging code SMA) Plastic retaining clip Technical data Rated values Dielectric strength between coil and contacts (1.2/50 μs) Protection category Ambient temperature °C Copper side view = 95.13.2 40 SERIES 40.61 Packaging codes How to code and identify retaining clip and packaging options for sockets. Example: 9 5 . P 5 S P A XI-2018, www.findernet.com A Please see general technical information Standard packaging SM Metal retaining clip SP Plastic retaining clip 21
40.52.8.012.0000 价格&库存
很抱歉,暂时无法提供与“40.52.8.012.0000”相匹配的价格&库存,您可以联系我们找货
  • 25+75.91688
  • 50+73.63625
  • 100+71.30355
  • 250+69.26243
库存:27
40.52.8.012.0000
  • 1+78.27040
  • 25+75.91688
  • 50+73.63625
  • 100+71.30355
  • 250+69.26243
库存:3
40.52.8.012.0000
  • 1+79.219061+10.24910
  • 5+72.231725+9.34510
  • 10+68.1266510+8.81400
  • 25+62.1000625+8.03430
  • 50+57.1215850+7.39020
  • 100+51.88106100+6.71220
库存:298
